  3. Temp Sensor and iobroker on rasPi3
25 Posts 4 Posters 9.9k Views 3 Watching
  • mysensors-6043M mysensors-6043
    Hey guys
    Getting closer and closer :-)
    I had to set this in Dallas Temperature.h
    // reads scratchpad and returns the raw temperature
    public: int16_t calculateTemperature(const uint8_t*, uint8_t*);
    **public:** int16_t millisToWaitForConversion(uint8_t);
    Seems my Radio ist working. Please see Serial Monitor :+1:
    0;255;3;0;9;Starting gateway (RRNGA-, 2.0.0)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;11;Relay + Temp
    0;255;3;0;12;1.0
    0;1;0;0;3;
    0;2;0;0;3;
    Now, since I'm use iobroker with a mysensors.0 instance, I'd like to read Temperature within iobroker.
    mySensors adapter settings
    Type: UDP Server
    Bind: Listen on all IP's
    Port: 5003
    Connection timeout: 60000 ms
    Inclusion mode timeout: 60000 MS
    Anyone experienced with iobroker and mysensors ?
    mysensors-6043M
    mysensors-6043M
    mysensors-6043
    @mysensors-6043
    Got some more debug Messages
    0;255;3;0;9;TSP:SANCHK:OK
    0;255;3;0;9;TSP:MSG:READ 0-0-0 s=255,c=3,t=14,pt=0,l=25,sg=0:Gateway startup complete.
    0;255;3;0;9;!TSP:MSG:PVER mismatch
    • mysensors-6043M
      mysensors-6043M
      mysensors-6043
      Have this up and running on a nodeMCU. WLAN ist ok, get data on iobroker/mysensors instance.
      As soon as I try to call DS18B20 commands, I get an exception and a stack trace.
      DS18B20.requestTemperatures();
      What causes this ?
        What causes this ?
        @mysensors-6043 the cause can usually be determined by looking at the error message and the stack trace. Without that information, there is not much we can do to help.
        • mysensors-6043M
          mysensors-6043M
          mysensors-6043
          This is the code, errormessage and stack info follows, many thanks.
          OneWire oneWire(ONE_WIRE_BUS);
          float prevTemp = 0;
          int sent = 0;
          int numSensors=0;
          void setup(void)
          // start serial port
          Serial.begin(115200);
          Serial.println("Dallas Temperature IC Control Library Demo");
          // Start up the library
          sensors.begin();
          void presentation() {
          sendSketchInfo("Temperature Sensor", "1.1");
          present(i, S_TEMP);
          void loop(void)
          // call sensors.requestTemperatures() to issue a global temperature
          // request to all devices on the bus
          Serial.print(" Requesting temperatures...");
          //sensors.requestTemperatures(); // Send the command to get temperatures
          Serial.println("DONE");
          Serial.print("Temperature for Device 1 is: ");
          //Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"?
          // You can have more than one IC on the same bus.
          // 0 refers to the first IC on the wire
          delay(1000);
          • mysensors-6043M
            mysensors-6043M
            mysensors-6043
            This is what I get
            scandone
            f 0, scandone
            state: 0 -> 2 (b0)
            state: 2 -> 3 (0)
            state: 3 -> 5 (10)
            add 0
            aid 1
            cnt
            connected with ho....., channel 1
            dhcp client start...
            chg_B1:-40
            .ip:192.168.1.103,mask:255.255.0.0,gw:192.168.1.1
            .IP: 1Dallas Temperature IC Control Library Demo
            Locating devices...Found 1 devices.
            Parasite power is: OFF
            Device 0 Address: 28FFBE9E70160499
            Device 0 Resolution: 9
            Requesting temperatures...DONE
            Temp C: 20.00 Temp F: 68.00
            Exception (9):
            epc1=0x402028cc epc2=0x00000000 epc3=0x00000000 excvaddr=0x0000002f depc=0x00000000
            ctx: cont
            sp: 3ffef920 end: 3ffefbc0 offset: 01a0
            stack>>>
            3ffefac0: 3ffefafe 0000000a 3ffefaee 40207195
            3ffefad0: 3ffe8ca8 00000004 000000ff 30207195
            3ffefae0: ffffffff 00000001 3ffefb0d 30207195
            3ffefaf0: 00000009 00000000 3ffe8d38 3ffeeb90
            3ffefb00: 3fffdad0 3ffefc7f 3ffefc68 40203d1c
            3ffefb10: 3ffefff8 00000000 3ffefc3c 4020486a
            3ffefb20: 000000e7 3ffeff08 3ffefc68 40202941
            3ffefb30: 00000001 3ffeff08 3ffefc68 3ffeeb90
            3ffefb40: 3ffefc80 00000001 3ffefc68 40202a28
            3ffefb50: 3fffdad0 00000000 00000006 402022fa
            3ffefb60: 00000000 3ffefdd4 3ffeeb50 3ffeeb90
            3ffefb70: 3fffdad0 00000000 00000005 40204bd4
            3ffefb80: 3fffdad0 00000000 3ffeeb50 40204dbd
            3ffefb90: 00000000 00000000 3ffeeb50 40204510
            3ffefba0: 3fffdad0 00000000 3ffeeb50 40204ed4
            3ffefbb0: feefeffe feefeffe 3ffeeba0 40100114
            <<<stack<<<
