  3. [SOLVED] ESP8266 WDT reset
34 Posts 6 Posters 47.9k Views 6 Watching
  • KosikaK
    KosikaK
    Kosika
    Hello!
    I'm quite new to this and have successfully created an ESP8266 (Adafruit HUZZA) gateway with an NRF24L01+PA+LNA radio. All is powered by an 2,4A USB charger.
    I've had it up and running without problems for some days. But after tweaking and having problems I reverted back to original settings (only tweaked PA level and channel).
    Now I get it working somewhat. Sometimes it's all fine, I can include and receive values. And then suddenly the chip reboots.
    I can replicate the reboot by restarting my Vera Edge (Reload Engine).
    Client 0 connected
    Client 0: 0;0;3;0;2;Get Version
    0;0;3;0;2;1.5.4
    0;0;3;0;9;read: 2-2-0 s=1,c=2,t=24,pt=0,l=0,sg=0:
    2;1;2;0;24;
    Client 0: 2;1;1;0;24;
    Soft WDT reset
    ctx: cont
    sp: 3ffefe70 end: 3fff01c0 offset: 01b0
    >>>stack>>>
    3fff0020:  3ffeee91 00000092 3ffeef88 40203f5e
    3fff0030:  3ffeee8b 0000000e 3ffeef1c 402040d4
    3fff0040:  3ffeee8b 00000030 3ffeef1c 40204120
    3fff0050:  a8e1fc02 000000a8 3ffeef1c 40204276
    3fff0060:  3ffeee8b 00000007 3ffeef1c 40203d0b
    3fff0070:  00000017 3ffeef1c 00000011 00000002
    3fff0080:  000000ff 3ffeee84 3ffeee8b 402031a5
    3fff0090:  00000019 00000001 00000000 3ffeebf3
    3fff00a0:  ffffffff 3fff0100 3ffeef1c 00000004
    3fff00b0:  00000000 00000000 3ffeee8b 4020101c
    3fff00c0:  3ffeebf2 00000000 00000001 3ffeee84
    3fff00d0:  3ffeebf3 00000000 3fff00fe 4020102c
    3fff00e0:  40217ee6 00000002 3ffeee8b 00000000
    3fff00f0:  000000ff 00000000 3ffeee84 40202ba1
    3fff0100:  3ffef002 0000000b 3ffeebf3 00000000
    3fff0110:  000000ff 00000000 3ffeee84 40203460
    3fff0120:  00000002 3ffeee8b 3ffef0d0 40205bbd
    3fff0130:  3ffeebe8 3ffeebe8 3ffef0d0 3ffef0d0
    3fff0140:  00000002 3ffeee84 3ffeee8b 40202439
    3fff0150:  3ffeedec 3ffeebe8 00000000 402026b4
    3fff0160:  3ffe8628 00000000 000003e8 40205302
    3fff0170:  00000000 3fff12c0 0101a8c0 3ffef194
    3fff0180:  00000000 0000000a 00000000 00000000
    3fff0190:  40205d49 0501a8c0 00000000 3ffef194
    3fff01a0:  3fffdc20 00000000 3ffef18d 40205d71
    3fff01b0:  00000000 00000000 3ffef1a0 40100114
    <<<stack<<<
     ets Jan  8 2013,rst cause:2, boot mode:(3,6)
    The client connects, and after a few sec I see soft WDC reset.
    Usualy the ESP just reboots and connect to my wifi and starts receiving values. But to get Vera to connect I need to reload the engine and then the ESP reboots.
    And sometimes it's just hangs afterwards.
     ets Jan  8 2013,rst cause:4, boot mode:(3,6)
    wdt reset
    The thing is that I had it going several days with PA level at HIGH with no big problem. Except when I wanted to include a new sensor . Then I started checking and everything then fell apart.
    I have dual 100uf capacitor on the 3.3V and one on the input 5V. And can't measure any voltage drops with my multimeter. Only had one 100uf on the 3.3v at first, added the others now when I try to troubleshoot.
    Any ideas with how I shall troubleshoot this?
    Re-flashed with original settings, and then restarted one sensor:
    Client 0 disconnected
    Client 0 connected
    0;0;3;0;2;1.5.4
    0;0;3;0;9;read: 2-2-0 s=255,c=3,t=15,pt=2,l=2,sg=0:544473088
    2;255;3;0;15;536870912
    0;0;3;0;9;read: 2-2-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.4
    2;255;0;0;17;1.5.4
    0;0;3;0;9;read: 2-2-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
    2;255;3;0;6;0
    Client 0: 2;255;3;0;6;M
    Soft WDT reset
    ctx: cont
    >>>stack>>>
    3fff0020:  3ffeee92 00000093 3ffeef88 40203f5e
    3fff0030:  3ffeee8b 000000ff 3ffeef1c 402040cb
    3fff0060:  3ffeee8b 00000008 3ffeef1c 40203d0b
    3fff0090:  00000019 00000001 00000000 3ffeebf4
    3fff00c0:  3ffeebf3 00000000 3ffeee8b 3ffeee84
    3fff00d0:  3ffeebf4 00000000 3fff00fe 4020102c
    3fff00e0:  40217ee6 00000003 3ffeee8b 00000000
    3fff0100:  3ffef002 0000000d 3ffeebf5 00000000
    <<<stack<<<
     ets Jan  8 2013,rst cause:2, boot mode:(1,6)
     ets Jan  8 2013,rst cause:4, boot mode:(1,6)
    wdt reset
    YveauxY 1 Reply Last reply
    • KosikaK Kosika
      Hello!
      Client 0 connected
      0;0;3;0;2;1.5.4
      2;1;2;0;24;
      Soft WDT reset
      ctx: cont
      >>>stack>>>
      <<<stack<<<
      wdt reset
      Client 0 connected
      0;0;3;0;2;1.5.4
      2;255;0;0;17;1.5.4
      2;255;3;0;6;0
      Soft WDT reset
      ctx: cont
      >>>stack>>>
      <<<stack<<<
      wdt reset
      YveauxY
      YveauxY
      @Kosika Please indicate which MySensors & ESP ARduino Port you're using.
      • KosikaK
        KosikaK
        Kosika
        wrote on last edited by Kosika
        Using Mysensors 1.5 Library and followed the guide here: https://www.mysensors.org/build/esp8266_gateway
        Using arduino version 1.6.8
        *EDIT. Using ESP 2.0.0
        • KosikaK Kosika
          YveauxY
          YveauxY
          @Kosika please try with MySensors 2.0.0 beta (development branch) and ESP Arduino 2.0.0
          • KosikaK
            KosikaK
            Kosika
            Hello and thanks for the tips.
            I have now upgraded to 2.0.0 of mysensors library.
            I reflashed the ESP module with the new libraries and open the serial monitor. It connects fine with the router etc.
            But as soon as I start a sensor (not touched them, still 1.5 version) it recieves a message and then reboots.
            connected with Skoda, channel 6
            dhcp client start...
            .ip:192.168.1.5,mask:255.255.255.0,gw:192.168.1.1
            .IP: 192.168.1.5
            0;255;3;0;9;Init complete, id=0, parent=0, distance=0
            0;255;3;0;9;read: 1-1-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0
            Soft WDT reset
            ctx: cont
            sp: 3ffef920 end: 3ffefcb0 offset: 01b0
            >>>stack>>>
            3ffefad0:  00000000 3ffefff8 3ffefff8 40204083
            3ffefae0:  402017b8 00000000 3ffefff8 40204083
            3ffefaf0:  00000000 3ffefff8 00000000 40202152
            3ffefb00:  001e8480 3ffe0001 3ffefd38 40202152
            3ffefb10:  00000000 00000040 00000000 00000000
            3ffefb20:  00000000 00000000 00000001 00000000
            3ffefb30:  00000001 00000030 00000040 40202179
            3ffefb40:  00000001 3ffefd30 00000001 402023a2
            3ffefb50:  00000009 021139b4 00002200 3ffe9c40
            3ffefb60:  3ffefff8 00000002 3ffefd30 40202ff8
            3ffefb70:  3ffefff8 00000000 3ffefeef 00000027
            3ffefb80:  3ffefbf0 3ffefff8 3ffefff8 40204083
            3ffefb90:  402017b8 3ffefbf1 3ffefff8 00000061
            3ffefba0:  3ffefbf0 3ffefff8 3ffefbf0 00000000
            3ffefbb0:  3ffefd54 3ffefd30 00000001 402024b1
            3ffefbc0:  00000001 00000000 3ffefd38 00000000
            3ffefbd0:  3ffefd54 3ffefd30 00000001 402035d0
            3ffefbe0:  3ffe88c0 00000004 00000009 3ffefd30
            3ffefbf0:  00000003 00000001 3ffefd30 40203657
            3ffefc00:  00000001 00000003 3ffefd30 40203690
            3ffefc10:  00000003 00000001 3ffefd54 40203acf
            3ffefc20:  0000000f 00000002 00000002 00000000
            3ffefc30:  3ffefcd8 00000000 3ffefd54 3ffeec80
            3ffefc40:  3fffdc00 00000000 3ffefd30 3ffefc70
            3ffefc50:  0000000f 00000000 00000001 00000002
            3ffefc60:  000000ff 00000012 00000000 3ffeec80
            3ffefc70:  3fffdc20 00000000 3ffeec78 3ffeec80
            3ffefc80:  3fffdc20 00000000 3ffeec78 40203388
            3ffefc90:  00000000 00000000 3ffeec78 40203cb0
            3ffefca0:  00000000 00000000 3ffeec90 40100114
            <<<stack<<<
            c_rSöfê0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
            0;255;3;0;9;Radio init successful.
            scandone
            state: 0 -> 2 (b0)
            state: 2 -> 3 (0)
            state: 3 -> 5 (10)
            add 0
            aid 5
            pm open phy_2,type:2 0 0
            cnt
            .IP: 192.168.1.5
            After the restart it seams to be ok with accepting radiomesages
            .IP: 192.168.1.5
            0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.4
            0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:48.8
            0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:44.8
            0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.6
            0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:44.7
            0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.5
            0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:44.6
            0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.7
            It also good when I reloaded Vera. I got values into vera aswell.
            But as soon as I power in a new sensor it restarts. is that normal? And sometimes when I restart Vera the ESP restarts aswell, so it's the same now. Works sometimes, sometimes not (mostly not)
            I notice that when the client connects to it fine, untill it sends "0;255;3;0;9;Client 0: 2;1;1;0;24"
            Then there is a soft WDT reset
            0;255;3;0;9;Client 0 connected
            0;255;3;0;9;Client 0: 0;0;3;0;2;Get Version
            0;255;3;0;9;read: 2-2-0 s=1,c=2,t=24,pt=0,l=0,sg=0:
            0;255;3;0;9;Client 0: 2;1;1;0;24;
            So the problem seams to be when a sensor starts up or when a client connects.
            Tested to telnet it and it works ok. No restart
            • KosikaK Kosika
              .IP: 192.168.1.5
              Soft WDT reset
              ctx: cont
              >>>stack>>>
              <<<stack<<<
              scandone
              state: 0 -> 2 (b0)
              state: 2 -> 3 (0)
              state: 3 -> 5 (10)
              add 0
              aid 5
              cnt
              .IP: 192.168.1.5
              .IP: 192.168.1.5
              YveauxY
              YveauxY
              Do you mean you connect it to the power supply?
              Could very well be that you're overloading the ESP power regulator. Try with a separate supply.
              • KosikaK
                KosikaK
                Kosika
                All sensors are connected to pro mini's thats powered by 2x AA batteries.
                I've now installed separate 5v->3v regulator for the GW radio.
                It looks like it starts up right, can reload vera etc but now it don't recieve any radiomessages at all. Something special when having separate regulator? It has the the GND, just VCC that's separated.
                scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 5 (10)
                add 0
                aid 4
                cnt
                .IP: 192.168.1.5
                One step forward, and two steps back.
                • KosikaK
                  KosikaK
                  Kosika
                  Okay, found the radio problem. I microscopit strand of copper wire had shorted the CS pin to the ESP 3.3v line. So now it recieves radio messages again.
                  But when powering on a sensor it restarts like before. And sometimes when reloading vera. But once it didn't restart on reload:
                  0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:35.1
                  0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.9
                  0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:35.3
                  0;255;3;0;9;read: 2-2-00;255;3;0;9;Client 0: 2;1;1;0;24;
                  Notice the lack of
                  That and
                  Seams to make the GW restart
                  • KosikaK
                    KosikaK
                    Kosika
                    Have had the GW running for a day now, as long as the client (Vera Edge) don't sent
                    Or I start up an new sensor it's stable and works well.
                    Problem now to figure out is how to connect a new sensor, as it restarts as soon as it's powered on.
                    Any ideas?
                    Note. Noticed that it only restarts upon new sensor startup if the client is connected.
                    .IP: 192.168.1.5
                    0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:39.8
                    0;255;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
                    NO restart as the client is not connected
                    0;255;3;0;9;Client 0: 0;0;3;0;5;1
                    0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.2
                    0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:39.7
                    0;255;3;0;9;Client 0: 255;255;3;0;4;3
                    Soft WDT reset
                    Here is restarted, inclusion mode or not does not matter
                    afenoA 1 Reply Last reply
                    • AffordableTechA
                      AffordableTechA
                      AffordableTech
                      wrote on last edited by AffordableTech
                      For one possible solution - refer to: [https://forum.mysensors.org/topic/3894/esp8266-unexpected-crash-or-reset](link url)
                      • AffordableTechA AffordableTech
                        YveauxY
                        YveauxY
                        @AffordableTech WDT resets are caused by a hang or too long loop in the software. Your topic describes a null pointer dereference, which is a different issue.
                        • KosikaK
                          KosikaK
                          Kosika
                          Had gotten my hopes up on this solution, but as it don't apply to 2.0 dev branch it was not the answer.
                          I'm no programmer so I can't really do any real bug searching. I only noticed that two types of messages makes it restart. What they mean or what they do it beyond my knowledge.
                          I'll just sit tight and hope some smart person comes up with a suggestion, meanwhile I'll continue to google the web :)
                          • 172pilot1
                            172pilot1
                            172pilot
                            I THINK I'm having the same problem.. I'm building my first WiFi gateway.. I used a Sparkfun Thing Dev board because it was handy and accessible. Only oddities were that since the Sparkfun board has an LED on GPIO 5, I set the LED pin to 5 instead of 7, and the inclusion pin to 2..
                            I haven't tried the dev branch (will do, and report back) but with 1.5, I get a connection to my wifi, then a reboot:
                            wdt reset
                            load 0x4010f000, len 1264, room 16
                            tail 0
                            chksum 0x0f
                            csum 0x0f
                            ~ld
                            Over and over again.. Vera says it's connected, but then says it cant communicate. As mentioned, this type of problem is usually a tight loop not giving time for the WDT on the 8266 but I'm not familiar enough with this code to track it down.. Any ideas?
                            -Steve
                            YveauxY AffordableTechA 2 Replies Last reply
                            • 172pilot1 172pilot
                              wdt reset
                              tail 0
                              chksum 0x0f
                              csum 0x0f
                              ~ld
                              -Steve
                              YveauxY
                              YveauxY
                              @172pilot please try with 2.0.0 development. 1.5 does not contain all fixes for ESP that 2.0.0 has.
                              172pilot1 1 Reply Last reply
                                wdt reset
                                tail 0
                                chksum 0x0f
                                csum 0x0f
                                ~ld
                                -Steve
                                AffordableTechA
                                AffordableTechA
                                AffordableTech
                                Hi @172pilot
                                PLEASE NOTE: I gather there are three different problems which have similar results:
                                • A power supply with insufficient current to drive the ESP causes it to crash / reboot.
                                • A NULL message (somewhere in the process) can cause ESP to restart.
                                • Something called a 'WDT Reset' , which I have never encountered (?possibly only applies when using a Vera controller?).
                                Because all three produce similar looking results, I posted my fix here, even though I had not seen a 'WDT Reset' message (??possibly because I wasn't running a Vera controller??).
                                My Symptoms
                                My system appeared to have been running 'fine' for a solid week (as a test), using MYScontroller, I didn't notice anything abnormal. I also had a telnet (Potty) connection to the ESP. It wasn't until I started testing OpenHAB that OpenHab would report that it 'could not communicate'. At the same time my telnet connection and MYScontroller just stopped, no error message etc.
                                Then, OpenHab log reported that it was 'creating new connection', and resumed communicating, BUT both the telnet link and MYScontroller never resumed communications. I would have to disconnect / reconnect both, then they would continue for a few minutes until OpenHab reported the error again, when they would 'stall' again - this kept repeating.
                                If I stopped OpenHab, then the Telnet and MYScontroller worked flawlessly. At first I assumed that the OpenHab binding was the problem. Lots of testing, inserting debug 'print' statements into the drivers etc etc... Eventually I discovered that the 'MySensors ESP driver' was receiving a NULL pointer, when it was expecting a char pointer to a message, this was causing the ESP to reset.
                                I've since been told this problem was fixed in the MySensors 2.0 (beta) drivers and only applies to the 1.5 version (current ver at this point in time).
                                I hope this helps others clarify which of the three 'causes' apply to their issue. For example, my ESP was resetting, I didn't have a clue if it was a "WDT" reset, it could have been an "ABC" or "XYZ" reset as far as I knew. I still don't know what a WDT reset is?
                                Cheers... Paul
                                p.s. The first thing to check with any radio device (ESP, nRf2401 or GSM etc) is that you MUST have a good power source. When these devices transmit their current requirements go up significantly, which can cause all sorts of weird and wonderful thing to happen. Whenever I have a problem with a radio device, I will (temporarily) power the (3.3v) RF device direct from a Lipo battery (3.7v) with a 1N4001 (or similar) diode in series, this drops the voltage to 3.1v. Even though the voltage is a tad low, the Lipo (or NiCad) can deliver tremendous 'grunt' (amps) thus its a 'clean' and stable power source!
                                  wrote on last edited by hek
                                  The esp (and AVR) has something called a watchdog timer. It's actually there to help if something goes wrong, resetting the MCU. The watchdog timer can be disabled and reconfigured to allow longer interval. On ESP it's enabled by default and on AVR you have to enable it yourself (requires a special bootloader).
                                  Its works by using a timer which gets "reset" by calling yield() or delay(). Normally you don't have to worry about it as yield() is called automatically in the main loop().
                                  If yield() isn't called each second (which is the default timeout on ESP) the MCU will reset.
                                  If you have some long blocking tasks you can disable the wdt temporariily like this:
                                   wdt_disable();
                                   <some blocking task>
                                   wdt_enable();
                                  https://github.com/esp8266/Arduino/blob/master/cores/esp8266/Esp.h#L29-L46
                                     wdt_disable();
                                     wdt_enable();
                                    YveauxY
                                    YveauxY
                                    @hek are you sure disabling the WDT does actually work for ESP? The fact that the function exists, doesn't automatically mean it works :smirk:
                                    In the past there were numerous issues of users who tried to disable it but kept getting WDT resets. But again, maybe that's been fixed in 2.x
                                    • YveauxY Yveaux
                                      172pilot1
                                      172pilot1
                                      172pilot
                                      @Yveaux
                                      Thanks for the response.. I actually did get the 1.5 to at least come up, by putting some WDT resets around in various places that may take a while in a loop, for example, BUT, based on yours, and several other recommendations, I decided to try the 2.0 dev branch.. I deleted everything in my librarys\MySensors directory, and downloaded the DEV branch, and re-extracted the code, and now I can't compile.. I'm getting this:
                                      Arduino: 1.6.9 (Windows 10), Board: "SparkFun ESP8266 Thing Dev, 80 MHz, 115200"
                                      Build options changed, rebuilding all
                                      In file included from C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
                                                       from C:\Users\sjones\Documents\Arduino\MyDevelopment-2-0-GatewayESP8266\MyDevelopment-2-0-GatewayESP8266.ino:70:
                                      C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = char*; size_t = unsigned int]':
                                      C:\Users\sjones\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:163:66:   required from here
                                      C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'char*'
                                           size_t left = source.available();
                                      C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'char*'
                                           source.read(buffer.get(), will_send);
                                      exit status 1
                                      Error compiling for board SparkFun ESP8266 Thing Dev.
                                      I found some recommendations to put the "#include <ESP8266WiFi.h>" close to the top, and it fixed it for other users, but I'm having no success with that..
                                      Any idea what this may be?
                                      Thanks in advance..
                                      -Steve
                                        @Yveaux
                                        exit status 1
                                        Thanks in advance..
                                        -Steve
                                        YveauxY
                                        YveauxY
                                        @172pilot I'm not behind a PC right now, so it's hard to replay the situation.
                                        I'd say you either didn't clean everything out completely (use e.g. a completely separate Arduino folder for sketches and libraries), or it's the ESP Arduino port you're using (which version did you install through board manager?)
                                        • YveauxY Yveaux
                                          172pilot1
                                          172pilot1
                                          172pilot
                                          @Yveaux Thanks.. Good to know what I'm doing SHOULD work.. :-)
                                          I have been storing everything in what I think is the default directory, which under my \users\sjones\Documents\Arduino\libraries. This is what the Arduino IDE is pointing to.
                                          Under that directory, I removed the MySensors directory and extracted the new 2.0 one.. BUT, I do see that there are more modules than just those under MySensors, so even though I think those are supposed to NOT conflict with the default ones, I missed one?
                                          Also, I dont understand why, but I see SOME arduino extension stuff under \program Files (x86)\arduino although I didn't see any MySensors information..
                                          And, the only other thing I saw which I didn't know how it got there was the one referred to in the error: "C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi" Since that specifically was referred to in the error, I thought maybe I had an old version there, so I renamed the ESP8266Wifi directory to "old", figuring that whatever put it there in the first place would replace it with the current version if needed, but it didn't happen - it just failed to compile, complaining that it was missing, so I put it back..
                                          I'm not near my home computer now, but maybe when I get home I'll try with a completely new windows profile (create a new user) and reinstall Arduino from scratch
                                          Thanks for your help and patience!
                                          -Steve
                                          AffordableTechA 1 Reply Last reply
