  3. [Solved] Nodes ignore I_FIND_PARENT_RESPONSE message?
10 Posts 2 Posters 3.7k Views 1 Watching
  • b0rmannB
    b0rmannB
    b0rmann
    wrote on last edited by tekka
    2.0.1-beta
    mqtt client gateway (RPi) log:
    TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    TSF:MSG:BC
    TSF:MSG:FPAR REQ,ID=3
    TSF:CHKUPL:OK,FCTRL
    TSF:MSG:GWL OK
    TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    TSF:MSG:BC
    TSF:MSG:FPAR REQ,ID=2
    TSF:CHKUPL:OK,FCTRL
    TSF:MSG:GWL OK
    TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    TSF:MSG:BC
    TSF:MSG:FPAR REQ,ID=1
    TSF:CHKUPL:OK,FCTRL
    TSF:MSG:GWL OK
    TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    TSF:MSG:BC
    TSF:CHKUPL:OK,FCTRL
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:CHKUPL:OK,FCTRL
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:CHKUPL:OK,FCTRL
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:CHKUPL:OK,FCTRL
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:CHKUPL:OK,FCTRL
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:CHKUPL:OK,FCTRL
    TSF:MSG:GWL OK
    tekkaT 1 Reply Last reply
    • b0rmannB b0rmann
      2.0.1-beta
      TSF:MSG:BC
      TSF:CHKUPL:OK,FCTRL
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:CHKUPL:OK,FCTRL
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:CHKUPL:OK,FCTRL
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:CHKUPL:OK,FCTRL
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:CHKUPL:OK,FCTRL
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:CHKUPL:OK,FCTRL
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:CHKUPL:OK,FCTRL
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:CHKUPL:OK,FCTRL
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:CHKUPL:OK,FCTRL
      TSF:MSG:GWL OK
      tekkaT
      tekkaT
      tekka
      @b0rmann With this piece of information it's hard to guess - please provide additional information such as sketch of your node(s) + full debug logs.
      • b0rmannB
        b0rmannB
        b0rmann
        nopde #1 - only repeater...
        #define MY_SPECIAL_DEBUG
        #define MY_BAUD_RATE 9600
        #define MY_NODE_ID 1
        #define MY_PARENT_NODE_ID 0
        #define MY_RF24_CE_PIN 9
        #define MY_RF24_CS_PIN 10
        #define MY_RF24_CHANNEL 1
        #define MY_REPEATER_FEATURE
        void setup() {}
        void presentation() {
          sendSketchInfo("Repeater", "1.1");
        void loop() {}
        • tekkaT tekka
          tekkaT
          tekkaT
          tekka
          You really have to provide the requested information if you want to receive support from forum members.
          Please provide sketches of node 2 and 3 and their debug logs.
          b0rmannB 2 Replies Last reply
          • tekkaT tekka
            b0rmannB
            b0rmannB
            b0rmann
            @tekka
            node 1, 2 and 3 have logging off :(
            btw, problem not in the sketches.
            #define MY_NODE_ID 2
            #define MY_RF24_CE_PIN A0
            #include <OneWire.h>
            #define PIN_ONE_WIRE 4
            #define MAX_ATTACHED_DS18B20 4
            #define TEMPERATURE_PRECISION 11
            #define MIN_TIMEOUT 600000ul
            #define MAX_TIMEOUT 900000ul
            // DS18B20
            OneWire oneWire(PIN_ONE_WIRE);
            DallasTemperature ds(&oneWire);
            unsigned long ds_last_read;
            DeviceAddress ds18b20[MAX_ATTACHED_DS18B20];
            int numDS=0;
            MyMessage msg_t(0, V_TEMP);
            void sendDS ();
            void before() {
                ds.begin();
                numDS = ds.getDeviceCount();
            void setup() {}
                wait(100);
                sendSketchInfo("Podlaha", "3.0");
                for ( int i = 0; i < MAX_ATTACHED_DS18B20; i++ ) {
                    if ( ds.getAddress(ds18b20[i], i)) {
                        ds.setResolution(ds18b20[i], TEMPERATURE_PRECISION);
                        wait(100);
                        present(ds18b20[i][7], S_TEMP, "DS18B20");
                unsigned long time = millis();
                if ( ds_last_read && time - ds_last_read < MIN_TIMEOUT ) return;
                ds_last_read = time;
                ds.requestTemperatures();
                for ( int i=0; i < numDS && i < MAX_ATTACHED_DS18B20; i++ ) {
                    if ( ! ds18b20[i] ) continue;
                    float temperature = ds.getTempC(ds18b20[i]);
                    if ( temperature < -50 ) continue;
                    if ( temperature > 120 ) continue;
                    if ( temperature == 85 ) continue;
                    send( msg_t.setSensor(ds18b20[i][7]).set(temperature, 1), false );
            • b0rmannB
              b0rmannB
              b0rmann
              node #5, with older mysensors library (2.0.0) work correctly
              TSF:MSG:READ,5-5-0,s=3,c=1,t=24,pt=7,l=5,sg=0:678627392
              Sending message on topic: MyGW1-out/5/3/1/0/24
              TSF:MSG:READ,5-5-0,s=255,c=3,t=22,pt=5,l=4,sg=0:32231
              Sending message on topic: MyGW1-out/5/255/3/0/22
              • tekkaT tekka
                b0rmannB
                b0rmannB
                b0rmann
                log from node #3...
                MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.0.1-beta
                TSM:INIT
                TSM:INIT:TSP OK
                TSM:INIT:STATID,ID=3
                TSF:ASID:OK,ID=3
                TSM:FPAR
                TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSF:MSG:BC
                TSF:MSG:READ,5-5-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                TSF:MSG:BC
                TSF:MSG:BC
                !TSM:FPAR:NO REPLY
                TSM:FPAR
                TSF:MSG:BC
                !TSM:FPAR:NO REPLY
                TSM:FPAR
                !TSM:FPAR:NO REPLY
                TSM:FPAR
                !TSM:FPAR:FAIL
                TSM:FAILURE
                TSM:FAILURE:PDT
                • b0rmannB b0rmann
                  log from node #3...
                  TSM:INIT
                  TSM:INIT:TSP OK
                  TSF:ASID:OK,ID=3
                  TSM:FPAR
                  TSF:MSG:BC
                  TSF:MSG:BC
                  TSF:MSG:BC
                  !TSM:FPAR:NO REPLY
                  TSM:FPAR
                  TSF:MSG:BC
                  !TSM:FPAR:NO REPLY
                  TSM:FPAR
                  !TSM:FPAR:NO REPLY
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  TSM:FAILURE
                  TSM:FAILURE:PDT
                  tekkaT
                  tekkaT
                  tekka
                  @b0rmann It's hard to analyse your problem if you do not provide the requested information. Please provide these information, in this order:
                  (1) Are all nodes + GW running the latest dev version, i.e. 2.0.1-beta?
                  (2) GW sketch
                  (3) GW full debug log
                  (4) node 2 full debug log
                  b0rmannB 1 Reply Last reply
                  • tekkaT tekka
                    (2) GW sketch
                    b0rmannB
                    b0rmannB
                    b0rmann
                    yes, it's too hard :)
                    1. yes
                    2. gw nave not "sketch", it's raspberry pi port of gw
                    problem solved by using external power source on radio (instead 3v3 raspberry pi output)
                    • b0rmannB b0rmann
                      1. yes
                      tekkaT
                      tekkaT
                      tekka
                      @b0rmann ok, great :)
