  2. Announcements
    Did you read the article?
    • A Andy Pethan
      I'm trying to understand the need for a separate Gateway if the Ras Pi is the host of the controller. Is it possible to use OpenHab on the Pi AND have the RF transceiver connected to that same Pi and skip the ethernet adapter w/ Arduinos? Or, if you have to use ethernet, could you use localhost as the IP? Or is there a technical reason why that wouldn't work (or would work, but in a totally different way)? Thank you.
      rozpruwaczR
      rozpruwaczR
      rozpruwacz
      @Andy-Pethan there is no need, where You read that ? I have a raspi with openhab and mqtt gw on single board. works very well.
      • A
        A
        Andy Pethan
        @gohan @rozpruwacz After reading a couple times it still wasn't clear that everything could run on one device (single Ras Pi), though that seemed like the intuitive answer. Thank you for confirming as I buy up parts.
        • A
          A
          Andy Pethan
          I figured out my problem -- I had the image and concept of this tutorial (http://www.instructables.com/id/Uber-Home-Automation-w-Arduino-Pi/) one tab over and never noticed at 3am that I mentally blended the articles. Sorry, everyone.
            In fact I was wondering what in the article wasn't clear.
            • S
              sineverba
              Going crazy here.
              I did get success with MySensors and first Arduino node on a fresh Raspbian (last image) and branch development. All ok!
              Now I want re-do on other SD (same Pi, same WIring, same Radio). I did put "old" sd on a secure location and re-start from scratch.
              I did compile with:
              ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
              and answer is:
              [SECTION] Detecting target machine.
                [OK] machine detected: SoC=BCM2835, Type=rpi1, CPU=armv6l.
              [SECTION] Detecting SPI driver.
                [OK] SPI driver detected:BCM.
              [SECTION] Detecting init system.
                [OK] init system detected: systemd.
              [SECTION] Saving configuration.
              [SECTION] Cleaning previous builds.
              [OK] Finished.
              Make ends with no error.
              The debug
              sudo ./bin/mysgw –d
              locks here:
              mysgw: Starting gateway...
              mysgw: Protocol version - 2.2.0-beta
              And no other lines.
              I Repeat, same PI, same Radio, same wiring. If I try other SD, all goes ok and I can use it on domoticz.
              Thank you
              S 1 Reply Last reply
              • S sineverba
                Going crazy here.
                I did compile with:
                and answer is:
                [OK] Finished.
                The debug
                sudo ./bin/mysgw –d
                locks here:
                And no other lines.
                Thank you
                sineverba
                @sineverba
                @sineverba said in 💬 Building a Raspberry Pi Gateway:
                Going crazy here.
                I did compile with:
                and answer is:
                [OK] Finished.
                The debug
                sudo ./bin/mysgw –d
                locks here:
                And no other lines.
                Thank you
                OK, re-re-done on fresh install and all went ok.
                I think that problem was when I deleted the PI default user and created another one.
                I did follow the gordon guide: https://gordonlesti.com/change-default-users-on-raspberry-pi/
                Probably a permission issues changing or not changing root?
                Thank you
                • L
                  L
                  lassivv
                  wrote on last edited by lassivv
                  #508
                  Hi all
                  Hope someone can help MySensors noob :) I try to do Raspberry pi 3 gateway with nrf24 module.
                  Hardware:
                  Raspberry pi 3
                  nrf24 module
                  3.3v 0.5A regulator.
                  status leds (3pcs)
                  Domoticz Beta
                  I start with this instructions:
                  https://www.mysensors.org/build/raspberry#improving-throughput-for-nrf24
                  commands what i use:
                  git clone https://github.com/mysensors/MySensors.git --branch master
                  cd MySensors
                  ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway (try ttyUSBMySensorsGateway too, but now help)
                  ./configure --my-transport=nrf24 --my-rf24-irq-pin=15
                  ./configure --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                  make
                  sudo ./bin/mysgw -d
                  After that i get error what is same to that instruction site:
                  http://i.imgur.com/jpiaMdC.png
                  I douple check wiring that seems to be all right. I think Linux console tell wrong wiring, if wiring is problem? But anyway i douple checked that wiring.
                  Hope someone can help me with this problem.
                  I try many times different settings, dont know do i need delete some old files or can i try again and again do configure and give "make" command.
                  • L lassivv
                    Hi all
                    Hardware:
                    Raspberry pi 3
                    nrf24 module
                    status leds (3pcs)
                    Domoticz Beta
                    cd MySensors
                    make
                    sudo ./bin/mysgw -d
                    @lassivv please don't post the same question in multiple places. Posting in multiple places will result in people trying to help you in one place, even after the problem has been solved in the other place. That is a waste of people's time.
                    Anyone trying to help @lassivv please post in https://forum.mysensors.org/topic/7050/multi-node-project-mysensors-noob-raspberry-gateway-problem
                    • L
                      L
                      lassivv
                      Sorry see this topic after i post my own topic, thinks this is better topic to my problems. But i continue my own topic.
                      • S
                        sineverba
                        I have a couple of nodes + PI working without issues from a couple of days.
                        Now, I would add encryption / signing / security etc to protect traffic between Arduinos and PI.
                        Could you please help me posting right configuration to add to the
                        ./configure
                        command?
                        Thank you very much!
                        • OliverDogO
                          OliverDogO
                          OliverDog
                          Why do Tx and Rx Leds blink every 5 to 6 seconds?
                          Is it about communication between RPi and Gateway?
                          Is there a way to disable it and keep blinks only with nodes communication?
                          OliverDogO 1 Reply Last reply
                          • S sineverba
                            ./configure
                            command?
                            sineverba
                            ./configure
                            command?
                            Sorry..... I would UP! this :)
                            AnticimexA 1 Reply Last reply
                            • S sineverba
                              ./configure
                              command?
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @sineverba is there not a --help argument to get a list of settings?
                              • AnticimexA Anticimex
                                sineverba
                                @Anticimex sure... Bit I did read also the guide and .... I did noto understand very well whats I need to activate (if need) on gateway and on Arduinos to block, for example, the persone that live on third floor to play with my heater ..... :-) thank you in advance
                                PS security only software, no other hardware implied / want use
                                Thank you!
                                • S sineverba
                                  Thank you!
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @sineverba I am not sure I understand what you want. You want to enable signing? There is extensive documentation on how to enable that. As for what to pass to the configure command on a rPi I am unsure of the exact naming but I am pretty sure the names are very similar to the #define:s the signing documentation describes.
                                    sineverba
                                    @Anticimex Yes, the doc is ... maybe ... too extensive :)
                                    By the way, I would signing. So I need to do on both? Gateway/Raspberry and Arduino?
                                    Thank you
                                    • S sineverba
                                      Thank you
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @sineverba I am not sure I understand how it can be too excessive? It sounds like it is inadequate since you still have questions. :)
                                      Of course you have to enable signing on both node and gateway. You also need to personalize the services with a hmac key. This is described. Please read the docs carefully. And if they are unclear, please provide a link to the documentation you have read, so I can verify you read the correct one.
                                        sineverba
                                        @Anticimex
                                        I'm talking about this: https://www.mysensors.org/about/signing
                                        Seems to me that probably need to be more clear your hint: you have to enable signing on both node and gateway.
                                        I hope that soon I will can test on my network :)
                                        Thank you for the moment :)
                                        • S sineverba
                                          @Anticimex
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          #520
                                          @sineverba yes, well that is for the official release so so far so good. I assume you also run the official version of the library and not the beta version, right?
                                          For details on rPi configuration, perhaps @marceloaqno can provide some assistance but you will find all information needed on that page for configuring signing on your nodes.
