  3. how to get data from controller?
7 Posts 3 Posters 2.6k Views 3 Watching
  • vgaV
    vgaV
    vga
    is it possible that my sensor can call a value from the controller?
    Scenario:
    Flow Sensor sends the total liter to the controller, after rebooting the sensor total liters will be 0 again. So the idea is to get the last value from the controller at startup.
    I haven´t find anything like this. Is there a function?
    AWIA 1 Reply Last reply
    • vgaV vga
      Scenario:
      AWIA
      AWIA
      AWI
      @vga You can with the gw.request function. Many of the controllers seem to have in not implemented (eg. Domoticz). For your scenario it would be a good solution to store the values in EEPROM (gw.saveState() (be aware that it only takes byte values
      alexsh1A 1 Reply Last reply
      • AWIA AWI
        alexsh1A
        alexsh1A
        alexsh1
        @AWI Are you sure about Domoticz? I am sure that a pulse meter node is requesting value from Domoticz every time it powers up and it is working.
          gw.request(CHILD_ID, V_VAR1);
          attachInterrupt(INTERRUPT, onPulse, RISING);
          lastSend=lastPulse=millis();
        • alexsh1A alexsh1
          AWIA
          AWIA
          AWI
          @alexsh1 you van get data from some specific variables, text and switches, but not for all sensors.
          • alexsh1A
            alexsh1A
            alexsh1
            @vga What's your controller please?
            @AWI It covers most of the things, no? Electricity pulse meter and water pulse meter. I have not come up with another example when gw.request may be applied.
            • alexsh1A alexsh1
              AWIA
              AWIA
              AWI
              @alexsh1 you can use special variables to store and retrieve values. These are not available in the Domoticz interface.
              As far as I know only switches, text and a very domoticz specific custom value can be retrieved. You can find some discussion on the Domoticz forum.
              • AWIA AWI
                alexsh1A
                alexsh1A
                alexsh1
                @AWI yes I spoke to Rob about it some time ago. V_VAR is good enough for my needs. I just do not see why one would want more
