  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 109.3k Views 40 Watching
    @LaMB95 are you using a Pro Mini 5V 16MHz or Pro Mini 3.3V 8MHz?
    If the wrong variant is selected in the Arduino IDE, all timings will be off, including the timings for serial communication.
    LaMB95L
    LaMB95L
    LaMB95
    @mfalkvidd
    I have an arduino pro mini 5V. But I have attached a breakout CP2102 usb connection to it. On the board there is a 3.3V point which I have plugged in as Vcc to the NRF24L01+ module.
    To upload the code I have selected the 5V 16Mhz as processor.
    • LaMB95L LaMB95
      @mfalkvidd
      @LaMB95 Interesting. I have never seen a 5V Pro Mini with 3.3V output. Where did you get it?
      Try different serial speeds in the serial monitor and see if you get something readable.
      LaMB95L 1 Reply Last reply
      • F
        F
        flopp
        wrote on last edited by flopp
        #63
        This post is deleted!
        mfalkviddM T 2 Replies Last reply
        • F flopp
          [[topic:post-is-deleted]]
          • F flopp
            tboha
            @flopp :
            No, it isn't that easy.
            To improve your NRF, please have a look at https://forum.mysensors.org/topic/1851/extending-range-of-regular-nrf24l01.
            I tried solution Nr. 2. It is easy to do and cheap. Improvements are noticeable but not dramatically.
            In regard to effort it is worth trying.
            If you aimed at changing NRF's frequency - no this is not possible at all. Base frequencies are selected within the chip itself and antenna resonant frequency has to match oscillator frequency.
              LaMB95L
              LaMB95L
              LaMB95
              @mfalkvidd Haha not really a 3.3 output I changed its input voltge to 3.3 hoping it would work.
              But nevertheless I managed to solve the issue.
              It seems to be an error in the Hardware serial.
              Refer: http://forum.arduino.cc/index.php?topic=46458.0
              The code bhagman has posted worked !
              • LaMB95L LaMB95
                LaMB95L
                LaMB95L
                LaMB95
                @mfalkvidd
                It worked yesterday now I am back to the same problem.
                What a wonder !
                • N
                  N
                  napo7
                  Hi !
                  It seems that the FRM69 library set the IRQ pin as optionnal. Can someone confirm that the IRQ pin is mandatory ?
                  tekkaT 1 Reply Last reply
                  • N napo7
                    Hi !
                    tekkaT
                    tekkaT
                    tekka
                    @napo7 yes, it is mandatory since the driver is IRQ-dependent
                    • N
                      N
                      napo7
                      wrote on last edited by napo7
                      #70
                      Well, I had a look in RFM69 driver, and it seems that the interrupts handlers are never sets ?
                      Am I wrong ?
                      Edit : In facts, DIO0 is not used as an Interrupt source in RFM69 driver : it's a pin that informs the library that, either, a packet has been received, or , the frame we try to send has been sent.
                      So, the code doesn't use interrupts, but this pin is more a "Data available" pin.
                      • scalzS
                        scalzS
                        @napo7
                        so, if data available or data sent, this can be an interrupt source for an mcu ;)
                        It's enabled in the init there https://github.com/mysensors/MySensors/blob/development/drivers/RFM69/RFM69.cpp#L123
                        • N
                          N
                          napo7
                          Yes I noticed it !
                          Since it didn't mention IRQ pin, I didn't seen it at first !
                          What misleaded me, is that on LowPowerLab forums, some users says that you can absolutely discard this interrupt and poll the radio frequently to ask if a packet is available.
                          • A
                            A
                            adamp237
                            I had this working perfectly on my Arduino Uno. I soldered it up to my Arduino Nano and it seems to work ok, but I'm not getting any data sent. The serial says it's connected OK but never sends any motion 1s or 0s. My MQTT server shows the following: Client mosqsub/3449-raspberryp received PUBLISH (d0, q0, r0, m0, 'mygateway1-out/255/255/3/0/3', ... (0 bytes))
                            Any idea what is going on? I've tested the motion sensor separately and that is sending a high value to pin 3 no worries.
                            gohanG 1 Reply Last reply
                            • A adamp237
                              @adamp237
                              Enable debug on the node and add some more serial prints in order to see better in detail where the code runs and where not
                              • S
                                siddmon
                                where can I find the picture for connecting NRF to arduino uno?
                                • S siddmon
                                  @siddmon to my knowledge, Arduino Uno the same pins as on Arduino Nano, Arduino Pro Mini and all other atmega328-based Arduino boards.
                                  • S
                                    siddmon
                                    @mfalkvidd Thanks and yes, they have the same pins, I didn't see Uno in the table so I google it and got incorrect instructions.
                                    Now that I used the same as nano my node seems work :)
                                    • S siddmon
                                      @siddmon great! Thanks for reporting back.
                                      • nitroburnN
                                        nitroburnN
                                        nitroburn
                                        Little mistake in the text, I don't think dupont cables are made of bread.
                                        "the antenna need to be single core inside, only one wire, not multi-wire breaded like you can find in common dupont cable (not good for antenna.)"
                                        should be
                                        "The antenna need to be single core inside, only one wire, not multi-wire braided like you can find in common dupont cable (not good for antenna)"
                                        • nitroburnN nitroburn
                                          should be
                                          #80
                                          @nitroburn thanks! I've updated the page.
                                          nitroburnN 1 Reply Last reply
