  3. nRf24L01+ connection quality meter
43 Posts 18 Posters 26.6k Views 33 Watching
  • AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    A little frustrated by radio's showing inconsistent behaviour I built a simple connection quality meter with a leftover of a previous project.
    0_1464549715094_upload-8cefcb84-2528-42e3-98e1-792b63fc0b50
    Not too complicated ;-) a nano, I2C lcd display, radio adapter board (guarantees a stable power supply for the radio) and the radio to be tested.
    0_1464549601260_upload-0bca4a04-80b0-4f70-9263-cef5d75e7702
    a little hot glue and it fits nicely in the box. The radio can be swapped on the outside. Power comes in from a power bank connected to the nano USB so that I can walk around the house.
    0_1464549797943_upload-328cbdd6-bd88-417c-9bbb-0160b1a2d55a
    The sketch sends values from 0..99 to a gateway with "ack" enabled. The LCD shows the "failed" sends and the number of not acknowledged messages. i.e. the messages which did not arrive at the gateway or did not make it on their return flight.
    It now takes less than a minute to sort the radio's :bowtie:
    • AWIA AWI
      @AWI is that hardware ack or software ack? (The MySensors ack confusion is driving me insane)
      AWIA 1 Reply Last reply
      • F
        F
        flopp
        Nice and very useful, also to test if there is signal in a special area in your house.
        Can you put the code here?
        • B
          B
          boozz
          @AWI
          Thanks for the idea! This can become very useful in deciding at which locations a repeater can be used to solve my coverage problem. In my setup I'm facing difficulties getting the signal through a glass pane at the rear of my house.
          Same question as @flopp: putting the code in here would be very useful
          Thanks,
          Boozz
            AWIA
            AWIA
            AWI
            @mfalkvidd my interpretation and based on experience:
            • fail (hardware ack..) is the node to node acknowledgement. (i.e. from node to repeater or gateway). Can not be switched on/off from the API. This is the return value from the send() function (or gw.send()). If a fail occurs the node tries multiple times to resend (this can take quitte a lot of time..) This acknowledgement is only from the next node in line.
            • missed (software ack) is the node to destination acknowledgement (i.e. node - repeater - gateway) . Can (and should) be enabled in the send() function. The acknowledgement is send automatically by the destination node in the form of an "echo" of the message sent. No automatic resend happens. Eventual action should be taken by the sender (controller / sketch in node).
            The "connection quality meter" measures the number of fails and averages this for 100 samples (percentate) and similar for not acknowledged "software ack's".
            Ik will post the sketch later today..
            • AWIA
              AWIA
              AWI
              The sketch for the connection quality meter.
               PROJECT: MySensors / Quality of radio transmission
               PROGRAMMER: AWI (MySensors libraries)
               DATE: 20160529/ last update: 20160530
               FILE: AWI_Send.ino
               LICENSE: Public domain
               Hardware: ATMega328p board w/ NRF24l01
              	and MySensors 2.0 (Development)
              Special:
              Summary:
              	Sends a radio message with counter each  x time to determine fault ratio with receiver
              Remarks:
              	Fixed node-id & communication channel to other fixed node
              Change log:
              20160530 - added moving average on fail/ miss count
              //****  MySensors *****
              #define MY_RADIO_NRF24									// Enable and select radio type attached
              #define MY_RF24_CHANNEL 80								// radio channel, default = 76
              #define MY_NODE_ID 250
              #define NODE_TXT "Q 250"								// Text to add to sensor name
              // #define MY_RF24_CE_PIN 7								// Ceech board, 3.3v (7,8)  (pin default 9,10)
              // #define MY_RF24_CS_PIN 8
              #define DESTINATION_NODE 0								// receiving fixed node id (default 0 = gateway)
              // display
              #include <Wire.h>											// I2C
              #include <LiquidCrystal_I2C.h>								// LCD display with I2C interface
              // helpers
              #define LOCAL_DEBUG
              #ifdef LOCAL_DEBUG
              #define Sprint(a) (Serial.print(a))						// macro as substitute for print, enable if no print wanted
              #define Sprintln(a) (Serial.println(a))					// macro as substitute for println
              #else
              #define Sprint(a)										// enable if no print wanted -or-
              #define Sprintln(a)										// enable if no print wanted
              // MySensors sensor
              #define counterChild 0
              // send constants and variables
              int messageCounter = 0 ;
              const int messageCounterMax = 100 ; 					// maximum message counter value
              const unsigned counterUpdateDelay = 100 ;				// send every x ms and sleep in between
              // receive constants and variables
              boolean failStore[messageCounterMax] ;					// moving average stores & pointers
              int failStorePointer = 0 ;
              boolean missedStore[messageCounterMax] ;
              int missedStorePointer = 0 ;
              int newMessage = 0 ;
              int lastMessage = -1 ;
              int missedMessageCounter = 0 ; 							// total number of messages in range (messageCounterMax)
              int failMessageCounter = 0 ; 							// total number of messages in range (messageCounterMax)
              // Loop delays
              const unsigned long displayInterval = 1000UL ;			// display update in ms
              unsigned long lastDisplayUpdate = 0 ;					// last update for loop timers
              // standard messages
              MyMessage counterMsg(counterChild, V_PERCENTAGE);		// Send value
              // ***** LCD
              LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
              	Wire.begin();  // I2C
                  // ** LCD display **
                  // LCD 2 lines * 16 char.
                  lcd.begin(16, 2);
                  lcd.setBacklight(HIGH);
                  lcd.setCursor(0, 0);
              	lcd.print("AWI Quality nRF24");
              	for(int i= 0 ; i <  messageCounterMax ; i++){		// init stores for moving averages
              		failStore[i] = true ;
              		missedStore[i] = true ;
              	missedStorePointer = failStorePointer = 0 ;
                  delay(1000);
              void presentation(){
              // MySensors
              	present(counterChild, S_DIMMER, "Quality counter " NODE_TXT) ;  // counter uses percentage from dimmer value
              	// Sprint("count:") ; Sprintln(messageCounter) ;
              	LCD_local_display();
              	missedStore[failStorePointer] = false  ; 			// set slot to false (ack message needs to set) ;
              	boolean succes = failStore[failStorePointer] = send(counterMsg.setDestination(DESTINATION_NODE).set(failStorePointer), true);  // send to destination with ack
              	if (!succes){
              		failMessageCounter++ ;
              		Sprint("Fail on message: ") ; Sprint(failStorePointer) ;
              		Sprint(" # ") ; Sprintln(failMessageCounter);
              	failStorePointer++ ;
              	if(failStorePointer >= messageCounterMax){
              		failStorePointer =  0	;						// wrap counter
              	wait(counterUpdateDelay) ;							// wait for things to settle and ack's to arrive
              void receive(const MyMessage &message) {  				// Expect few types of messages from controller
              	newMessage = message.getInt();						// get received value
              	switch (message.type){
              		case V_PERCENTAGE:
              			missedStore[newMessage] = true ;			// set corresponding flag to received.
              			if (newMessage > lastMessage){				// number of messages missed from lastMessage (kind of, faulty at wrap)
              				Sprint("Missed messages: ") ; Sprintln( newMessage - lastMessage - 1) ;
              				missedMessageCounter += newMessage - lastMessage - 1 ;
              			lastMessage = newMessage ;
              			break ;
              		default: break ;
              // calculate number of false values in array
              // takes a lot of time, but who cares...
              int getCount(boolean countArray[], int size){
              	int falseCount = 0 ;
              	for (int i = 0 ; i < size ; i++){
              		falseCount += countArray[i]?0:1 ;
              	return falseCount ;
              void LCD_local_display(void){
              /* prints all available variables on LCD display with units
                  char buf[17]; 											// buffer for max 16 char display
                  snprintf(buf, sizeof buf, "Failed:%4d %3d%%", failMessageCounter, getCount(failStore, messageCounterMax));
                  lcd.print(buf);
                  lcd.setCursor(0, 1);
                  snprintf(buf, sizeof buf, "Missed:%4d %3d%%", missedMessageCounter, getCount(missedStore, messageCounterMax));
              	lcd.print(buf);
              • B
                B
                boozz
                Thnx!
                :+1:
                • AWIA
                  AWIA
                  AWI
                  I have been walking through and around the house with the meter to find the best radio solutions. So far I have the best reach with the nRF24L01+PA+LNA with the plastic/ aluminum foil (the ugly fix ;-), credits @Oitzu).
                  0_1464961145010_upload-8716e90d-606f-4d9e-8dcb-697cb95fbbd6
                  0_1464959045642_upload-85c16c8d-ac9f-40a9-a1cb-8464cc0bba0b
                  b.t.w. I added "parent" and "destination" node to the display to show where the meter is connected to. Destination is fixed in the sketch but the "parent" will change if the meter connects to another node (i.e. repeater)
                  To give you a real life impression . The transmitter (also nRF24L01+PA+LNA) is where the red arrow is behind two thick brick walls and a few trees. So, unless you live in a big mansion this should be sufficient range. Open field performance would be much better.
                  0_1464961025398_upload-b1ddebfd-d124-433f-a00e-6296301a71f1
                  For the rest of the tests I had a large variance in results. Some general observations:
                  • nRF24L01+PA+LNA without the "shielding" is pretty similar (and sometimes even worse) than the standard radio with the pcb antenna.
                  • all nRF24L01+ in SMD version have a comparable performance to the standard ones
                  • The standard radio's I have tested with a silk screen (white lines) and pin designation print on the back seem to be fine.
                    0_1464960195473_upload-9ff7ca2d-75e5-45b7-bea3-8824b6c19dd2
                  • The (around 18) radio's is have tested without silk screen (3 different batches) are either "bad" performers (few meters) or don't perform at all. ( I noticed earlier and already put them apart. I was able to sort out 6 that can be used for short distance.).
                    0_1464960320567_upload-b0a4caa9-7764-485b-a12e-8b9577dbe3e5
                  • I don;t have any "blob" samples..
                  I know this is far from scientific proof, but hope it gives you some guidance..
                  YveauxY 1 Reply Last reply
                  • OitzuO
                    OitzuO
                    Oitzu
                    wrote on last edited by Oitzu
                    @AWI there also 2 versions of the PA/LNA Modules out there. Which one do you tested?
                    • AWIA AWI
                      YveauxY
                      YveauxY
                      In the picture, these radios have the notorious 1242AF datecode on the chip (if you didn't take the pictures yourself, do you have the same date code?). I also have a batch of these and they perform very well!
                      • D
                        D
                        drock1985
                        Thanks @awi for this, might have to build one myself to test a potential bad batch of radios i have.
                        Do you need the LCD for this or is the data also print in serial?
                        Thanks,
                        My Projects
                        2 Door Chime Sensor
                        Washing Machine Monitor
                        • D drock1985
                          Thanks,
                          AWIA
                          AWIA
                          AWI
                          @drock1985 It will print the data on serial but not very well formatted. You don't need the LCD but it is easy to carry around the house. (a laptop too :smiley: but be aware of disturbances coming from the laptop i.e. Wifi ) I thought off blinking led's also. You can easily change the sketch, there is not much to it..
                          • OitzuO Oitzu
                            AWIA
                            AWIA
                            AWI
                            @Oitzu which versions do you relate to? I also have some with ceramic antenna (smd connection)
                            • B
                              B
                              boozz
                              @AWI
                              Kijken je buren niet gek op wanneer je met je meter rondloopt? :wink:
                              gr.
                              Boozz
                              • B boozz
                                @AWI
                                gr.
                                Boozz
                                AWIA
                                AWIA
                                AWI
                                @boozz my neighbors ask me every two weeks what I am doing and what all those strange looking things in my garden and on my roof are... :flushed:
                                • B
                                  B
                                  boozz
                                  @AWI
                                  And when you start explaining they look somewhat odd don't they?
                                  • mrc-coreM
                                    mrc-coreM
                                    mrc-core
                                    I'm having a problem in this part off the code:
                                    "present(counterChild, S_DIMMER, "Quality counter " NODE_TXT) ; // counter uses percentage from dimmer value"
                                    I'm getting this error:
                                    "exit status 1
                                    'present' was not declared in this scope"
                                    How can i fix this ?
                                    • mrc-coreM mrc-core
                                      "exit status 1
                                      @mrc-core sounds like you are using the stable (1.5.x) version of MySensors. This sketch requires the development version which is available on github
                                      • mrc-coreM
                                        mrc-coreM
                                        mrc-core
                                        Thanks for the quick reply.
                                        i'm going to change the versions :)
                                        • bjacobseB
                                          bjacobseB
                                          bjacobse
                                          Can this be extended to also measure NRF24l01 standby current? Maybe some "fake" modules have a high current consumption in stadnby mode, this could drain batteries quickly when used in battery operated devices
