  2. Announcements
    I get that when another instance of the process is already running
    cadetC
    cadetC
    cadet
    @gohan I was try to find it with ps -ef, but nothing found. Reload RPI.
    @korleone was write about this
    "Hello, it seems I found the problem: Complete newbie thing: 🔰
    sudo ./bin/mysgw -h worked, but /usr/local/bin/mysgw didn't
    I just gave the right to the folder, and now it's working."
    But what right hi gave ?
      sudo ./bin/mysgw -h could work, it only depends in which folder you are running the command from
        mvader
        FYI looks like on the 2.3.1 beta the transport has been changed to rf24 instead of nrf24
          magjef29
          Is the rasberry pi serving as a gateway and a server in this project? Or do you have to have a separate pi to host something like openhab and another pi for your gateway?
          • M magjef29
            #965
            Hi @magjef29, welcome to the MySensors forum!
            You can run your controller(s) on the same Raspberry Pi.
            Depending on what tou mean by ”server”, the gateway can be a server, but the gateway is not a controller.
            If you haven’t already, see the getting started guide for information about the different parts.
            • А
              А
              Артем ТИхонович
              Hi! Does anybody test Cubieboard as Gateway? I have a cubieboard runing archlinux with spi enabled in kernel. How i define pins for nrf24 gateway connection? Or i need to make big changes in code to star work with different bord than Rpi?
              Best regards
              • А
                А
                Артем ТИхонович
                This is my old dream to connect directly nrf to Cubieboard GPIOs. Few years ago i try to do this without success using this lib - https://github.com/bearpawmaxim/librf24-sunxi
                • А Артем ТИхонович
                  #968
                  Hi @артем-тихонович, welcome to the MySensors forum!
                  For the NRF24, the same defines as for normal sketches are used. Documentation: https://www.mysensors.org/apidocs/group__RF24SettingGrpPub.html
                  The defines can be added to the Raspberry Pi gateway by following the instructions on https://www.mysensors.org/build/raspberry#advanced
                  I have not heard about anyone using the Cubieboard but hopefully someone else has. The information provided on https://www.mysensors.org/build/orange might be useful if the Cubieboard is similar to the Orange Pie.
                  oh, and in case you haven't already, see the ./configure --help text about the most common NRF24 defines; you might not need the advanced build options.
                  • А
                    А
                    Артем ТИхонович
                    Thank you, @mfalkvidd. Ihave a little troubles with correct defining gpios from Cubie. In fex file the gpios defines is:
                    [gpio_para]
                    gpio_used = 1
                    gpio_num = 2
                    gpio_pin_1 = port:PH07<0><default><default><default>
                    gpio_pin_2 = port:PH15<6><default><default><default>
                    in sys/gpio:
                    [root@Archey boot]# ls -ls /sys/class/gpio/
                    total 0
                    0 --w------- 1 root root 4096 Nov 21 11:58 export
                    0 lrwxrwxrwx 1 root root 0 Nov 18 17:01 gpio1_ph7 -> ../../devices/platform/gpio-sunxi/gpio/gpio1_ph7
                    0 lrwxrwxrwx 1 root root 0 Nov 21 11:54 gpio2_ph15 -> ../../devices/platform/gpio-sunxi/gpio/gpio2_ph15
                    0 lrwxrwxrwx 1 root root 0 Nov 18 10:45 gpiochip1 -> ../../devices/platform/gpio-sunxi/gpio/gpiochip1
                    0 --w------- 1 root root 4096 Nov 18 16:52 unexport
                    When i define in configure: --my-rf24-ce-pin=1 --my-rf24-cs-pin=2 build is ok, but test failed with error:
                    Nov 21 11:58:15 ERROR Could not open /sys/class/gpio/gpio1/direction[root@Archey MySensors]#
                    when i define --my-transport=nrf24 --my-rf24-ce-pin=gpio1_ph7 the build failed wirh error:
                    ./drivers/RF24/RF24.cpp: In function 'void RF24_ce(bool)':
                    <command-line>:0:16: error: 'gpio1_ph7' was not declared in this scope
                    ./drivers/RF24/RF24.cpp:52:17: note: in expansion of macro 'MY_RF24_CE_PIN'
                    hwDigitalWrite(MY_RF24_CE_PIN, level);
                    How can i resolve this problem? Please help.
                    • А
                      А
                      Артем ТИхонович
                      I just see for another app using nrf24 on cubieboard
                      and funcrtion to use nrf24 have GPIO defining is RF24 radio(SUNXI_GPB(10), SUNXI_GPB(11), "/dev/spidev0.0");
                      GPIO set using this style: SUNXI_GPB(10), this type of gpio defined in #include "gpio_sun4i.h" file. Maybe this specific defining in ARCHLINUX ARM distro.
                      • alowhumA
                        alowhumA
                        alowhum
                        I hereby donate these images:
                        4_1542918057729_step1.png 3_1542918057729_step2.png 2_1542918057728_step3.png 1_1542918057727_step4.png 0_1542918057727_step5.png
                        • А Артем ТИхонович
                          In case someone can help @артем-тихонович, please post the answer in https://forum.mysensors.org/post/95304 so we don’t unnecessarily discuss the same thing in separate threads.
                          • MasMatM
                            MasMatM
                            MasMat
                            wrote on last edited by MasMat
                            #973
                            I get weird errors when "make"ing. Branch master.
                            My command:
                            sudo ./configure --my-transport=rf24 --my-rf24-irq-pin=15 --my-signing-debug --my-signing=password --my-security-password=ZZZZZZZZZZ --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=XXXX --my-mqtt-password=YYYYY --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-config-file=/etc/mysensors.conf
                            M -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                            In file included from ./MySensors.h:148:0,
                                             from examples_linux/mysgw.cpp:82:
                            ./core/MySigningAtsha204Soft.cpp: In function ‘bool signerAtsha204SoftGetNonce(MyMessage&)’:
                            ./core/MySigningAtsha204Soft.cpp:173:55: error: no matching function for call to ‘min(unsigned int, int)’
                              msg.set(_signing_verifying_nonce, MIN(MAX_PAYLOAD, 32));
                            In file included from /usr/include/c++/6/algorithm:62:0,
                                             from ./drivers/Linux/Arduino.h:32,
                                             from ./MySensors.h:39,
                            /usr/include/c++/6/bits/stl_algo.h:3453:5: note: candidate: template<class _Tp, class _Compare> constexpr _Tp std::min(std::initializer_list<_Tp>, _Compare)
                                 min(initializer_list<_Tp> __l, _Compare __comp)
                            /usr/include/c++/6/bits/stl_algo.h:3453:5: note:   template argument deduction/substitution failed:
                            ./core/MySigningAtsha204Soft.cpp:173:55: note:   mismatched types ‘std::initializer_list<_Tp>’ and ‘unsigned int’
                            /usr/include/c++/6/bits/stl_algo.h:3447:5: note: candidate: template<class _Tp> constexpr _Tp std::min(std::initializer_list<_Tp>)
                                 min(initializer_list<_Tp> __l)
                            /usr/include/c++/6/bits/stl_algo.h:3447:5: note:   template argument deduction/substitution failed:
                            In file included from /usr/include/c++/6/bits/char_traits.h:39:0,
                                             from /usr/include/c++/6/ios:40,
                                             from /usr/include/c++/6/ostream:38,
                                             from /usr/include/c++/6/iostream:39,
                                             from examples_linux/mysgw.cpp:20:
                            /usr/include/c++/6/bits/stl_algobase.h:243:5: note: candidate: template<class _Tp, class _Compare> constexpr const _Tp& std::min(const _Tp&, const _Tp&, _Compare)
                                 min(const _Tp& __a, const _Tp& __b, _Compare __comp)
                            /usr/include/c++/6/bits/stl_algobase.h:243:5: note:   template argument deduction/substitution failed:
                            ./core/MySigningAtsha204Soft.cpp:173:55: note:   deduced conflicting types for parameter ‘const _Tp’ (‘unsigned int’ and ‘int’)
                            /usr/include/c++/6/bits/stl_algobase.h:195:5: note: candidate: template<class _Tp> constexpr const _Tp& std::min(const _Tp&, const _Tp&)
                                 min(const _Tp& __a, const _Tp& __b)
                            /usr/include/c++/6/bits/stl_algobase.h:195:5: note:   template argument deduction/substitution failed:
                            ./core/MySigningAtsha204Soft.cpp: In function ‘void signerAtsha204SoftPutNonce(MyMessage&)’:
                            ./core/MySigningAtsha204Soft.cpp:190:89: error: no matching function for call to ‘min(unsigned int, int)’
                              (void)memcpy((void *)_signing_nonce, (const void *)msg.getCustom(), MIN(MAX_PAYLOAD, 32));
                            ./core/MySigningAtsha204Soft.cpp:190:89: note:   mismatched types ‘std::initializer_list<_Tp>’ and ‘unsigned int’
                            ./core/MySigningAtsha204Soft.cpp:190:89: note:   deduced conflicting types for parameter ‘const _Tp’ (‘unsigned int’ and ‘int’)
                            ./core/MySigningAtsha204Soft.cpp: In function ‘bool signerAtsha204SoftSignMsg(MyMessage&)’:
                            ./core/MySigningAtsha204Soft.cpp:229:50: error: no matching function for call to ‘min(unsigned int, int)’
                                           MIN(MAX_PAYLOAD-mGetLength(msg), 32));
                            ./core/MySigningAtsha204Soft.cpp:229:50: note:   mismatched types ‘std::initializer_list<_Tp>’ and ‘unsigned int’
                            ./core/MySigningAtsha204Soft.cpp:229:50: note:   deduced conflicting types for parameter ‘const _Tp’ (‘unsigned int’ and ‘int’)
                            ./core/MySigningAtsha204Soft.cpp: In function ‘bool signerAtsha204SoftVerifyMsg(MyMessage&)’:
                            ./core/MySigningAtsha204Soft.cpp:283:55: error: no matching function for call to ‘min(unsigned int, int)’
                                                MIN(MAX_PAYLOAD-mGetLength(msg), 32))) {
                            ./core/MySigningAtsha204Soft.cpp:283:55: note:   mismatched types ‘std::initializer_list<_Tp>’ and ‘unsigned int’
                            ./core/MySigningAtsha204Soft.cpp:283:55: note:   deduced conflicting types for parameter ‘const _Tp’ (‘unsigned int’ and ‘int’)
                            ./core/MySigningAtsha204Soft.cpp: In function ‘void signerCalculateSignature(MyMessage&, bool)’:
                            ./core/MySigningAtsha204Soft.cpp:307:48: error: no matching function for call to ‘min(uint8_t&, int)’
                               uint8_t bytes_to_include = MIN(bytes_left, 32);
                            ./core/MySigningAtsha204Soft.cpp:307:48: note:   mismatched types ‘std::initializer_list<_Tp>’ and ‘unsigned char’
                            ./core/MySigningAtsha204Soft.cpp:307:48: note:   deduced conflicting types for parameter ‘const _Tp’ (‘unsigned char’ and ‘int’)
                            ./core/MySigningAtsha204Soft.cpp:289:1: warning: control reaches end of non-void function [-Wreturn-type]
                            Makefile:98: recipe for target 'build/examples_linux/mysgw.o' failed
                            make: *** [build/examples_linux/mysgw.o] Error 1
                            Can someone better versed help?
                            EDIT: tested branch development, no problems.
                              Could be same as https://forum.mysensors.org/topic/10036/unable-to-compile-raspberry-pi-gateway-when-signing-enable
                              MasMatM 1 Reply Last reply
                                MasMatM
                                MasMatM
                                MasMat
                                #975
                                @mfalkvidd It sure looks the same. I did a fresh git clone to update my gateway, so shouldn't it be fixed? From what appears on github it looked fixed..
                                EDIT appears fixed in development branch. But not master?
                                • MasMatM MasMat
                                  @masmat said in 💬 Building a Raspberry Pi Gateway:
                                  Yes that is correct
                                  • R
                                    R
                                    Robert Król
                                    hi,
                                    is it possible to conect NRF24 to SPI1 channel on RBpi3?
                                    (i mean pins 26, 35, 36,38,40)??
                                    • R Robert Król
                                      hi,
                                      #978
                                      Welcome to the forum @robert-król
                                      I have not tried it myself, but I beleive https://forum.mysensors.org/post/76079 shows how to do it.
                                      • B
                                        B
                                        barrydou
                                        wrote on last edited by barrydou
                                        #979
                                        Hello
                                        Is it possible to redefine pin used for DI00 with rfm69 (with configure option for example) ?
                                        Indeed, DI00 is on pin 22 on raspberry, and pin 2 on arduino.
                                        But with NRF, pin 2 on arduino is for IRQ, which is connected to pin 15 on raspberry.
                                        So if it was possible to force pin 15 for DI00, we could use adaptator card like this one https://www.mysensors.org/hardware/nrf2rfm69.
                                        gohanG 1 Reply Last reply
                                        • R
                                          R
                                          Rolo6442u
                                          Hi, just build an Ethernet gateway on a raspberry pi B+ following the instructions on this site. And it works! I'm running raspbian stretch lite and used the master branch. No issues. I use the RFM69 radio and this gateway has the HW model. I did have to update al my nodes to use the new RFM69 drivers but that was clearly mentioned in the article.
                                          I have two questions:
                                          1. In this section :
                                          log_pipe=0
                                          log_pipe_file=/tmp/mysgw.pipe
                                          Is this correct, I think there should be a 1 to enable this type of logging.
                                          1. When a new version of mysensors is released, how do I update the gateway version on the raspberry pi?
                                          And here is a picture of my work:
                                          Thanks for the effort you put into this project!
