💬 Building a Raspberry Pi Gateway
Background: I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. I have also set up the raspberry pi as a gateway in the MyController Gateway setup page in Safari. It found it and it seem to work.
However to my question. How do I know if the Raspberry Pi gateway with NRF24L01 work? How can I monitor what the Raspberry Pi gateway receive? Is there a similar way as the "Serial Monitor" that I use in the Arduino application, when accessing Arduino Uno via USB?
If there is I need to monitor this via OSX Terminal.
@Christian-Simonsen If you don't have debug enabled you could also just use:
tail -f /dev/ttyUSB20My port is named ttyUSB20. You should substitute whatever you have named your port.
Thanks I'll test it. But it seems like I've jumped over a step or two. Or something isn't working. Nothing happened when I wrote "Make" in Terminal, so I jumped over this step. I guess that might be the problem.
Do I have to configure (./configure -help) or can I use the default values when I connect the NRF24L01 to the GPIO pins?
@b0rmann what happened? Did you fixed the problem you described in your last message?
it's my problem. accidentally disconnected power from nrf24 on running gw
@marceloaqno I have it completely working now. :satisfied: A Raspberry Pi PulseCounter for water/gas/electricity consumption measurements with ethernet/mqtt. I can post my code here if you want.
Minor detail:
millis() / 1000;should be
millis() * 1000;to get micros() ;)
Minor detail:
@ericvdb Congrats! oops, sorry about my mistake.
This post is deleted!
Seems I'm closing in to working solution. I didn't understand how to use the ./configure element before now. However I ended up with these configurations
pi@raspberrypi:~ $ ./MySensors/configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-radio=nrf24 --my-rf24-irq-pin=15 [SECTION] Detecting target machine. [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l, REV=a01041. [OK] init system detected: systemd [SECTION] Saving configuration. [SECTION] Cleaning previous builds. make: *** No rule to make target 'clean'. Stop. [OK] Finished. pi@raspberrypi:~ $ sudo ./MySensors/examples_linux/mysGateway -d mysGateway: Starting gateway... mysGateway: Protocol version - 2.0.1-beta mysGateway: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta mysGateway: TSF:LRT:OK mysGateway: TSM:INIT mysGateway: TSM:INIT:TSP OK mysGateway: TSM:INIT:GW MODE mysGateway: TSM:READY mysGateway: MCO:REG:NOT NEEDED mysGateway: MCO:BGN:STP mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1 mysGateway: TSM:READY:NWD REQ mysGateway: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK: mysGateway: TSF:SRT:OKBased on this it seem to all be ok on the Raspberry Pi side.. So I uploaded the "MockMySensors" sketch to my Arduino Uno with NRF24 connected. Below is the code and failure message I get from the Arduino. Do I need to set a gateway address or something?
Starting sensor (RNNNA-, 2.0.0) TSM:INIT TSM:RADIO:OK TSP:ASSIGNID:OK (ID=254) TSM:FPAR TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: !TSM:FPAR:FAIL !TSM:FAILURE TSM:PDT``` -
Starting sensor (RNNNA-, 2.0.0) TSM:INIT TSM:RADIO:OK TSP:ASSIGNID:OK (ID=254) TSM:FPAR TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: !TSM:FPAR:FAIL !TSM:FAILURE TSM:PDT```@Christian-Simonsen you need to be within the MySensors folders to execute commands configure and make.
I recommend you to test that everything is working before using the option --my-rf24-irq-pin=15Like this:
cd MySensors ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-radio=nrf24 make sudo ./examples_linux/mysGateway -d -
Thanks for adding signing.
I want to use my rPi to generate random soft serials for my sensors.
Could all three "gen" commands output the line to put in SecurityPersonalizer.ino like it does when using the "set" commands? -
cd MySensors ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-radio=nrf24 make sudo ./examples_linux/mysGateway -d@marceloaqno said:
cd MySensors
./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --myThanks for letting me know, didn't know that not running it from the specific folder would have an impact.
I reconfigured it as you recommended. and restarted the gateway, with the result below.
pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d mysGateway: Starting gateway... mysGateway: Protocol version - 2.0.1-beta mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta mysGateway: TSF:LRT:OK mysGateway: TSM:INIT mysGateway: TSM:INIT:TSP OK mysGateway: TSM:INIT:GW MODE mysGateway: TSM:READY mysGateway: MCO:REG:NOT NEEDED mysGateway: MCO:BGN:STP mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1 mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0: mysGateway: !TSF:MSG:LEN,0!=7 mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0: mysGateway: !TSF:MSG:LEN,0!=7 mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0: mysGateway: !TSF:MSG:LEN,0!=7 mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0: mysGateway: !TSF:MSG:LEN,0!=7 mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0: mysGateway: !TSF:MSG:LEN,0!=7 mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0: mysGateway: !TSF:MSG:LEN,14!=7 mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0: mysGateway: !TSF:MSG:LEN,0!=7 mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0: mysGateway: !TSF:MSG:LEN,0!=7 mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0: mysGateway: !TSF:MSG:LEN,14!=7 mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0: mysGateway: !TSF:MSG:LEN,0!=7What is the best way to test if the gateway work? What sketch should I use on the arduino? and how do I see in Terminal that the mysGateway receive the transfer successfully?
very interesting data...
journalctl -u mysgateway --since 13:15 | grep MSG:READ
Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=3,c=1,t=23,pt=2,l=2,sg=0:97 Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6 Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=3,c=1,t=23,pt=2,l=2,sg=0:97 Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.6 Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6 Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=3,c=1,t=23,pt=2,l=2,sg=0:97 Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7 Oct 21 13:16:31 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7 Oct 21 13:16:31 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6 Oct 21 13:17:17 pi mysGateway[30406]: TSF:MSG:READ,2-2-0,s=251,c=1,t=0,pt=7,l=5,sg=0:24.5 Oct 21 13:17:17 pi mysGateway[30406]: TSF:MSG:READ,2-2-0,s=167,c=1,t=0,pt=7,l=5,sg=0:24.6 Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,2-10-0,s=251,c=1,t=0,pt=7,l=5,sg=0:24.5 Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7 Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,2-10-0,s=167,c=1,t=0,pt=7,l=5,sg=0:24.6 Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,2-10-0,s=251,c=1,t=0,pt=7,l=5,sg=0:24.5 Oct 21 13:17:19 pi mysGateway[30406]: TSF:MSG:READ,10-10-0,s=12,c=1,t=0,pt=7,l=5,sg=0:34 Oct 21 13:17:19 pi mysGateway[30406]: TSF:MSG:READ,10-10-0,s=14,c=1,t=0,pt=7,l=5,sg=0:24node 2
sensor 167 - dht18b20 indoor
sensor 251 - dht18b20 indoornode 3
sensor 0 - dht18b20 outdoor
sensor 3 - light (0..100)
sensor 4 - light (0..100)questions:
why node 2 and node 3 send messages directly and via node 10?24.6 - is actual value from 2/251, but gateway receive this value from 3/0 How is it possible?
Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.6 -
Is there anyone here that can give me some one-to-one support this evening to setup the Raspberry Pi + NRF24L01 as a gateway with MyController, and a Arduino Uno + NRF24L01 as Sensor node. I'm stuck after trying various things over the past week, so looks like I need some additional skills/knowledge to get the first setup working.
Maybe we can use Skype or some other medium. I will gladly pay a bit for this support if anyone is interested. I have some free time from 18:00 CET - 23:30 CET today...
I have a gateway and 1 sensor ,obviously.
I have added serial GW but anyone sensor appear, i'm sure that the sensor works, and the gateway also (see with the command mysGateway -d).
Can you have any idea ? Thank you -
@marceloaqno said:
cd MySensors
You can pretty much test out using any of the arduino examples here:
https://github.com/mysensors/MySensors/tree/development/examples
Each one will present itself to the gateway when it starts up and you will see the presentation in the debug log. Make sure to run:
https://github.com/mysensors/MySensors/tree/development/examples/ClearEepromConfig
on the arduino first to make sure it starts with a fresh eeprom. After you select an Arduino sketch to test it with (seriously it doesn't matter which one you try) make sure to look at the sketch and add:
// Enable and select radio type attached #define MY_RADIO_NRF24 #define MY_NODE_ID 4For MY_NODE_ID you can select any number. Just make sure that each new sensor node that you create has a different node number so like start out at MY_NODE_ID 1 and when you make another sensor node you can #define MY_NODE_ID 2 and so on.
Next load it up to the Arduino, open the serial monitor, and see what happens. If you watch the serial monitor on the arduino you will see it present itself to the gateway and then you can confirm it in the debug log on the raspberry pi.
I think it is pretty normal to have the problems you are having. I uninstalled and reinstalled the gateway 3 times on the Raspberry Pi before I finally got it all figured out. Once you get it running it is a glorious thing.
@marceloaqno said:
cd MySensors
mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0: mysGateway: !TSF:MSG:LEN,0!=7looks like a power issue with the nrf24 module.
