  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 92.4k Views 37 Watching
  • S Samuel235
    I seem to be getting a connection to my gateway, while monitoring the two topics for the gateway i only seem to see any activity regarding this sensor on the gateway-out topic, and it keeps sending out a type 2 message (req). The serial monitor of the sensors is showing:
    104198 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    114199 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    124200 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    134201 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    144202 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    154203 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    164204 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    174205 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    184206 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    194207 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    So it seems to be sending a request package, but i don't see it on the gateway-in topic and i see other sensors sending data to the gateway-in topic so i'm not subscribed to the wrong one. Is this a structural request message or is this the feature that requests the last known message from the gateway? Either way, there doesn't seem to be any sensor data being sent from the node to the gateway.
    #81
    @Samuel235 said in 💬 Power Meter Pulse Sensor:
    I dont know if I dont understand you, but it seems like your node is requesting the last pulse counter. I have mentioned this in several threads I have a problem with this (both this thread and rain sensor thread). Im using an ethernet gw and the request reaches the gw but there my error led blinks and it fails to send it back (or recieve it on the node) so it re-request it.
    I have never been able to pinpoint it due to repeaters in between.
    https://forum.mysensors.org/topic/2116/hard-to-grab-time-and-value-sent-from-controller/ (old).
    S 1 Reply Last reply
    • sundberg84S sundberg84
      Samuel235
      @sundberg84 - You do understand me correctly :). I made a thread on the troubleshooting section of the forum for this simply because i suspected it was normal behaviour, however. It seems that the node isn't sending any other data to the gateway at all and it can not get the previous value as there isn't one. So, my post here and on the troubleshooting section was me aiming to get to this point and then troubleshoot the actual node to see what can be done to get it to send data.
      • S
        Samuel235
        Has anyone came across their pulse meter not sending the message for WATT, the other two messages are being sent perfectly fine. My WATT message has been working all day and suddenly stopped.
        • NiklasON
          NiklasON
          NiklasO
          Make sure that you don't reach your wattage limit in the sketch.
          • NiklasON NiklasO
            Samuel235
            @NiklasO - Where is this value stored? I've cleared the EEPROM and the MQTT topic too, but it still refuses to send the watt value.
            NiklasON 1 Reply Last reply
            • S Samuel235
              NiklasON
              NiklasON
              NiklasO
              wrote on last edited by NiklasO
              #86
              @Samuel235
              In the sketch, change this
              #define MAX_WATT 10000 // Max watt value to report. This filetrs outliers.
              I have it set to 20000, using 15 000 easily when it's cold outside. ;-) Just make sure that you use the right divider for your pulse/kWh count.
              • NiklasON NiklasO
                @Samuel235
                Samuel235
                Ahh i see what it is it; its set to not send if it hasn't changed.... how much of a silly error that was from me. The wattage is way below 1000 but because i'm using a normal LED on another arduino flashing at a constant rate to set my node up, its not changing the watt value.
                Back to solving my initial issue now >.<
                Thank you.
                • NiklasON
                  NiklasON
                  NiklasO
                  Ah, I see. Well, I would like the sensor to send data even if it hasn't changed. What did you change?
                    Watt usage is normally changing all the time, so you should have data reported quite often
                      NiklasON
                      NiklasON
                      NiklasO
                      #90
                      @gohan But Samuel235 had that problem? ;-) Edit: well, ok, he had a different setup. I need to read better. ;)
                      • S
                        Samuel235
                        To be honest, i had it running for a while before it stopped sending the WATTS. But i'm guessing this is the issue as if i vary the blinks it sends it. I'de like to see if anyone has this working recently on OpenHAB through means of not touching the node sketch like people have posted before. I have an idea to send the data of the pulse count message onto the request message topic on MQTT and so then when it requests previous count it would have it.
                        M 1 Reply Last reply
                        • S
                          Samuel235
                          #92
                          This post is deleted!
                          • S Samuel235
                            mickecarlsson
                            wrote on last edited by mickecarlsson
                            #93
                            EDIT:
                            This was not the case, I am still debugging the issue, in the mean time I have deleted the code.
                            After some debugging it seems that Domoticz messes with the V_WATT and V_KWH, and the solution is to have two sensors, one for kWh and one for W.
                            After I changed it, I have consistent W and kWh.
                            See also this issue for Home Assistant
                              mickecarlsson
                              #94
                              OK, I think I have nailed it. I am now running a beta code pulling S0 from my energy meter and I am getting consistent results.
                              Before when I checked the domoticz.db I got this for Energy:
                              sqlite> select Name, sValue from DeviceStatus;
                              Storage kWh|0.000;4773.700
                              Now I get this:
                              Storage kWh|118.000;11678062.000
                              Notice that the first field is now with value, previously it was 0.000 (and I have updated the meter count to the actual value)
                              And in table Meter I now get consistent results:
                              sqlite> SELECT Value, Usage, Date FROM Meter WHERE DeviceRowID=43;
                              11678003|1170|2017-07-22 09:25:00
                              11678012|1170|2017-07-22 09:30:00
                              11678021|1180|2017-07-22 09:35:00
                              11678031|1180|2017-07-22 09:40:00
                              11678043|1170|2017-07-22 09:45:00
                              11678053|1180|2017-07-22 09:50:00
                              11678062|1180|2017-07-22 09:55:00
                              11678072|1180|2017-07-22 10:00:00
                              The field Usage is now populated as it should.
                              I will let the code run for a couple of days, then I will post the updated code here.
                                mickecarlsson
                                Here is a code example that works for me. I have an energy meter with S0 output and I use Domoticz as the controller.
                                 * Version 1.0 - Henrik EKblad
                                 * Version 1.1 - Mikael Carlsson
                                 * This sketch provides an example how to implement a sensor reading from an energy meter
                                 * Use this sensor to measure KWH and Watt of your house meeter
                                 * You need to set the correct pulsefactor of your meeter (blinks per KWH).
                                 * The sensor starts by fetching current KWH value from gateway.
                                 * Reports both KWH and Watt back to gateway.
                                 * Unfortunately millis() won't increment when the Arduino is in
                                 * sleepmode. So we cannot make this sensor sleep if we also want
                                 * to calculate/report watt-number.
                                 * http://www.mysensors.org/build/pulse_power
                                // Enable debug prints
                                #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
                                #define PULSE_FACTOR 1000       // Nummber of blinks per KWH of your meter
                                #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
                                #define MAX_WATT 10000          // Max watt value to report. This filters bad data.
                                #define CHILD_ID 1              // Id of the sensor child
                                unsigned long SEND_FREQUENCY =
                                    20000; // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                                double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
                                bool pcReceived = false;
                                volatile unsigned long watt = 0;
                                unsigned long oldWatt = 0;
                                double oldKwh;
                                unsigned long lastSend;
                                MyMessage wattMsg(CHILD_ID,V_WATT);
                                MyMessage kwhMsg(CHILD_ID,V_KWH);
                                    request(CHILD_ID, V_VAR1);
                                    // Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output
                                    // If no pullup is used, the reported usage will be too high because of the floating pin
                                    pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
                                    attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
                                    lastSend=millis();
                                    sendSketchInfo("Energy Meter", "1.0");
                                    present(CHILD_ID, S_POWER);
                                    unsigned long now = millis();
                                    bool sendTime = now - lastSend > SEND_FREQUENCY;
                                    if (pcReceived && (SLEEP_MODE || sendTime)) {
                                        // New watt value has been calculated
                                        if (!SLEEP_MODE && watt != oldWatt) {
                                            // Check that we dont get unresonable large watt value.
                                            // could happen when long wraps or false interrupt triggered
                                            // We need to send in all values at one time to get consistent data
                                            if (watt<((unsigned long)MAX_WATT)) {
                                                send(wattMsg.set(watt));  // Send watt value to gw
                                                Serial.print("Watt: ");
                                                Serial.println(watt);
                                                oldWatt = watt;
                                                send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                                                Serial.print("pulseCount: ");
                                                double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                                                oldPulseCount = pulseCount;
                                                send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                                                Serial.print("kWh: ");
                                                Serial.println(kwh);
                                                oldKwh = kwh;
                                        lastSend = now;
                                    } else if (sendTime && !pcReceived) {
                                        // No count received. Try requesting it again
                                        lastSend=now;
                                    if (SLEEP_MODE) {
                                        sleep(SEND_FREQUENCY);
                                    if (message.type==V_VAR1) {
                                        Serial.println(pulseCount);
                                        pcReceived = true;
                                void onPulse()
                                    if (!SLEEP_MODE) {
                                        unsigned long interval = newBlink-lastBlink;
                                        if (interval<10000L) { // Sometimes we get interrupt on RISING
                                            return;
                                        watt = (3600000000.0 /interval) / ppwh;
                                        lastBlink = newBlink;
                                    pulseCount++;
                                • D
                                  D
                                  dakipro
                                  One (probably stupid) question about the batter powered option: Since sensor cannot keep track of real time power usage as it sleeps most of the time, would it be possible to do the math on the controller side and get "5min delay real time power usage"?
                                  By dividing number of pulses since last transmission, is that basically what this sensor is doing when not being powered by batteries?
                                  I could experiment with 2min delay f.eks, and see how batteries hold. If dht22 temp sensors works over a year with 5min transmission time, i hope 2min delay in pulse meter can hold 6mnt or something?
                                  Another thing is that the electrical box is all metal, and there is a lot of electricity around the sensor so radio could struggle (I guess a repeater would definitively help)
                                    wrote on last edited by gohan
                                    #97
                                    Is it only me that is getting a compile error?
                                    Error: call of overloaded 'set(volatile long unsigned int&)' is ambiguous
                                    send(wattMsg.set(watt)); \ Send watt value to gw
                                    error: call of overloaded 'set(volatile long unsigned int&)' is ambiguous
                                    send(pcMsg.set(pulseCount)); \ Send pulse count value to gw
                                    followed by all the possible candidates of .set arguments
                                      @gohan I get the same, both for 2.1.1 and 2.2.0-beta. Strange. I thought there were Jenkins tests that endured the examples compiled.
                                        Replacing all
                                        unsigned long
                                        with
                                        uint32_t
                                        makes the sketch compile fine, but I don't know if that is the correct solution.
                                          I created an issue for this, https://github.com/mysensors/MySensors/issues/910
