  3. Beginner First node setup issue
2 Posts 2 Posters 810 Views 2 Watching
  • CyberzoidC Offline
    CyberzoidC Offline
    Cyberzoid
    Hello
    I'm having some trouble understanding how to get my first node running. First I'm a bit confused on how to read the output. Mainly the fact that things are seemingly named differently between pages. This is how I understand it so far.
    s = sensor id			->this sensor id
    c = command				->message type
    t = message type		->Sub type
    pt = payload type		->???
    l = length of packet	->size
    sg = signed yes or no	->not using
    Beyond that if I'm reading the output right, it's trying to get a node id; however, I manualy put one in.
    Also what does the first numbers mean? eg 1-1-255-255.
    And what the st field means? bc?
    The setup
    I'm using the DallasTemperatueSensor example modified for the DHT11 temp sensor. The sensor is working.
    Some code excerpts
    //setup
    gw.begin(NULL, 1);
    gw.present(2, S_TEMP);
    //loop
    gw.send(msg.setSensor(2).set(temperature1,1));
    The controller is just the serial example
    The controller also has a 47uf cap between 3.3v and gnd
    Node 1 Output
    find parent
    send: 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    temp=21.00	Hum=32.00
    Controller Output
    0;0;3;0;9;read and forward: 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;0;3;0;9;send: 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
    Thank you in advanced.
    • CyberzoidC Cyberzoid
      Hello
      The setup
      Some code excerpts
      //setup
      gw.begin(NULL, 1);
      //loop
      Node 1 Output
      find parent
      Controller Output
      Hi @Cyberzoid
      Welcome to MySensors!
      A description of how ro read all the output is available at http://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
