  2. Announcements
  • R Reza
    @marceloaqno
    i am beginner and i can not turning off the UART functioning. . . also on some board usb port after power off/on lost and i should disconnect/connect cable... i test your steps serial gateway with raspberry and GPIO with virtual usb serial . and i see this problem solve and after power off/on gateway is connect .
    i suggest that you add this commands to page of rs485 gateway step by step and update this .
    (https://www.mysensors.org/build/rs485)
    I thank you for hard working and trying
    b0rmannB
    b0rmannB
    b0rmann
    wrote on last edited by b0rmann
    #301
    @Reza
    if you want use rpi /dev/ttyAMA0 for rs485 gateway -
    1. remove string "console=serial0,115200" from /boot/cmdline.txt
    2. add strings "enable_uart=1" and "dtoverlay=pi3-disable-bt" to /boot/config.txt (only on rpi3)
    3. reboot raspi
    R 1 Reply Last reply
    • M marceloaqno
      @marceltrapman
      If you use the --my-controller-ip-address= option, the gateway will act as a client and attempt to conect to the supplied ip and port. If you want the gateway to open port 5003, omit this option.
      marceltrapmanM
      marceltrapmanM
      marceltrapman
      wrote on last edited by marceltrapman
      #302
      @marceloaqno nice, working now :+1:
      Thank you...
      Fulltime Servoy Developer
      • b0rmannB b0rmann
        @Reza
        3. reboot raspi
        R
        R
        Reza
        @b0rmann
        thank you friend , but i am sorry i am very beginner in raspberry pi . because i use vera before and with raspberry and orange pi i use recently. so i need a full steps for a rs485 gateway(wiring and commands . . .) i dont know what is ttyAMA0 ! i use a serial gateway with usb port with raspberrypi 3 but i have some problem , but with a raspberrypi gateway and use a virtual serial port (ttyUSB020) all of my problem resolve. but i have problem with wireless. so i want have a wiring network. i want a full steps for setup a rs485 module with raspberrypi 3(wiring and steps for install...) thank you for help
        M 1 Reply Last reply
        • AndurilA
          AndurilA
          Anduril
          Do I read that correctly, does this gateway also gives a ethernet link to a serial-only controller? How do I have to configure ip and port? In the build section I see no option to set them.
          T 1 Reply Last reply
          • E ericvdb
            use sudo ;)
            LaMB95L
            LaMB95L
            LaMB95
            @LaMB95 said:
            @ericvdb
            Okay what could be the problem? :3
            • R Reza
              @b0rmann
              marceloaqno
              Code Contributor
              @Reza There are many guides on the web teaching how to connect and use rs485 with the RPi. I recommend you start with them and when you are sure it is working, you add MySensors to the equation.
              • M marceloaqno
                R
                R
                Reza
                ok thank you :(
                • AndurilA Anduril
                  Tag
                  @Anduril
                  you will get all the build options for the mysgw with the command
                  ./configure -help
                  Here you can configure all options like serial and ethernet
                  • AndurilA
                    AndurilA
                    Anduril
                    just cloned and read the --help, but still I don't know how to use.
                    To make it a litte less abstract: I have a ethernet gateway (ESP8266) running at 192.168.38.19 with port 5003 to connect to. I want to have this accessible by a serial-only controller on the raspberry.
                    I tried to do this config and make afterwards, but starting gave only FAILs...
                    ./configure --my-gateway=ethernet --my-controller-ip-address=192.168.38.19 --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
                    ~/MySensors$ sudo ./bin/mysgw -d
                    mysgw: Starting gateway...
                    mysgw: Protocol version - 2.1.0
                    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.0
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: !TSM:INIT:TSP FAIL
                    mysgw: TSM:FAIL:CNT=1
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:FAIL:RE-INIT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:CNT=2
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:CNT=3
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:CNT=4
                    mysgw: TSM:FAIL:PDT
                    I think my config is wrong and it tries to connect to a nrf24 at the rpi. So what's the correct config for my case?
                    Thanks in advance.
                    gohanG 1 Reply Last reply
                    • AndurilA Anduril
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:PDT
                      Thanks in advance.
                      @Anduril
                      Why are you using an esp8266 as a serial gateway? Wouldn't it be easier to use a normal UNO?
                      • AndurilA
                        AndurilA
                        Anduril
                        I'm using a ESP8266 as ethernet gateway and want to have this connected as virtuall serial port to my raspberry pi so my controller can connect to that.
                        • lakshmcL
                          lakshmcL
                          lakshmc
                          I using RPi2 and NRF24 for this. I followed the instructions, to clone the repo, and then added config
                          ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-transport=nrf24
                          make
                          when i run with sudo ./bin/mysgw -d, it is failing to connect to MQTT. Can you please help?
                          mysgw: TSF:LRT:OK
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: TSM:INIT:TSP OK
                          mysgw: TSM:INIT:GW MODE
                          mysgw: MCO:REG:NOT NEEDED
                          mysgw: MCO:BGN:STP
                          mysgw: MCO:BGN:INIT OK,TSP=1
                          mysgw: Attempting MQTT connection...
                          mysgw: connect: Connection refused
                          mysgw: failed to connect
                          P 1 Reply Last reply
                          • AndurilA Anduril
                            @Anduril
                            Have you aver considered Using the GatewayESP8266MQTTClient? What controller are you trying to connect?
                            • AndurilA
                              AndurilA
                              Anduril
                              I use pimatic which does not have a native compatibility to ethernet or mqtt. Thats why my question came up on how to configure it to do this...
                              Building a Raspberry Pi Gateway:
                              If you are running a controller on the Raspberry Pi that doesn't support communication with the gateway through ethernet, you can use a virtual serial port:
                              ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
                              • AndurilA Anduril
                                @Anduril you might be able to use nodered or socat to convert the tcp connection to a serial port.
                                https://linux.die.net/man/1/socat
                                https://nodered.org/
                                • AndurilA
                                  AndurilA
                                  Anduril
                                  that's what I tried in the past and am using now (socat), but it does not reconnect and has some other drawbacks. Reading of an officially supported way sounded interesting
                                  • lakshmcL lakshmc
                                    make
                                    mysgw: TSF:LRT:OK
                                    mysgw: TSM:INIT
                                    mysgw: TSF:WUR:MS=0
                                    mysgw: MCO:BGN:STP
                                    P
                                    P
                                    pete1450
                                    wrote on last edited by pete1450
                                    #317
                                    @lakshmc Make sure you don't have the daemon running already
                                    If not, I'm getting the same problem on the 2.1.1 that was just released. 2.1.0 was working "fine"(besides my suspecting a bug that doesn't let any inclusion happen, hence I tried the new version). Time to go back to the serial gateway right into the vera.
                                    • P pete1450
                                      marceloaqno
                                      Code Contributor
                                      @pete1450 @lakshmc
                                      Make sure you are not using an old version of mosquitto (or any other broker you're using):
                                      $ mosquitto -h
                                      mosquitto version 1.4.10 (build date 2016-09-20 11:02:07-0600)
                                      It's working fine with the 2.1.1 release:
                                      [alarm@pi3 mysgw]$ sudo ./bin/mysgw -d
                                      mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: MCO:BGN:STP
                                      mysgw: connected to 127.0.0.1
                                      mysgw: MQTT connected
                                      mysgw: Sending message on topic: mysensors-out/0/255/0/0/18
                                      mysgw: TSF:MSG:READ,2-2-0,s=1,c=1,t=17,pt=7,l=5,sg=0:108.12
                                      mysgw: TSF:MSG:ACK REQ
                                      mysgw: TSF:MSG:SEND,0-0-2-2,s=1,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:108.12
                                      mysgw: Sending message on topic: mysensors-out/2/1/1/0/17
                                      mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=17,pt=7,l=5,sg=0:48.31
                                      mysgw: TSF:MSG:SEND,0-0-2-2,s=2,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:48.31
                                      mysgw: Sending message on topic: mysensors-out/2/2/1/0/17
                                      mysgw: TSF:MSG:READ,2-2-0,s=3,c=1,t=17,pt=7,l=5,sg=0:362.86
                                      mysgw: TSF:MSG:SEND,0-0-2-2,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:362.86
                                      mysgw: Sending message on topic: mysensors-out/2/3/1/0/17
                                      • M marceloaqno
                                        @pete1450 @lakshmc
                                        $ mosquitto -h
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: MCO:BGN:STP
                                        P
                                        P
                                        pete1450
                                        @marceloaqno I should have specified, I'm getting the connection errors with the ethernet gateway.
                                        • P pete1450
                                          marceloaqno
                                          Code Contributor
                                          @pete1450 Could you send the debug log with the connection errors?
