  2. Announcements
  • Djames SuhankoD
    Djames SuhankoD
    Djames Suhanko
    wrote on last edited by Djames Suhanko
    #608
    wow, it's was really fast! Thanks to answer. I'm use an ethernet interface. It's up but have no cable on their. I didn't install a controller yet, so, is there no problem yet, right?
    Sorry that, I'm really a newbie using MySensors.
    [updating]
    ysgw: Starting gateway...
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:FAIL:RE-INIT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=2
    mysgw: TSM:FAIL:PDT
      @Djames-Suhanko said in 💬 Building a Raspberry Pi Gateway:
      --my-controlle-ip-address
      this also is not necessary. Also for now remove all these --my-gateway=mqtt --my-mqtt-publish-topic-prefix=mysensors-out
      --my-mqtt-subscribe-topic-prefix=mysensors-in
      --my-mqtt-client-id=mygateway1
      and use it as ethernet gateway to keep it simple
      • Djames SuhankoD
        Djames SuhankoD
        Djames Suhanko
        Ok, I will try it right now!
        • E
          E
          erobot
          Hello folks,
          my past experience is using nrf24 library at https://github.com/Blavery/lib_nrf24, and i was able to send/receive "text" data (or "string" data) in between Raspi3 (master node) and Arduino (slave). And this is a big issue, because what i need is numerical data (float or integer), not text data, so Raspi 3 can process the numerical data (such as to do the plotting), and based on the processed data to make some decisions. My raspi 3 is controlling a moving robot. Can you advise appropriate nrf24 library for raspberry pi and Arduino, and sample codes for this kind of applicaitons? Thanks
          • E erobot
            Hello folks,
            Welcome to the MySensors community @erobot !
            Not sure how you found us, but the library we use here is...MySensors. It certanly does what you describe. The best way to start is to read how MySensors works at https://www.mysensors.org/about and then go on to the many build examples and build your first node.
            • Richard van der PlasR
              hi there, somehow my gateway seems to stop receiving data after a day or so from my sensors,
              restarting the service seems to solve it for a time, how can i troubleshoot this issue ?
              Carl HC gohanG 2 Replies Last reply
              • Richard van der PlasR Richard van der Plas
                Carl HC
                Carl HC
                Carl H
                @Richard-van-der-Plas
                Same trouble for me. I use mySensors since 2 years and I have no problem with my Arduino Gateway. But from now 2 weeks, I try to use a pi gateway. It's working well but sometime, don't no why, my nrf24 stop to receive messages. Just restarting mygw service and re-work again. I don't see nothing anormal in my log, stop randomlly after 1 or 2 days.
                Maybe a power issue to nrf24, I will try to add capacitor just for testing if can resolve this problem.
                • skywatchS
                  skywatchS
                  skywatch
                  Same here too. With Rpi3 gateway. Would stop for hours, maybe start agian for a hour or two and then stop.
                  Have been running debug mode for last day, no idea what happened, but been stable so perhaps something in the update/upgrade made a problem and has now been fixed.
                  Will keep an eye on here and let you know if I find anything.
                    Looks as if it happened after updating Home Assistant, but that should be 2 different things right ?
                      @Richard-van-der-Plas what version are you using?
                      Carl HC Richard van der PlasR 2 Replies Last reply
                        Carl HC
                        Carl HC
                        Carl H
                        @gohan for me version dev (2.2)
                        • skywatchS
                          skywatchS
                          skywatch
                          dev 2.2.0 beta
                            Have you tried both ethernet or mqtt?
                              @gohan the latest stable version i guess. Where can i check?
                              gohanG 1 Reply Last reply
                                @Richard-van-der-Plas try the 2.2 beta, it usually works better
                                Richard van der PlasR 1 Reply Last reply
                                  @gohan just checked it's 2.1.1, is it easy to upgrade?
                                    @Richard-van-der-Plas just clone the 2.2 dev instead of the stable, the rest is the same
                                      @gohan fatal: destination path 'MySensors' already exists and is not an empty directory. It goes wrong with the first command, could you please give me some pointers ?
                                        you need to either delete or rename the Mysensors folder :)
                                        • llegoffL
                                          llegoffL
                                          llegoff
                                          I designed a PCB for rfm or nrf -> raspberry pi
                                          https://www.openhardware.io/view/470/MySensors-Gateway-for-Raspberry-PI
