  3. 💬 OH MySensors RGBW Controller
mysensorspcbrgbwcontroller
106 Posts 18 Posters 58.1k Views 19 Watching
  • L
    L
    LastSamurai
    @ThetaDev Maybe you you could get away with it but especially the radio is very sensitive concerning the power supply. Cheap pro minis often use very cheap regulators too and then this might become a problem.
    I also wanted to support the high power version of the NRF and that definitly needs more power than provided by the onboard regulator.
    • pepsonP
      pepsonP
      pepson
      Hi
      How i can modify sketch files INO to use it with radio RFM69HW with this adaptaer:
      https://www.openhardware.io/view/16/NRF2RFM69#tabs-design
      • L
        L
        LastSamurai
        I never tried that but as far as I know you have to tell Mysensors to use a different kind of radio by adding a define like:
        #define MY_RADIO_RFM69
        Just do a quick search on this forum though ;)
        • pepsonP
          pepsonP
          pepson
          And your project works also with Home Assistant ?
          Can you show how it looks in your automation ? Which controller you use ? (Domoticz or other)
          And on MySensors 2.2.0 this also works ?
          • L
            L
            LastSamurai
            I only had Home Assistant installed for some days (did not really like it at the time) so I can't tell you that it works 100% but it did back then. You have to add some strange additional messages but I tried to integrate that into my code.
            I am using my RGBW controllers with openhab 2 in one location and with domoticz in another. As it is controlled by MySensors it works (and looks) pretty much like any other mysensors node. Both installations run on 2.2. Hope this helps :)
            pepsonP 1 Reply Last reply
            • L LastSamurai
              pepsonP
              pepsonP
              pepson
              @lastsamurai
              Very thanks for info. I try build and test with Home Assistant.
              • Sergio RiusS
                Sergio RiusS
                Sergio Rius
                wrote on last edited by Sergio Rius
                #87
                Mmmmm... How much have you pushed this board? I mean, in terms of load.
                I just had one fail at me and I'm trying to understand what component may have been the weak link.
                It was driving a 5m white stripe when it turned himself off and on again, but although the light was still on the node was down. I took it out and almost burned my hand. Not the mosfets, but the arduino and radio. Nothing seems bad (components good looking, arduino seems to start) but as soon as you apply 12v, even without load it starts the barbecue.
                It seems that the mosfets are good to 4,2Ah if I understand it. So what would be the boards specs? :thinking_face:
                  Have you checked the voltage on the arduino?
                  Sergio RiusS 1 Reply Last reply
                    Sergio RiusS
                    Sergio RiusS
                    Sergio Rius
                    @gohan As you suspected, it was 12v.
                      No wonder why it got hot, poor little arduino :D
                        Sergio RiusS
                        Sergio RiusS
                        Sergio Rius
                        @gohan Yeah, but what is not that intiutive for me is why when load increases in the mosfets side, the ams regulator goes away.
                        Anyways, no one knows what max led strip length is this board good for?
                        L 1 Reply Last reply
                          https://www.openhardware.io/view/559/LED-RGBW-Controller
                          You may also consider this one
                          • Sergio RiusS Sergio Rius
                            L
                            L
                            LastSamurai
                            @sergio-rius A little late, sorry, but that depends on the mosfets you are actually using. I am driving ~5m strips of white leds with most of my controllers and they don't even really get hot.
                            There is also a big(ish) update from my side concerning this project: I have designed, 3d printed and tested my own case for the controllers and they work great. I have just added the stl files and some images to the project page!!
                            For now this project is done from my side. The controllers have been working great for the past 2 years but due to the "huge" (~1s) delay with my Mysensors network (with signing and openhab on a raspi) when switching the leds I am currently testing some MQTT and wifi based RGBWW controller boards as an alternative.
                            • pepsonP
                              pepsonP
                              pepson
                              Hello
                              How long led strips in meters i can connect to this device ? What max power led strips support it ?
                              • pepsonP
                                pepsonP
                                pepson
                                Why on 5 picture POWER MOSFET IRLM2502 is other side solder than on picture 9 ?
                                • pepsonP
                                  pepsonP
                                  pepson
                                  Hi
                                  I build this project but i want use it with radio RFM69HW and controller Home Assistant. But it not working with Home Assistant. Not connect with gateway on my RPI3b+. Other node with this radio connect ok. I dont know why ?Radio works and show this:
                                  | / |_ / | ___ _ __ ___ ___ _ __ ___
                                  | |/| | | | _
                                  \ / _ \ _ \/ __|/ _ \|
                                  _/ __|
                                  | || | / | | _ \ _ | | _
                                  |_
                                  , |/ ___|| ||/_/|| |/
                                  __/ 2.2.0
                                  16 MCO:BGN:INIT NODE,CP=RPNNA---,VER=2.2.0
                                  26 TSM:INIT
                                  28 TSF:WUR:MS=0
                                  30 TSM:INIT:TSP OK
                                  32 TSM:INIT:STATID=61
                                  34 TSF:SID:OK,ID=61
                                  36 TSM:FPAR
                                  1038 TSF:MSG:SEND,61-61-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  3045 !TSM:FPAR:NO REPLY
                                  3047 TSM:FPAR
                                  4050 TSF:MSG:SEND,61-61-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  6060 !TSM:FPAR:NO REPLY
                                  6062 TSM:FPAR
                                  7065 TSF:MSG:SEND,61-61-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  9072 !TSM:FPAR:NO REPLY
                                  9074 TSM:FPAR
                                  10076 TSF:MSG:SEND,61-61-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  12083 !TSM:FPAR:FAIL
                                  12085 TSM:FAIL:CNT=1
                                  12087 TSM:FAIL:DIS
                                  12089 TSF:TDI:TSL
                                  22093 TSM:FAIL:RE-INIT
                                  22095 TSM:INIT
                                  22097 TSM:INIT:TSP OK
                                  22099 TSM:INIT:STATID=61
                                  22104 TSF:SID:OK,ID=61
                                  22106 TSM:FPAR
                                  23109 TSF:MSG:SEND,61-61-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  25116 !TSM:FPAR:NO REPLY
                                  25118 TSM:FPAR
                                  26120 TSF:MSG:SEND,61-61-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  28127 !TSM:FPAR:NO REPLY
                                  28129 TSM:FPAR
                                  29132 TSF:MSG:SEND,61-61-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  31139 !TSM:FPAR:NO REPLY
                                  31141 TSM:FPAR
                                  32143 TSF:MSG:SEND,61-61-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  34150 !TSM:FPAR:FAIL
                                  34152 TSM:FAIL:CNT=2
                                  34154 TSM:FAIL:DIS
                                  34156 TSF:TDI:TSL
                                    Do you see any error in the gateway log?
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      This from gateway:
                                      pi@hassbian:~/MySensors $ sudo ./bin/mysgw -d
                                      mysgw: Starting gateway...
                                      mysgw: Protocol version - 2.2.0
                                      mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: TSM:INIT:TSP OK
                                      mysgw: TSM:INIT:GW MODE
                                      mysgw: MCO:REG:NOT NEEDED
                                      mysgw: Listening for connections on 0.0.0.0:5003
                                      mysgw: MCO:BGN:STP
                                      mysgw: MCO:BGN:INIT OK,TSP=1
                                      mysgw: TSF:MSG:READ,61-61-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      mysgw: TSF:MSG:BC
                                      mysgw: TSF:MSG:FPAR REQ,ID=61
                                      mysgw: TSF:CKU:OK,FCTRL
                                      mysgw: TSF:MSG:GWL OK
                                      mysgw: !TSF:MSG:SEND,0-0-61-61,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                      mysgw: TSF:MSG:BC
                                      mysgw: TSF:MSG:BC
                                      mysgw: TSF:MSG:BC
                                      mysgw: TSF:MSG:BC
                                      Other node works ok with this gateway.... Only this RGNW not working.
                                      This is log from gateway with connectionm with other node:
                                      mysgw: TSF:MSG:SEND,0-0-30-30,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      mysgw: TSF:MSG:READ,30-30-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                      mysgw: TSF:MSG:PINGED,ID=30,HP=1
                                      mysgw: TSF:MSG:SEND,0-0-30-30,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      mysgw: TSF:MSG:READ,30-30-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      mysgw: TSF:MSG:SEND,0-0-30-30,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                      mysgw: TSF:MSG:READ,30-30-0,s=255,c=0,t=18,pt=0,l=5,sg=0:2.2.0
                                      mysgw: TSF:MSG:READ,30-30-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                      mysgw: TSF:MSG:READ,30-30-0,s=255,c=3,t=11,pt=0,l=24,sg=0:Cover Roleta Sypialnia__
                                      mysgw: TSF:MSG:READ,30-30-0,s=255,c=3,t=12,pt=0,l=4,sg=0:20.0
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=0,t=5,pt=0,l=21,sg=0:Roller Shutter for HA
                                      mysgw: TSF:MSG:READ,30-30-0,s=21,c=0,t=29,pt=0,l=0,sg=0:
                                      mysgw: TSF:MSG:READ,30-30-0,s=41,c=0,t=29,pt=0,l=0,sg=0:
                                      mysgw: TSF:MSG:READ,30-30-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                      mysgw: TSF:MSG:SEND,0-0-30-30,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=29,pt=2,l=2,sg=0:1
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:100
                                      mysgw: TSF:MSG:READ,30-30-0,s=21,c=1,t=45,pt=2,l=2,sg=0:60
                                      mysgw: TSF:MSG:READ,30-30-0,s=21,c=1,t=0,pt=2,l=2,sg=0:60
                                      mysgw: TSF:MSG:READ,30-30-0,s=41,c=1,t=44,pt=2,l=2,sg=0:55
                                      mysgw: TSF:MSG:READ,30-30-0,s=41,c=1,t=0,pt=2,l=2,sg=0:55
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:99
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:98
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:97
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:96
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:95
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:94
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:93
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:92
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:91
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:90
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:89
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:88
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:87
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=3,pt=2,l=2,sg=0:86
                                      mysgw: TSF:MSG:READ,30-30-0,s=1,c=1,t=31,pt=2,l=2,sg=0:1
                                      mysgw: TSF:MSG:READ,30-30-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      mysgw: TSF:MSG:BC
                                      mysgw: TSF:MSG:FPAR REQ,ID=30
                                      mysgw: TSF:PNG:SEND,TO=0
                                      mysgw: TSF:CKU:OK
                                      mysgw: !TSF:MSG:SEND,0-0-30-30,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                      mysgw: TSF:MSG:BC
                                      mysgw: !TSF:MSG:SEND,0-0-30-30,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                                      • pepsonP
                                        pepsonP
                                        pepson
                                        I found one bug in your project PCB. Pin from radio nae IRQ should be connect on PCB to pin 2 ARDUINO. But it is not connect. Also when i use radio RFM69HW i also need connect PIN 2 Arduino to pin DI00 on radio RFM69HW. This should be correct... Now pin 9 from radio is not connect to any pin Arduino.
                                        On RFM69HW all works ok. In previus post my radio is fix.
                                        • pepsonP
                                          pepsonP
                                          pepson
                                          Hi
                                          Is any chance to implement in sketch option to Node after connect power go to state OFF. Now it go to ON. In situation when power lost and come back all leds will be ON.
                                          and is any chance to implement in your sketch option to add manual button to enable LEDS color WHITE ?
                                          Any color i want to setup by gateway but on the wall i want mount switch to enable color white and also to disable.
                                          Please add this if you can... In sketch setup pin on which button works and also color which should be turn on....
