  3. PCB support
PCB support
mountpcbfixationsupport
8 Posts 6 Posters 3.7k Views 4 Watching
  • yoonieY
    yoonieY
    yoonie
    Hi everyone ^^
    just a little question about PCB support…
    i'm at the end of a project, but i'm a little stuck on the fixation part of the board…
    in the first version, i have just putt two hole with pretty random diameter, but for the actual version (i hope final version), i want to chose the most smaller diameter, but with possibility of attachement in a plastic box
    so two questions :
    -what kind of fixation do you usually use, and where can i find them?
    -what diameter could i use on the pcb for the fixation? (2mm start to be tricky for routing with just two hole on the board, 4mm was… maybe not impossible, but really close to that!)
    Thanks ;)
    Domotics on pi2, rfxcom 433, z-wave with uzb, and serial gateway
    • yoonieY yoonie
      Hi everyone ^^
      so two questions :
      Thanks ;)
      GertSandersG
      GertSandersG
      GertSanders
      @yoonie
      Fixing a board in a box ... it depends, bit I try to use 2mm holes because if have small screws of that diameter.
      I have also used double sided 3m tape which sticks quite well to a pcb and a plastic housing. No holes needed then.
      • yoonieY
        yoonieY
        yoonie
        @GertSanders
        well, 2mm works fine (no routing pb), but i keep in mind the double sided tape idea ;)
        Thanks for the tips ^^
        YveauxY 1 Reply Last reply
        • yoonieY yoonie
          @GertSanders
          YveauxY
          YveauxY
          @yoonie said:
          double sided tape
          Hot glue fixates almost everything, including pcb's.
          • YveauxY Yveaux
            @yoonie said:
            double sided tape
            Or like eevblog calls it - hot-snot :)
            • scalzS
              scalzS
              like guys said :)
              on my side now I try to use holes for M3 screws, but M2 is nice too ;)
              • yoonieY
                yoonieY
                yoonie
                Thanks for answers ;)
                i think i should find some m2 motherboard spacers and screws in the bottom of a cardboard box, and if i need a box, double sided tape or hot glue ^^
                • TD22057T
                  TD22057T
                  TD22057
                  There are standards for PCB hole sizes. You can find Eagle parts for M2, M2.5, M3 drill holes with tight and loose clearance in my Eagle parts library. I created the parts from this blog page.
