  3. dht22 with relay irregular measurement and operation
3 Posts 2 Posters 1.3k Views 3 Watching
  • DickD
    DickD
    Dick
    Double dht22 with relay is working good but the 2 DHT's give logging irregular
    H1= 50.20
    H0= 75.70
    H0= 75.80
    T1= 23.90
    H1= 50.30
    T0= 21.40
    H0= 75.70
    T0= 21.50
    H0= 75.90
    T0= 21.40
    H0= 75.80
    is it possible to measure in an sequence? Also the relay cannot be used by the button everytime I like, also immediate after the measurement it can be used. is there something wrong in the delay?
    Here the code as it is now
    #include <DHT.h>
    #include <Bounce2.h>
    #define CHILD_ID_HUM1 0
    #define CHILD_ID_HUM2 1
    #define CHILD_ID_TEMP1 3
    #define CHILD_ID_TEMP2 4
    // RelayWithActuator stuff
    #define RELAY_PIN  6  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  7  // Arduino Digital I/O pin number for button
    #define CHILD_ID 5   // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    bool state;
    MyMessage msg(CHILD_ID,V_LIGHT);
    #define HEARTBEAT       10
    unsigned int     timer = 0;
    // Sleep time between reads (in milliseconds)
    #define SLEEP_TIME      3000
    DHT* dht[2];
    byte sensorPin[2] = {3, 4};
    float lastTemp[2] = {0.0, 0.0};
    float lastHum[2] = {0.0, 0.0};
    boolean metric = true;
    //MyMessage msgHum(CHILD_ID_HUM1, V_HUM);
    //MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP);
      for (int i = 0; i < 2; i++)
        dht[i] = new DHT;
        dht[i]->setup(sensorPin[i]);
      gw.sendSketchInfo("HumidityAndRelay", "1.0");
      gw.present(CHILD_ID_HUM1, S_HUM);
      gw.present(CHILD_ID_HUM2, S_HUM);
      gw.present(CHILD_ID_TEMP1, S_TEMP);
       // Setup the button and Activate internal pull-up
      pinMode(BUTTON_PIN,INPUT_PULLUP);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_LIGHT);
      pinMode(RELAY_PIN, OUTPUT);
      state = gw.loadState(CHILD_ID);
      timer = 0;
      gw.process();
      timer++;
      if (timer > (SLEEP_TIME / HEARTBEAT))
        // Reset timer again and for the next timed loop
        timer = 0;
          delay(dht[i]->getMinimumSamplingPeriod());
          float temperature = dht[i]->getTemperature();
          if (isnan(temperature))
            Serial.print(F("Failed reading temperature from DHT"));
            Serial.println(i);
          else if (temperature != lastTemp[i])
            lastTemp[i] = temperature;
            if (!metric)
              temperature = dht[i]->toFahrenheit(temperature);
            //gw.send(msgTemp.set(temperature, i));
            Serial.print(F("T"));
            Serial.print(i);
            Serial.print(F("= "));
            Serial.println(temperature);
          float humidity = dht[i]->getHumidity();
          if (isnan(humidity))
            Serial.print("Failed reading humidity from DHT");
            Serial.println(i);
          else if (humidity != lastHum[i])
            lastHum[i] = humidity;
            //gw.send(msgHum.set(humidity, 1));
            Serial.print(F("H"));
            Serial.print(i);
            Serial.println(humidity);
      // Get the button update state (true if a change was detected)
      if (debouncer.update() && debouncer.read() == 0) {
          gw.send(msg.set(state?false:true), true); // Send new state and request ack back
      gw.wait(HEARTBEAT); //sleep a bit
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         gw.saveState(CHILD_ID, state);
         // Write some debug info
         Serial.print(message.sensor);
    • DickD
      DickD
      Dick
      somebody any suggestions?
      • gundark2G
        gundark2G
        gundark2
        wrote on last edited by gundark2
        So I'm new to all this, however anytime I get funky things going on when I have multiple sensors on a node I found that introducing a delay in between the readings helped smooth things out. Hopefully someone will correct me if I'm wrong, but I have had some luck with delays. Also I built one to control my hot tub and I found noise from the pump messed things up, de-coupling capacitors became my friend after that.
