  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 93.0k Views 37 Watching
  • NiklasON NiklasO
    Make sure that you don't reach your wattage limit in the sketch.
    Samuel235
    @NiklasO - Where is this value stored? I've cleared the EEPROM and the MQTT topic too, but it still refuses to send the watt value.
    NiklasON 1 Reply Last reply
    • S Samuel235
      NiklasON
      NiklasON
      NiklasO
      wrote on last edited by NiklasO
      #86
      @Samuel235
      In the sketch, change this
      #define MAX_WATT 10000 // Max watt value to report. This filetrs outliers.
      I have it set to 20000, using 15 000 easily when it's cold outside. ;-) Just make sure that you use the right divider for your pulse/kWh count.
      S 1 Reply Last reply
      • NiklasON NiklasO
        @Samuel235
        Samuel235
        Ahh i see what it is it; its set to not send if it hasn't changed.... how much of a silly error that was from me. The wattage is way below 1000 but because i'm using a normal LED on another arduino flashing at a constant rate to set my node up, its not changing the watt value.
        Back to solving my initial issue now >.<
        Thank you.
        • NiklasON
          NiklasON
          NiklasO
          Ah, I see. Well, I would like the sensor to send data even if it hasn't changed. What did you change?
            Watt usage is normally changing all the time, so you should have data reported quite often
              NiklasON
              NiklasON
              NiklasO
              #90
              @gohan But Samuel235 had that problem? ;-) Edit: well, ok, he had a different setup. I need to read better. ;)
                Samuel235
                To be honest, i had it running for a while before it stopped sending the WATTS. But i'm guessing this is the issue as if i vary the blinks it sends it. I'de like to see if anyone has this working recently on OpenHAB through means of not touching the node sketch like people have posted before. I have an idea to send the data of the pulse count message onto the request message topic on MQTT and so then when it requests previous count it would have it.
                  Samuel235
                  #92
                  • S Samuel235
                    mickecarlsson
                    wrote on last edited by mickecarlsson
                    #93
                    EDIT:
                    This was not the case, I am still debugging the issue, in the mean time I have deleted the code.
                    After some debugging it seems that Domoticz messes with the V_WATT and V_KWH, and the solution is to have two sensors, one for kWh and one for W.
                    After I changed it, I have consistent W and kWh.
                    See also this issue for Home Assistant
                      mickecarlsson
                      #94
                      OK, I think I have nailed it. I am now running a beta code pulling S0 from my energy meter and I am getting consistent results.
                      Before when I checked the domoticz.db I got this for Energy:
                      sqlite> select Name, sValue from DeviceStatus;
                      Storage kWh|0.000;4773.700
                      Now I get this:
                      Storage kWh|118.000;11678062.000
                      Notice that the first field is now with value, previously it was 0.000 (and I have updated the meter count to the actual value)
                      And in table Meter I now get consistent results:
                      sqlite> SELECT Value, Usage, Date FROM Meter WHERE DeviceRowID=43;
                      11678003|1170|2017-07-22 09:25:00
                      11678012|1170|2017-07-22 09:30:00
                      11678021|1180|2017-07-22 09:35:00
                      11678031|1180|2017-07-22 09:40:00
                      11678043|1170|2017-07-22 09:45:00
                      11678053|1180|2017-07-22 09:50:00
                      11678062|1180|2017-07-22 09:55:00
                      11678072|1180|2017-07-22 10:00:00
                      The field Usage is now populated as it should.
                      I will let the code run for a couple of days, then I will post the updated code here.
                        mickecarlsson
                        Here is a code example that works for me. I have an energy meter with S0 output and I use Domoticz as the controller.
                         * Version 1.0 - Henrik EKblad
                         * Version 1.1 - Mikael Carlsson
                         * This sketch provides an example how to implement a sensor reading from an energy meter
                         * Use this sensor to measure KWH and Watt of your house meeter
                         * You need to set the correct pulsefactor of your meeter (blinks per KWH).
                         * The sensor starts by fetching current KWH value from gateway.
                         * Reports both KWH and Watt back to gateway.
                         * Unfortunately millis() won't increment when the Arduino is in
                         * sleepmode. So we cannot make this sensor sleep if we also want
                         * to calculate/report watt-number.
                         * http://www.mysensors.org/build/pulse_power
                        // Enable debug prints
                        #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
                        #define PULSE_FACTOR 1000       // Nummber of blinks per KWH of your meter
                        #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
                        #define MAX_WATT 10000          // Max watt value to report. This filters bad data.
                        unsigned long SEND_FREQUENCY =
                            20000; // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                        double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
                        bool pcReceived = false;
                        unsigned long oldPulseCount = 0;
                        unsigned long oldWatt = 0;
                        double oldKwh;
                        unsigned long lastSend;
                        MyMessage wattMsg(CHILD_ID,V_WATT);
                        MyMessage kwhMsg(CHILD_ID,V_KWH);
                        MyMessage pcMsg(CHILD_ID,V_VAR1);
                            request(CHILD_ID, V_VAR1);
                            pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
                            attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
                            lastSend=millis();
                            present(CHILD_ID, S_POWER);
                            unsigned long now = millis();
                            if (pcReceived && (SLEEP_MODE || sendTime)) {
                                if (!SLEEP_MODE && watt != oldWatt) {
                                    // could happen when long wraps or false interrupt triggered
                                    // We need to send in all values at one time to get consistent data
                                    if (watt<((unsigned long)MAX_WATT)) {
                                        Serial.print("Watt: ");
                                        Serial.println(watt);
                                        oldWatt = watt;
                                        send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                                        Serial.print("pulseCount: ");
                                        double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                                        oldPulseCount = pulseCount;
                                        send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                                        Serial.print("kWh: ");
                                        Serial.println(kwh);
                                        oldKwh = kwh;
                                lastSend = now;
                            } else if (sendTime && !pcReceived) {
                                // No count received. Try requesting it again
                                lastSend=now;
                            if (SLEEP_MODE) {
                                sleep(SEND_FREQUENCY);
                            if (message.type==V_VAR1) {
                                pulseCount = oldPulseCount = message.getLong();
                                Serial.print("Received last pulse count from gw:");
                                Serial.println(pulseCount);
                                pcReceived = true;
                        void onPulse()
                            if (!SLEEP_MODE) {
                                unsigned long interval = newBlink-lastBlink;
                                if (interval<10000L) { // Sometimes we get interrupt on RISING
                                    return;
                                watt = (3600000000.0 /interval) / ppwh;
                                lastBlink = newBlink;
                            pulseCount++;
                        • D
                          dakipro
                          One (probably stupid) question about the batter powered option: Since sensor cannot keep track of real time power usage as it sleeps most of the time, would it be possible to do the math on the controller side and get "5min delay real time power usage"?
                          By dividing number of pulses since last transmission, is that basically what this sensor is doing when not being powered by batteries?
                          I could experiment with 2min delay f.eks, and see how batteries hold. If dht22 temp sensors works over a year with 5min transmission time, i hope 2min delay in pulse meter can hold 6mnt or something?
                          Another thing is that the electrical box is all metal, and there is a lot of electricity around the sensor so radio could struggle (I guess a repeater would definitively help)
                            wrote on last edited by gohan
                            #97
                            Is it only me that is getting a compile error?
                            Error: call of overloaded 'set(volatile long unsigned int&)' is ambiguous
                            send(wattMsg.set(watt)); \ Send watt value to gw
                            error: call of overloaded 'set(volatile long unsigned int&)' is ambiguous
                            send(pcMsg.set(pulseCount)); \ Send pulse count value to gw
                            followed by all the possible candidates of .set arguments
                              @gohan I get the same, both for 2.1.1 and 2.2.0-beta. Strange. I thought there were Jenkins tests that endured the examples compiled.
                              • mfalkviddM
                                Replacing all
                                unsigned long
                                with
                                uint32_t
                                makes the sketch compile fine, but I don't know if that is the correct solution.
                                • mfalkviddM
                                  I created an issue for this, https://github.com/mysensors/MySensors/issues/910
                                    The problem with "unsigned long" is that it can have different size based on platform it's compiled on.
                                    Like @mfalkvidd says, use int32_t, uint32_t, int16_t and uint16_t which has a fixed width.
                                      I was suspecting something like that, but I was not sure if changing variable type would affect something else
                                        Ok, I got it working. On wemos it doesn't count pulses though. On domoticz does it have to configured as the value computed or from device? I'm asking because if you disconnect the sensor, on domoticz I keep seeing the same power reading
                                          BTW, is there a way to have the pulse meter running on gateway? I got stuck because at startup it asks the controller the last count value and since the controller is not yet connected it just doesn't work.
                                          A rejoe2R 2 Replies Last reply
