  2. Announcements
  3. πŸ’¬ Building a Raspberry Pi Gateway
    It's OK, don't worry. We need to update the guide with the new instructions πŸ˜€
    marceloaqno
    Code Contributor
    @gohan Done!
    • F
      F
      ftw64
      @marceloaqno Thanks! That indeed does the trick! And no worries, it is my own decision to play with beta(!) code (and it was a fun weekend troubleshooting it - I learned a lot about the structure of the MySensors code)!
      Only 'bad' thing is that 2.2.0 is not compatible with my existing nodes :-).
      I appreciate all the work that has been put into MySensors.
      • Fat FlyF
        Fat FlyF
        Fat Fly
        This is really stupid. :D RFM69 radio need powered separately ?
          They shouldn't, but it's always a matter trying πŸ˜€
          • O
            O
            Oliver Acevedo
            This post is deleted!
            • Richard van der PlasR
              How will this work with HASS running on the same pi ?
              Fat FlyF 1 Reply Last reply
                It's the same as it was running on separate hw, you will only set ip address of the gateway in hass
                  so i can attach the NRF24L01+ to the pi running HA, make it a Ethernet Gateway and point to his own ip adress ?, will this be a long job with converting from a USB connected GW (Arduino with local sensors ? )
                    That's pretty much it. I don't know what is your current setup and what sensors you have, but is should not be a long job. Anyway you can install the ethernet gateway and when you are done you take care of the sensors
                      excellent, will the cpu utilisation be much higher that with a usb connected gw ?
                        No, it uses very few cpu
                        • manulM
                          manulM
                          manul
                          @Richard van der Plas: I strongly recommend to use MQTT instead of Ethernet gateway, as it is a standard way for 2 processes to communicate, and platform-agnostic.
                          HASS comes with an embed MQTT broker taht works out of the box.
                          Plus:
                          • you can easily mock either your sensors network or your controller
                          • it does support secure communication
                          • you can add other clients to observe the event, e.g. to log what is coming from/what is sent to the gateway
                            I suggested ethernet because it's easier to setup and configure, mqtt is the next step.
                            • P
                              P
                              pettib
                              Hi
                              I also have problem to get the NRF24L01+ chip to work with the RPi3.
                              I find that the masterbranch don't recognize the board as RPi3 and sets SoC and Type as unknown.
                              But if i take development branch itΒ΄s detecting RPi3 and seems to work correct.
                              This is result from development Branch configure:
                              [SECTION] Detecting target machine.
                              [OK] machine detected: SoC=BCM2837, Type=rpi3, CPU=armv7l.
                              [SECTION] Detecting SPI driver.
                              [OK] SPI driver detected:BCM.
                              [SECTION] Detecting init system.
                              [OK] init system detected: systemd.
                              [SECTION] Saving configuration.
                              [SECTION] Cleaning previous builds.
                              [OK] Finished.
                              This is result from Master Branch configure:
                              [OK] machine detected: SoC=unknown, Type=unknown, CPU=armv7l.
                              [SECTION] Checking GPIO Sysfs.
                              [OK] /sys/class/gpio/export found
                              [OK] SPI driver detected:SPIDEV.
                              [OK] Finished.
                              This is the result from cat /proc/cpuinfo:
                              Hardware : BCM2835
                              Revision : a02082
                              //Peter
                                That's odd, I have the 2.1.1 compiled on mine rpi 3
                                M 1 Reply Last reply
                                  marceloaqno
                                  Code Contributor
                                  #456
                                  @pettib @gohan There have been some changes in /proc/cpuinfo in newer versions of kernels which leads to a wrong detection.
                                  The problem was fix in #827 and will be available in the master branch in the next mysensor release.
                                    I'm using dietpi and I compiled it like 2 weeks ago..
                                    • Richard van der PlasR Richard van der Plas
                                      Fat FlyF
                                      Fat FlyF
                                      Fat Fly
                                      @Richard-van-der-Plas what is this: HASS ?
                                        Ok, i am standig on a crossroad it seems, i have to build a new gateway but i am also interested in the MQTT option, this is between mysensors & HomeASSistant i presume? i have some ESP's lying around unused, but i have 0 knowledge of mqtt (i dont think my hass has it running by default)
                                          Just go with ethernet first that is easier, get used to it then take your time to learn MQTT. Of course MQTT is more advanced has authentication and encryption but it adds complexity to initial setup.
                                          With your input, this post could be even better πŸ’—
