  2. Announcements
    I'd compile it as ethernet gateway, follow the guide on how to configure the parameters, then you can use MySController (search the forum, there is a topic with download link) and use that to connect to it
    Djames SuhankoD 1 Reply Last reply
    • Djames SuhankoD Djames Suhanko
      Hi.
      I have a Raspberry Pi already configured as gateway, but I don't know how to interact with. I means, how can I read incoming data from? I tried open /dev/ttyMySensorsGateway as a common serial port but I got a message error:
      cu: open (/dev/ttyMySensorsGateway): Permission denied
      cu: /dev/ttyMySensorsGateway: Line in use
      With 'ps ax' command I can see only '/usr/local/sbin/PiGatewaySerial -d' running as a deamon.
      Could someone explain me what's ne next step for?
      Welcome to the MySensors community @Djames-Suhanko
      It looks like you are using the Raspberry Pi gateway for MySensors 1.5. If you are just starting out, I suggest you use the gateway for the current version instead. Documentation: https://www.mysensors.org/build/raspberry
      That version of the gateway has a debug mode where you can see the messages in the console.
      The next step would be to select a controller. Information about this is available at https://www.mysensors.org/about/network
        Djames SuhankoD
        Djames SuhankoD
        Djames Suhanko
        @gohan Thank you to answer! Good tip, I will do that!
          Djames SuhankoD
          Djames SuhankoD
          Djames Suhanko
          @mfalkvidd Yes, I'm using 1.5. Thank you for suggest me the newer version. I will update it today!
          • Djames SuhankoD
            Djames SuhankoD
            Djames Suhanko
            wrote on last edited by Djames Suhanko
            #605
            Hello, all!
            I read a lot of comments to find a solution to my problem, but seems it's something that I couldn't understand yet.
            The old version was working in my Raspberry Pi using Raspbian Wheeze, so, to install the new version i updated my system until the latest version (Raspbian Stetch). I could compile MySensors, but I'm getting the common error when testing with mysgw -d:
            "MYSGW: MCD:BGN INIT GW, CP=RNNG---,VER-2.1.1" and so on.
            I used this parameters in configure:
            ./configure --my-transport=nrf24 --my-gateway=ethernet
            --my-port=5003 --my-controlle-ip-address=192.168.1.2
            --my-gateway=mqtt --my-mqtt-publish-topic-prefix=mysensors-out
            --my-mqtt-subscribe-topic-prefix=mysensors-in
            --my-mqtt-client-id=mygateway1
            I couldn't find a solution yet. Can someone help me?
              Hello, all!
              #606
              @Djames-Suhanko MYSGW: MCD:BGN INIT GW, CP=RNNG---,VER-2.1.1 means that the gateway is starting up. It is not an error.
              "controller" is misspelled in your configure command though.
                @Djames-Suhanko I think you have to decide wether you want to make an ethernet or mqtt gateway, you can't specify both
                • Djames SuhankoD
                  Djames SuhankoD
                  Djames Suhanko
                  #608
                  wow, it's was really fast! Thanks to answer. I'm use an ethernet interface. It's up but have no cable on their. I didn't install a controller yet, so, is there no problem yet, right?
                  Sorry that, I'm really a newbie using MySensors.
                  [updating]
                  ysgw: Starting gateway...
                  mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: !TSM:INIT:TSP FAIL
                  mysgw: TSM:FAIL:CNT=1
                  mysgw: TSM:FAIL:PDT
                  mysgw: TSM:FAIL:RE-INIT
                  mysgw: TSM:INIT
                  mysgw: TSM:FAIL:CNT=2
                  mysgw: TSM:FAIL:PDT
                    @Djames-Suhanko said in 💬 Building a Raspberry Pi Gateway:
                    this also is not necessary. Also for now remove all these --my-gateway=mqtt --my-mqtt-publish-topic-prefix=mysensors-out
                    and use it as ethernet gateway to keep it simple
                    • Djames SuhankoD
                      Djames SuhankoD
                      Djames Suhanko
                      Ok, I will try it right now!
                      • E
                        E
                        erobot
                        Hello folks,
                        my past experience is using nrf24 library at https://github.com/Blavery/lib_nrf24, and i was able to send/receive "text" data (or "string" data) in between Raspi3 (master node) and Arduino (slave). And this is a big issue, because what i need is numerical data (float or integer), not text data, so Raspi 3 can process the numerical data (such as to do the plotting), and based on the processed data to make some decisions. My raspi 3 is controlling a moving robot. Can you advise appropriate nrf24 library for raspberry pi and Arduino, and sample codes for this kind of applicaitons? Thanks
                        • E erobot
                          Hello folks,
                          Welcome to the MySensors community @erobot !
                          Not sure how you found us, but the library we use here is...MySensors. It certanly does what you describe. The best way to start is to read how MySensors works at https://www.mysensors.org/about and then go on to the many build examples and build your first node.
                          • Richard van der PlasR
                            hi there, somehow my gateway seems to stop receiving data after a day or so from my sensors,
                            restarting the service seems to solve it for a time, how can i troubleshoot this issue ?
                            Carl HC gohanG 2 Replies Last reply
                            • Richard van der PlasR Richard van der Plas
                              Carl HC
                              Carl HC
                              Carl H
                              @Richard-van-der-Plas
                              Same trouble for me. I use mySensors since 2 years and I have no problem with my Arduino Gateway. But from now 2 weeks, I try to use a pi gateway. It's working well but sometime, don't no why, my nrf24 stop to receive messages. Just restarting mygw service and re-work again. I don't see nothing anormal in my log, stop randomlly after 1 or 2 days.
                              Maybe a power issue to nrf24, I will try to add capacitor just for testing if can resolve this problem.
                              • skywatchS
                                skywatchS
                                skywatch
                                Same here too. With Rpi3 gateway. Would stop for hours, maybe start agian for a hour or two and then stop.
                                Have been running debug mode for last day, no idea what happened, but been stable so perhaps something in the update/upgrade made a problem and has now been fixed.
                                Will keep an eye on here and let you know if I find anything.
                                  Looks as if it happened after updating Home Assistant, but that should be 2 different things right ?
                                    @Richard-van-der-Plas what version are you using?
                                    Carl HC Richard van der PlasR 2 Replies Last reply
                                      Carl HC
                                      Carl HC
                                      Carl H
                                      @gohan for me version dev (2.2)
                                      • skywatchS
                                        skywatchS
                                        skywatch
                                        dev 2.2.0 beta
                                          Have you tried both ethernet or mqtt?
