  2. Announcements
  • AndurilA
    AndurilA
    Anduril
    just cloned and read the --help, but still I don't know how to use.
    To make it a litte less abstract: I have a ethernet gateway (ESP8266) running at 192.168.38.19 with port 5003 to connect to. I want to have this accessible by a serial-only controller on the raspberry.
    I tried to do this config and make afterwards, but starting gave only FAILs...
    ./configure --my-gateway=ethernet --my-controller-ip-address=192.168.38.19 --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
    ~/MySensors$ sudo ./bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.1.0
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.0
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:FAIL:RE-INIT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=2
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=3
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=4
    mysgw: TSM:FAIL:PDT
    I think my config is wrong and it tries to connect to a nrf24 at the rpi. So what's the correct config for my case?
    Thanks in advance.
    gohanG 1 Reply Last reply
    • AndurilA Anduril
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: TSM:FAIL:PDT
      mysgw: TSM:INIT
      mysgw: TSM:FAIL:PDT
      mysgw: TSM:INIT
      mysgw: TSM:FAIL:PDT
      mysgw: TSM:INIT
      mysgw: TSM:FAIL:PDT
      Thanks in advance.
      @Anduril
      Why are you using an esp8266 as a serial gateway? Wouldn't it be easier to use a normal UNO?
      • AndurilA
        AndurilA
        Anduril
        I'm using a ESP8266 as ethernet gateway and want to have this connected as virtuall serial port to my raspberry pi so my controller can connect to that.
        • lakshmcL
          lakshmcL
          lakshmc
          I using RPi2 and NRF24 for this. I followed the instructions, to clone the repo, and then added config
          ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-transport=nrf24
          make
          when i run with sudo ./bin/mysgw -d, it is failing to connect to MQTT. Can you please help?
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:INIT:TSP OK
          mysgw: TSM:INIT:GW MODE
          mysgw: MCO:REG:NOT NEEDED
          mysgw: MCO:BGN:STP
          mysgw: MCO:BGN:INIT OK,TSP=1
          mysgw: failed to connect
          P 1 Reply Last reply
          • AndurilA Anduril
            @Anduril
            Have you aver considered Using the GatewayESP8266MQTTClient? What controller are you trying to connect?
            • AndurilA
              AndurilA
              Anduril
              I use pimatic which does not have a native compatibility to ethernet or mqtt. Thats why my question came up on how to configure it to do this...
              Building a Raspberry Pi Gateway:
              If you are running a controller on the Raspberry Pi that doesn't support communication with the gateway through ethernet, you can use a virtual serial port:
              ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
              • AndurilA Anduril
                @Anduril you might be able to use nodered or socat to convert the tcp connection to a serial port.
                https://linux.die.net/man/1/socat
                https://nodered.org/
                • AndurilA
                  AndurilA
                  Anduril
                  that's what I tried in the past and am using now (socat), but it does not reconnect and has some other drawbacks. Reading of an officially supported way sounded interesting
                  • lakshmcL lakshmc
                    make
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: MCO:BGN:STP
                    P
                    P
                    pete1450
                    wrote on last edited by pete1450
                    #317
                    @lakshmc Make sure you don't have the daemon running already
                    If not, I'm getting the same problem on the 2.1.1 that was just released. 2.1.0 was working "fine"(besides my suspecting a bug that doesn't let any inclusion happen, hence I tried the new version). Time to go back to the serial gateway right into the vera.
                    • P pete1450
                      marceloaqno
                      Code Contributor
                      @pete1450 @lakshmc
                      Make sure you are not using an old version of mosquitto (or any other broker you're using):
                      $ mosquitto -h
                      mosquitto version 1.4.10 (build date 2016-09-20 11:02:07-0600)
                      It's working fine with the 2.1.1 release:
                      [alarm@pi3 mysgw]$ sudo ./bin/mysgw -d
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: MCO:BGN:STP
                      mysgw: connected to 127.0.0.1
                      mysgw: MQTT connected
                      mysgw: TSF:MSG:READ,2-2-0,s=1,c=1,t=17,pt=7,l=5,sg=0:108.12
                      mysgw: TSF:MSG:ACK REQ
                      mysgw: TSF:MSG:SEND,0-0-2-2,s=1,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:108.12
                      mysgw: Sending message on topic: mysensors-out/2/1/1/0/17
                      mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=17,pt=7,l=5,sg=0:48.31
                      mysgw: TSF:MSG:SEND,0-0-2-2,s=2,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:48.31
                      mysgw: Sending message on topic: mysensors-out/2/2/1/0/17
                      mysgw: TSF:MSG:READ,2-2-0,s=3,c=1,t=17,pt=7,l=5,sg=0:362.86
                      mysgw: TSF:MSG:SEND,0-0-2-2,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:362.86
                      mysgw: Sending message on topic: mysensors-out/2/3/1/0/17
                      • M marceloaqno
                        @pete1450 @lakshmc
                        $ mosquitto -h
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: MCO:BGN:STP
                        P
                        P
                        pete1450
                        @marceloaqno I should have specified, I'm getting the connection errors with the ethernet gateway.
                        • P pete1450
                          marceloaqno
                          Code Contributor
                          @pete1450 Could you send the debug log with the connection errors?
                          • lakshmcL
                            lakshmcL
                            lakshmc
                            @marceloaqno After installing broker and gateway fresh, seems to be working. Thanks for your help.
                            • M marceloaqno
                              P
                              P
                              pete1450
                              @marceloaqno
                              Ran as root and made sure I didn't have mysgw already running:
                              rm -r MySensors/
                              cd MySensors/
                              ./configure --my-controller-ip-address=192.168.1.136 --my-port=5003 --my-rf24-irq-pin=15
                              make
                              root@raspberrypi:~/downloads/MySensors# ./bin/mysgw -d
                              mysgw: TSF:LRT:OK
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: Eth: connect
                              • b0rmannB
                                b0rmannB
                                b0rmann
                                every few days mysgw randomly dies :(
                                Jan 19 06:40:01 pi mysgw[17960]: TSF:MSG:READ,5-5-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                                Jan 19 06:40:01 pi mysgw[17960]: Sending message on topic: mysensors/out/1/5/255/3/0/21
                                Jan 19 06:40:01 pi mysgw[17960]: TSF:MSG:READ,0-5-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                                Jan 19 06:40:01 pi mysgw[17960]: TSF:MSG:BC
                                Jan 19 06:40:01 pi systemd[1]: mysgw.service: main process exited, code=killed, status=11/SEGV
                                Jan 19 06:40:01 pi systemd[1]: Unit mysgw.service entered failed state.
                                • P pete1450
                                  @marceloaqno
                                  rm -r MySensors/
                                  cd MySensors/
                                  make
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: Eth: connect
                                  marceloaqno
                                  Code Contributor
                                  @pete1450 If you use the --my-controller-ip-address= option, the gateway will act as a client and attempt to conect to the supplied ip and port. If you want the gateway to open port 5003, omit this option.
                                  • AndurilA
                                    AndurilA
                                    Anduril
                                    @marceloaqno what is the correct configure option to make this gatway connect to an ethernet gateway and let a serial-only-controller connect to it. I suppose to use the pty option, but didn't got this working. As said above, socat and nodered are no option.
                                    • M marceloaqno
                                      P
                                      P
                                      pete1450
                                      #326
                                      @marceloaqno Well that fixed the connection issue. Now I'm just back to square one where pressing start doesn't do anything. Why do I not need to specify my controllers ip? That is the ip for my veralite. Whats the use case for that option.
                                      • b0rmannB b0rmann
                                        marceloaqno
                                        Code Contributor
                                        @b0rmann Could you provide the following information?
                                        • Your RPi model and which linux distribution you are using.
                                        • gcc version
                                        • The version and options you used to build the gateway (./configure --option)
                                        • The number of nodes on your network that sends messages to the gateway.
                                        • The broker you are using for MQTT and its version
                                        • AndurilA Anduril
                                          marceloaqno
                                          Code Contributor
                                          @Anduril Sorry, the gateway does not support what you're trying to do.
