  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 107.7k Views 36 Watching
  • S stingone
    No compile error but i cant see anything on the serial monitor. also the temp sensor burend out with a 4k7 resistor :S
    remisR
    remisR
    remis
    @stingone
    Hi. The same issue for me . I solve it with : 38400 bauds configuration serial port ( instead of 115200 default value)
    and i lowering the RF power output with low_pa enable: it confirms that I have some issues with power suppply.
    good luck
    • bentrikB
      bentrikB
      bentrik
      wrote on last edited by bentrik
      #22
      It seems the DallasTempereture library is not a part of the default Library setup from Mysensors as of version 2.0? I tried to compile the above code, but I had to manually download DallasTemperature from GitHub first. Then OneWire was also missing. Adding these two libraries brought me a bit further, but I get a long list of errors connected to OneWire. What libraries should be used?
      • bentrikB bentrik
        @bentrik the library is part of the MySensorsArduinoExamples, which can be downloaded at https://github.com/mysensors/MySensorsArduinoExamples/archive/master.zip
        bentrikB 1 Reply Last reply
        • SealanderS
          SealanderS
          Sealander
          wrote on last edited by Sealander
          #24
          Hi All, i'm also new here and into this. Like others i also ran into problems compiling this sketch, i tried al libraries mentioned in the posts in this thread, but no go. keep getting this error message:
          In file included from C:\Users\Gebruiker\Desktop\My Sensors\MySensors-master\MySensorsArduinoExamples-master\examples\DallasTemperatureSensor\DallasTemperatureSensor.ino:37:0:
          C:\Users\Gebruiker\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h: In function 'void loop()':
          C:\Users\Gebruiker\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:252:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
           int16_t millisToWaitForConversion(uint8_t);
          DallasTemperatureSensor:85: error: within this context
                exit status 1
          within this context
          Can someone help me with this problem? i have no clue at all and woud really like to build me a working sensor so i can hook it up to my Domoticz setup. thanks
          hin this context
          S 1 Reply Last reply
          • SealanderS Sealander
                  exit status 1
            within this context
            hin this context
            stingone
            @Sealander
            see solution above. Delete your dallas library and replace with the one above in the master zip file. That was the solution for me.
              bentrikB
              bentrikB
              bentrik
              #26
              @mfalkvidd Thanks for the feedback, It got me a bit further.
              I have a fresh Windows Arduino 1.6.12 install, and I have download the MySensors Library 2.0 through the Library manager, and I've found MySensors.h and MyConfig.h under \Documents\Arduino\libraries\MySensors
              I'm able to compile and upload the RelayActuator but quite a few of the library files seem to be missing in 2.0. DallasTemperature seem to be one of them.-But I struggled with DallasTemperature and some others.
              I copied all the whole MySensors-1.5.4.zip library files to to C:\Program Files (x86)\Arduino\libraries, and I managed to compile, but I got an error message saying Invalid version found: 1.04
              Then I tried to only copy the DallasTemperature and OneWire folder, and I had no errors.
              -So I assume all library files the entire MySensors Examples catalouge are not ready in Libraries 2.0.
              Anyways: The solution to get this sensor to work with Arduino 1.6.12, following the Download and API guide, adding MySensors 2.0 through the Library Manager, is to manually add:
              \Arduino\libraries\OneWire\
              -from https://github.com/mysensors/MySensorsArduinoExamples/archive/master.zip
              -And not adding the whole structure.
              Now I just have to find out how to make it speak to my serial gateway :satisfied:
              • wendanW
                wendanW
                wendan
                I get the feeling it is possible to use more then one sensor parallel on port 3. I wonder if each sensor is being monitored? Am I right and do I need to alter or change something?
                • wendanW
                  wendanW
                  wendan
                  my feeling was right.... i just connected 5 temp censors it is working great
                  • J
                    J
                    Joseph Absher
                    wrote on last edited by Joseph Absher
                    #29
                    I am getting the error:
                    DallasTemperatureSensor.ino: In function 'void loop()':
                    DallasTemperatureSensor:93: error: 'getConfig' was not declared in this scope
                         float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                    Does anyone have any suggestions?
                    • J Joseph Absher
                      @Joseph-Absher https://forum.mysensors.org/topic/5841/getconfig-was-not-declared-in-this-scope-v2-1-1-fixed
                      • J
                        J
                        Joseph Absher
                        @mfalkvidd That worked. Thanks.
                        • Vincent LgrdV
                          Vincent LgrdV
                          Vincent Lgrd
                          I'm a beginner in home automation and I'm trying MySensor for the first time. My acctual configaration is a Domoticz on a Raspberry Pi 2B and a RFLink GW with a NRF24L01 module to try to measure with a MySensor probe.
                          I've building a temperature sensor with a DS18B20 sensor on a Official Arduino nano board and I can not run the sensor correctly.
                          The arduino serial monitor show these:
                          3 TSM:INIT
                          4 TSF:WUR:MS=0
                          11 TSM:INIT:TSP OK
                          12 TSM:FPAR
                          15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          2022 !TSM:FPAR:NO REPLY
                          2024 TSM:FPAR
                          2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          4034 !TSM:FPAR:NO REPLY
                          4036 TSM:FPAR
                          4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          6046 !TSM:FPAR:NO REPLY
                          6048 TSM:FPAR
                          6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          8058 !TSM:FPAR:FAIL
                          8059 TSM:FAIL:CNT=1
                          8061 TSM:FAIL:PDT
                          Someone could help me?
                            Did you set node ID?
                            • Vincent LgrdV
                              Vincent LgrdV
                              Vincent Lgrd
                              Where should I put it? In arduino sensor code?
                                Yes, it's like #define MY_NODE_ID 2 and put it at beginning of the code
                                • Vincent LgrdV
                                  Vincent LgrdV
                                  Vincent Lgrd
                                  Ok , with Node ID, I have this:
                                  3 MCO:BGN:BFR
                                  63 TSM:INIT
                                  64 TSF:WUR:MS=0
                                  71 TSM:INIT:TSP OK
                                  73 TSM:INIT:STATID=2
                                  75 TSF:SID:OK,ID=2
                                  76 TSM:FPAR
                                  113 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2120 !TSM:FPAR:NO REPLY
                                  2122 TSM:FPAR
                                  2158 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  4166 !TSM:FPAR:NO REPLY
                                  4168 TSM:FPAR
                                  4204 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  6212 !TSM:FPAR:NO REPLY
                                  6214 TSM:FPAR
                                  6250 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  8258 !TSM:FPAR:FAIL
                                  8259 TSM:FAIL:CNT=1
                                    ok, but we are going off topic since now your problem seems to be the radios can't talk to each other, so if you take a look in troubleshooting section you will see others having this error that usually if bad wiring, missing capacitor on vcc of the nrf24, range/interference problem. How far are the 2 radio modules? Try putting them 2-3 meters apart.
                                    • Vincent LgrdV
                                      Vincent LgrdV
                                      Vincent Lgrd
                                      Thanks, my radio modules are very close, they are on the same table for test. On of them may be damaged, I must receive others. I'm going in the troubleshooting section to avoid polluting this article.
                                      Thanks for your help
                                        Put them at least 2 meters apart, just to play safe.
                                        • Vincent LgrdV
                                          Vincent LgrdV
                                          Vincent Lgrd
                                          It's the same, I've even reversed the radio modules
