  2. Announcements
    On my test RPI3 it is working.... I have to double check the other one.
      you need to either delete or rename the Mysensors folder :)
      Richard van der PlasR
      @gohan Hi there updated to the latest dev, but i still have to restart the service after a few days, this is the message in the log:
      Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Closing socket at ('192.168.1.115', 5003).#033[0m
      Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Socket closed at ('192.168.1.115', 5003).#033[0m
      Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] No response. Disconnected.#033[0m
      Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.115', 5003)#033[0m
      checking with top, i see high CPU utilization:
      20921 root      20   0   20036    872    784 R  CPU ->99,5  0,1 682:53.59 mysgw
      • C ccy
        @Grubstake: Thanks. I have tried to follow "NRF24L01+ Radio" pin out connection. I have double / triple check my wiring is correct. But I still get the same fail message in mysgw debug mode:
        [root@alarmpi bin]# ./mysgw -d
        mysgw: Starting gateway...
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: !TSM:INIT:TSP FAIL
        mysgw: TSM:FAIL:CNT=1
        mysgw: TSM:FAIL:PDT
        mysgw: TSM:FAIL:RE-INIT
        mysgw: TSM:INIT
        mysgw: TSM:FAIL:CNT=2
        mysgw: TSM:FAIL:PDT
        mysgw: TSM:INIT
        mysgw: TSM:FAIL:CNT=3
        mysgw: TSM:FAIL:PDT
        mysgw: Received SIGINT
        Here is my /boot/config.txt:
        gpu_mem=64
        initramfs initramfs-linux.img followkernel
        dtparam=spi=on
        and the spi dev:
        # ls /dev/spidev0.*
        I am using ArchLinuxARM:
        # uname -a
        Linux alarmpi 4.9.13-3-ARCH #1 SMP Fri Mar 3 18:45:16 MST 2017 armv7l GNU/Linux
        I only wiring 7 pins (1-7) on NRF24l01+.
        Raspberry Pi 2 hardware information:
        # cat /proc/cpuinfo
        processor       : 0
        model name      : ARMv7 Processor rev 5 (v7l)
        BogoMIPS        : 38.40
        Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
        CPU implementer : 0x41
        CPU architecture: 7
        CPU variant     : 0x0
        CPU part        : 0xc07
        CPU revision    : 5
        processor       : 1
        BogoMIPS        : 38.40
        CPU architecture: 7
        CPU variant     : 0x0
        CPU part        : 0xc07
        CPU revision    : 5
        processor       : 2
        BogoMIPS        : 38.40
        CPU architecture: 7
        CPU variant     : 0x0
        CPU part        : 0xc07
        CPU revision    : 5
        processor       : 3
        BogoMIPS        : 38.40
        CPU architecture: 7
        CPU variant     : 0x0
        CPU part        : 0xc07
        CPU revision    : 5
        Hardware        : BCM2835
        Revision        : a21041
        Serial          : 00000000475d18a4
        # cat /sys/firmware/devicetree/base/model
        Raspberry Pi 2 Model B Rev 1.1
        Output from MySensors configure:
        # ./configure
        ./configure: line 111: warning: command substitution: ignored null byte in input
        [OK] Finished.
        I finally find out my raspberry pi board isn't detected properly in configure. I change the function detect_machine:
        function detect_machine {
            case $hardware in
            BCM2835)
                soc="BCM2835"
                if [[ $machine == "Raspberry"* ]]; then
                    local rev=($(detect_rpi_revision))
                    if [[ $rev == "a02082" || $rev == "a22082" ]]; then
                        tp="RPi3"
                        tp="Rpi2"
                    fi
                fi
        make mysgw again, and I get this finally:
        # ./mysgw -d
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:INIT:TSP OK
        mysgw: TSM:INIT:GW MODE
        mysgw: MCO:REG:NOT NEEDED
        mysgw: MCO:BGN:STP
        mysgw: MCO:BGN:INIT OK,TSP=1
        J
        J
        jacikaas
        @ccy
        Hello, I'm also have issue with this question. My Raspberry Pi 2 type is a01041, but by the original "configure" file it is not recognized:
        Maybe someone could explain why it is not recognized?
        "Configure" file lines:
            case $hardware in
            BCM2835)
                soc="BCM2835"
                        tp="RPi3"
                        tp="Rpi2"
                    fi
                fi
        My Raspberry Pi 2 info:
        processor       : 0
        BogoMIPS        : 38.40
        CPU architecture: 7
        CPU variant     : 0x0
        CPU part        : 0xc07
        CPU revision    : 5
        processor       : 1
        BogoMIPS        : 38.40
        CPU architecture: 7
        CPU variant     : 0x0
        CPU part        : 0xc07
        CPU revision    : 5
        processor       : 2
        BogoMIPS        : 38.40
        CPU architecture: 7
        CPU variant     : 0x0
        CPU part        : 0xc07
        CPU revision    : 5
        processor       : 3
        BogoMIPS        : 38.40
        CPU architecture: 7
        CPU variant     : 0x0
        CPU part        : 0xc07
        CPU revision    : 5
        Hardware        : BCM2835
        Revision        : a01041
        Serial          : 0000000049a14619
        • TriXwooDT
          TriXwooDT
          TriXwooD
          Double radio or alternative pin for spi1:
          https://forum.mysensors.org/topic/7702/double-spi-radio-raspberry-pi/2
          • A
            arraWX
            I followed the instructions carefully. However I get an error. Can someone help?
            cd MySensors
            ./configure --my-transport=nrf24 --my-gateway=ethernet
            This results in a warning:
              [WARNING] No supported SPI driver detected.
            When I run make I get the follwing error:
            ./MySensors.h:254:2: error: #error No support for nRF24 radio on this platform
                             from ./MySensors.h:290,
            compilation terminated.
            Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
            Hope someone can help. Thanks.
            • skywatchS
              skywatchS
              skywatch
              Maybe you didn't enable SPI on the pi.
              From command prompt type 'sudo raspi-config', then select option 5 from the menu. This takes you to where you can enable the SPI bus on the pi. Then try again.
              S>
              • A
                arraWX
                @skywatch Thank you! That solved my problem.
                • Sefi NinioS
                  Sefi NinioS
                  Sefi Ninio
                  wrote on last edited by Sefi Ninio
                  #640
                  Hello friends,
                  Reading the instructions for building a RaspberryPi Gateway using RFM69, it states that one should use the development branch and not master, since the Pi is using a different version of the driver.
                  Anyone knows when this will be merged to master branch?
                  Also, since this forces all nodes to use development branch as well to be able to communicate with the gateway, assuming I use the development branch now and it is later on merged into master, is there an easy way to upgrade nodes remotely to the new code?
                  I am planning to use Wall Switch Insertable Node, and Mini Relay Mode - Both support OTA updates, am I correct to assume this will allow upgrading without taking the nodes out of where they are located?
                  Sefi
                    Like all nodes, you need to change the bootloader in order to enable ota.
                    • llegoffL
                      llegoffL
                      llegoff
                      hello, is there a inclusion mode planned for the raspberry pi gateway ?
                      • R
                        R
                        ricorico94
                        wrote on last edited by ricorico94
                        #643
                        This seems a great job, but despite I had a look at many posts (yes, many out of the dozens of pages.. ;-) ), I still can't figure out some questions..
                        • Beyond the obvious advantage of saving an arduino (and power supply, space..), is there an advantage for having the gateway hosted by the raspberry PI hosting my Domoticz ? (like more CPU available for handling communications or for signing ? or on the opposite more risks to overload the PI CPU -despite only a couple persons have complained about high CPU load))
                        • the default setup is Ethernet. What are the pros and cons of ethernet vs serial setup ? (speed? reliability ? possibility to move to other gateway?..)
                        • Is signing now implemented in this setup ? I didn't see it explicitely described, but some posts seem related to signing.
                        • if I want to use an external antenna and the high power NRF24, should I use an aother power source than raspberry PI ? (or maybe sharing the same USB charger, but diverting the power in parallel of the PI ?)
                        • is there a tutorial somewhere detailing how to uninstall and migrate to an external gateway ? During such migration, would I need to "touch" again my sensors and would I lose history logs of these sensors in Domoticz ?
                        Sorry for all these questions..
                        br,
                        Ricorico94
                        • R ricorico94
                          br,
                          Ricorico94
                          #644
                          @ricorico94 said in 💬 Building a Raspberry Pi Gateway:
                          Not really. Cpu usage is normally 0-2% so it doesn't affect either way.
                          Switching between different gateway types (serial, ethernet, mqtt) can be easier since there is no need to re-wire anything, just reconfigure and recompile. But that could be done with a all-in-one Arduino setup as well.
                          Remote debug might be a benefit, since logging in to the raspberry pi to view log files can be done remotely. Remote debug for Arduino is possible, but usually requires additional hardware.
                          The raspberry pi has room for more logging, which can help troubleshooting.
                          The biggest downside is that a raspberry pi environment is infinitely more complex than an Arduino, which could affect reliability and make troubleshooting harder. On the other hand, there are more debugging tools available which might make troubleshooting easier.
                          No difference in speed. No difference in reliability.
                          Ethernet can easily be made accessible over the network. Doing that with serial can be done but is a bit tricky.
                          Some controllers don't have support for all gateway types. See https://www.mysensors.org/controller for details.
                          Yes. See the help text produced by running ./configure --help
                          Yes. See the note on https://www.mysensors.org/build/raspberry#wiring
                          See my answer in the question you posted yesterday.
                          No worries. Except for posting one of the questions again (which wastes people's time and confuses people when they read only one of the places), you are very welcome to post as many questions as you like. Asking questions is usually the next best way to learn.
                          • R
                            R
                            ricorico94
                            Thanks a lot for your clear explanations ! Very useful !
                            and.. bravo ! for all your work
                            • R
                              R
                              ricorico94
                              #646
                              I'm trying to install the gateway on a Raspberry Pi 2 hosting Domoticz already (I had used the standard Domoticz image).
                              I receive an error message on the make step, but maybe I've not properly understood instructions (not very friendly with raspberry and linux environment).
                              First, I wired the NRF24 with PA (meaning I used an adapter and the 5V physical PIN#4) and the IRQ (wired on physical pin #15)
                              Then I logged into my raspberry and staid in initial directory (pi@raspberrypi )
                              I then typed:
                              pi@raspberrypi ~ $ git clone https://github.com/mysensors/MySensors.git --branch master
                              Cloning into 'MySensors'...
                              remote: Counting objects: 14895, done.
                              remote: Compressing objects: 100% (8/8), done.
                              remote: Total 14895 (delta 0), reused 5 (delta 0), pack-reused 14887
                              Receiving objects: 100% (14895/14895), 12.17 MiB | 1.68 MiB/s, done.
                              Resolving deltas: 100% (9022/9022), done.
                              pi@raspberrypi ~ $ cd MySensors
                              pi@raspberrypi ~/MySensors $ ./configure --help
                              Hopefully I did it in adequate folder ? (now I see a Mysensors folder in my /home/pi folder).
                              Then I typed:
                              pi@raspberrypi ~/MySensors $ --my-transport=nrf24
                              -bash: --my-transport=nrf24 : commande introuvable
                              pi@raspberrypi ~/MySensors $ ./configure --my-transport=nrf24
                                [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l.
                                [OK] SPI driver detected:BCM.
                                [OK] init system detected: sysvinit.
                              [OK] Finished.
                              So far, no error.. but should I have typed "./configure --my-transport=nrf24 --my-rf24-irq-pin=15" to implement the IRQ ? If yes, can I retype that command with new settings without issue ?
                              Then I understaood I had to run make command:
                              gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/RPi -I./drivers/BCM -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                              cc1: error: bad value (cortex-a7) for -mtune switch
                              Makefile:118: recipe for target 'build/drivers/Linux/log.o' failed
                              But errors... :anguished:
                              I tried to search on forum, and saw someone else meniotning a smilar error, but people were answering about OrangePI, whereas I use a Rasp PI 2.
                              I probably misunderstood some steps.. Could someone help me ?
                              Note: in instructions, there's a statement I don't understand for ethernet gateway: "To set the gateway as a client that connects to a controller, use:--my-gateway=ethernet --my-controller-url-address=YOUR-CONTROLLER-ADDRES" . IN which case do we need that ? (as said, I plan to simply use this gateway on My dodmoticz rasp PI).
                              br,
                              Ricorico94
                                That is fine, no need to add extra parameters as by defaults it will configure as ethernet gateway. Also try using the development branch as it has lots of bugs fixed.
                                • A
                                  arraWX
                                  @ricorico94 Yesterday I managed to make a working rpi gateway. I am on rpi3, use a socket adapter board for the radio and use domoticz. I posted all the details here: https://forum.mysensors.org/topic/7793/nrf24l01-problems-in-2-1-1-and-2-2-0-beta/24
                                  • R
                                    R
                                    ricorico94
                                    #649
                                    @arraWX : I looked at your post. Unfortunately, the error I face is before the start, as it's during the make, so it appears I follow the first steps you describe (config & make), but I still don't know how to solve the make errors.
                                    In case it can help understanding what's going on or what to do, I ran the command:
                                    gcc -v
                                    which displayed: gcc version 4.6.3 (Debian 4.6.3-14+rpi1)
                                    Could it be an issue this "+rpi1" whreas I've a PI 2 ?
                                    • A
                                      arraWX
                                      Do not know if it is of any help, but mine says: gcc version 4.9.2 (Raspbian 4.9.2-10)
                                      • R
                                        R
                                        ricorico94
                                        I tried to update gcc, just in case.. though I'm not sure of what I do.:confused:
                                        I ran:
                                        pi@raspberrypi ~/MySensors $ sudo apt-get upgrade gcc
                                        and after a little while, it ended without obvious mistake.
                                        but if I do gcc -v again, I still get
                                        (even after reboot)
                                        Is there another step to be done, or am I using wrong command ?
                                          try running first sudo apt-get update and then sudo apt-get upgrade , it should update all packages
