  3. Over the air updates
87 Posts 15 Posters 62.6k Views 12 Watching
  • T ToSa
    @Damme
    I need to better understand the setup to think about what's going on. My take from the above:
    You have three nodes:
    • Gateway (address 0)
    • SD OTA Loader Node ?!? (address 254)
    • Sensor Node (address 34)
    Is that right?
    DammeD
    DammeD
    Damme
    Code Contributor
    @ToSa Yes, And I think I figured it out.. I by mistake changed BROADCAST_ADDRESS to GATEWAY_ADDRESS in the bootloader then I was playing around. Testing the correct version now.. :)
    T 1 Reply Last reply
    • DammeD Damme
      ToSa
      Code Contributor
      wrote on last edited by ToSa
      #62
      @Damme
      interesting setup :+1:
      to make it work with non-static addressed nodes you should probably keep the destination set to GATEWAY_ADDRESS for the REQUEST_ID call and only change afterwards.
      Never mind - looking at the line number you mentioned that's probably what you did :)
      DammeD 1 Reply Last reply
      • T ToSa
        @Damme
        DammeD
        DammeD
        Damme
        Code Contributor
        wrote on last edited by Damme
        #63
        @ToSa Now I remember why I changed some things in there. (broadcast to gateway)
        From the beginning I had problem getting it to talk with the GW. It only sends out
        <- 255,255,255,2,3,7,255, and gets no response, The GW tries to send but fails. (wierd..) (I dont have any relay nodes)
        This is with no modifications at all.
        0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0:
        0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,st=fail:0
        other packages send out works just fine.. (To other nodes)
        and the OTA bootloader can receive other packages
        Go
        -> 23,23,0,42,225,1,11,205,204,90,66,1,
        (from a temp / hum node)
        Any ideas how to fix this?
        • T ToSa
          Really really nice project !!!
          I worked on a similar setup about two years ago with different RF modules but didn't finish. Now I was about to restart and realized that the nRF24 modules are waaaaay less expensive. I just started adjusting the old code for the nRF24 modules I ordered when I found this great project. The raspberry PI for me is the way to go as I own two sitting almost idle and don't own a Vera.
          The one feature I'm missing after reading through the majority of the available documentation is over the air updates of the sensor node software. As this is one of the features I completed for my old design, I'll go ahead and try to port the bootloader and the RPi based state-less firmware server to work with the protocol and routing implemented here... if successful I'll post the results.
          If you worked already on over the air updates or you know somebody who did, please let me know and I'll focus my efforts on something else :-)
          Tobias
          DammeD
          DammeD
          Damme
          Code Contributor
          #64
          @ToSa I finally figured out why my OTA bootloader didn't read any answers from my GW (Both on I_FIND_PARENT and I_ID_REQUEST) - The answers came to quick! First I tried hardcode a delay 125ms on the GW and it worked, so I changed the code on send write to the following and now all messages arrive. Been testing it for a couple of reboots now. I'm using 5v (at 3.3v) and 16MHz
          edit; noticed it misses packages sometimes now but not close to 100% like before, more like 5% now. I'llinvestigate futher then I'm trying to upload data.
            static uint8_t sendAndWait(uint8_t reqType, uint8_t resType) {
            	msg.type = reqType;
            	for (uint8_t i = 0; i < 10; i++) {
            		sendWrite(msg);
            		for (uint8_t j = 0; j < 20; j++) {
            			for (uint8_t j = 0; j < 100; j++) {
            				uint8_t pipe;
            				boolean avail = available(&pipe);
            				wdt_reset();
            				if (avail && pipe<=6) {
            					read(rmsg.array,pipe);
            					if(!(mGetVersion(rmsg) == PROTOCOL_VERSION))
            						continue;
            					if (rmsg.destination == nc.nodeId) {
            						if (mGetCommand(rmsg) == C_INTERNAL) {
            							if (rmsg.type == I_FIND_PARENT_RESPONSE) {
            								if (rmsg.data[0] < nc.distance - 1) {
            									nc.distance = rmsg.data[0] + 1;
            									nc.parentNodeId = rmsg.sender;
            									eeprom_write_byte((uint8_t*)EEPROM_PARENT_NODE_ID_ADDRESS, nc.parentNodeId);
            									eeprom_write_byte((uint8_t*)EEPROM_DISTANCE_ADDRESS, nc.distance);
            						if ((mGetCommand(rmsg) == mGetCommand(msg)) && (rmsg.type == resType))
            							return 1;
            				delaym(1);
            	return 0;
          • DammeD
            DammeD
            Damme
            Code Contributor
            #65
            I had to put my project in the trash bin.. There is not enough RAM in the atmega328 to fit mysensors and SD-lib :) Tried 3 different versions..Too bad..! I could only transmit one package before SRAM got overrunned.
            YveauxY Z T 3 Replies Last reply
            • DammeD Damme
              YveauxY
              YveauxY
              @Damme Now do you get why I abandoned the MQTT implementation on the ATMega itself? ;-)
              • DammeD Damme
                Z
                Z
                Zeph
                wrote on last edited by Zeph
                #67
                If you want to stay with the AVR:
                ATMega1284 based: http://lowpowerlab.com/moteino/#whatisitMEGA $20+shipping. This can add a RF69* radio, but you could instead (or also) attach a nRF24L01+
                ATMega2560 based: http://www.ebay.com/itm/121391548557 $15 shipped This has even more lines broken out than the Arduino Mega2560. (If you don't mind the larger form, Arduino Mega2560 clones start under $14 shipped).
                Or you can switch to an embedded ARM system. Teensy 3.1 for $17+ship. STM32F103 board on eBay for $7. DUE clone on eBay for $18. STM Nucleo from distributors for $11+ship (eMed programmed).
                And of course you can use the Raspberry Pi or BeagleBone Black with a faster but power hungry ARM running Linux.
                • DammeD Damme
                  ToSa
                  Code Contributor
                  Did you try not using MySensors but the reduced nRF24 driver version I used for the bootloader itself? If the node does not need to do routing and is expected to only respond to one or two types of messages, that might be an option and is definitely smaller...
                  • greglG
                    greglG
                    gregl
                    Hi @ToSa
                    Do you know if your OTA Bootloader uses more flash mem on the atmega328 vs the Optiboot bootloader?
                    I have a sketch which needs Optiboot to fit and really hoping i can one day use your cool OTA stuff.
                    Looking at your github it seems MyOtaBootloader.hex is 9.36k whereas Optiboot v5,0a the optiboot_atmega328.hex is 1.418k ( but there is also a optiboot_atmega328.lst file at 19.778k - I dont know enough to know if this is part of the bootloader or if its just the source???)
                    Cheers,
                    Greg
                    • Z
                      Z
                      Zeph
                      OptiBoot fits in 1/2 KiB (the binary on-chip size, not the hex file).
                      The OTA Bootloader is obviously larger. If you are using close to 31.5KiB on an ATMega328p, it won't fit with any bootloader larger than OptiBoot.
                      Make sure you use the latest compiler - 1.5.7 seems to squeeze harder (smaller binary), and I presume 1.0.6 (which has also been upgraded to a newer compiler) will also do so.
                      How big does the compiler say your sketch is, at the end of a compile?
                      • greglG
                        greglG
                        gregl
                        I'll check when i get home tonight.
                        Very interesting about the new compiler. I'm pretty sure im using 1.0.5-r2, and i've recently begun using Atmel studio with Visual Micro addon - just soooo much better when dealing with long sketches!!!
                        Cheers,
                        Greg
                        • greglG gregl
                          Cheers,
                          Greg
                          ToSa
                          Code Contributor
                          @gregl the fuses determine how much space is reserved for the bootloader. I don't have the datasheet at hand but I think it varies from .5k to 4k. Optiboot is one of the smallest out there and the OTA bootloader consumes the full space because it needt to includs the (shrinked) wireless driver.
                          • Z
                            Z
                            Zeph
                            #73
                            I think the OTA bootloader which does not rely on any extra memory is a great option!
                            And I think the option of having external flash may work out well too. Sending an image to be written to SPI flash might not expand the application code as much (it already has the library). Then the bootloader just has to copy from SPI to application flash. I'm thinking that might make for a smaller total footprint, since there would be no need to fit 2 nRF libraries in the 32KiB flash - a trimmed down nRF library in the boot section plus the full nRF library in application section.
                            Of course, if the application gets hosed, you would not be able to do OTA bootloading and would have to physically access the node to recover, but if it's a matter of fitting or not fitting into FLASH, that might be a risk one is willing to take.
                            • Z Zeph
                              marceltrapmanM
                              marceltrapmanM
                              marceltrapman
                              Because I am sure that Flash memory will come in handy sooner or later I have added the Winbond W25X40 to the first version of my board already :).
                              Fulltime Servoy Developer
                              • tekkaT
                                tekkaT
                                tekka
                                just managed to optimize the OTA bootloader to under 2k - 2k more for sketches with OTA.
                                • tekkaT tekka
                                  ToSa
                                  Code Contributor
                                  @tekka
                                  That sounds great! Can you post your code (or share a pull request)? This would either allow us to free up the remaining space or to add encryption :)
                                  The only neck-breaker would be if any of the size reduction increases the risk for a bricked node that needs manual intervention (e.g. reset / power cycle etc.).
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    what is the current status of the OTA firmware updates? Is external flash necessary at all? Is someone working on it?
                                    Right now I am trying to get DualOptiboot from lowpowerlabs.com to work with my board, and an external flash / eeprom. But was wondering if it would be used at all.
                                    Then when I got the bootloader working, I need to test firmware updates, but the road is still long and windy to get there (at the moment, only have 1 hour here, and there, to work on the hardware)
                                    • tekkaT
                                      tekkaT
                                      tekka
                                      @tbowmo
                                      Did some work on the OTA bootloader: combined optiboot (for uploads via IDE / avrdude) + OTA bootloader with some major modifications. Current version is stable and works for regular OTA updates :)
                                      I will post the source once I find some spare time to clean and comment it.
                                      • klimK
                                        klimK
                                        klim
                                        hi, is your work on ota based on internal o external flash?
                                        • tekkaT
                                          tekkaT
                                          tekka
                                          @tbowmo
                                          internal: FW streaming via controller
