💬 Building a Raspberry Pi Gateway
I created a virtual serial port using this ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway. I can see the port in the dev folder, but when I run dmesg I do not see it listed and therefore my openhab can not find it. How can I fix this?
@jmmorgan83 You may need another name for the port, such as
./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020 -
./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020@marceloaqno
Unfortunately, no luck:(. -
@hausinger After the command:
sudo ./bin/mysgw -dIt wasn't supposed to go back to bash, the gateway would wait for new messages.
I'm not sure what's going on with your setup because I tested your configuration options here and it worked.@marceloaqno said:
I'm not sure what's going on with your setup because I tested your configuration options here and it worked.Thank you for your answer. What can I do now? Can I check, that this port is unused? And how can I check this?
Or is there another problem? -
FYI: I do not think the Rpi gateway works with Openhab on the same unit. I have tried both the virtual serial port and mqtt, and neither will work with Openhab 1.83.
Hi all,
So I built this and all seems to be well. But.....how do I test it properly?
I also installed pidome and have that able to 'see' the MSYGW, but it advises to only add it if it is working.
So how to know if mysgw is working OK? Is there somewhere a step-by-step way to do this?
sudo ./bin/mysgw -d and sudo ./bin/mysgw -h now both give 'command not found' - which is odd as they were both working eariler ???
A reboot makes no difference. Although after reboot I see mysgw running in 'top' but even stopping that service and trying sudo mysgw -d again doesn't seem to work.Any idea whats wrong? Any suggestions to get this going?
That doesn't appear anywhere on this tutorial, so maybe it needs adding for completion?
Anyway the output is now......
pi@PiDomePi:~ $ sudo /usr/local/bin/mysgw -d
mysgw: Starting gateway...
mysgw: Protocol version - 2.0.1-beta
mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta
mysgw: TSF:LRT:OK
mysgw: TSM:INIT
mysgw: TSM:INIT:TSP OK
mysgw: TSM:INIT:GW MODE
mysgw: TSM:READY
mysgw: MCO:REG:NOT NEEDED
mysgw: MCO:BGN:STP
mysgw: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1When i did build install I missed out bit for the leds, can I just re-run the ./config and 'make' then 'make install' again? Or will that cause problems??
I just think that the lights will be useful in the early stages of getting this running...Thanks for the help, no way would I have got that without you! :)
mysgw: TSF:LRT:OK
mysgw: TSM:INIT
mysgw: TSM:READY
mysgw: MCO:BGN:STP
Can I just check that this is OK? .....
./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-transport=nrf24 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
Can you see any problems here, it seemed to work but I hope to test fully this week, maybe tomorrow.....
What makes you think that the cabling is wrong? - I checked and can't see any problem....can you be less cryptic please? :)
hi
yesterday i tried to build a rpi-gateway but i had trouble to access, after changeing the rights on the port to 777 and group to dialout i could access via
fhem. and i didn't use the symlink, i used the port directly /dev/pts/0@115200 andthen it works perfectly!thanks...
p.s.: i uses always sudo while make and the other installation commands.
greets mike
Get this error from the gateway installed on Raspberry Pi2 with RFM69 Radio.
From the IDE it works fine:
0;255;3;0;9;Starting gateway (RRNGA-, 2.0.0)
0;255;3;0;9;TSM:INIT
0;255;3;0;9;TSM:RADIO:OK
0;255;3;0;9;TSM:GW MODE
0;255;3;0;9;TSM:READY
0;255;0;0;18;2.0.0
0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
0;255;3;0;9;TSP:MSG:BC
0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
0;255;3;0;9;TSP:CHKUPL:OK
0;255;3;0;9;TSP:MSG:GWL OK
0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
0;255;3;0;9;TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
255;255;3;0;3;
255;255;3;0;3;
255;255;3;0;3;
255;255;3;0;3;mysgw: Starting gateway...
mysgw: Protocol version - 2.1.0-beta
mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.0-beta
mysgw: TSF:LRT:OK
mysgw: TSM:INIT
mysgw: TSF:WUR:MS=0
mysgw: !TSM:INIT:TSP FAIL
mysgw: TSM:FAIL:CNT=1From the gateway on the Pi this is the error:
./bin/mysgw -d
mysgw: TSF:LRT:OK
mysgw: TSM:INIT
mysgw: TSF:WUR:MS=0
mysgw: TSM:FAIL:PDT
mysgw: TSM:FAIL:RE-INIT
mysgw: TSM:INIT
mysgw: TSM:FAIL:CNT=2
mysgw: TSM:FAIL:PDT
mysgw: TSM:INIT
mysgw: TSM:FAIL:CNT=3
mysgw: TSM:FAIL:PDT
mysgw: TSM:INIT
mysgw: TSM:FAIL:CNT=4
mysgw: TSM:FAIL:PDTAny ideas where I might start looking at?
Thanks,
Martin
