  3. Multi Button Relay Sketch
69 Posts 12 Posters 38.2k Views 18 Watching
  • rayanR rayan
    @Boots33
    oh , after added this device , happen a Event ! node id of motion sensor and this device is 1 ! and after sense of motion light on in dashborad ! why both Catch node id 1 .
    i dont add #define node id for motion and for this. but both take id 1 and Interference
    Boots33B
    Boots33B
    Boots33
    @rayan As far as I am aware if you don't set the id manually then the controller gives out an id. Why it has doubled up I don't know. Did you use that arduino before and it was originally given that address?
    Anyway you will have to delete the node from the mysensors hardware device in Domiticz then clear the eeprom of that arduino using the clearEepromConfig sketch in the mysensors examples and then reload the mains switch sketch. It should then be given a new id.
    rayanR 1 Reply Last reply
    • Boots33B Boots33
      rayanR
      rayanR
      rayan
      @Boots33
      thank you very much
      • Boots33B Boots33
        @SGi I have used two buttons in my Mains controller project. I have posted just the relay code below to show you what you need to do. I have not used the eeprom to store the state but you could soon add that back in. The main thing you need to do is check to see which sensor the incoming message is for.
           DESCRIPTION
           Based on the RelayWithButtonActuator sketch
        // Enabled repeater feature for this node
        //#define MY_REPEATER_FEATURE
        #include <Bounce2.h>
        #define RELAY_ON 1
        #define RELAY_OFF 0
        #define SSR_A_ID 1   // Id of the sensor child
        #define SSR_B_ID 2   // Id of the sensor child
        const int buttonPinA = 3;
        const int buttonPinB = 4;
        const int relayPinA = 5;
        const int relayPinB = 6;
        int oldValueA = 0;
        int oldValueB = 0;
        bool stateA = false;
        bool stateB = false;
        Bounce debouncerA = Bounce();
        Bounce debouncerB = Bounce();
        MyMessage msgA(SSR_A_ID, V_STATUS);
        MyMessage msgB(SSR_B_ID, V_STATUS);
          pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
          pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
          pinMode(relayPinA, OUTPUT);
          pinMode(relayPinB, OUTPUT);
          // After setting up the buttons, setup debouncer
          debouncerA.attach(buttonPinA);
          debouncerA.interval(5);
          debouncerB.attach(buttonPinB);
          debouncerB.interval(5);
          digitalWrite(relayPinA, RELAY_OFF);
          digitalWrite(relayPinB, RELAY_OFF);
        void presentation()  {
          sendSketchInfo("Mains Controller", "1.0");
          present(SSR_A_ID, S_LIGHT);
          present(SSR_B_ID, S_LIGHT);
           Example on how to asynchronously check for new messages from gw
          debouncerA.update();
          // Get the update value
          int valueA = debouncerA.read();
          if (valueA != oldValueA && valueA == 0) {
            send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
          oldValueA = valueA;
          debouncerB.update();
          int valueB = debouncerB.read();
          if (valueB != oldValueB && valueB == 0) {
            send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
          oldValueB = valueB;
            switch (message.sensor) {
              case 1:
                stateA = message.getBool();
                digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
                break;
              case 2:
                stateB = message.getBool();
                digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
                break;
              // Write some debug info
            Serial.println(message.sensor);
            Serial.print("from node:");
            Serial.println(message.sender);
        SGiS
        SGiS
        SGi
        This post is deleted!
        • Boots33B Boots33
             DESCRIPTION
          #define RELAY_ON 1
          #define RELAY_OFF 0
          int oldValueA = 0;
          int oldValueB = 0;
            oldValueA = valueA;
            oldValueB = valueB;
                case 1:
                  break;
                case 2:
                  break;
          SGiS
          SGiS
          SGi
          @Boots33 Whoa sorry, here is the code in the proper format/window...
           * Version 0.1 - SGI
           * Sketch to control 4 relays for irrigations, including 4 local push buttons..
          // Define Relays
          #define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
          #define NUMBER_OF_RELAYS 4 // Total number of attached relays
          #define RELAY_ON 0  // GPIO value to write to turn on attached relay
          #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
          // Define Sensor ID's
          #define SSR_A_ID 11   // Id of the sensor child
          #define SSR_B_ID 12   // Id of the sensor child
          #define SSR_C_ID 13   // Id of the sensor child
          #define SSR_D_ID 14   // Id of the sensor child
          // Define Buttons
          const int buttonPinA = 1;
          const int buttonPinB = 2;
          const int buttonPinC = 3;
          const int buttonPinD = 4;
          // Define Variables
          int oldValueA = 0;
          int oldValueB = 0;
          int oldValueC = 0;
          int oldValueD = 0;
          bool stateA;
          bool stateB;
          bool stateC;
          bool stateD;
          // Define Debounce
          Bounce debouncerC = Bounce();
          Bounce debouncerD = Bounce();
          // Define messages to send back to gateway
          MyMessage msgC(SSR_C_ID, V_STATUS);
          MyMessage msgD(SSR_D_ID, V_STATUS);
            // Setup relay pins and set to output then set relays to startup off
              pinMode(pin, OUTPUT);
              // Set relay off
              digitalWrite(pin, 1);
            pinMode(buttonPinC, INPUT_PULLUP);
            pinMode(buttonPinD, INPUT_PULLUP);
            debouncerC.attach(buttonPinC);
            debouncerC.interval(5);
            debouncerD.attach(buttonPinD);
            debouncerD.interval(5);
            sendSketchInfo("Irrigation with Buttons", "0.1");
            present(SSR_C_ID, S_LIGHT);
            present(SSR_D_ID, S_LIGHT);
              send(msgA.set(stateA?false:true), true); // Send new state and request ack back
            oldValueA = valueA;
              send(msgB.set(stateB?false:true), true); // Send new state and request ack back
            oldValueB = valueB;
            debouncerC.update();
            int valueC = debouncerC.read();
            if (valueC != oldValueC && valueC == 0) {
              send(msgC.set(stateC ? false : true), true); // Send new state and request ack back
            oldValueC = valueC;
            debouncerD.update();
            int valueD = debouncerD.read();
            if (valueD != oldValueD && valueD == 0) {
              send(msgD.set(stateD ? false : true), true); // Send new state and request ack back
            oldValueD = valueD;
            if (message.type==V_STATUS) {
                case 1:
                  digitalWrite(message.sensor+4, stateA ? RELAY_ON : RELAY_OFF);
                  break;
                case 2:
                  digitalWrite(message.sensor+4, stateB ? RELAY_ON : RELAY_OFF);
                  break;
                case 3:
                  stateC = message.getBool();
                  digitalWrite(message.sensor+4, stateC ? RELAY_ON : RELAY_OFF);
                  break;
                case 4:
                  stateD = message.getBool();
                  digitalWrite(message.sensor+4, stateD ? RELAY_ON : RELAY_OFF);
                  break;
               // Change relay state
               // digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
               // Store state in eeprom
               //saveState(message.sensor, message.getBool());
               Serial.print(message.sensor);
          • Boots33B Boots33
            @rayan Ok had a quick look and I don't think we need to do a lot for this to work.
            The only extra change I have made is to add four new lines at the end of the setup function
               /*--------------------- Added these lines for toggle switch-------------------------*/
              oldValueA = digitalRead(buttonPinA);  // set oldValueA to the current status of the toggle switch
              oldValueB = digitalRead(buttonPinB);  // set oldValueB to the current status of the toggle switch
              send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
              send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
            As you can see the oldValue variables are now set to represent the current state of the toggle switches when the node boots up. this should stop any changes in state being made in the main loop until a switch is toggled.
            The other two lines just send a message to the controller to tell it the switches are off. this should make the controller icons show the correct state
            Below is the full sketch, I have nothing to test it on so give it a try and see how it goes
            #define RELAY_ON 1
            #define RELAY_OFF 0
            const int buttonPinA = 18;
            const int buttonPinB = 19;
            int oldValueA = 0;
            int oldValueB = 0;
              if (valueA != oldValueA) {
              oldValueA = valueA;
              if (valueB != oldValueB) {
              oldValueB = valueB;
                  case 1:
                    break;
                  case 2:
                    break;
            SGiS
            SGiS
            SGi
            @Boots33 i just worked out what was wrong the code above... and now understand how the message.sensor number works... now my only issue is why the buttons on pins 2,3,4 work but not pin 1... does pin 1 on the arduino have special use?
            Boots33B 1 Reply Last reply
            • SGiS SGi
              Boots33B
              Boots33B
              Boots33
              wrote on last edited by Boots33
              #26
              @SGi great that you worked it out and improved your understanding of mysensors as well. 😊. Probably good to post the fix so others may also gain from the thread.
              I think digital pins 0 and 1 are also used for serial communication so probably best to avoid them wherever possible. If you turn off debugging they will probably work but you may have problems uploading sketches too. The analogue pins can also be used as digital pins if you need a few more.
              • Boots33B Boots33
                @rayan maybe trying to send the off message before the presentation stops it from sending
                try this , have moved the messages to the main loop where they will only be sent once in the first loop
                #define RELAY_ON 1
                #define RELAY_OFF 0
                int oldValueA = 0;
                int oldValueB = 0;
                int trigger = 0;
                 // send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
                 // send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
                if (trigger == 0){
                  trigger = 1;
                  oldValueA = valueA;
                  oldValueB = valueB;
                      case 1:
                        break;
                      case 2:
                        break;
                pepsonP
                pepsonP
                pepson
                #define RELAY_ON 1
                #define RELAY_OFF 0
                int oldValueA = 0;
                int oldValueB = 0;
                int trigger = 0;
                if (trigger == 0){
                  trigger = 1;
                  oldValueA = valueA;
                  oldValueB = valueB;
                      case 1:
                        break;
                      case 2:
                        break;
                Thanks this code works ok. But by switch i must still connect to GND to keep change status. Is possible to change it to give only impuls GND to change status Relay ? I want use switch monostable.
                And anybody tell me how i can clear all eeprom in my Arduino Mini Pro. I want clear eeprom before upload sketch.
                rayanR Boots33B 2 Replies Last reply
                • pepsonP pepson
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  int oldValueA = 0;
                  int oldValueB = 0;
                  int trigger = 0;
                  if (trigger == 0){
                    trigger = 1;
                    oldValueA = valueA;
                    oldValueB = valueB;
                        case 1:
                          break;
                        case 2:
                          break;
                  rayanR
                  rayanR
                  rayan
                  @pepson
                  go to : file > examples > mysensors > clear eeprom config
                  and select arduino pro mini from : tools > board > arduino pro or pro mini
                  • Boots33B Boots33
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    int oldValueA = 0;
                    int oldValueB = 0;
                    int trigger = 0;
                    if (trigger == 0){
                      trigger = 1;
                      oldValueA = valueA;
                      oldValueB = valueB;
                          case 1:
                            break;
                          case 2:
                            break;
                    rayanR
                    rayanR
                    rayan
                    @Boots33 this your code is good, but there is a small issue .button work just when the connection is ok (radio with gateway) ! and when radio is disconnect or controller is off, so button dont work handy . do you have any idea for this ? that when controller is off the button work handy
                    pepsonP Boots33B 2 Replies Last reply
                    • rayanR rayan
                      pepsonP
                      pepsonP
                      pepson
                      @rayan
                      Hi
                      I do this eeprom clear and after that when i upload sketch for relay with buttons , this not working. Any communication with Gateway. Upload sketch successful write.
                      I need changes in code to button monostable. Now if i want enable RELAY i must still connect pin to GND by button. I want only give impuls GND and relay should have enable. Again give impuls GND should disable relay. The same as working Fibaro relay switch by Z-Wave.
                      In code should be add option to select buttons:
                      -Monostable
                      -Bistable
                      • pepsonP pepson
                        @rayan
                        Hi
                        -Monostable
                        -Bistable
                        rayanR
                        rayanR
                        rayan
                        @pepson
                        i am beginner and i hope some one help to you
                        • pepsonP
                          pepsonP
                          pepson
                          Maybe @Boots33 or @SGi help us please
                          • korttomaK
                            korttomaK
                            korttoma
                            Here is an example that I'm using with 4 relays and 4 monostable buttons:
                            #define SN "RelayButtonArray"
                            #define SV "1.0"
                            #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
                            #define RELAY_OFF 1
                            #define noRelays 4                     //2-4
                            const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
                            const int buttonPin[] = {6, 7, 4, 5};   //  switch around pins to your desire
                            class Relay             // relay class, store all relevant data (equivalent to struct)
                              public:
                                int buttonPin;                   // physical pin number of button
                                int relayPin;             // physical pin number of relay
                                boolean relayState;               // relay status (also stored in EEPROM)
                            Relay Relays[noRelays];
                            Bounce debouncer[noRelays];
                            MyMessage msg[noRelays];
                              void before() {
                              wait(100);
                              // Initialize Relays with corresponding buttons
                              for (int i = 0; i < noRelays; i++) {
                                Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                                Relays[i].relayPin = relayPin[i];
                                msg[i].sensor = i;                                   // initialize messages
                                msg[i].type = V_LIGHT;
                                pinMode(Relays[i].buttonPin, INPUT_PULLUP);
                                wait(100);
                                Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                                digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                                wait(50);
                                debouncer[i] = Bounce();                        // initialize debouncer
                                debouncer[i].attach(buttonPin[i]);
                                debouncer[i].interval(30);
                                wait(50);
                              sendSketchInfo(SN, SV);
                              wait(100);
                                present(i, S_LIGHT);                               // present sensor to gateway
                              wait(100);
                              for (byte i = 0; i < noRelays; i++) {
                                if (debouncer[i].update()) {
                                  int value = debouncer[i].read();
                                  if ( value == LOW) {
                                    // save sensor state in EEPROM (location == sensor number)
                                    saveState( i, Relays[i].relayState );
                              //wait(20);
                                if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                                  digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                  saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                              wait(20);
                            • Tomas
                            breimannB N T 3 Replies Last reply
                            • pepsonP pepson
                              #define RELAY_ON 1
                              #define RELAY_OFF 0
                              int oldValueA = 0;
                              int oldValueB = 0;
                              int trigger = 0;
                              if (trigger == 0){
                                trigger = 1;
                                oldValueA = valueA;
                                oldValueB = valueB;
                                    case 1:
                                      break;
                                    case 2:
                                      break;
                              Boots33B
                              Boots33B
                              Boots33
                              @pepson The sketch i have in my first post at the top of the page will work for a push button. the one you are using has been modified for use with a toggle switch.
                              • pepsonP
                                pepsonP
                                pepson
                                ok i test your first sketch. But maybe you can create sketch where we can setvin sketch what button we want use ?
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  I'm the sketch I'm using you can freely define what pins you want to use:
                                  • Tomas
                                  • rayanR rayan
                                    Boots33B
                                    Boots33B
                                    Boots33
                                    #37
                                    As far as I know that is the way Mysensors works at the moment, if the node boots up and cannot find the gateway then it wont run the loop part of the sketch.
                                    If the gateway drops out after the node has booted then the loop part of the sketch will still run while the node tries to re-establish the connection. Because the sketch relies on an ACK back from the gateway to toggle the relay it still wont work if the gateway is down.
                                    You could modify the sketch so it does not rely on the ACK. This would at least allow it to work if the gateway goes down after the node has booted.
                                    Another way to ensure the switch will operate would be to add some circuit to override the node, like discussed Here
                                    Have made a quick change to the sketch so it does not need the ACK. I have not tried it but give it a go and see if it works
                                    #define RELAY_ON 1
                                    #define RELAY_OFF 0
                                    int oldValueA = 0;
                                    int oldValueB = 0;
                                    int trigger = 0;
                                    if (trigger == 0){
                                      trigger = 1;
                                       // send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
                                        send(msgA.set(stateA ? false : true), false); // Send new state with no request for ack
                                        stateA = stateA ? false : true;               // invert the state
                                         digitalWrite(relayPinA, stateA ? RELAY_ON : RELAY_OFF);  // toggle the relay
                                      oldValueA = valueA;
                                        //send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
                                        send(msgB.set(stateB ? false : true), false); // Send new state with no request for ack
                                        stateB = stateB ? false : true;                // invert the state
                                         digitalWrite(relayPinB, stateB ? RELAY_ON : RELAY_OFF);  // toggle the relay
                                      oldValueB = valueB;
                                          case 1:
                                            break;
                                          case 2:
                                            break;
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      ok then i test it.
                                      But can you also add option to set mode button ? Bistable and monostable ?
                                      • Boots33B Boots33
                                        #define RELAY_ON 1
                                        #define RELAY_OFF 0
                                        int oldValueA = 0;
                                        int oldValueB = 0;
                                        int trigger = 0;
                                        if (trigger == 0){
                                          trigger = 1;
                                          oldValueA = valueA;
                                          oldValueB = valueB;
                                              case 1:
                                                break;
                                              case 2:
                                                break;
                                        rayanR
                                        rayanR
                                        rayan
                                        wrote on last edited by rayan
                                        #39
                                        @Boots33
                                        ack is important , so we can not found any solution for this ? for exapmle add a code to this sketch , that when radio is disconnect so without ack work and when radio is ok this way stop and with ack work again.
                                        this idea is for when a radio have problem or fail or other reason... so this light or other divece dont stop working and work handy when radio go to correct or change radio....
                                        if you can change your code and add this option , so your sketch is best code for light control
                                        • pepsonP
                                          pepsonP
                                          pepson
                                          wrote on last edited by pepson
                                          #40
                                          @korttoma your sketch not working for me. I change numer relay to 2 and change pin buttons and relay and not control relay.
                                          @Boots33
                                          Ok i correct your sketch and use:
                                          Switch Bistable:
                                             DESCRIPTION
                                             Sketch for 2x relay with buttons bistable. After back power all relays set OFF and send correct status OFF to controller.
                                          // Define Relays
                                          #define RELAY_OFF 0  // GPIO value to write to turn off attached relay
                                          // Define buttons and relays
                                          // Define Variables
                                          int oldValueA = 0;
                                          int oldValueB = 0;
                                          int trigger = 0;
                                            sendSketchInfo("2xRelay with bistable", "1.1");
                                          if (trigger == 0){
                                            trigger = 1;
                                            oldValueA = valueA;
                                            oldValueB = valueB;
                                                case 1:
                                                  break;
                                                case 2:
                                                  break;
                                          Switch monostable:
                                             DESCRIPTION
                                             Sketch for 2x relay with buttons monostable. After back power all relays set OFF and send correct status OFF to controller.
                                          // Define Relays
                                          // Define Variables
                                          int oldValueA = 0;
                                          int oldValueB = 0;
                                          int trigger = 0;
                                            sendSketchInfo("2xRelay with monostable", "1.0");
                                          if (trigger == 0){
                                            trigger = 1;
                                            oldValueA = valueA;
                                            oldValueB = valueB;
                                                case 1:
                                                  break;
                                                case 2:
                                                  break;
                                          On this sketches it works ok. After power down and then power back all relays go to OFF and correct send info to Gateway and Domoticz that relays is OFF. But when Gateway is available.
                                          But problem is when GATEWAY is not awailable when power for node come back.
                                          If before lost power relay is ON and then power lost , and gateway is lost, and then power back to Node it goes to OFF all relay. It is ok.But when Gateway come back and now is available still show in Domoticz that relay is ON(on begin was ON). But Node should update status info after Gateway come back and is now available. But no update and show in Domoticz latest status.
                                          It is very need and then this sketches will be the best for lights :)
                                          When power lost and then come back, Node with sketches faster start then start Raspberry with Domoticz and connect Gateway Serial MySensors. An in this situation status is not update in Gateway/Domoticz.
                                          Please help us. please
