Problems with first sensors
@blebbens i think you can just put it over "define child id"
@Tore-André-Rosander said:
define child id"
I think so too.
These are probably just minor mistakes, changing from MySensors versions.
No, just add the define node id.
So, I have to delete CHILD_ID und change it to MY_NODE_ID?
Okay, reaching home today, perhaps. Hope, this works.
The old define, might become useless, but it wont be in the way either. It is your choice.
@blebbens I just replaced my RPi Gateway (the direct connection to GPIO) with the Serial Gateway, and the Repeater node you are seeing must be your gateway. Before i connected any nodes i got the same repeater node listed as hardware as you did, so it is probably your node that is the problem.
I have exactly same error after loading new sketch (sensebender with BMP085). It was working fine for few days and suddenly it doesn't work. After verting my modification it doesn't work. Clear EEPROM doesn't solve the problem. RFM69W and static ID.
Gateway work fine with other sensors (sensebender without mods).TSM:INIT TSM:RADIO:OK TSP:ASSIGNID:OK (ID=100) TSM:FPAR TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: !TSM:FPAR:FAIL !TSM:FAILURE TSM:PDT -
hi,
Was not at home for about 2 weeks now (driving home in 2 days), but AliExpress delivered 10 NRF2401 non-amplified without antenna. Is it still necessary to define low power and data rate of 1mbps?
#define MY_RF24_DATARATE RF24_1MBPSDo I have to set the node ID still manually?
I am trying to set up a Serial Gateway using the arduino IDE, this time using a NRF24L01 (not amplified, with build-in-antenna).
The Sketch compiles without any error, but afterwards the IDE tells me an error occurred: error during uploading the Sketch.
This occurs on compiling mysensors sketches.
Never had this Problem before. Now I get this error on all WIN10-machines.
Any tips ?
Any tips ?
No...it ... is... so... frustrating...
Arduino IDE works fine, but all things combined with mysensors are not working.
Tried to upload the ClearEepromConfig sketch to the serial gateway (nano, NRF24L01+). After compiling the sketch, the IDE is not able to upload the sketch to the nano (error on uploading the sketch). The same with other example mysensors sketches.
Tried this on 2 WIn10-PCs and 2 Macs.
Tried it severl times... uploading an empty sketch works fine.
Uploading a mysensors sketch ends with:Arduino: 1.6.10 (Windows 10), Board: "Arduino Nano, ATmega328" C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\blebb\OneDrive\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10610 -build-path "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\blebb\AppData\Local\Temp\arduino_modified_sketch_724130\GatewaySerial.ino" C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\blebb\OneDrive\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10610 -build-path "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\blebb\AppData\Local\Temp\arduino_modified_sketch_724130\GatewaySerial.ino" Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr Detecting libraries used... "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul" Generating function prototypes... "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\preproc\ctags_target_for_gcc_minus_e.cpp" "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\preproc\ctags_target_for_gcc_minus_e.cpp" Sketch wird kompiliert... "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp.o" Compiling libraries... Compiling library "SPI" Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\libraries\SPI\SPI.cpp.o Compiling library "MySensors" Compiling core... "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.S" -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.S.o" Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WInterrupts.c.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\hooks.c.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring.c.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_analog.c.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_digital.c.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.c.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_shift.c.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\CDC.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial0.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial1.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial2.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial3.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\IPAddress.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\PluggableUSB.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Print.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Stream.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Tone.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\USBCore.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WMath.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WString.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\abi.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\main.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\new.cpp.o "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.S.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WInterrupts.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\hooks.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_analog.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_digital.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_shift.c.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\CDC.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial0.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial1.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial2.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial3.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\IPAddress.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\PluggableUSB.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Print.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Stream.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Tone.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\USBCore.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WMath.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WString.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\abi.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\main.cpp.o" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\new.cpp.o" Linking everything together... "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.elf" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp.o" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\libraries\SPI\SPI.cpp.o" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/core\core.a" "-LC:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp" -lm "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.elf" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.eep" "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.elf" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.hex" Bibliothek SPI in Version 1.0 im Ordner: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI wird verwendet Bibliothek MySensors in Version 2.0.0 im Ordner: C:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors wird verwendet Der Sketch verwendet 13.982 Bytes (45%) des Programmspeicherplatzes. Das Maximum sind 30.720 Bytes. Globale Variablen verwenden 714 Bytes (34%) des dynamischen Speichers, 1.334 Bytes für lokale Variablen verbleiben. Das Maximum sind 2.048 Bytes. C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b57600 -D -Uflash:w:C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.hex:i Beim Hochladen des Sketches ist ein Fehler aufgetretenSorry, did not find any logfile. I just want to use mysensors. Bought so many sensors.
@blebbens I'm afraid, but your issue is not MySensors-related.
However, this may give further information:
For comparison, please post the same Arduino IDE log when uploading the blink example (not an empty sketch) and - if successful - confirm that you see a blinking led in a 1sec interval.blink example:
// the setup function runs once when you press reset or power the board void setup() { // initialize digital pin 13 as an output. pinMode(13, OUTPUT); } // the loop function runs over and over again forever void loop() { digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level) delay(1000); // wait for a second digitalWrite(13, LOW); // turn the LED off by making the voltage LOW delay(1000); // wait for a second } -
I downgraded from arduino.cc IDE 1.6.10 to 1.6.8. Now it uploads to the arduino nano without errors...
Seriell monitor (serial gateway):
0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0) 0;255;3;0;9;TSM:INIT 0;255;3;0;9;TSM:RADIO:OK 0;255;3;0;9;TSM:GW MODE 0;255;3;0;9;TSM:READY 0;255;3;0;14;Gateway startup complete. 0;255;0;0;18;2.0.0 0;255;3;0;9;No registration required 0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OKNow I want to connect the gw to my test VeraEdge. I followed the instructions, uploaded the .xml-files and created a device. But, in APPS/DEVELOP PPS/SERIAL PORT CONFIG" I can not find the via USB connected serial gateway. And, I do not know where to restart vera itself or the luup engine.
The dashboard shows this message: MySensors plugin : Choose the Serial Port. Under DEVICES the MySensors Plugin shows: Lua Startup Failure.
Using the IDE I saw the gw is working (see above). Why does Vera not recognize the gw on USB ?
Could someone help, please ?
