  3. Function repeater not working 2
4 Posts 3 Posters 1.5k Views 2 Watching
  • D
    D
    Daemon D
    wrote on last edited by Daemon D
    Topics Continued
    https://forum.mysensors.org/topic/4526/solved-function-repeater-not-working
    Again not work, writes NACK:1
    MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.0.1-beta
    TSM:INIT
    TSM:INIT:TSP OK
    TSF:ASID:OK,ID=3
    TSM:FPAR
    TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSF:MSG:READ,0-0-3,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSF:MSG:FPAR RES,ID=0,D=0
    TSF:MSG:FPAR OK,ID=0,D=1
    TSM:FPAR:OK
    TSM:ID
    TSM:ID:OK,ID=3
    TSM:UPL
    TSF:PING:SEND,TO=0
    TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    TSF:MSG:READ,0-0-3,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSF:MSG:PONG RECV,HP=1
    TSF:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    !TSF:MSG:SEND,3-3-0-0,s=255,c=0,t=18,pt=0,l=10,sg=0,ft=0,st=NACK:2.0.1-beta
    TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=OK:0
    TSF:MSG:READ,0-0-3,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:Alarm Sensor
    TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    TSF:MSG:SEND,3-3-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    TSF:MSG:SEND,3-3-0-0,s=2,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    TSF:MSG:SEND,3-3-0-0,s=3,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    TSF:MSG:SEND,3-3-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    TSF:MSG:SEND,3-3-0-0,s=5,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    MCO:REG:REQ
    TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    TSF:MSG:READ,0-0-3,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    MCO:PIM:NODE REG=1
    MCO:BGN:STP
    MCO:BGN:INIT OK,ID=3,PAR=0,DIS=1,REG=1
    TSF:MSG:READ,5-5-0,s=1,c=1,t=0,pt=7,l=5,sg=0:20.3
    TSF:MSG:REL MSG
    TSF:MSG:SEND,5-3-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.3
    TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    TSF:MSG:BC
    TSF:MSG:FPAR REQ,ID=6
    TSF:CHKUPL:OK,FCTRL
    TSF:MSG:GWL OK
    !TSF:MSG:SEND,3-3-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:1
    TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
    TSF:MSG:READ,5-5-0,s=3,c=1,t=16,pt=2,l=2,sg=0:0
    TSF:MSG:REL MSG
    TSF:MSG:SEND,5-3-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
    TSF:MSG:REL MSG
    TSF:MSG:READ,0-0-5,s=3,c=1,t=16,pt=2,l=2,sg=0:0
    TSF:MSG:REL MSG
    TSF:MSG:SEND,0-3-5-5,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
    TSF:MSG:REL MSG
    TSF:MSG:BC
    TSF:PING:SEND,TO=0
    TSF:CHKUPL:OK
    TSF:MSG:GWL OK
    TSF:MSG:BC
    Node 6 not working
    YveauxY tekkaT 2 Replies Last reply
    • D Daemon D
      Topics Continued
      TSM:INIT
      TSM:INIT:TSP OK
      TSF:ASID:OK,ID=3
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:ID:OK,ID=3
      TSM:UPL
      TSF:PING:SEND,TO=0
      TSF:CHKUPL:OK
      TSM:UPL:OK
      TSM:READY
      MCO:REG:REQ
      MCO:PIM:NODE REG=1
      MCO:BGN:STP
      TSF:MSG:REL MSG
      TSF:MSG:BC
      TSF:CHKUPL:OK,FCTRL
      TSF:MSG:GWL OK
      TSF:MSG:REL MSG
      TSF:MSG:REL MSG
      TSF:MSG:REL MSG
      TSF:MSG:REL MSG
      TSF:MSG:BC
      TSF:PING:SEND,TO=0
      TSF:CHKUPL:OK
      TSF:MSG:GWL OK
      TSF:MSG:BC
      Node 6 not working
      YveauxY
      YveauxY
      @Daemon-D You will have to supply more information if you want some help from the forum community.
      In the topic you're referring you indicated the issue was solved, as you got your setup working.
      If now, suddenly, it does not work anymore then please describe what has changed, supply serial logging of e.g. node nr 6 etc etc.
      • D Daemon D
        Topics Continued
        TSM:INIT
        TSM:INIT:TSP OK
        TSF:ASID:OK,ID=3
        TSM:FPAR
        TSM:FPAR:OK
        TSM:ID
        TSM:ID:OK,ID=3
        TSM:UPL
        TSF:PING:SEND,TO=0
        TSF:CHKUPL:OK
        TSM:UPL:OK
        TSM:READY
        MCO:REG:REQ
        MCO:PIM:NODE REG=1
        MCO:BGN:STP
        TSF:MSG:REL MSG
        TSF:MSG:BC
        TSF:CHKUPL:OK,FCTRL
        TSF:MSG:GWL OK
        TSF:MSG:REL MSG
        TSF:MSG:REL MSG
        TSF:MSG:REL MSG
        TSF:MSG:REL MSG
        TSF:MSG:BC
        TSF:PING:SEND,TO=0
        TSF:CHKUPL:OK
        TSF:MSG:GWL OK
        TSF:MSG:BC
        Node 6 not working
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        @Daemon-D Please provide the sketch for node 3, node 6 and the debug log from GW and node 6.
        • D
          D
          Daemon D
          How can I get a log with GW if Serial?
