  2. Announcements
  3. 💬 Water Meter Pulse Sensor
109 Posts 37 Posters 66.9k Views 35 Watching
  • S stevefury
    @mfalkvidd how looks the sensor now with the modifications? and how to wire this?
    #101
    @stevefury sorry, I don't understand. Which modifications are you referring to?
    • I
      I
      ibibiuooui
      I'm just getting this....
      16:57:15.660 -> 10091 TSM:FAIL:RE-INIT
      16:57:15.660 -> 10093 TSM:INIT
      16:57:15.660 -> 10101 !TSM:INIT:TSP FAIL
      16:57:15.660 -> 10103 TSM:FAIL:CNT=2
      16:57:15.660 -> 10107 TSM:FAIL:DIS
      16:57:15.713 -> 10111 TSF:TDI:TSL
      • rejoe2R
        rejoe2R
        rejoe2
        @ibibiuooui said in 💬 Water Meter Pulse Sensor:
        !TSM:INIT:TSP FAIL
        See https://www.mysensors.org/build/parser: There's a problem in the initialisation of your transceiver (whatever it may be). So first check wiring, see https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time for further details. If that doesn't help, imo you should open up a seperate thread.
        • CrankyCoderC
          CrankyCoderC
          CrankyCoder
          wrote on last edited by CrankyCoder
          #104
          I am finally getting around to trying this out. I was playing with just trying to see if i can get the pulses. First thing i did was take an old compass and put it beside the meter and had someone turn on the water. I could definitely see the compass needle pull a little as the water was flowing. So I assumed that pull was enough to be detectable with my hall effect sensor. I have tried a couple, and just can't seem to get it to pick up.
          If i use a magnet, simple code will detect the pulse and the green led on the sensor lights up.
          But no matter where I put that sensor near the meter it just doesn't seem to detect it. Not quite sure what's happening.
          The meter i have is this one.
          https://www.badgermeter.com/resources/add29b88-1ffb-49c9-80ab-bb8697bd6d1a/absolute digital encoder product data sheet ade-ds-00183-en.pdf/
          Not sure if anyone has any recommendation on which hall effect sensor would be the best for this but ill take suggestions lol
          My sensor I am testing with is
          3144E Hall Effect Sensor
          Doesn't have a sensitivity dial but the recommended one on this build page didn't either.
          Home Automation Tinkerer
          www.CrankyCoder.net
          Gateway: MQTTClientGateway
          MySensors: 2.3
          • bart59B bart59
            I wanted to operate my water pulse meter on batteries and also get the water flow. The original design had the following issues with that:
            • Incorrect flow calc: micros() was used to calculate the flow, however micros() wraps every 70 minutes which looks like a huge flow (which is then discarded in code)
            • Volume calc: millis() wraps every 50 days which is not handled correctly either
            • Too much current for battery use: The IR LED of the TCRT5000 is always on and the LM393 comparator is also taking a few mA's
            • Could not report flow in sleep mode because millis() does not increment on sleep - need to do this based on calculation of total sleep time. We now simply calculate the number of pulses per minute and deduct the flow
            • I also had issued with the data transport reliability, so I added error counters (which show up on the Gateway as distance sensors)
            • I also wanted to provide a measurement counter to the gateway (that counts up each time a message is sent)
            • The sensor will reboot itself when too many errors occur
            So I modified the circuit of the IR sensor:
            • Assumption that the wheel of the water meter turns slowly (takes at least a few seconds to turn around)
            • We will wake up every 500 millisecond to turn on the IR LED connected to PIN 8. Pin 8 also powers the photo transistor that measures the reflection
            • I removed the power from the opamp circuit that is linked to the photo transistor
            • The voltage from the photo transistor is then read using an analog read on A1. Based on a threshold value we will deduct if the mirror on the water meter is in view
            • Pin 7 is connected to a learning switch which will turn the device in a specific mode and the min/max values on A1 are used to calculate the value of the threshold (which is then stored in the EEPROM)
            • After 30 seconds in learning mode, the new threshold is established and the LED on Pin 6 will show the actual on/off mirror signals, so you can see the pulses are correctly counted
            • switch back the DIP switch on Pin 7 to bring back normal mode
            • The circuit also contains the battery voltage sensor circuit (I am using a 1.5V battery and step up circuit). So the resistors used are 470k from + pole of battery to the A0 input and 1 M ohm from A0 to ground
             * Version 1.0 - Henrik Ekblad
             * Version 1.1 - GizMoCuz
             * Version 1.2 - changed BM: using low power separate circuit for infra red on pin 8 + analog A1
             * ISSUES WITH ORIGINAL CODE
             * Incorrect flow calc: micros() was used to calculate the flow, however micros() is wraps every 70 minutes which looks like a huge flow (which is discarded)
             * Volume calc: millis() wraps every 50 days which is not handled correctly
             * Too much current for battery use: The IR LED of the TCRT5000 is always on and the LM393 comparator is also taking a few mA's
             * Could not report flow in sleep mode because millis() does not increment on sleep - need to do this based on calculation of total sleep time
             * MODIFIED CIRCUIT IR SENSOR
             * Assumption that the wheel of the water meter turns slowly (takes at least a few seconds to turn around)
             * We will wake up every second to turn on the IR LED (connected to PIN 8). Pin 8 also powers the photo transistor that measures the reflection
             * The voltage from the photo transistor is then read using an analog read on A1. Based on a treshold value we will deduct if the mirror is in view
             * Pin 7 is connected to a learning switch which will turn the device in continous mode and the min/max values on A1 are used to recalc the treshold
             * during a 30 second period. After this period the new treshold is established and the LED on Pin 6 will show the actual on/off mirror signals
             * http://www.mysensors.org/build/pulse_water
            // BOARD: PRO MINI 3.3V/ 8Mhz ATMEGA328 8Mhz
            #define MY_NODE_ID 10                 // hard code the node number
            #define SENSOR_POWER 8                // pin that will provide power to IR LED + sense circuit
            #define IR_SENSE_PIN  A1              // input for IR voltage
            #define BATTERY_SENSE_PIN  A0         // select the input pin for the battery sense point
            #define LEARN_SWITCH_PIN 7            // switch (SW1 on battery module) to turn on learning mode (low==on)
            #define LEARN_LED_PIN 6               // LED feedback during learning mode (LED on battery module)
            #define LEARN_TIME 30                 // number of seconds we will keep learn loop
            #define PULSE_FACTOR 1000             // Nummber of blinks per m3 of your meter (One rotation/1 liter)
            #define MAX_FLOW 80                   // Max flow (l/min) value to report. This filters outliers.
            #define CHILD_ID 1                    // Id of the sensor child (contains 3 subs: V_FLOW, V_VOLUME, VAR1)
            #define CHILD_PINGID 2                // ID of ping counter
            #define CHILD_ERRID 3                 // ID of error counter
            #define CHECK_FREQUENCY 500           // time in milliseconds between loop (where we check the sensor) - 500ms
            #define MIN_SEND_FREQ 60              // Minimum time between send (in multiplies of CHECK_FREQUENCY). We don't want to spam the gateway (30 seconds)
            #define MAX_SEND_FREQ 1200            // Maximum time between send (in multiplies of CHECK_FREQUENCY). We need to show we are alive (600 sec/10 min)
            #define IR_ON_SETTLE 2                // number of milliseconds after we turned on the IR LED and we assume the receive signal is stable (in ms)
            #define EE_TRESHOLD 10                // config addresses 0 + 1 used for treshold from learning (loadState() returns only uint8 value)
            #define TRESHOLD_MARGIN 3             // additional margin before we actually see a one or zero
            #define RESETMIN 5                    // number of cycle times (either 30 sec of 10 min) we consistently need to have transmission errors before we perform hard reset
            MyMessage volumeMsg(CHILD_ID,V_VOLUME); // display volume and flow on the same CHILD_ID
            MyMessage flowMsg(CHILD_ID,V_FLOW); // flow
            MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
            MyMessage pingMsg(CHILD_PINGID,V_DISTANCE); // use distance to keep track of changing value
            MyMessage errMsg(CHILD_ERRID,V_DISTANCE); // use distance to keep track of changing value
            double ppl = ((double)PULSE_FACTOR / 1000.0);    // Pulses per liter
            unsigned int oldBatteryPcnt = 0;          // check if changed
            unsigned int minsendcnt = MIN_SEND_FREQ;  // counter for keeping minimum intervals between sending
            unsigned int maxsendcnt = MAX_SEND_FREQ;  // counter for keeping maximum intervals between sending
            unsigned int treshold = 512;              // threshold value when to swap on/off for pulse
            unsigned long pulseCount = 0;             // total volume of this pulse meter (value stored/received on gateway on pcReceived)
            unsigned long oldPulseCount = 0;          // to see if we have received something
            boolean pcReceived = false;               // received volume from prior reboot
            boolean onoff = false;                    // sensor value above/below treshold
            unsigned int intervalcnt = 0;             // number of cycles between last period (for flow calculation)
            double flow = 0;                          // maintain flow
            double oldflow = 0;                       // keep prior flow (only send on change)
            unsigned int learntime=LEARN_TIME*2;      // timer for learning period
            unsigned int learnlow = 1023;             // lowest value found during learning
            unsigned int learnhigh = 0;               // highest value found during learning
            boolean learnsaved = false;               // have saved learned value
            unsigned long pingcnt = 0;
            unsigned long errcnt = 0;                 // error count
            unsigned int errcnt2 = 0;                 // error counter set to 0 when sending is ok
            void(* resetFunc) (void) = 0;//declare reset function at address 0 (for rebooting the Arduino)
              // make sure a few vars have the right init value after software reboot
              pingcnt = 0;
              pcReceived = false;
              pulseCount = oldPulseCount = 0;
              // setup hardware
              pinMode(SENSOR_POWER, OUTPUT);
              digitalWrite(SENSOR_POWER, LOW);
              pinMode(LEARN_SWITCH_PIN, INPUT_PULLUP);
              pinMode(LEARN_LED_PIN, INPUT);      // default is input because this pin also has SW2 of battery block
              // Fetch last known pulse count value from gateway
              request(CHILD_ID, V_VAR1);
              // Fetch threshold value from EE prom
              treshold = readEeprom(EE_TRESHOLD);
              if (treshold<30 || treshold>1000) treshold = 512;   // wrong value in EEprom, take default
              Serial.print("Treshold: ");
              Serial.println(treshold);
              // use the 1.1 V internal reference for the battery and IR sensor
               analogReference(INTERNAL1V1);
            #else
               analogReference(INTERNAL);
              analogRead(IR_SENSE_PIN); // settle analogreference value
              wait(CHECK_FREQUENCY); // wait a bit
            void presentation()  {
              sendSketchInfo("Water Meter", "1.2");
              // Register this device as Waterflow sensor
              present(CHILD_ID, S_WATER);
              present(CHILD_PINGID, S_DISTANCE);
              present(CHILD_ERRID, S_DISTANCE);
              if (digitalRead(LEARN_SWITCH_PIN)==LOW) {
                pinMode(LEARN_LED_PIN, OUTPUT);
                digitalWrite(SENSOR_POWER, HIGH);
                intervalcnt = 0;
                learn_loop();
              } else {
                learnlow = 1023;
                learnhigh = 0;
                normal_loop();
            void learn_loop() {
              // will run into this loop as long as we are learning
              wait(500);
              unsigned int sensorValue = analogRead(IR_SENSE_PIN);
              Serial.print("IR: ");
              Serial.print(sensorValue);
              if (learntime>0) {
                // still learning
                learntime--;
                learnsaved = false;
                digitalWrite(LEARN_LED_PIN, !digitalRead(LEARN_LED_PIN));  // blink led
                if (sensorValue < learnlow) {
                  learnlow = sensorValue;
                  Serial.println(" Lowest");
                } else if (sensorValue > learnhigh) {
                  learnhigh = sensorValue;
                  Serial.println(" Highest");
                } else Serial.println();
              } else {
                if (!learnsaved) {
                  treshold = (learnhigh + learnlow)/2;
                  storeEeprom(EE_TRESHOLD, treshold);
                learnsaved = true;
                // just display using LED
                digitalWrite(LEARN_LED_PIN, sensorValue>treshold);
                Serial.println((sensorValue>treshold ? " on" : " off"));
            void normal_loop() {
              unsigned long start_loop = millis();    // to allow adjusting wait time
              intervalcnt++;
              // we start doing a measurement
              wait(IR_ON_SETTLE);
              #ifdef MY_DEBUG_DETAIL
              Serial.println(sensorValue);
              boolean nowvalue = onoff;
              if (onoff && (sensorValue<treshold-TRESHOLD_MARGIN)) nowvalue = false;
              if (!onoff && (sensorValue>treshold+TRESHOLD_MARGIN)) nowvalue = true;
              if (nowvalue != onoff) {
                // we have a pulse, only count on upwards pulse
                onoff = nowvalue;
                if (onoff) {
                  pulseCount++;
                  #ifdef MY_DEBUG
                  Serial.print("p: ");
                  Serial.println(pulseCount);
              if (minsendcnt>0) minsendcnt--;
              if (maxsendcnt>0) maxsendcnt--;
              // send minimum interval when we have pulse changes or if we had some flow the prior time or send on timeout
              if ((minsendcnt==0 && (pulseCount != oldPulseCount)) || (minsendcnt==0 && oldflow != 0) || maxsendcnt==0) {
                if (!pcReceived) {   //Last Pulsecount not yet received from controller, request it again
                  Serial.print("Re-request var1 ..");
            // Prevent flooding the gateway with re-requests,,, wait at least 1000 ms for gateway (cannot be sleep or smartSleep
                  wait(2*CHECK_FREQUENCY);
                  return;
                pingcnt++;
                sensorValue = analogRead(BATTERY_SENSE_PIN);
                // ((1e6+470e3)/1e6)*1.1 = Vmax = 1.67 Volts
                // 1.67/1023 = Volts per bit = 0.00158065
                Serial.print("Battery %: ");
                Serial.println(batteryPcnt);
                  oldBatteryPcnt = batteryPcnt;
                double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                flow = ((double) (pulseCount-oldPulseCount)) * (60000.0 / ((double) intervalcnt*(double) CHECK_FREQUENCY)) / ppl;  // flow in liter/min
                #ifdef MY_DEBUG
                Serial.print("pulsecount:");
                Serial.print("volume:");
                Serial.println(volume, 3);
                Serial.print("l/min:");
                Serial.println(flow);
                bool b = send(lastCounterMsg.set(pulseCount));  // Send  pulsecount value to gw in VAR1
                if (b) errcnt2=0; else { errcnt++; errcnt2++; }
                b = send(volumeMsg.set(volume, 3));               // Send volume (set function 2nd argument is resolution)
                b = send(flowMsg.set(flow, 2));                   // Send flow value to gw
                b = send(pingMsg.set(pingcnt));                   // ensure at least this var has a different value
                b = send(errMsg.set(errcnt2+((float) errcnt2/100),2));    // ensure we always send error count
                oldPulseCount = pulseCount;
                intervalcnt = 0;
                oldflow = flow;
                if (errcnt2>= (5*RESETMIN)) {
                  Serial.println("Reset");
                  wait(300);
                  resetFunc(); //call reset to reboot the Arduino
            // calculate how long it took to process all of this. then go to sleep for the remaining period
              unsigned long end_loop = millis();
              if (end_loop - start_loop < CHECK_FREQUENCY)
                sleep(CHECK_FREQUENCY - (end_loop > start_loop ? end_loop - start_loop : 0));
              if (message.type==V_VAR1) {
                unsigned long gwPulseCount=message.getULong();
                pulseCount += gwPulseCount;
                oldPulseCount += gwPulseCount;
                flow=oldflow=0;
                pcReceived = true;
            void storeEeprom(int pos, int value) {
                // function for saving the values to the internal EEPROM
                // value = the value to be stored (as int)
                // pos = the first byte position to store the value in
                // only two bytes can be stored with this function (max 32.767)
                saveState(pos, ((unsigned int)value >> 8 ));
                pos++;
                saveState(pos, (value & 0xff));
            int readEeprom(int pos) {
                // function for reading the values from the internal EEPROM
                // pos = the first byte position to read the value from
                int hiByte;
                int loByte;
                hiByte = loadState(pos) << 8;
                pos++;
                loByte = loadState(pos);
                return (hiByte | loByte);
            Emmanuel AbrahamE
            Emmanuel AbrahamE
            Emmanuel Abraham
            @bart59 Can you post full circuit diagram for the modified code you made?
            • Paolo RendanoP
              Paolo RendanoP
              Paolo Rendano
              I made some improvements on this sketch. Please review them here: https://github.com/mysensors/MySensors/pull/1540
              with these changes you will have:
              1 - factory reset
              2 - automatic home assistant entities creation
              3 - counter correction from home assistant using service notify.mysensors
              4 - fixed counter automatically incremented by 1 at each device restart (due to arduino library interrupt bug)
              5- other tiny improvements
              • J
                J
                JeeLet
                wrote on last edited by JeeLet
                #107
                Thanks for the feedback
                For those who think MySensors is finished, the proof is in the pudding, thousands of systems are functional :earth_asia:
                • S
                  StephanXL
                  I really like the update you did for Home Assistant integration.
                  But: I do not really understand, how to correctly send the VALUE_TO_ADD.
                  This is what I tried to add 967.067 m³:
                  service: notify.mysensors
                  data:
                    message: VALUE_TO_ADD
                    target: text.water_meter_100_2
                    data: 967067
                  But I just get this error message:
                  Fehler beim Aufrufen des Diensts notify.mysensors. expected dict for dictionary value @ data['data']. Got None
                  These are my newly found entities:
                  What is wrong here?
                  S 1 Reply Last reply
                  • S StephanXL
                    data:
                      data: 967067
                    What is wrong here?
                    StephanXL
                    I finally got this to work. Unlike what the description here says, this is how to update the value:
                    In Home Assistant, go to Developer->Service->YAML mode:
                    service: text.set_value
                    data:
                      value: "967067"
                    target:
                      entity_id: text.water_meter_100_2
                    (change 967067 with the value you want to add to the current counter)
                    The service "notify.mysensors" seems to be deprecated by Home Assistant.
