  3. [SOLVED] ESP8266 WDT reset
34 Posts 6 Posters 47.9k Views 6 Watching
  • KosikaK Kosika
    Hello and thanks for the tips.
    I have now upgraded to 2.0.0 of mysensors library.
    I reflashed the ESP module with the new libraries and open the serial monitor. It connects fine with the router etc.
    But as soon as I start a sensor (not touched them, still 1.5 version) it recieves a message and then reboots.
    connected with Skoda, channel 6
    dhcp client start...
    .ip:192.168.1.5,mask:255.255.255.0,gw:192.168.1.1
    .IP: 192.168.1.5
    0;255;3;0;9;read: 1-1-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0
    Soft WDT reset
    ctx: cont
    sp: 3ffef920 end: 3ffefcb0 offset: 01b0
    >>>stack>>>
    3ffefad0:  00000000 3ffefff8 3ffefff8 40204083
    3ffefae0:  402017b8 00000000 3ffefff8 40204083
    3ffefaf0:  00000000 3ffefff8 00000000 40202152
    3ffefb00:  001e8480 3ffe0001 3ffefd38 40202152
    3ffefb10:  00000000 00000040 00000000 00000000
    3ffefb20:  00000000 00000000 00000001 00000000
    3ffefb30:  00000001 00000030 00000040 40202179
    3ffefb40:  00000001 3ffefd30 00000001 402023a2
    3ffefb50:  00000009 021139b4 00002200 3ffe9c40
    3ffefb60:  3ffefff8 00000002 3ffefd30 40202ff8
    3ffefb70:  3ffefff8 00000000 3ffefeef 00000027
    3ffefb80:  3ffefbf0 3ffefff8 3ffefff8 40204083
    3ffefb90:  402017b8 3ffefbf1 3ffefff8 00000061
    3ffefba0:  3ffefbf0 3ffefff8 3ffefbf0 00000000
    3ffefbb0:  3ffefd54 3ffefd30 00000001 402024b1
    3ffefbc0:  00000001 00000000 3ffefd38 00000000
    3ffefbd0:  3ffefd54 3ffefd30 00000001 402035d0
    3ffefbe0:  3ffe88c0 00000004 00000009 3ffefd30
    3ffefbf0:  00000003 00000001 3ffefd30 40203657
    3ffefc00:  00000001 00000003 3ffefd30 40203690
    3ffefc10:  00000003 00000001 3ffefd54 40203acf
    3ffefc20:  0000000f 00000002 00000002 00000000
    3ffefc30:  3ffefcd8 00000000 3ffefd54 3ffeec80
    3ffefc40:  3fffdc00 00000000 3ffefd30 3ffefc70
    3ffefc50:  0000000f 00000000 00000001 00000002
    3ffefc60:  000000ff 00000012 00000000 3ffeec80
    3ffefc70:  3fffdc20 00000000 3ffeec78 3ffeec80
    3ffefc80:  3fffdc20 00000000 3ffeec78 40203388
    3ffefc90:  00000000 00000000 3ffeec78 40203cb0
    3ffefca0:  00000000 00000000 3ffeec90 40100114
    <<<stack<<<
    c_rSöfê0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    pm open phy_2,type:2 0 0
    cnt
    .IP: 192.168.1.5
    After the restart it seams to be ok with accepting radiomesages
    .IP: 192.168.1.5
    0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.4
    0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:48.8
    0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:44.8
    0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.6
    0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:44.7
    0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.5
    0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:44.6
    0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.7
    It also good when I reloaded Vera. I got values into vera aswell.
    But as soon as I power in a new sensor it restarts. is that normal? And sometimes when I restart Vera the ESP restarts aswell, so it's the same now. Works sometimes, sometimes not (mostly not)
    I notice that when the client connects to it fine, untill it sends "0;255;3;0;9;Client 0: 2;1;1;0;24"
    Then there is a soft WDT reset
    0;255;3;0;9;Client 0 connected
    0;255;3;0;9;Client 0: 0;0;3;0;2;Get Version
    0;255;3;0;9;read: 2-2-0 s=1,c=2,t=24,pt=0,l=0,sg=0:
    0;255;3;0;9;Client 0: 2;1;1;0;24;
    So the problem seams to be when a sensor starts up or when a client connects.
    Tested to telnet it and it works ok. No restart
    Do you mean you connect it to the power supply?
    Could very well be that you're overloading the ESP power regulator. Try with a separate supply.
    • KosikaK
      KosikaK
      Kosika
      All sensors are connected to pro mini's thats powered by 2x AA batteries.
      I've now installed separate 5v->3v regulator for the GW radio.
      It looks like it starts up right, can reload vera etc but now it don't recieve any radiomessages at all. Something special when having separate regulator? It has the the GND, just VCC that's separated.
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 4
      cnt
      .IP: 192.168.1.5
      One step forward, and two steps back.
      • KosikaK
        KosikaK
        Kosika
        Okay, found the radio problem. I microscopit strand of copper wire had shorted the CS pin to the ESP 3.3v line. So now it recieves radio messages again.
        But when powering on a sensor it restarts like before. And sometimes when reloading vera. But once it didn't restart on reload:
        0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:35.1
        0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.9
        0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:35.3
        0;255;3;0;9;read: 2-2-00;255;3;0;9;Client 0: 2;1;1;0;24;
        Notice the lack of
        That and
        Seams to make the GW restart
        • KosikaK
          KosikaK
          Kosika
          wrote on last edited by Kosika
          Have had the GW running for a day now, as long as the client (Vera Edge) don't sent
          Or I start up an new sensor it's stable and works well.
          Problem now to figure out is how to connect a new sensor, as it restarts as soon as it's powered on.
          Any ideas?
          Note. Noticed that it only restarts upon new sensor startup if the client is connected.
          .IP: 192.168.1.5
          0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:39.8
          0;255;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
          NO restart as the client is not connected
          0;255;3;0;9;Client 0: 0;0;3;0;5;1
          0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.2
          0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:39.7
          0;255;3;0;9;Client 0: 255;255;3;0;4;3
          Soft WDT reset
          Here is restarted, inclusion mode or not does not matter
          afenoA 1 Reply Last reply
          • AffordableTechA
            AffordableTechA
            AffordableTech
            wrote on last edited by AffordableTech
            For one possible solution - refer to: [https://forum.mysensors.org/topic/3894/esp8266-unexpected-crash-or-reset](link url)
            • AffordableTechA AffordableTech
              @AffordableTech WDT resets are caused by a hang or too long loop in the software. Your topic describes a null pointer dereference, which is a different issue.
              • KosikaK
                KosikaK
                Kosika
                Had gotten my hopes up on this solution, but as it don't apply to 2.0 dev branch it was not the answer.
                I'm no programmer so I can't really do any real bug searching. I only noticed that two types of messages makes it restart. What they mean or what they do it beyond my knowledge.
                I'll just sit tight and hope some smart person comes up with a suggestion, meanwhile I'll continue to google the web :)
                • 172pilot1
                  172pilot1
                  172pilot
                  I THINK I'm having the same problem.. I'm building my first WiFi gateway.. I used a Sparkfun Thing Dev board because it was handy and accessible. Only oddities were that since the Sparkfun board has an LED on GPIO 5, I set the LED pin to 5 instead of 7, and the inclusion pin to 2..
                  I haven't tried the dev branch (will do, and report back) but with 1.5, I get a connection to my wifi, then a reboot:
                  wdt reset
                  tail 0
                  chksum 0x0f
                  csum 0x0f
                  ~ld
                  Over and over again.. Vera says it's connected, but then says it cant communicate. As mentioned, this type of problem is usually a tight loop not giving time for the WDT on the 8266 but I'm not familiar enough with this code to track it down.. Any ideas?
                  -Steve
                  YveauxY AffordableTechA 2 Replies Last reply
                  • 172pilot1 172pilot
                    wdt reset
                    tail 0
                    chksum 0x0f
                    csum 0x0f
                    ~ld
                    -Steve
                    @172pilot please try with 2.0.0 development. 1.5 does not contain all fixes for ESP that 2.0.0 has.
                    172pilot1 1 Reply Last reply
                      wdt reset
                      tail 0
                      chksum 0x0f
                      csum 0x0f
                      ~ld
                      -Steve
                      AffordableTechA
                      AffordableTechA
                      AffordableTech
                      Hi @172pilot
                      PLEASE NOTE: I gather there are three different problems which have similar results:
                      • A power supply with insufficient current to drive the ESP causes it to crash / reboot.
                      • A NULL message (somewhere in the process) can cause ESP to restart.
                      • Something called a 'WDT Reset' , which I have never encountered (?possibly only applies when using a Vera controller?).
                      Because all three produce similar looking results, I posted my fix here, even though I had not seen a 'WDT Reset' message (??possibly because I wasn't running a Vera controller??).
                      My Symptoms
                      My system appeared to have been running 'fine' for a solid week (as a test), using MYScontroller, I didn't notice anything abnormal. I also had a telnet (Potty) connection to the ESP. It wasn't until I started testing OpenHAB that OpenHab would report that it 'could not communicate'. At the same time my telnet connection and MYScontroller just stopped, no error message etc.
                      Then, OpenHab log reported that it was 'creating new connection', and resumed communicating, BUT both the telnet link and MYScontroller never resumed communications. I would have to disconnect / reconnect both, then they would continue for a few minutes until OpenHab reported the error again, when they would 'stall' again - this kept repeating.
                      If I stopped OpenHab, then the Telnet and MYScontroller worked flawlessly. At first I assumed that the OpenHab binding was the problem. Lots of testing, inserting debug 'print' statements into the drivers etc etc... Eventually I discovered that the 'MySensors ESP driver' was receiving a NULL pointer, when it was expecting a char pointer to a message, this was causing the ESP to reset.
                      I've since been told this problem was fixed in the MySensors 2.0 (beta) drivers and only applies to the 1.5 version (current ver at this point in time).
                      I hope this helps others clarify which of the three 'causes' apply to their issue. For example, my ESP was resetting, I didn't have a clue if it was a "WDT" reset, it could have been an "ABC" or "XYZ" reset as far as I knew. I still don't know what a WDT reset is?
                      Cheers... Paul
                      p.s. The first thing to check with any radio device (ESP, nRf2401 or GSM etc) is that you MUST have a good power source. When these devices transmit their current requirements go up significantly, which can cause all sorts of weird and wonderful thing to happen. Whenever I have a problem with a radio device, I will (temporarily) power the (3.3v) RF device direct from a Lipo battery (3.7v) with a 1N4001 (or similar) diode in series, this drops the voltage to 3.1v. Even though the voltage is a tad low, the Lipo (or NiCad) can deliver tremendous 'grunt' (amps) thus its a 'clean' and stable power source!
                        wrote on last edited by hek
                        The esp (and AVR) has something called a watchdog timer. It's actually there to help if something goes wrong, resetting the MCU. The watchdog timer can be disabled and reconfigured to allow longer interval. On ESP it's enabled by default and on AVR you have to enable it yourself (requires a special bootloader).
                        Its works by using a timer which gets "reset" by calling yield() or delay(). Normally you don't have to worry about it as yield() is called automatically in the main loop().
                        If yield() isn't called each second (which is the default timeout on ESP) the MCU will reset.
                        If you have some long blocking tasks you can disable the wdt temporariily like this:
                         wdt_disable();
                         <some blocking task>
                         wdt_enable();
                        https://github.com/esp8266/Arduino/blob/master/cores/esp8266/Esp.h#L29-L46
                           wdt_disable();
                           wdt_enable();
                          @hek are you sure disabling the WDT does actually work for ESP? The fact that the function exists, doesn't automatically mean it works :smirk:
                          In the past there were numerous issues of users who tried to disable it but kept getting WDT resets. But again, maybe that's been fixed in 2.x
                          • YveauxY Yveaux
                            172pilot1
                            172pilot1
                            172pilot
                            @Yveaux
                            Thanks for the response.. I actually did get the 1.5 to at least come up, by putting some WDT resets around in various places that may take a while in a loop, for example, BUT, based on yours, and several other recommendations, I decided to try the 2.0 dev branch.. I deleted everything in my librarys\MySensors directory, and downloaded the DEV branch, and re-extracted the code, and now I can't compile.. I'm getting this:
                            Arduino: 1.6.9 (Windows 10), Board: "SparkFun ESP8266 Thing Dev, 80 MHz, 115200"
                            In file included from C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
                                             from C:\Users\sjones\Documents\Arduino\MyDevelopment-2-0-GatewayESP8266\MyDevelopment-2-0-GatewayESP8266.ino:70:
                            C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = char*; size_t = unsigned int]':
                            C:\Users\sjones\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:163:66:   required from here
                            C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'char*'
                                 size_t left = source.available();
                            C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'char*'
                                 source.read(buffer.get(), will_send);
                            exit status 1
                            Error compiling for board SparkFun ESP8266 Thing Dev.
                            I found some recommendations to put the "#include <ESP8266WiFi.h>" close to the top, and it fixed it for other users, but I'm having no success with that..
                            Any idea what this may be?
                            Thanks in advance..
                            -Steve
                              @Yveaux
                              exit status 1
                              Thanks in advance..
                              -Steve
                              @172pilot I'm not behind a PC right now, so it's hard to replay the situation.
                              I'd say you either didn't clean everything out completely (use e.g. a completely separate Arduino folder for sketches and libraries), or it's the ESP Arduino port you're using (which version did you install through board manager?)
                              • YveauxY Yveaux
                                172pilot1
                                172pilot1
                                172pilot
                                @Yveaux Thanks.. Good to know what I'm doing SHOULD work.. :-)
                                I have been storing everything in what I think is the default directory, which under my \users\sjones\Documents\Arduino\libraries. This is what the Arduino IDE is pointing to.
                                Under that directory, I removed the MySensors directory and extracted the new 2.0 one.. BUT, I do see that there are more modules than just those under MySensors, so even though I think those are supposed to NOT conflict with the default ones, I missed one?
                                Also, I dont understand why, but I see SOME arduino extension stuff under \program Files (x86)\arduino although I didn't see any MySensors information..
                                And, the only other thing I saw which I didn't know how it got there was the one referred to in the error: "C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi" Since that specifically was referred to in the error, I thought maybe I had an old version there, so I renamed the ESP8266Wifi directory to "old", figuring that whatever put it there in the first place would replace it with the current version if needed, but it didn't happen - it just failed to compile, complaining that it was missing, so I put it back..
                                I'm not near my home computer now, but maybe when I get home I'll try with a completely new windows profile (create a new user) and reinstall Arduino from scratch
                                Thanks for your help and patience!
                                -Steve
                                AffordableTechA 1 Reply Last reply
                                  -Steve
                                  AffordableTechA
                                  AffordableTechA
                                  AffordableTech
                                  Hi @172pilot
                                  I'm fairly certain from what you have described that you have NOT done this, but just in case I will mention it. Remember, simply renaming a folder within libraries (eg. 'MySensors' to 'MySensorsOLD') can cause grief as the old and new will both be compiled / seen by the linker.
                                  I think your 'new user' idea will work.
                                  FWIW: Some time ago I had a similar issue with a different library, I can't remember the details, but I found/fixed it by doing a global search of "C:" for various keywords (e.g. "ESP8" and "MySen" in your case). I ended up finding files I didn't realise were there.
                                  Good luck!
                                  Paul
                                    Hi @172pilot
                                    Good luck!
                                    Paul
                                    172pilot1
                                    172pilot1
                                    172pilot
                                    @AffordableTech @Yveaux
                                    I uninstalled Arduino completely, deleted everything I could find, and reinstalled from scratch, and after a bit of patience and rebooting the vera, I now have a functioning Wifi gateway using a Sparkfun 8266 Thing Dev board, and an NRF radio.. Then I was able to build a quick "Arduino switch" with an Uno and an NRF just to test, and it works great!!
                                    Now it's time to get creative and build some stuff!
                                    Thanks again!!
                                    -Steve
                                    • KosikaK Kosika
                                      Any ideas?
                                      .IP: 192.168.1.5
                                      Soft WDT reset
                                      afenoA
                                      afenoA
                                      afeno
                                      Any ideas?
                                      I have the same problem. I'm using the Esp8266Gateway sketch in the Lib v1.5 and have a NRF24 radio as described in the instructions.
                                      Every time that I connect a new sensor, the MCU is restarting as you described. This is only happening when the Gateway is connected to a controller (Homeassistant or MYSController). If the gateway is not connected to any controller then it receive the data without any problem.
                                      @Kosika, How did you solved the problem?
                                      KosikaK YveauxY 2 Replies Last reply
                                      • afenoA afeno
                                        Any ideas?
                                        KosikaK
                                        KosikaK
                                        Kosika
                                        @afeno
                                        I have not solved this problem. But I have put this project on ice the last 2 months, but I will soon continue by doing a complete reinstall of all libraries etc.
                                        • afenoA afeno
                                          Any ideas?
                                          @afeno @Kosika please switch to the new 2.0.0 library, for your gateway, repeaters and sensors.
                                          Esp support has been improved in there, and developer support will be faster.
                                          afenoA 2 Replies Last reply
