  2. Announcements
    Like all nodes, you need to change the bootloader in order to enable ota.
    • llegoffL
      llegoffL
      llegoff
      hello, is there a inclusion mode planned for the raspberry pi gateway ?
      • R
        R
        ricorico94
        wrote on last edited by ricorico94
        #643
        This seems a great job, but despite I had a look at many posts (yes, many out of the dozens of pages.. ;-) ), I still can't figure out some questions..
        • Beyond the obvious advantage of saving an arduino (and power supply, space..), is there an advantage for having the gateway hosted by the raspberry PI hosting my Domoticz ? (like more CPU available for handling communications or for signing ? or on the opposite more risks to overload the PI CPU -despite only a couple persons have complained about high CPU load))
        • the default setup is Ethernet. What are the pros and cons of ethernet vs serial setup ? (speed? reliability ? possibility to move to other gateway?..)
        • Is signing now implemented in this setup ? I didn't see it explicitely described, but some posts seem related to signing.
        • if I want to use an external antenna and the high power NRF24, should I use an aother power source than raspberry PI ? (or maybe sharing the same USB charger, but diverting the power in parallel of the PI ?)
        • is there a tutorial somewhere detailing how to uninstall and migrate to an external gateway ? During such migration, would I need to "touch" again my sensors and would I lose history logs of these sensors in Domoticz ?
        Sorry for all these questions..
        br,
        Ricorico94
        • R ricorico94
          br,
          Ricorico94
          #644
          @ricorico94 said in 💬 Building a Raspberry Pi Gateway:
          Not really. Cpu usage is normally 0-2% so it doesn't affect either way.
          Switching between different gateway types (serial, ethernet, mqtt) can be easier since there is no need to re-wire anything, just reconfigure and recompile. But that could be done with a all-in-one Arduino setup as well.
          Remote debug might be a benefit, since logging in to the raspberry pi to view log files can be done remotely. Remote debug for Arduino is possible, but usually requires additional hardware.
          The raspberry pi has room for more logging, which can help troubleshooting.
          The biggest downside is that a raspberry pi environment is infinitely more complex than an Arduino, which could affect reliability and make troubleshooting harder. On the other hand, there are more debugging tools available which might make troubleshooting easier.
          No difference in speed. No difference in reliability.
          Ethernet can easily be made accessible over the network. Doing that with serial can be done but is a bit tricky.
          Some controllers don't have support for all gateway types. See https://www.mysensors.org/controller for details.
          Yes. See the help text produced by running ./configure --help
          Yes. See the note on https://www.mysensors.org/build/raspberry#wiring
          See my answer in the question you posted yesterday.
          No worries. Except for posting one of the questions again (which wastes people's time and confuses people when they read only one of the places), you are very welcome to post as many questions as you like. Asking questions is usually the next best way to learn.
          • R
            R
            ricorico94
            Thanks a lot for your clear explanations ! Very useful !
            and.. bravo ! for all your work
            • R
              R
              ricorico94
              #646
              I'm trying to install the gateway on a Raspberry Pi 2 hosting Domoticz already (I had used the standard Domoticz image).
              I receive an error message on the make step, but maybe I've not properly understood instructions (not very friendly with raspberry and linux environment).
              First, I wired the NRF24 with PA (meaning I used an adapter and the 5V physical PIN#4) and the IRQ (wired on physical pin #15)
              Then I logged into my raspberry and staid in initial directory (pi@raspberrypi )
              I then typed:
              pi@raspberrypi ~ $ git clone https://github.com/mysensors/MySensors.git --branch master
              Cloning into 'MySensors'...
              remote: Counting objects: 14895, done.
              remote: Compressing objects: 100% (8/8), done.
              remote: Total 14895 (delta 0), reused 5 (delta 0), pack-reused 14887
              Receiving objects: 100% (14895/14895), 12.17 MiB | 1.68 MiB/s, done.
              Resolving deltas: 100% (9022/9022), done.
              pi@raspberrypi ~ $ cd MySensors
              pi@raspberrypi ~/MySensors $ ./configure --help
              Hopefully I did it in adequate folder ? (now I see a Mysensors folder in my /home/pi folder).
              Then I typed:
              pi@raspberrypi ~/MySensors $ --my-transport=nrf24
              -bash: --my-transport=nrf24 : commande introuvable
              pi@raspberrypi ~/MySensors $ ./configure --my-transport=nrf24
              [SECTION] Detecting target machine.
                [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l.
              [SECTION] Detecting SPI driver.
                [OK] SPI driver detected:BCM.
              [SECTION] Detecting init system.
                [OK] init system detected: sysvinit.
              [SECTION] Saving configuration.
              [SECTION] Cleaning previous builds.
              [OK] Finished.
              So far, no error.. but should I have typed "./configure --my-transport=nrf24 --my-rf24-irq-pin=15" to implement the IRQ ? If yes, can I retype that command with new settings without issue ?
              Then I understaood I had to run make command:
              pi@raspberrypi ~/MySensors $ make
              gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/RPi -I./drivers/BCM -c drivers/Linux/log.c -o build/drivers/Linux/log.o
              cc1: error: bad value (cortex-a7) for -mtune switch
              Makefile:118: recipe for target 'build/drivers/Linux/log.o' failed
              make: *** [build/drivers/Linux/log.o] Error 1
              But errors... :anguished:
              I tried to search on forum, and saw someone else meniotning a smilar error, but people were answering about OrangePI, whereas I use a Rasp PI 2.
              I probably misunderstood some steps.. Could someone help me ?
              Note: in instructions, there's a statement I don't understand for ethernet gateway: "To set the gateway as a client that connects to a controller, use:--my-gateway=ethernet --my-controller-url-address=YOUR-CONTROLLER-ADDRES" . IN which case do we need that ? (as said, I plan to simply use this gateway on My dodmoticz rasp PI).
              br,
              Ricorico94
                That is fine, no need to add extra parameters as by defaults it will configure as ethernet gateway. Also try using the development branch as it has lots of bugs fixed.
                • A
                  A
                  arraWX
                  @ricorico94 Yesterday I managed to make a working rpi gateway. I am on rpi3, use a socket adapter board for the radio and use domoticz. I posted all the details here: https://forum.mysensors.org/topic/7793/nrf24l01-problems-in-2-1-1-and-2-2-0-beta/24
                  • R
                    R
                    ricorico94
                    #649
                    @arraWX : I looked at your post. Unfortunately, the error I face is before the start, as it's during the make, so it appears I follow the first steps you describe (config & make), but I still don't know how to solve the make errors.
                    In case it can help understanding what's going on or what to do, I ran the command:
                    gcc -v
                    which displayed: gcc version 4.6.3 (Debian 4.6.3-14+rpi1)
                    Could it be an issue this "+rpi1" whreas I've a PI 2 ?
                    • A
                      A
                      arraWX
                      Do not know if it is of any help, but mine says: gcc version 4.9.2 (Raspbian 4.9.2-10)
                      • R
                        R
                        ricorico94
                        I tried to update gcc, just in case.. though I'm not sure of what I do.:confused:
                        I ran:
                        pi@raspberrypi ~/MySensors $ sudo apt-get upgrade gcc
                        and after a little while, it ended without obvious mistake.
                        but if I do gcc -v again, I still get
                        (even after reboot)
                        Is there another step to be done, or am I using wrong command ?
                          try running first sudo apt-get update and then sudo apt-get upgrade , it should update all packages
                          • R
                            R
                            ricorico94
                            @gohan : JUst tried it, but same result.. no change on version number.
                            is there something like apt-get install to be done also ?
                            M 1 Reply Last reply
                              I don't know really... I am using dietpi on a RPI3 and there is a convenient tool that you can check what to install and installs for you and among the others I have chosen the "Build-Essentials" that contains all the common packages for compile, so I don't know what packages are included.
                              • R ricorico94
                                marceloaqno
                                Code Contributor
                                @ricorico94 Do you see gcc-4.9 in the list returned by the command below?
                                sudo apt-cache search gcc
                                If it's listed, try installing it by specifying the version:
                                sudo apt-get install gcc-4.9
                                • R
                                  R
                                  ricmail85
                                  Hi, wouldn't be proper to include in the guide also the command "--my-rfm69-irq-pin=22" during the configure procedure in order to improve the throughput for the rfm69 radios?
                                  • R
                                    R
                                    ricorico94
                                    Thanks to @marceloaqno and @Gohan and @arraWX , I could progress somewhow.. but still not working.
                                    When listing the versions as per Marceloagno advice, I could see gcc-4.6 and -4.7 and 4.8 but nothing else (no 4.9).
                                    I then decided to take the risk of installing the 4.8.. The commands from Marcelagno did not work (well, I mean gcc - v was still showing 4.6).
                                    Then I followed this tutorial on upgrade step by step to upgrade to gcc-4.8 and then the make command apparently succeeded (well, plenty messages, some warnings.. but no error apparently, as ar as I could see. I dd not find the folders desribed in website, but the commands were still ok.. weird, but I'm too rookie..)
                                    I then followed again the Mysensors tutorial with
                                    sudo ./bin/mysgw -h
                                    sudo ./bin/mysgw -d (and no error message. great!)
                                    sudo make install
                                    but then I ran
                                    sudo systemctl enable mysgw.service
                                    and I got error message
                                    sudo: systemctl: command not found
                                    After some search, I saw that it's a Jessie command whereas I discovered that my good old version of Rasp Pi, which was built from the standard Domoticz image in 2015 is still Wheezy
                                    pi@raspberrypi ~/MySensors $ cat /etc/os-release
                                    PRETTY_NAME="Raspbian GNU/Linux 7 (wheezy)"
                                    NAME="Raspbian GNU/Linux"
                                    VERSION_ID="7"
                                    VERSION="7 (wheezy)"
                                    ID=raspbian
                                    ID_LIKE=debian
                                    ANSI_COLOR="1;31"
                                    HOME_URL="http://www.raspbian.org/"
                                    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                    Any idea of what I should do now?..
                                    another commande equivalent to the systemctl ?
                                    an upgrade to Jessie (any risk ? and how to do it safely ?)
                                    br,
                                    Ricorico94
                                    • petewillP
                                      petewillP
                                      petewill
                                      I am new to Linux and hopefully have an easy question...
                                      I have followed the build instructions and everything seems to be working well so far. One issue I'm having is getting node-red to see the usb port (/dev/ttyUSB020). I did some searching online and found that if I run the following command node-red will see the port and things start working.
                                      sudo chmod 666 /dev/ttyUSB020
                                      The problem is that each time I reboot the Pi the command needs to be run again. Does anyone have any ideas on how I can resolve this so I don't need to run the command each time the system is booted? Thanks in advance.
                                      mfalkviddM gohanG 2 Replies Last reply
                                      • petewillP petewill
                                        #659
                                        @petewill you can put the chmod command in /etc/rc.local
                                        That will execute it on every boot.
                                        https://www.raspberrypi.org/documentation/linux/usage/rc-local.md
                                          @petewill or you can compile the gateway as ethernet or mqtt that are both supported by node-red, making life a little easier
                                          petewillP 1 Reply Last reply
