  3. 💬 OH MySensors RGBW Controller
mysensorspcbrgbwcontroller
106 Posts 18 Posters 55.9k Views 19 Watching
  • J Jan Gatzke
    @peerkersezuuker
    The node always starts with white on. This is normal behaviour.
    peerkersezuukerP
    peerkersezuukerP
    peerkersezuuker
    @Jan-Gatzke
    Thank you, i see it in the code now ...
    I tested it with setting the RGB levels one by one to 255, and this works, so the channels are responding to the initialisation code.
    And because it is rebuild to version 2.0, i forgot one void to adjust...
    void incomingMessage(
    should be
    void receive(
    Problem solved, thank you very much.
    With regards
    Peer van Hoek
    Domoticz / My Sensors / Z-Wave
    https://www.kermisbuks.nl
    J 1 Reply Last reply
    • peerkersezuukerP peerkersezuuker
      @Jan-Gatzke
      should be
      void receive(
      With regards
      Peer van Hoek
      J
      J
      Jan Gatzke
      @peerkersezuuker
      Great.Can you post the complete 2.0 sketch, please? I am going to upgrade and this would be a good starting point.
      peerkersezuukerP 1 Reply Last reply
      • J Jan Gatzke
        @peerkersezuuker
        peerkersezuukerP
        peerkersezuukerP
        peerkersezuuker
        @Jan-Gatzke
        Sure, no problem.
        But it is not 100% clean, i am just a coppier and paste'r....
        If you can clean it up that would be nice.
        Based on the MySensors Project: http://www.mysensors.org
        This sketch controls a (analog)RGBW strip by listening to new color values from a (domoticz) controller and then fading to the new color.
        Version 1.0 - Changed pins and gw definition
        Version 0.9 - Oliver Hilsky
        TODO
        safe/request values after restart/loss of connection
        #define SN   "RGBW 01"
        #define SV   "1.0"
        // change the pins to free up the pwm pin for led control
        #define MY_RF24_CE_PIN 4 //<-- NOTE!!! changed, the default is 9
        #define MY_RF24_CS_PIN 10 // default is 10
        #define MY_REPEATER_FEATURE
        #define MY_NODE_ID 6
        // Load mysensors library
        // Load Serial Peripheral Interface library
        // Arduino pin attached to driver pins
        #define RED_PIN 3
        #define WHITE_PIN 9
        #define GREEN_PIN 5
        #define BLUE_PIN 6
        #define NUM_CHANNELS 4 // how many channels, RGBW=4 RGB=3...
        #define CHILD_ID 1
        // Smooth stepping between the values
        #define STEP 1
        #define INTERVAL 10
        const int pwmIntervals = 255;
        float R; // equation for dimming curve
        // Stores the current color settings
        byte channels[4] = {RED_PIN, GREEN_PIN, BLUE_PIN, WHITE_PIN};
        byte values[4] = {0, 0, 0, 255};
        byte target_values[4] = {0, 0, 0, 255};
        // stores dimming level
        byte dimming = 100;
        byte target_dimming = 100;
        // tracks if the strip should be on of off
        boolean isOn = true;
        // time tracking for updates
        unsigned long lastupdate = millis();
          // Initializes the sensor node (with callback function for incoming messages)
          //begin(incomingMessage);	// 123 = node id for testing
          // Set all channels to output (pin number, type)
          for (int i = 0; i < NUM_CHANNELS; i++) {
            pinMode(channels[i], OUTPUT);
          // set up dimming
          R = (pwmIntervals * log10(2))/(log10(255));
          // get old values if this is just a restart
          request(CHILD_ID, V_RGBW);
          // init lights
          updateLights();
          // debug
          if (isOn) {
            Serial.println("RGBW is running...");
          Serial.println("Waiting for messages...");
        void presentation()  {
          sendSketchInfo(SN, SV);
          // Register this device as Waterflow sensor
          present(CHILD_ID, S_RGBW_LIGHT, SN, true);
          // Process incoming messages (like config and light state from controller) - basically keep the mysensors protocol running
        //  process();
          // and set the new light colors
          if (millis() > lastupdate + INTERVAL) {
            updateLights();
        // callback function for incoming messages
          Serial.print("Got a message - ");
          Serial.print("Messagetype is: ");
          Serial.println(message.type);
          // acknoledgment
          if (message.isAck())
           	Serial.println("Got ack from gateway");
          // new dim level
          else if (message.type == V_DIMMER) {
              Serial.println("Dimming to ");
              Serial.println(message.getString());
              target_dimming = message.getByte();
              // a new dimmer value also means on, no seperate signal gets send (by domoticz)
            isOn = true;
          // on / off message
          else if (message.type == V_STATUS) {
            Serial.print("Turning light ");
            isOn = message.getInt();
            if (isOn) {
              Serial.println("on");
            } else {
              Serial.println("off");
          // new color value
          else if (message.type == V_RGBW) {
            const char * rgbvalues = message.getString();
            inputToRGBW(rgbvalues);
            // a new color also means on, no seperate signal gets send (by domoticz); needed e.g. for groups
            isOn = true;
        // this gets called every INTERVAL milliseconds and updates the current pwm levels for all colors
        void updateLights() {
          // update pin values -debug
          //Serial.println(greenval);
          //Serial.println(redval);
          //Serial.println(blueval);
          //Serial.println(whiteval);
          //Serial.println(target_greenval);
          //Serial.println(target_redval);
          //Serial.println(target_blueval);
          //Serial.println(target_whiteval);
          //Serial.println("+++++++++++++++");
          // for each color
          for (int v = 0; v < NUM_CHANNELS; v++) {
            if (values[v] < target_values[v]) {
              values[v] += STEP;
              if (values[v] > target_values[v]) {
                values[v] = target_values[v];
              values[v] -= STEP;
          // dimming
          if (dimming < target_dimming) {
            dimming += STEP;
            if (dimming > target_dimming) {
              dimming = target_dimming;
            dimming -= STEP;
          // debug - new values
          // set actual pin values
            if (isOn) {
              // normal fading
              analogWrite(channels[i], dimming / 100.0 * values[i]);
              // non linear fading, idea from https://diarmuid.ie/blog/pwm-exponential-led-fading-on-arduino-or-other-platforms/
              //analogWrite(channels[i], pow (2, (dimming / R)) - 1);
            } else {
              analogWrite(channels[i], 0);
        // converts incoming color string to actual (int) values
        // ATTENTION this currently does nearly no checks, so the format needs to be exactly like domoticz sends the strings
        void inputToRGBW(const char * input) {
          Serial.print("Got color value of length: ");
          Serial.println(strlen(input));
          if (strlen(input) == 6) {
            Serial.println("new rgb value");
            target_values[0] = fromhex (& input [0]);
            target_values[1] = fromhex (& input [2]);
            target_values[2] = fromhex (& input [4]);
            target_values[3] = 0;
          } else if (strlen(input) == 9) {
            Serial.println("new rgbw value");
            target_values[0] = fromhex (& input [1]); // ignore # as first sign
            target_values[1] = fromhex (& input [3]);
            target_values[2] = fromhex (& input [5]);
            target_values[3] = fromhex (& input [7]);
          } else {
            Serial.println("Wrong length of input");
          Serial.print("New color values: ");
          Serial.println(input);
            Serial.print(target_values[i]);
            Serial.print(", ");
          Serial.println("");
          Serial.print("Dimming: ");
          Serial.println(dimming);
        // converts hex char to byte
        byte fromhex (const char * str)
          char c = str [0] - '0';
          if (c > 9)
            c -= 7;
          int result = c;
          c = str [1] - '0';
          if (c > 9)
            c -= 7;
          return (result << 4) | c;
          @Jan-Gatzke
          Sure, no problem.
          TODO
          #define SV   "1.0"
          #define RED_PIN 3
          #define WHITE_PIN 9
          #define GREEN_PIN 5
          #define BLUE_PIN 6
          #define CHILD_ID 1
          #define STEP 1
          #define INTERVAL 10
          byte dimming = 100;
            // set up dimming
            // init lights
            updateLights();
            // debug
            if (isOn) {
          //  process();
              updateLights();
            // acknoledgment
            // new dim level
              isOn = true;
            // on / off message
              if (isOn) {
              } else {
            // new color value
              isOn = true;
            // for each color
                values[v] += STEP;
                values[v] -= STEP;
            // dimming
              dimming += STEP;
              dimming -= STEP;
              if (isOn) {
                // normal fading
              } else {
            } else {
              Serial.print(", ");
            Serial.println("");
            if (c > 9)
              c -= 7;
            int result = c;
            c = str [1] - '0';
            if (c > 9)
              c -= 7;
          J
          J
          Jan Gatzke
          @peerkersezuuker
          If I find the time, I will clean it up. I want to have a look at the non linear fading. IMHO the initial settings need to be customized, too. Instead of switching the white LEDs on the node could request the values from the controller (if possible) or from eeprom.
          • J
            J
            Jan Gatzke
            wrote on last edited by Jan Gatzke
            #25
            As promised I had a look at the sketch. The node can now save and restore values for rgbw, dimming and status to/from the controller. I had a look at the non linear fading, too. I got it partially working and refreshed my math knowledge a lot. :)
            In the end I removed the code for it because it made the sketch much more complicated and I didn't like the results. The formula from the original sketch was ok for fading a single LED from 0% to 100%. It didn't cover other starting values and the combination of the colors. IMHO only the dimming can be done non linear without problems. For this I would use a static table of PWM values and percent values. Doing the log calculations on the pro mini seems to be too slow for a smooth fading. I saw massive flickering.
            Here is the sketch:
              Version 1.1 - Added save/restore of values to/from controller, removed non linear fading code
            #define SV   "1.1"
            //Uncomment to enable repeater mode
            //#define MY_REPEATER_FEATURE
            //Uncomment to assign static node ID
            //#define MY_NODE_ID 9
            #define RED_PIN 3
            #define WHITE_PIN 9
            #define GREEN_PIN 5
            #define BLUE_PIN 6
            #define CHILD_ID 1
            #define STEP 1
            #define INTERVAL 10
            MyMessage lastvalueMsg(CHILD_ID, V_VAR1);
            MyMessage lastisonMsg(CHILD_ID, V_VAR2);
            MyMessage lastdimmMsg(CHILD_ID, V_VAR3);
            byte values[4] = {0, 0, 0, 0};
            byte target_values[4] = {0, 0, 0, 0};
            byte dimming = 100;
            boolean isOn = false;
            // tracks if the strip's last status was off. This overrides isOn at startup
            boolean wasOff = true;
            //tracks if the old values have bben requested from the controller. This prevents the request from being send multipßle times in the main loop.
            boolean valuesrequested = false;
              // debug
              if (isOn) {
              if (!valuesrequested) {
                Serial.println("Requesting old values...");
                //Request RGBW values
                request( CHILD_ID, V_VAR1 );
                wait(200);
                //Request Status
                request( CHILD_ID, V_VAR2 );
                wait(200);
                //Request dimm level
                request( CHILD_ID, V_VAR3 );
                valuesrequested = true;
              // set the new light colors
                updateLights();
              // acknoledgment
              // new dim level
              else if (message.type == V_DIMMER or message.type == V_VAR3) {
                send(lastdimmMsg.set(target_dimming));
                if (!wasOff) {
                  isOn = true;
                  send(lastisonMsg.set(isOn));
              // on / off message
              else if (message.type == V_STATUS or message.type == V_VAR2) {
                if (isOn) {
                  wasOff = false;
                } else {
              // new color value
              else if (message.type == V_RGBW or message.type == V_VAR1) {
                send(lastvalueMsg.set(rgbvalues));
                if (!wasOff) {
                  isOn = true;
              // for each color
                  values[v] += STEP;
                  values[v] -= STEP;
              // dimming
                dimming += STEP;
                dimming -= STEP;
                if (isOn) {
                  // normal fading
                } else {
              } else {
                Serial.print(", ");
              Serial.println("");
              if (c > 9)
                c -= 7;
              int result = c;
              c = str [1] - '0';
              if (c > 9)
                c -= 7;
            • L
              L
              LastSamurai
              @Jan-Gatzke Good job! I have a working 2.0 Version but it lacks your new features. I will take the time and add yours to the code in my git repo :)
              • L LastSamurai
                J
                J
                Jan Gatzke
                @LastSamurai
                Thx. Those new features, however, are kind of a workaround. It would have been better if the node could request the V_RGBW value directly. MySensors supports this, but domoticz doesn't seem to. I have testet this and domoticz always returned "0" as value. And because you and me are both using domoticz, I decided to implement this feature using V_VAR1-3.
                I am still thinking about the fading. I think we could get better colors if we could compensate the non linear dimming of the LEDs. With the actual sketch colors composed of mid range values could be wrong because every PWM value above 150 or so looks like almost full power. So 00AAFF almost looks like 00FFFF. AA has a value of 170 where FF is 255. This should make a big difference.
                AWIA 1 Reply Last reply
                • J
                  J
                  Jan Gatzke
                  I have tried to get some kind of non linear fading by calculating the values for 256 steps using Excel and putting them in an array. The result is pretty good. Please test and share your opinion. ;)
                  #define SV   "1.1"
                  #define RED_PIN 3
                  #define WHITE_PIN 9
                  #define GREEN_PIN 5
                  #define BLUE_PIN 6
                  #define CHILD_ID 1
                  #define STEP 1
                  #define INTERVAL 10
                  //Stores corrected values for each step from 0 to 255. See https://diarmuid.ie/blog/pwm-exponential-led-fading-on-arduino-or-other-platforms/
                  byte converted_values[256] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,3,3,3,3,3,3,3,3,3,3,3,3,4,4,4,4,4,4,4,4,4,5,5,5,5,5,5,5,5,6,6,6,6,6,6,7,7,7,7,7,7,8,8,8,8,8,9,9,9,9,9,10,10,10,10,11,11,11,11,12,12,12,13,13,13,13,14,14,14,15,15,15,16,16,17,17,17,18,18,19,19,20,20,20,21,21,22,22,23,23,24,24,25,26,26,27,27,28,29,29,30,31,31,32,33,34,34,35,36,37,38,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,54,55,56,57,58,60,61,62,64,65,67,68,70,71,73,75,76,78,80,81,83,85,87,89,91,93,95,97,99,101,104,106,108,111,113,116,118,121,123,126,129,132,135,138,141,144,147,150,154,157,161,164,168,171,175,179,183,187,191,195,200,204,209,213,218,223,228,233,238,243,249,255};
                  byte dimming = 100;
                    // debug
                    if (isOn) {
                      wait(200);
                      //Request Status
                      wait(200);
                      updateLights();
                    // acknoledgment
                    // new dim level
                      if (!wasOff) {
                        isOn = true;
                    // on / off message
                      if (isOn) {
                        wasOff = false;
                      } else {
                    // new color value
                      if (!wasOff) {
                        isOn = true;
                    int convertedvalue=0;
                    // for each color
                        values[v] += STEP;
                        values[v] -= STEP;
                    // dimming
                      dimming += STEP;
                      dimming -= STEP;
                      if (isOn) {
                        // normal fading
                        //analogWrite(channels[i], dimming / 100.0 * values[i]);
                        //Fading with corrected values see https://diarmuid.ie/blog/pwm-exponential-led-fading-on-arduino-or-other-platforms/
                        analogWrite(channels[i], dimming / 100.0 * converted_values[values[i]]);
                      } else {
                    } else {
                      Serial.print(", ");
                    Serial.println("");
                    if (c > 9)
                      c -= 7;
                    int result = c;
                    c = str [1] - '0';
                    if (c > 9)
                      c -= 7;
                  AWIA L 2 Replies Last reply
                  • J Jan Gatzke
                    @LastSamurai
                    AWIA
                    AWIA
                    AWI
                    wrote on last edited by AWI
                    #29
                    @Jan-Gatzke for Domoticz you can use V_TEXT. You can request a value and manipulate it in Lua. Also Domoticz is terrible with rgb as it only allows saturated colors.
                    • J Jan Gatzke
                      #define SV   "1.1"
                      #define RED_PIN 3
                      #define WHITE_PIN 9
                      #define GREEN_PIN 5
                      #define BLUE_PIN 6
                      #define CHILD_ID 1
                      #define STEP 1
                      #define INTERVAL 10
                      byte dimming = 100;
                        // debug
                        if (isOn) {
                          wait(200);
                          //Request Status
                          wait(200);
                          updateLights();
                        // acknoledgment
                        // new dim level
                          if (!wasOff) {
                            isOn = true;
                        // on / off message
                          if (isOn) {
                            wasOff = false;
                          } else {
                        // new color value
                          if (!wasOff) {
                            isOn = true;
                        // for each color
                            values[v] += STEP;
                            values[v] -= STEP;
                        // dimming
                          dimming += STEP;
                          dimming -= STEP;
                          if (isOn) {
                            // normal fading
                          } else {
                        } else {
                          Serial.print(", ");
                        Serial.println("");
                        if (c > 9)
                          c -= 7;
                        int result = c;
                        c = str [1] - '0';
                        if (c > 9)
                          c -= 7;
                      AWIA
                      AWIA
                      AWI
                      @Jan-Gatzke the FastLED library allows for very fast math with color values. Also some very educational stuff for color manipulation in the code and documentation.
                      • AWIA AWI
                        J
                        J
                        Jan Gatzke
                        @AWI
                        Thx for the info. This comes 24 hours to late. :joy:
                        • pepsonP
                          pepsonP
                          pepson
                          Is any chance to also project PCB for radio RFM69HW ?
                          L 1 Reply Last reply
                          • pepsonP pepson
                            L
                            L
                            LastSamurai
                            @pepson I wont do it because my networks is using NRFs but the kicad files are online, you could just get those and only change the radio part.
                            • pepsonP
                              pepsonP
                              pepson
                              I dont know software kicad... and can i please you to help me for changing it to radio RFM69HW please ?
                              tbowmoT 1 Reply Last reply
                                @pepson, please respect @LastSamurai (who has gracefully shared his hardware design files) when he says he won't change it.
                                There are resources online on how to learn Kicad,
                                • pepsonP pepson
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @pepson
                                  There are also converter boards available, that let you use rfm69hw in a nrf24 socket. That could be an option. Search openhardware.io for it..
                                  • pepsonP
                                    pepsonP
                                    pepson
                                    wrote on last edited by pepson
                                    #37
                                    Ok i find:
                                    https://www.openhardware.io/view/16/NRF2RFM69
                                    very thanks
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      #38
                                      What software is for file kicad_pcb ?
                                      I download this but i can not open this file by this soft...
                                      http://kicad-pcb.org/download/windows/
                                      Or in which file is write project PCB ?
                                      • pepsonP pepson
                                        L
                                        L
                                        LastSamurai
                                        @pepson The *.kicad_pcb file should be the pcb, the *.sch file the schematics.
                                        You could just use the schematics to remake my project by yourself though and learn kicad on the way. Otherwise the suggested adaptor seems to be the easiest solution.
                                        pepsonP 1 Reply Last reply
                                        • L LastSamurai
                                          pepsonP
                                          pepsonP
                                          pepson
                                          @LastSamurai
                                          But in soft kicad i dont have option to open this file... kicad can only open *.pro
