  3. nRf24L01+ connection quality meter
43 Posts 18 Posters 26.4k Views 33 Watching
  • cjrpriestC
    cjrpriestC
    cjrpriest
    wrote on last edited by cjrpriest
    #21
    Hi @AWI, could you kindly post your updated version of the sketch that has the parent and destination node numbers on the display?
    AWIA 1 Reply Last reply
    • cjrpriestC cjrpriest
      AWIA
      AWIA
      AWI
      @cjrpriest Here you go..
       PROJECT: MySensors / Quality of radio transmission
       PROGRAMMER: AWI (MySensors libraries)
       DATE: 20160529/ last update: 20160530
       FILE: AWI_Send.ino
       LICENSE: Public domain
       Hardware: ATMega328p board w/ NRF24l01
      	and MySensors 2.0
      Special:
      Summary:
      	Sends a radio message with counter each  x time to determine fault ratio with receiver
      Remarks:
      	Fixed node-id & communication channel to other fixed node
      Change log:
      20160530 - added moving average on fail/ miss count, update to 2.0
      //****  MySensors *****
      #define MY_RADIO_NRF24									// Enable and select radio type attached
      //#define MY_RF24_CHANNEL 80								// radio channel, default = 76
      #define MY_NODE_ID 250
      #define NODE_TXT "Q 250"								// Text to add to sensor name
      //#define MY_PARENT_NODE_ID 42							// fixed parent to controller when 0 (else comment out = AUTO)
      // #define MY_RF24_CE_PIN 7								// Ceech board, 3.3v (7,8)  (pin default 9,10)
      // #define MY_RF24_CS_PIN 8
      #define DESTINATION_NODE 0								// receiving fixed node id (default 0 = gateway)
      // display
      #include <Wire.h>											// I2C
      #include <LiquidCrystal_I2C.h>								// LCD display with I2C interface
      // helpers
      #define LOCAL_DEBUG
      #ifdef LOCAL_DEBUG
      #define Sprint(a) (Serial.print(a))						// macro as substitute for print, enable if no print wanted
      #define Sprintln(a) (Serial.println(a))					// macro as substitute for println
      #else
      #define Sprint(a)										// enable if no print wanted -or-
      #define Sprintln(a)										// enable if no print wanted
      // MySensors sensor
      #define counterChild 0
      // send constants and variables
      int messageCounter = 0 ;
      const int messageCounterMax = 100 ; 					// maximum message counter value
      const unsigned counterUpdateDelay = 500 ;				// send every x ms and sleep in between
      // receive constants and variables
      boolean failStore[messageCounterMax] ;					// moving average stores & pointers
      int failStorePointer = 0 ;
      boolean missedStore[messageCounterMax] ;
      int missedStorePointer = 0 ;
      int newMessage = 0 ;
      int lastMessage = -1 ;
      int missedMessageCounter = 0 ; 							// total number of messages in range (messageCounterMax)
      int failMessageCounter = 0 ; 							// total number of messages in range (messageCounterMax)
      uint8_t parent = 0 ;									// parent node-id
      // Loop delays
      const unsigned long displayInterval = 1000UL ;			// display update in ms
      unsigned long lastDisplayUpdate = 0 ;					// last update for loop timers
      // standard messages
      MyMessage counterMsg(counterChild, V_PERCENTAGE);		// Send value
      // ***** LCD
      //LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
      LiquidCrystal_I2C lcd(0x27, 16, 2);  // Set the LCD I2C address
      	Wire.begin();  // I2C
          // ** LCD display **
          // LCD 2 lines * 16 char.
          lcd.begin(16, 2);
          lcd.setBacklight(HIGH);
          lcd.setCursor(0, 0);
      	lcd.print("AWI Quality nRF24");
      	for(int i= 0 ; i <  messageCounterMax ; i++){		// init stores for moving averages
      		failStore[i] = true ;
      		missedStore[i] = true ;
      	missedStorePointer = failStorePointer = 0 ;
      	delay(1000);
      void presentation(){
      // MySensors
      	present(counterChild, S_DIMMER, "Quality counter " NODE_TXT) ;  // counter uses percentage from dimmer value
      	// Sprint("count:") ; Sprintln(messageCounter) ;
      	LCD_local_display();
      	missedStore[failStorePointer] = false  ; 			// set slot to false (ack message needs to set) ;
      	boolean succes = failStore[failStorePointer] = send(counterMsg.setDestination(DESTINATION_NODE).set(failStorePointer), true);  // send to destination with ack
      	if (!succes){
      		failMessageCounter++ ;
      		Sprint("Fail on message: ") ; Sprint(failStorePointer) ;
      		Sprint(" # ") ; Sprintln(failMessageCounter);
      	failStorePointer++ ;
      	if(failStorePointer >= messageCounterMax){
      		failStorePointer =  0	;						// wrap counter
      	parent = getParentNodeId();							// get the parent node (0 = gateway)
      	wait(counterUpdateDelay) ;							// wait for things to settle and ack's to arrive
      void receive(const MyMessage &message) {  				// Expect few types of messages from controller
      	newMessage = message.getInt();						// get received value
      	switch (message.type){
      		case V_PERCENTAGE:
      			missedStore[newMessage] = true ;			// set corresponding flag to received.
      			if (newMessage > lastMessage){				// number of messages missed from lastMessage (kind of, faulty at wrap)
      				Sprint("Missed messages: ") ; Sprintln( newMessage - lastMessage - 1) ;
      				missedMessageCounter += newMessage - lastMessage - 1 ;
      			lastMessage = newMessage ;
      			break ;
      		default: break ;
      // calculate number of false values in array
      // takes a lot of time, but who cares...
      int getCount(boolean countArray[], int size){
      	int falseCount = 0 ;
      	for (int i = 0 ; i < size ; i++){
      		falseCount += countArray[i]?0:1 ;
      	return falseCount ;
      void LCD_local_display(void){
      /* prints all available variables on LCD display with units
          char buf[17]; 											// buffer for max 16 char display
          snprintf(buf, sizeof buf, "p%-3dFail%4d%3d%%", parent, failMessageCounter, getCount(failStore, messageCounterMax));
          lcd.print(buf);
          lcd.setCursor(0, 1);
          snprintf(buf, sizeof buf, "d%-3dMiss%4d%3d%%", DESTINATION_NODE , missedMessageCounter, getCount(missedStore, messageCounterMax));
      	lcd.print(buf);
      cjrpriestC karl261K 2 Replies Last reply
      • AWIA AWI
         FILE: AWI_Send.ino
        	and MySensors 2.0
        Special:
        Summary:
        Remarks:
        Change log:
        // display
        // helpers
        #define LOCAL_DEBUG
        #ifdef LOCAL_DEBUG
        #else
        // MySensors sensor
        // Loop delays
        // ***** LCD
            lcd.begin(16, 2);
        	delay(1000);
        // MySensors
        	if (!succes){
        		case V_PERCENTAGE:
        			break ;
        		default: break ;
        	return falseCount ;
            lcd.print(buf);
        	lcd.print(buf);
        cjrpriestC
        cjrpriestC
        cjrpriest
        Thanks very much @AWI 👍
        • AWIA AWI
           FILE: AWI_Send.ino
          	and MySensors 2.0
          Special:
          Summary:
          Remarks:
          Change log:
          // display
          // helpers
          #define LOCAL_DEBUG
          #ifdef LOCAL_DEBUG
          #else
          // MySensors sensor
          // Loop delays
          // ***** LCD
              lcd.begin(16, 2);
          	delay(1000);
          // MySensors
          	if (!succes){
          		case V_PERCENTAGE:
          			break ;
          		default: break ;
          	return falseCount ;
              lcd.print(buf);
          	lcd.print(buf);
          karl261K
          karl261K
          karl261
          wrote on last edited by karl261
          #24
          @AWI Strange, with the latest sketch I get
          nrf-quality-meter.ino:88:34: error: invalid conversion from 'int' to 't_backlighPol' [-fpermissive]
          In file included from nrf-quality-meter.ino:45:0:
          C:\Dokumente und Einstellungen\Philipp\Eigene Dateien\Arduino\libraries\LiquidCrystal/LiquidCrystal_I2C.h:53:4: error: initializing argument 3 of 'LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, t_backlighPol)' [-fpermissive]
          LiquidCrystal_I2C (uint8_t lcd_Addr, uint8_t backlighPin, t_backlighPol pol);
          compiling...
          It works using the other line...
          // ***** LCD
          • karl261K karl261
            compiling...
            // ***** LCD
            AWIA
            AWIA
            AWI
            @karl261 probably I am using another library for the display. I got it from the Arduino library manager.
            • N
              N
              Nicklas Starkel
              @AWI what is the board between the nano and the radio?
              Something available via aliexpress?
              I really do not need this as I live in a small flat.. but I NEED THIS! :laughing:
              • N Nicklas Starkel
                AWIA
                AWIA
                AWI
                wrote on last edited by AWI
                #27
                @Nicklas-Starkel you can find it in the MySensors shop It is a nrf24l01+ socket adapter board. It guarantees a stable supply and includes the famous "radio capacitor"
                • siodS
                  siodS
                  siod
                  wrote on last edited by siod
                  #28
                  Hi @AWI,
                  thanks for the code and the project! ~~Unfortunately my biggest problem is to get my LCD working. It does not do anything with your code, other testcode to test the display is working fine. I am using this line and it should work fine:
                  Any idea what else I could check? I am using arduino IDE 1.6.10
                  edit: getting this in the serial monitor of the device:
                  TSM:INIT
                  TSM:RADIO:OK
                  TSP:ASSIGNID:OK (ID=250)
                  TSM:FPAR
                  TSP:MSG:SEND 250-250-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  TSP:MSG:READ 3-3-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                  TSP:MSG:BC
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  then it starts over again...
                  edit2:
                  Think I got it now, seems like my gateway wasn´t responding or whatever, now it seems to work...
                  Edit3:
                  I got 1 fail and 5000 miss 60%...
                  Now what does this mean??
                  Edit4:
                  I think I need some help: Most of the time I get this on my gw´s Serial Monitor:
                  0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                  0;255;3;0;9;TSP:MSG:READ 250-250-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                  0;255;3;0;9;TSP:MSG:BC
                  0;255;3;0;9;TSP:MSG:FPAR REQ (sender=250)
                  0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                  0;255;3;0;9;TSP:MSG:GWL OK
                  After some reboots of the quality meter and I guess with a lot of luck it starts working occasionally
                  This is from the serial monitor of the quality meter:
                  TSP:MSG:READ 0-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
                  !TSP:MSG:PVER mismatch
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  I already added a 47u Cap and added those lines to the code:
                  #define MY_PARENT_NODE_ID 0                         // fixed parent to controller when 0 (else comment out = AUTO)
                  no luck at all...
                  edit5:
                  Now I opened the serial output of my GW again, which seems to started the communication:
                  0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  0;255;3;0;9;TSP:MSG:PINGED (ID=250, hops=1)
                  0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                  0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  0;255;3;0;9;!TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                  0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                  0;255;3;0;9;Sending message on topic: mygateway1-out/250/255/0/0/17
                  0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  0;255;3;0;9;Sending message on topic: mygateway1-out/250/255/3/0/6
                  0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=0,t=4,pt=0,l=21,sg=0:Quality counter Q 250
                  0;255;3;0;9;Sending message on topic: mygateway1-out/250/0/0/0/4
                  0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                  0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=1,t=3,pt=2,l=2,sg=0:0
                  0;255;3;0;9;TSP:MSG:ACK msg
                  0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=ok:0
                  0;255;3;0;9;Sending message on topic: mygateway1-out/250/0/1/0/3
                  0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=1,t=3,pt=2,l=2,sg=0:1
                  0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=ok:1
                  0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=1,t=3,pt=2,l=2,sg=0:2
                  I don´t get it what is going on here. Restarted quality meter: blank LCD... :(
                  still learning...
                  • NickBuilderN
                    NickBuilderN
                    NickBuilder
                    wrote on last edited by NickBuilder
                    #29
                    Great tool for a mysensors builder @AWI! I also want to sort out the good radios from the bad, I have enough trouble as it is trying to troubleshoot my questionable sensors.
                    I got around to building a quality meter for myself, although without the adapter board and with some additional differences. But I really don't understand the output, the fail and miss percentage is almost always 100 % for most of my radios. Am I missing something? Perhaps I should change some addresses to static ones? I thought that perhaps I had to define a corresponding item in Openhab in order for the packages to be acknowledged but this doesn't change the outcome.
                    Here's the serial output from the "quality meter":
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSP:MSG:READ 0-0-250 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    TSP:MSG:PAR OK (ID=0, dist=1)
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:CHKID:OK (ID=250)
                    TSM:UPL
                    TSP:PING:SEND (dest=0)
                    !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                    TSP:MSG:READ 0-0-250 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    TSP:MSG:PONG RECV (hops=1)
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=1,st=fail:0100
                    !TSP:MSG:SEND 250-250-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=2,st=fail:2.0.0
                    !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=3,st=fail:0
                    TSP:MSG:READ 0-0-250 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=0,t=4,pt=0,l=21,sg=0,ft=4,st=fail:Quality counter Q 250
                    Request registration...
                    !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=fail:2
                    !TSM:UPL FAIL, SNP
                    TSM:FPAR
                    !TSP:SEND:TNR
                    TSM:FPAR
                    !TSP:SEND:TNR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=fail:2
                    TSP:MSG:READ 0-0-250 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    Node registration=1
                    Init complete, id=250, parent=0, distance=1, registration=1
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:0
                    Fail on message: 0 # 1
                    TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:0
                    Missed messages: 0
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:1
                    Fail on message: 1 # 2
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:2
                    Fail on message: 2 # 3
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:3
                    Fail on message: 3 # 4
                    !TSM:UPL FAIL, SNP
                    TSM:FPAR
                    TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:3
                    Missed messages: 2
                    !TSP:SEND:TNR
                    Fail on message: 4 # 5
                    !TSP:SEND:TNR
                    Fail on message: 5 # 6
                    !TSP:SEND:TNR
                    Fail on message: 6 # 7
                    !TSP:SEND:TNR
                    Fail on message: 7 # 8
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 8 # 9
                    !TSP:SEND:TNR
                    Fail on message: 9 # 10
                    !TSP:SEND:TNR
                    Fail on message: 10 # 11
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=fail:11
                    Fail on message: 11 # 12
                    TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:11
                    Missed messages: 7
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:12
                    Fail on message: 12 # 13
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:13
                    Fail on message: 13 # 14
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:14
                    Fail on message: 14 # 15
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:15
                    Fail on message: 15 # 16
                    !TSM:UPL FAIL, SNP
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 16 # 17
                    !TSP:SEND:TNR
                    Fail on message: 17 # 18
                    !TSP:SEND:TNR
                    Fail on message: 18 # 19
                    !TSP:SEND:TNR
                    Fail on message: 19 # 20
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:CHKUPL:FAIL (hops=255)
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 20 # 21
                    !TSP:SEND:TNR
                    Fail on message: 21 # 22
                    !TSP:SEND:TNR
                    Fail on message: 22 # 23
                    !TSP:SEND:TNR
                    Fail on message: 23 # 24
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 24 # 25
                    !TSP:SEND:TNR
                    Fail on message: 25 # 26
                    !TSP:SEND:TNR
                    Fail on message: 26 # 27
                    !TSP:SEND:TNR
                    Fail on message: 27 # 28
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 28 # 29
                    !TSP:SEND:TNR
                    Fail on message: 29 # 30
                    !TSP:SEND:TNR
                    Fail on message: 30 # 31
                    !TSP:SEND:TNR
                    Fail on message: 31 # 32
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 32 # 33
                    !TSP:SEND:TNR
                    Fail on message: 33 # 34
                    !TSP:SEND:TNR
                    Fail on message: 34 # 35
                    !TSP:SEND:TNR
                    Fail on message: 35 # 36
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=fail:36
                    Fail on message: 36 # 37
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:37
                    Fail on message: 37 # 38
                    TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:37
                    Missed messages: 25
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:38
                    Fail on message: 38 # 39
                    TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:38
                    Missed messages: 0
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:39
                    Fail on message: 39 # 40
                    TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:39
                    Missed messages: 0
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:40
                    Fail on message: 40 # 41
                    !TSM:UPL FAIL, SNP
                    TSM:FPAR
                    TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:40
                    Missed messages: 0
                    !TSP:SEND:TNR
                    Fail on message: 41 # 42
                    !TSP:SEND:TNR
                    Fail on message: 42 # 43
                    !TSP:SEND:TNR
                    Fail on message: 43 # 44
                    TSM:FPAR:OK
                    TSM:ID
                    !TSP:SEND:TNR
                    Fail on message: 44 # 45
                    TSM:UPL
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=fail:45
                    Fail on message: 45 # 46
                    TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:45
                    Missed messages: 4
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:46
                    Fail on message: 46 # 47
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:47
                    Fail on message: 47 # 48
                    TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:47
                    Missed messages: 1
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:48
                    Fail on message: 48 # 49
                    TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:48
                    Missed messages: 0
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:49
                    Fail on message: 49 # 50
                    !TSM:UPL FAIL, SNP
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 50 # 51
                    !TSP:SEND:TNR
                    Fail on message: 51 # 52
                    !TSP:SEND:TNR
                    Fail on message: 52 # 53
                    !TSP:SEND:TNR
                    Fail on message: 53 # 54
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 54 # 55
                    !TSP:SEND:TNR
                    Fail on message: 55 # 56
                    !TSP:SEND:TNR
                    Fail on message: 56 # 57
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 57 # 58
                    !TSP:SEND:TNR
                    Fail on message: 58 # 59
                    !TSP:SEND:TNR
                    Fail on message: 59 # 60
                    !TSP:SEND:TNR
                    Fail on message: 60 # 61
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 61 # 62
                    !TSP:SEND:TNR
                    Fail on message: 62 # 63
                    !TSP:SEND:TNR
                    Fail on message: 63 # 64
                    !TSP:SEND:TNR
                    Fail on message: 64 # 65
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 65 # 66
                    !TSP:SEND:TNR
                    Fail on message: 66 # 67
                    !TSP:SEND:TNR
                    Fail on message: 67 # 68
                    !TSP:SEND:TNR
                    Fail on message: 68 # 69
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 69 # 70
                    !TSP:SEND:TNR
                    Fail on message: 70 # 71
                    !TSP:SEND:TNR
                    Fail on message: 71 # 72
                    !TSP:SEND:TNR
                    Fail on message: 72 # 73
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 73 # 74
                    !TSP:SEND:TNR
                    Fail on message: 74 # 75
                    !TSP:SEND:TNR
                    Fail on message: 75 # 76
                    !TSP:SEND:TNR
                    Fail on message: 76 # 77
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 77 # 78
                    !TSP:SEND:TNR
                    Fail on message: 78 # 79
                    !TSP:SEND:TNR
                    Fail on message: 79 # 80
                    !TSP:SEND:TNR
                    Fail on message: 80 # 81
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 81 # 82
                    !TSP:SEND:TNR
                    Fail on message: 82 # 83
                    !TSP:SEND:TNR
                    Fail on message: 83 # 84
                    !TSP:SEND:TNR
                    Fail on message: 84 # 85
                    TSM:FPAR
                    !TSP:SEND:TNR
                    Fail on message: 85 # 86
                    !TSP:SEND:TNR
                    Fail on message: 86 # 87
                    !TSP:SEND:TNR
                    Fail on message: 87 # 88
                    !TSP:SEND:TNR
                    Fail on message: 88 # 89
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                    TSP:MSG:READ 99-99-0 s=0,c=1,t=1,pt=7,l=5,sg=0:62.2
                    !TSM:MSG:REL MSG, but not a repeater
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=fail:89
                    Fail on message: 89 # 90
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=fail:90
                    Fail on message: 90 # 91
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:91
                    Fail on message: 91 # 92
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:92
                    Fail on message: 92 # 93
                    TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:92
                    Missed messages: 43
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:93
                    Fail on message: 93 # 94
                    TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:93
                    Missed messages: 0
                    !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:94
                    Fail on message: 94 # 95
                    !TSM:UPL FAIL, SNP
                    TSM:FPAR
                    TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:94
                    Missed messages: 0
                    !TSP:SEND:TNR
                    Fail on message: 95 # 96
                    !TSP:SEND:TNR
                    Fail on message: 96 # 97
                    !TSP:SEND:TNR
                    Fail on message: 97 # 98
                    !TSP:SEND:TNR
                    Fail on message: 98 # 99
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    Also, the meter in action generating the output above can be seen here: LINK
                    After some time, >10 min, the fail percentage is 100 % and the miss percentage around 85 %. Not impressive if interpreted correctly. Could someone give me some pointers to what the problem is? I don't talk "mysensors protocol".
                    Sorry @siod, I don't think I can help you. You seem to get a lot more messages through though.
                    • NickBuilderN NickBuilder
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      !TSM:UPL FAIL, SNP
                      TSM:FPAR
                      !TSP:SEND:TNR
                      TSM:FPAR
                      !TSP:SEND:TNR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      Node registration=1
                      Missed messages: 0
                      !TSM:UPL FAIL, SNP
                      TSM:FPAR
                      Missed messages: 2
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      Missed messages: 7
                      !TSM:UPL FAIL, SNP
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      Missed messages: 25
                      Missed messages: 0
                      Missed messages: 0
                      !TSM:UPL FAIL, SNP
                      TSM:FPAR
                      Missed messages: 0
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR:OK
                      TSM:ID
                      !TSP:SEND:TNR
                      TSM:UPL
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      Missed messages: 4
                      Missed messages: 1
                      Missed messages: 0
                      !TSM:UPL FAIL, SNP
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      Missed messages: 43
                      Missed messages: 0
                      !TSM:UPL FAIL, SNP
                      TSM:FPAR
                      Missed messages: 0
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      !TSP:SEND:TNR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      AWIA
                      AWIA
                      AWI
                      #30
                      @NickBuilder you seem to have a pretty bad connection (hardware related) . The meter has to be built with a reliable power source and connections. I can't see from the movie how your radio is powered. The reason for using the adapter plate is that it includes a separate ldo and capacitors.
                      NickBuilderN 1 Reply Last reply
                      • siodS siod
                        Hi @AWI,
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSP:MSG:BC
                        !TSM:FPAR:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        edit2:
                        Edit3:
                        Edit4:
                        !TSM:FPAR:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        no luck at all...
                        edit5:
                        AWIA
                        AWIA
                        AWI
                        #31
                        @siod the meter works like a normal sketch. If it does not get past making a connection the rest of the code won't start (ie the LCD). To be honest I can't make up a reason from the serial logs except that your node has problems finding it's parent.
                        • AWIA AWI
                          NickBuilderN
                          NickBuilderN
                          NickBuilder
                          @AWI, it's hardly visible but I'm actually using a 3V3 buck and a 10 uF cap to power the radio. But I took your advice and tried tos power the radio seperately with two AA batterys, and a cap just in case. This should be a really clean source of power but the outcome is still the same.
                          I guess I'll order som new radios, hopefully from a different supplier. I'll get some adapter boards with (switchless) LDO's while I'm at it.
                          Why is the parent changing from 255 to 0 back and forth? I have a serial gateway connected to a Pi and aside from some temp sensors I also have an RC switch for my outlets which also acts as a gateway but the adress is neither 255 nor 0.
                          Thanks!
                            Thanks!
                            AWIA
                            AWIA
                            AWI
                            @NickBuilder I hope you solve your issues with new radio's. I have very little which don't function at all.
                            The id "0" belongs to your gateway "255" is a kind of broadcast id which is a.o. used when a node number is not known. Both id's are not available for you to assign to a node.
                            • karl261K
                              karl261K
                              karl261
                              For those who need and don't have a display like me, here is my sketch version for output to the serial console. So what I do is, I run around with a laptop connected to the node and watch the serial console, or, I just move around with a tablet and the node. The tablet is connected to my raspi and I watch the output of my gw on the pi using picocom. Picocom handles very well the missing line feeds in the output. The gw output is also very informative, there are no statistics, but still I see when stuff fails...
                              Thanks for the cool sketch @AWI!
                               FILE: AWI_Send.ino
                                  and MySensors 2.0
                              Special:
                              Summary:
                              Remarks:
                              Change log:
                              // MIN, LOW, HIGH, MAX
                              #define MY_PARENT_NODE_ID 99                          // fixed parent to controller when 0 (else comment out = AUTO)
                              #define MY_BAUD_RATE 9600
                              // helpers
                              #define LOCAL_DEBUG
                              #ifdef LOCAL_DEBUG
                              #else
                              // MySensors sensor
                                  delay(1000);
                              // MySensors
                                  Sprint("Parent: "); Sprint(parent); Sprint("       Fail "); Sprint(failMessageCounter); Sprint("   "); Sprint(getCount(failStore, messageCounterMax)); Sprintln("%");
                                  Sprint("Destination: "); Sprint(DESTINATION_NODE); Sprint("  Miss "); Sprint(missedMessageCounter); Sprint("   "); Sprint(getCount(missedStore, messageCounterMax)); Sprintln("%");
                                  if (!succes){
                                      case V_PERCENTAGE:
                                          break ;
                                      default: break ;
                                  return falseCount ;
                              • Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                @karl261 I tried your code and it pretty much just gives me failures? I don't have any issues with nodes and tried it out of curiosity, any ideas? It seems to send pretty fast, perhaps its spamming my gateway too much?
                                karl261K 1 Reply Last reply
                                • Mark SwiftM Mark Swift
                                  karl261K
                                  karl261K
                                  karl261
                                  @Mark-Swift Where do you see the failures? Do you have a log output?
                                  The code is for mysensors 2.0.0. Did you adapt all the network specific #define in the beginning of the sketch to your network? In my example there is a static parent set and the static parent has the ID 99. If that does not exist, there will be failures.
                                  • Mark SwiftM
                                    Mark SwiftM
                                    Mark Swift
                                    Hi @karl261 I'm using the latest 2.0 snapshot, and did change the network specific settings. I'll grab a debug output and post it up next time I get access to the gateway...
                                    • AWIA AWI
                                      NickBuilderN
                                      NickBuilderN
                                      NickBuilder
                                      @AWI, thanks to your sketch and the concept of transmission quality measurement I did some adjustments to my setup.
                                      I guess the most critical reason for the bad numbers shown on the meter for my network was due to a poor gateway. After applying the cheep and dirty EMI fix, a ground connected foil, and playing around with the transceiver power I finally got some good numbers on the meter.
                                      So now I've placed a post-it on each module indicating a sort of long term fail average. A couple of them shows quite poor fail/miss values, 60-80 %. The best ones reaches around 5-15 % but this could be due to the gateway radio.
                                      Actually I still don't know if the gateway transceiver is optimized. I should test some additional radio units.
                                      Using large caps for the radio is recommended. There's no reason why not to use a bigger cap, > x00 uF. The ones rated for lower voltages are quite small in physical terms.
                                      Thank you for this @AWI!
                                      • D
                                        D
                                        dakipro
                                        I just wanted to say thanks for this project, I think we need more tools like this that increase quality of our projects (and thus increase WAF as well).
                                        Also wanted to ask would it be too complicated and/or practical to include measurement of the radio consumption while it is sending and sleeping?
                                        Maybe a switch/jumper and a bit of code modification that would let radio sleep, and we could use a amper meter in serial with the radio? Even better if some simple "integrated" current measurement method could be used, some voltage drop on some other pins measured directly in the tester or what not (that would be above my knowledge, but I might just try it in a few months when I get some spare time)
                                        • D dakipro
                                          AWIA
                                          AWIA
                                          AWI
                                          @dakipro It would take a resistor and analog power reading to include basic power measurement. Current would vary between ~3mA and 70mA (with amplified radio).
                                          H 1 Reply Last reply
