  3. 💬 Insulated Whole House Fan
mysensorswhole house fan
72 Posts 11 Posters 23.1k Views 11 Watching
  • flyswiftlyF flyswiftly
    @rechin304 said:
    dht.setup(DHT_DATA_PIN);
    For what it's worth, I just went through a very long debug session trying to get a simple dht11 based sensor built and working. For reasons I don't even pretend to understand, the one thing I changed that allows it to work is changing the 'sleep' command in this section of the setup function to a 'wait' command.
    rechin304R
    rechin304R
    rechin304
    @flyswiftly thanks for trying,
    in my case still i do not see any data. What library do you use ? The one from MySensorsArduinoExamples-master.zip ?
    flyswiftlyF 1 Reply Last reply
    • rechin304R rechin304
      flyswiftlyF
      flyswiftlyF
      flyswiftly
      @rechin304
      Actually, no. It turns out when I looked through my IDE that I am using the prior version of the DHT library. That did also force me to comment out the read sensor line just to make it compile. Maybe the combination of the two changes is what does the trick. I hadn't made those changes together, so I missed the possible significance of this change:
      //  dht.readSensor(true);
      Running a diff on both the library you point out and the one I'm using shows that adding that bool to the readSendor function is the only code difference.
      rechin304R 1 Reply Last reply
        @rechin304
        rechin304R
        rechin304R
        rechin304
        @flyswiftly
        I also did that try an older version library for DHT and receive data. So conclusion is that on current (latest) DHT library for DHT11 is not working. Now I'm on a business trip to China for a week and With this chance i will buy there DHT 22 to be sure. I will be back in a week with conclusion.
        • rechin304R
          rechin304R
          rechin304
          wrote on last edited by rechin304
          #24
          I can confirm that DHT library that is in example do not work with DHT11 and DHT22 in my case, using other (older) library i can see data.
          petewillP 1 Reply Last reply
            petewillP
            petewillP
            petewill
            @rechin304 Sorry, just to make sure I understand, are you saying it works with a DHT22 or not? I may still be on an old library too.
            • petewillP petewill
              rechin304R
              rechin304R
              rechin304
              #26
              @petewill
              Works with DHT22 and other library (old one). I could not make it work withe one from example.
              I'm almost ready with build, waiting for final pieces. hope to receive them this week.
              one more ting i noticed is that clock is behind with 2minutes, so i need to check the code again.
              • rechin304R
                rechin304R
                rechin304
                I have an working prototype, see video https://goo.gl/photos/VSQeaevHh7UbbStr9
                Many thanks to @petewill for his work and inspiration.
                I will post final pictures when ready.
                • rechin304R
                  rechin304R
                  rechin304
                  Added new lead screw pitch of 2Mm that decrease open/close time from 3 minutes to 40 sec. see pics https://goo.gl/photos/mQvF1S9FrdNYPpdH9
                  buyed from here http://www.ebay.com/itm/322139119923?_trksid=p2057872.m2749.l2649&var=511054006707&ssPageName=STRK%3AMEBIDX%3AIT
                  for who is interested.
                    petewillP
                    petewillP
                    petewill
                    @rechin304 Awesome! Glad you got it working!!
                    L 1 Reply Last reply
                      L
                      L
                      lis610
                      @petewill Hi Pete
                      Just Start building the system and got an error at sketch verify.
                      "exit status 1
                      'class Adafruit_ST7735' has no member named 'setFont'"
                      • L lis610
                        @petewill Hi Pete
                        "exit status 1
                        petewillP
                        petewillP
                        petewill
                        @lis610 Sorry for the delay. Work has been very busy. I have attached the libraries I'm using. I was able to get it to compile when I just tested. https://drive.google.com/file/d/1wauxHRf5pyqLnBGsfCP8UPJQR1wNdkoF/view?usp=sharing
                        Let me know if you have issues with this.
                        • L
                          L
                          lis610
                          THANK YOU so much for sharing. Most of the errors gone, but one left (using Arduino v.1.8.5; MySensors v 2.3.0):
                          [C:\Users\BEAST\Documents\Arduino\Whole-House-Fan\code\New folder\WholeHouseFan2.0\WholeHouseFan2.0.ino: In function 'void presentation()':
                          WholeHouseFan2.0:197: error: 'TEMP_CHILD_NAME' was not declared in this scope present(TEMP_ID, S_TEMP, TEMP_CHILD_NAME);
                          exit status 1]
                          • L lis610
                            exit status 1]
                            petewillP
                            petewillP
                            petewill
                            @lis610 Sorry about that. I just fixed the code on the build page. Hopefully that will get you up and running :)
                            • L
                              L
                              lis610
                              Thank you. Did you upload the file for download?
                              • L lis610
                                petewillP
                                petewillP
                                petewill
                                @lis610 yes, I uploaded it to the page in the link at the top of this page.
                                • L
                                  L
                                  lis610
                                  Cannot locate file "WholeHouseFan2.0.ino"
                                  • L lis610
                                    petewillP
                                    petewillP
                                    petewill
                                    wrote on last edited by petewill
                                    #37
                                    @lis610 Strange. It disappeared. I added it again and just downloaded it so you should be good. Sorry for all the issues!
                                    • L
                                      L
                                      lis610
                                      Thank you. The box is ready. Next step connect all hardware. So far no luck with the display (KMR-1.8 SPI). What kind of display model you used in this project.
                                      • L lis610
                                        petewillP
                                        petewillP
                                        petewill
                                        @lis610 This is the display I used.
                                        http://www.ebay.com/itm/331443126874?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                                        • L
                                          L
                                          lis610
                                          Got the same display. It is working with Adafruit graphicstest example. I did not connect any components just display. If I ran the FAN sketch should be something showing on the display?
                                          Or need to connect everything?
