  3. MyNodes.NET
  4. Installing ASP.NET 5/Core onto Raspberry Pi 3
Scheduled Pinned Locked Moved MyNodes.NET
13 Posts 4 Posters 7.0k Views 4 Watching
  • nutcrackerN
    nutcrackerN
    nutcracker
    Has anyone had any luck in attempting to do the above? I've tried to follow the instructions on the website but the download link doesn't work (http://docs.asp.net/en/latest/getting-started/installing-on-linux.html).
    I've tried installing alternatives but no luck - issues with ARM/Intel compatibility... what am I doing wrong?
    Nutz
    • nutcrackerN
      nutcrackerN
      nutcracker
      Have made some progress... by following the instructions here...
      https://github.com/lluppes/pisharp
      However, I'm now stumped with an error to do with libuv.
      Welcome to MyNodes.NET.
      Please configure the system in the web interface.
      System.DllNotFoundException: libuv
      at (wrapper managed-to-native) Microsoft.AspNet.Server.Kestrel.Networking.Libuv+NativeMethods:uv_loop_size ()
      at Microsoft.AspNet.Server.Kestrel.Networking.Libuv.loop_size () <0x6f73f560 + 0x00023> in <filename unknown>:0
      at Microsoft.AspNet.Server.Kestrel.Networking.UvLoopHandle.Init (Microsoft.AspNet.Server.Kestrel.Networking.Libuv uv) <0x6f73f478 + 0x0002f> in <filename unknown>:0
      at Microsoft.AspNet.Server.Kestrel.KestrelThread.ThreadStart (System.Object parameter) <0x6f73eef0 + 0x0008f> in <filename unknown>:0
      • derwishD
        derwishD
        derwish
        It seems Microsoft has removed the old version of the ASP.NET framework, as soon as the new released. Wait for MyNodes be updated on the new framework.
        • nutcrackerN
          nutcrackerN
          nutcracker
          Thanks derwish.... any ETA on that ?
          • derwishD
            derwishD
            derwish
            I will try to do it on the weekend.
            • nutcrackerN
              nutcrackerN
              nutcracker
              Thanks derwish!
              • derwishD
                derwishD
                derwish
                I started to port MyNodes, but it's not as easy as I thought. Meanwhile, you can try to install everything according to the old instructions: https://docs.asp.net/en/1.0.0-rc1/getting-started/installing-on-linux.html
                nutcrackerN 1 Reply Last reply
                • derwishD derwish
                  nutcrackerN
                  nutcrackerN
                  nutcracker
                  @derwish ok... so what versions of the software do I need to have installed to ensure compatibility with MyNodes...? (I thought I had already tried rc1). Thanks.
                  • K
                    K
                    kellers76
                    Is there something new to install .net on the raspberry?
                    I have tried it, but the installation does not get to run.
                    • derwishD
                      derwishD
                      derwish
                      Hi. At this moment the project was successfully ported to the ASP .NET Core (thanks to gildorwang). But I did not try to run it on raspberry. You can try last version. At the same time, I'm porting MyNodes to the node.js. This project is ready for 70%. It will work on raspberry, but at the moment it is not ready to use.
                      • K
                        K
                        kellers76
                        Hello derwish,
                        Thank you for your info
                        I plan my new house with about 100 - 120 mysensor nodes to install and wants to then manage the nodes with your great software.
                        TerrenceT 1 Reply Last reply
                        • K kellers76
                          Hello derwish,
                          TerrenceT
                          TerrenceT
                          Terrence
                          @kellers76 Wow, that is a lot of sensors. What and where will you be measuring? Just a general grouping.
                          • K
                            K
                            kellers76
                            @Terrence said in Installing ASP.NET 5/Core onto Raspberry Pi 3:
                            Hi terrence, i steer and rule in every room the light, the rolls and the heating
