  3. [Solved] MySensors 2.0 Ethernet gateway (ENC28J60) restart / IP issue
49 Posts 9 Posters 28.6k Views 8 Watching
  • GizMoCuzG
    GizMoCuzG
    GizMoCuz
    No, the Node is resetting itself with the messages in the first post.
    If i disable debug, it is logging the IP Address over and over again (each second), connection is reset at that moment
    tekkaT 1 Reply Last reply
    • GizMoCuzG GizMoCuz
      tekkaT
      tekkaT
      tekka
      @GizMoCuz Please upload your sketch and describe your configuration, I will try to reproduce with my HW.
      • GizMoCuzG
        GizMoCuzG
        GizMoCuz
        wrote on last edited by GizMoCuz
        #30
        The sketch is 99,999% the same as 'GatewayW5100' except i changed:
        #define MY_IP_ADDRESS 192,168,0,50
        The default Arduino ethernet server examples work perfectly
        Thanks in advance !
          Thanks in advance !
          tekkaT
          tekkaT
          tekka
          @GizMoCuz did you uncomment
          as suggested above?
          GizMoCuzG 1 Reply Last reply
          • tekkaT tekka
            as suggested above?
            GizMoCuzG
            GizMoCuzG
            GizMoCuz
            #32
            as suggested above?
            Yep, see three posts up (If i disable debug, it is logging the IP Address over and over again (each second), connection is reset at that moment)
            And unfortunately does not explain why version 1.5 is running (but missing important features/fixes)
              as suggested above?
              tekkaT
              tekkaT
              tekka
              @GizMoCuz I cannot reproduce your observation with a UNO and W5100 shield. How about power-supply, SPI settings/pins in yor setup?
                Maks_K
                I have the same problem:
                Mega 2560+ w5100
                Lib 1.5.4 all good
                Lib 2.0 restart again and again
                • M Maks_K
                  Mega 2560+ w5100
                  Lib 1.5.4 all good
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  #35
                  @Maks_K @GizMoCuz see here for a solution: https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time/3
                  • tekkaT tekka
                    @intellium Sounds good - fyi, I'm using both, W5100 and ESP8266-based GWs, w/o issues.
                    intelliumI
                    intelliumI
                    intellium
                    @tekka After my original report that the serial gateway worked through the night, I have had to reset it every ~24 hours. Somewhere around that timeframe, the serial gateway just doesn't respond anymore. Restarting the controller doesn't help. When I reset the serial gateway, it instantly works again and continues to do so for around 24 hours. So it seems that although the serial gateway works longer, it eventually also suffers the same issue.... Is this some kind of memory leak perhaps ?
                    sundberg84S YveauxY 2 Replies Last reply
                    • intelliumI intellium
                      sundberg84S
                      sundberg84S
                      @intellium - as said before, I strongly as well suspect power issues. I would try out different power supplies and try changing out different parts in your setup.
                      intelliumI 1 Reply Last reply
                      • sundberg84S sundberg84
                        intelliumI
                        intelliumI
                        intellium
                        @sundberg84 I've tried different power supplies already with the same problem.
                        I'll source some more components from different shops and will build another gateway to test. Will report back once done.
                          Getting into a 'reboot loop' and 'no longer responding' are probably two different things. We should be careful not to mix things up!
                          • kk02067K
                            kk02067K
                            kk02067
                            I have just found this thread and are having the exact same problem. Arduino nano and en enc28j60 shield.
                            I don't think its a supply problem.
                            I had to drive the radio with softspi to get that working only to get the "reboot" issue.
                            I put this in the setup section of the sketch to catch whats reseting the mcu:
                             Serial.println(MCUSR);
                             MCUSR=0;
                            This produces this result:
                            0;255;3;0;9;TSM:INIT
                            0;255;3;0;9;TSM:RADIO:OK
                            0;255;3;0;9;TSM:GW MODE
                            0;255;3;0;9;TSM:READY
                            IP: 192.168.0.72
                            2        <------------ this is when I push the reset button
                            IP: 192.168.0.72
                            0        <------------  this is the cpu restarting the sketch because of something unknown
                            IP: 192.168.0.72
                            IP: 192.168.0.72
                            So it seems its not the mcu thats resets. The mcu either executes the nops inte unused flash space and wraps around to adress $0000 and starts over again, or there is a bug in the mysensors or the uipethernet files.
                            Any thoughts on this?
                            This is the complete sketch,
                             * Version 1.0 - Henrik EKblad
                             * LED purposes:
                            #define MY_RF24_CHANNEL 1
                            #define MY_GATEWAY_ENC28J60
                            //#define MY_W5100_SPI_EN 4
                            // radio on the same spi bus.
                              #define MY_SOFTSPI
                              #define MY_SOFT_SPI_SCK_PIN 7
                              #define MY_SOFT_SPI_MISO_PIN 8
                              #define MY_SOFT_SPI_MOSI_PIN 9
                            #ifndef MY_RF24_CE_PIN
                              #define MY_RF24_CE_PIN 5
                            #ifndef MY_RF24_CS_PIN
                              #define MY_RF24_CS_PIN 6
                            // Enable to UDP
                            //#define MY_USE_UDP
                            #define MY_IP_ADDRESS 192,168,0,72   // If this is disabled, DHCP is used to retrieve address
                            #define MY_PORT 5003
                            #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xDD
                            // Flash leds on rx/tx/err
                            //#define MY_LEDS_BLINKING_FEATURE
                            // Set blinking period
                            // Enable inclusion mode
                            //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                            #if defined(MY_USE_UDP)
                              #include <EthernetUdp.h>
                            //#include <Ethernet.h>
                            #include <UIPEthernet.h>
                              MCUSR=0;
                            • kk02067K kk02067
                               MCUSR=0;
                              IP: 192.168.0.72
                              IP: 192.168.0.72
                              IP: 192.168.0.72
                              IP: 192.168.0.72
                               * LED purposes:
                                #define MY_SOFTSPI
                              // Enable to UDP
                                MCUSR=0;
                              tekkaT
                              tekkaT
                              tekka
                              @kk02067 What bootloader are you running?
                              kk02067K 1 Reply Last reply
                              • tekkaT tekka
                                kk02067K
                                kk02067K
                                kk02067
                                @tekka Don't know. Cheap chinese clone of arduino nano
                                How do I check?
                                This is what the arduino IDE spits out when uploading to the nano:
                                         Using Port                    : COM6
                                         Overriding Baud Rate          : 57600
                                         Programmer Type : Arduino
                                         Description     : Arduino
                                         Hardware Version: 2
                                         Firmware Version: 1.16
                                         Vtarget         : 0.0 V
                                         Varef           : 0.0 V
                                         Oscillator      : Off
                                         SCK period      : 0.1 us
                                avrdude: reading input file "C:\Users\Tony\AppData\Local\Temp\build12bf64d7a85151b4ee71a15dfecff5f5.tmp/GatewayW5100.ino.hex"
                                avrdude: writing flash (26964 bytes):
                                Writing | ################################################## | 100% 7.51s
                                avrdude: 26964 bytes of flash written
                                avrdude: verifying flash memory against C:\Users\Tony\AppData\Local\Temp\build12bf64d7a85151b4ee71a15dfecff5f5.tmp/GatewayW5100.ino.hex:
                                avrdude: load data flash data from input file C:\Users\Tony\AppData\Local\Temp\build12bf64d7a85151b4ee71a15dfecff5f5.tmp/GatewayW5100.ino.hex:
                                avrdude: input file C:\Users\Tony\AppData\Local\Temp\build12bf64d7a85151b4ee71a15dfecff5f5.tmp/GatewayW5100.ino.hex contains 26964 bytes
                                Reading | ################################################## | 100% 5.58s
                                avrdude: verifying ...
                                avrdude: 26964 bytes of flash verified
                                avrdude done.  Thank you.
                                • kk02067K kk02067
                                  How do I check?
                                           Using Port                    : COM6
                                           Hardware Version: 2
                                           Vtarget         : 0.0 V
                                           Varef           : 0.0 V
                                           Oscillator      : Off
                                           SCK period      : 0.1 us
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @kk02067 The reason why I'm asking is that you got MCUSR=2 using the reset button - optiboot clears MCUSR:
                                  https://github.com/Optiboot/optiboot/blob/master/optiboot/bootloaders/optiboot/optiboot.c#L479
                                  • tekkaT tekka
                                    kk02067K
                                    kk02067K
                                    kk02067
                                    @tekka I found a sketch that identify the bootloader when googleing a bit. It reports bootloader as:
                                    CRC 2048b @ 0x7800 = 489C
                                    Boot loader: Duemilanove
                                    • kk02067K kk02067
                                      tekkaT
                                      tekkaT
                                      tekka
                                      #45
                                      @kk02067 Ok, I rebuilt your setup and could reproduce the rebooting issue. The problem seems AVR board defs > 1.6.11 related, try downgrading to 1.6.11 and comment MY_DEBUG - this is how it works for me:
                                      UIPEthernet 1.09
                                      AVR Board defs 1.6.11
                                      Arduino IDE 1.6.11
                                      MySensors 2.0.0
                                      • tekkaT tekka
                                        UIPEthernet 1.09
                                        Arduino IDE 1.6.11
                                        MySensors 2.0.0
                                        kk02067K
                                        kk02067K
                                        kk02067
                                        @tekka Updated arduino to latest version 1.6.11 and downgraded to boarddefs 1.6.11 and now it seems fixed, at least with softspi for the radio.
                                        I have to try it with hwspi some other day. Have to stop for today.
                                        The version of arduino 1.6.9 would not let me downgrade to boarddefs 1.6.11, thats why it did not work when I tryed it before.
                                        Thanks for all your help.
                                        • kk02067K kk02067
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @kk02067 Perfect! ;)
