  2. Announcements
  3. 💬 Water Meter Pulse Sensor
109 Posts 37 Posters 66.9k Views 35 Watching
  • S smilvert
    I having problem to place the tcrt5000 on the correct place. Can anyone please show where to put it? Is it over the black (that spins every 0.5 l)?
    I have this type of water meter alt text
    F
    F
    flopp
    @smilvert
    I also have same meter as the picture. Yesterday I installed my sensor
    I took a TCRT5000 IR sensor, https://www.mysensors.org/store/water
    A cap from a soda bottle, cut it so it fits above left red wheel(X0,0001) which means one lap i 1 liter
    It works but it counts little bit wrong, I have change the
    if (interval<500000L)
    to
    if (interval<2500000L)
    but anyway it counts about 3 times to much. I will check it later today
    F S 2 Replies Last reply
    • F flopp
      @smilvert
      to
      F
      F
      flopp
      @flopp
      This didn't worked so well, I got a lot of errors everytime nRF was sending data, then I got one pulse.
      Anyone know how to protect the digital input to NOT fall when nRF sends?
      Wait, when I was writing this text :) I just remember that nRF is using Pin 2, is that correct?
      I will try to use pin 3 instead, as interrupt pin
      F 1 Reply Last reply
      • F flopp
        @flopp
        F
        F
        flopp
        @flopp
        tried pin3, didn't help
        Can it be something wrong with LM393(pcb)?
        • F flopp
          @smilvert
          to
          smilvert
          @flopp Nice. You don't use a green led? I tried that and it seems to work better but then I struggle with the mounting.
          Need to try this again!
          • S smilvert
            F
            F
            flopp
            @smilvert said in 💬 Water Meter Pulse Sensor:
            I am using IR to detect movements. Green LED is flashing eveytime the IR detects movement and Red LED is power for PCB.
            I am using Digital Output from PCB to pin 2 or 3 on my UNO. I have tried both with INPUT_PULLUP and without, also tried 20K between Digital Output and GND. nothing is helping
            How do you use green LED with water meter?
            • N
              N
              noname
              Hi all i just wanna see The OUTPUT of Serial Monitor for this project sow i can see results .
                Just enable the my_debug
                • B
                  B
                  Bur Han
                  How can i get the pulses from SonOff.... i cannot find any digital pin 3 in sonoff... im new to this please guide me
                  • SoloamS
                    SoloamS
                    Soloam
                    Any one used this approach? From the text I see that the node sleeps! How does it measures the consumption if the node is sleeping?
                    Thank you
                    • SoloamS Soloam
                      Thank you
                      #70
                      @soloam could you clarify what you refer to when saying "this"? Earlier posts discuss infrared, led, magnetometer and other solutions so it is a bit hard to answer your question.
                      • SoloamS
                        SoloamS
                        Soloam
                        @mfalkvidd hello!
                        I was referring to this statement in the site:
                        "Use this mode if you power the sensor with a battery. In this mode the sensor will sleep most of the time and only report the cumulative water volume."
                        Thank you
                          according to the sensor you use, each pulse should wake the node and add a count, then back to sleep.
                          • SoloamS
                            SoloamS
                            Soloam
                            That is nice! But I would have to test it out! Probably that would make the node all the time awake during a long bath! Ok, it would not use the radio all the time, but I would like to know who that would affect the battery!
                            Thank you all for the feedback
                            K 1 Reply Last reply
                            • SoloamS Soloam
                              K
                              K
                              kimot
                              wrote on last edited by kimot
                              #74
                              @soloam
                              We sometimes forgot about other circuit than Arduino.
                              Use CMOS counter IC and wake up your Arduino for example every 20 impulse and read counter status.
                              If you want Safe battery.
                              • bjornhallbergB
                                bjornhallbergB
                                bjornhallberg
                                @flopp Did you ever manage to stabilize the readings? Am I understanding you correctly that the readings were fine but the transmission got the reading scrambled?
                                Did you try to find a magnetic field with the meter instead? I have a similar meter and I'm wondering how best to approach the problem. I've seen people hook up Raspberries and cameras to do OCR basically but that seems like way too complex for an easy problem.
                                • bjacobseB
                                  bjacobseB
                                  bjacobse
                                  wrote on last edited by bjacobse
                                  #76
                                  @flopp said in 💬 Water Meter Pulse Sensor:
                                  TCRT5000 IR senso
                                  I have not had good results using TCRT5000 IR sensor, did you?
                                  @bjornhallberg well I still think this is the best approach to use RPI + OCR
                                  https://forum.mysensors.org/topic/1594/automatic-water-meter-reading-with-a-webcam
                                  https://blog.m.nu/vattenmatning-med-raspberry-pi-och-webkamera/
                                  F zboblamontZ 2 Replies Last reply
                                  • bjornhallbergB
                                    bjornhallbergB
                                    bjornhallberg
                                    While looking into the water meter I realized that we are getting a "smart" meter replacement soon. I'll see if I can speed up the replacement schedule. Anyhow, the replacement is a Kamstrup Multical 21 (https://www.kamstrup.com/en-en/water-solutions/water-meters/multical-21) which has several options for reading:
                                    • Requesting the data via optical interface?
                                    • Enabling the pulse function via optical interface, and then reading the IR pulse at 1imp/10lit.
                                    • Reading the wireless mbus signal? (e.g. https://github.com/weetmuts/wmbusmeters)
                                      zboblamontZ
                                      zboblamontZ
                                      zboblamont
                                      @bjornhallberg Suggest you discuss with your water supplier, and see what THEY intend to deploy for comms and explain what your own objectives are, that may refine what you are looking at, and they MIGHT actually help rather than be play "stupid" which is unfortunately common nowadays. In all probability they will be looking at wireless m-bus for drive-by readings, this is the predominant method of retrieval.
                                      I admit to surprise at them deploying ultrasonics, they are on the expensive end of the market but they are extremely reliable and accurate.
                                      • bjacobseB bjacobse
                                        TCRT5000 IR senso
                                        F
                                        F
                                        flopp
                                        @bjacobse said in 💬 Water Meter Pulse Sensor:
                                        TCRT5000 IR senso
                                        I didn’t get it to work.
                                        I was so lucky that my water company change the meter to a meter with wireless m-bus.
                                        So I bought a box for this and now I have 100% correct readings.
                                          TCRT5000 IR senso
                                          zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          @bjacobse Another option perhaps to consider (if it is physically viable), is to insert a meter and sensor of your choice within your property, they are not expensive nowadays and easy enough to fit ?
                                          A simple meter and reed switch such as this link text or similar perhaps.
                                          bjacobseB 1 Reply Last reply
