  3. Multi Button Relay Sketch
69 Posts 12 Posters 38.2k Views 18 Watching
  • rayanR rayan
    @Boots33
    ack is important , so we can not found any solution for this ? for exapmle add a code to this sketch , that when radio is disconnect so without ack work and when radio is ok this way stop and with ack work again.
    this idea is for when a radio have problem or fail or other reason... so this light or other divece dont stop working and work handy when radio go to correct or change radio....
    if you can change your code and add this option , so your sketch is best code for light control
    Boots33B
    Boots33B
    Boots33
    @rayan said:
    @Boots33
    There have been a few threads about the issue of nodes not running the loop part of the sketch if a connection to the gateway cannot be established. Have a look Here and Here for a bit more info. It is a feature I am sure many would like to see in the next version of MySensors. For the moment MySensors does not support 100% what you want to do.
    If you want to combine the two versions of the sketches you will need to have a method to check whether a connection to the gateway is present. You could try something like this in the loop.
    if (isTransportOK()){
        // put code to execute when connection is available here
      else {
        // put code to execute when no connection is available here
    You will be adding a fair bit of complexity to the sketch. Can you tell me why the ACK is so important for you.
    rayanR 1 Reply Last reply
    • pepsonP
      pepsonP
      pepson
      wrote on last edited by pepson
      #42
      What is ACK ?
      And can you show me all code with your if transport is ok to send update status to gateway...but if transport is wrong example try send every 1 minut and stop when send is good.
      I am begginner sorry
      Did you know any info that this function will be implement in next version as you write in latest your post ?
      • Boots33B Boots33
        @rayan said:
        @Boots33
          else {
        rayanR
        rayanR
        rayan
        wrote on last edited by rayan
        #43
        @Boots33
        ack is a feedback . is this true ? so when i am out of home and i want turn on light , so ack show me that light is on or no ! also when there is a problem in connection and ack dont receive, so node search and found a new way for connection.
        now i dont have a arduino and radio for test :) but do you think this code will be ok ?without else.
         if (!isTransportOK())
        if (...)            //if change switch to up or down
        ...                 //change state of relay
        if(isTransportOK())
        send(msg.set(state ? true : false), true);  // (last state)
          debouncer.update();
          // Get the update value
          int value = debouncer.read();
          if (value != oldValue && value == 0) {
            send(msg.set(state ? false : true), true); // Send new state and request ack back
          oldValue = value;
        (i can not work with Bounce2 library :) ) please help to fill lines
        in loop we add a "if (!isTransportOK())" and write when change switch (on/off) state of relay change and this is repeat until connection will be ok ! so send a ack and for continue follow your code...
        is this right ? can you do this change ?
        • pepsonP
          pepsonP
          pepson
          Hi
          I can test it but i must have finall code because i dont know what code i must put in (...). I am begginer user and i dont know how write programming.
          • pepsonP pepson
            Hi
            rayanR
            rayanR
            rayan
            @pepson
            @Boots33 can solve this maybe because i dont work with Bounce2 lib.
            • pepsonP
              pepsonP
              pepson
              Ok but can you give me ready code which i must put in code to my relays and then i test it.
              • pepsonP pepson
                rayanR
                rayanR
                rayan
                @pepson
                i dont have a ready sketch! wait to boots answer
                • pepsonP
                  pepsonP
                  pepson
                  Ok i am waiting...
                  • Boots33B
                    Boots33B
                    Boots33
                    wrote on last edited by Boots33
                    #49
                    Guys I feel this thread has wandered a long way from the original topic and has taken up a lot of time. i really don't think there is a lot to be gained by turning the fairly simple relay sketch into what you now desire.
                    Even with the changes it still will not work if it boots up and can't find the gateway.
                    I am posting a final sketch which you may like to try, again it is untested so you may still need to work on it. I hope you understand I have a few of my own uncompleted projects that I want to get back to with the limited free time I have. Good luck with your MySensors journey.
                    #define MY_REPEATER_FEATURE
                    #include <Bounce2.h>
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    #define SSR_A_ID 1   // Id of the sensor child
                    #define SSR_B_ID 2   // Id of the sensor child
                    const int buttonPinA = 18;
                    const int buttonPinB = 19;
                    const int relayPinA = 5;
                    const int relayPinB = 6;
                    int oldValueA = 0;
                    int oldValueB = 0;
                    bool stateA = false;
                    bool stateB = false;
                    int trigger = 0;
                    Bounce debouncerA = Bounce();
                    Bounce debouncerB = Bounce();
                    MyMessage msgA(SSR_A_ID, V_STATUS);
                    MyMessage msgB(SSR_B_ID, V_STATUS);
                      pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
                      pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
                      pinMode(relayPinA, OUTPUT);
                      pinMode(relayPinB, OUTPUT);
                      // After setting up the buttons, setup debouncer
                      debouncerA.attach(buttonPinA);
                      debouncerA.interval(5);
                      debouncerB.attach(buttonPinB);
                      debouncerB.interval(5);
                      digitalWrite(relayPinA, RELAY_OFF);
                      digitalWrite(relayPinB, RELAY_OFF);
                        /*--------------------- Added these lines for toggle switch-------------------------*/
                      oldValueA = digitalRead(buttonPinA);  // set oldValueA to the current status of the toggle switch
                      oldValueB = digitalRead(buttonPinB);  // set oldValueB to the current status of the toggle switch
                     // send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
                     // send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
                    void presentation()  {
                      sendSketchInfo("Mains Controller", "1.0");
                      present(SSR_A_ID, S_LIGHT);
                      present(SSR_B_ID, S_LIGHT);
                       Example on how to asynchronously check for new messages from gw
                    if (trigger == 0){
                      trigger = 1;
                        connectionPresent();
                      else {
                       connectionLost();
                        switch (message.sensor) {
                          case 1:
                            stateA = message.getBool();
                            digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
                            break;
                          case 2:
                            stateB = message.getBool();
                            digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
                            break;
                          // Write some debug info
                        Serial.println(message.sensor);
                        Serial.print("from node:");
                        Serial.println(message.sender);
                    void connectionPresent() {
                         debouncerA.update();
                      int valueA = debouncerA.read();
                      if (valueA != oldValueA) {
                        send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
                      oldValueA = valueA;
                      debouncerB.update();
                      int valueB = debouncerB.read();
                      if (valueB != oldValueB) {
                        send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
                      oldValueB = valueB;
                      void connectionLost() {
                       // send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
                        send(msgA.set(stateA ? false : true), false); // Send new state with no request for ack
                        stateA = stateA ? false : true;               // invert the state
                         digitalWrite(relayPinA, stateA ? RELAY_ON : RELAY_OFF);  // toggle the relay
                      oldValueA = valueA;
                        //send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
                        send(msgB.set(stateB ? false : true), false); // Send new state with no request for ack
                        stateB = stateB ? false : true;                // invert the state
                         digitalWrite(relayPinB, stateB ? RELAY_ON : RELAY_OFF);  // toggle the relay
                      oldValueB = valueB;
                    rayanR 2 Replies Last reply
                    • pepsonP
                      pepsonP
                      pepson
                      Still not working correct. After lost connection with gateway and then change status , after connection restore , but status is still not update in Domoticz. Still show before lost connection.
                      • Boots33B Boots33
                        #define RELAY_ON 1
                        #define RELAY_OFF 0
                        int oldValueA = 0;
                        int oldValueB = 0;
                        int trigger = 0;
                        if (trigger == 0){
                          trigger = 1;
                          else {
                           connectionLost();
                              case 1:
                                break;
                              case 2:
                                break;
                          oldValueA = valueA;
                          oldValueB = valueB;
                          oldValueA = valueA;
                          oldValueB = valueB;
                        rayanR
                        rayanR
                        rayan
                        #51
                        This post is deleted!
                        • Boots33B Boots33
                          #define RELAY_ON 1
                          #define RELAY_OFF 0
                          int oldValueA = 0;
                          int oldValueB = 0;
                          int trigger = 0;
                          if (trigger == 0){
                            trigger = 1;
                            else {
                             connectionLost();
                                case 1:
                                  break;
                                case 2:
                                  break;
                            oldValueA = valueA;
                            oldValueB = valueB;
                            oldValueA = valueA;
                            oldValueB = valueB;
                          rayanR
                          rayanR
                          rayan
                          @Boots33
                          hi my friend.
                          i use your sketch and thank you.but there is a problem.
                          sketchs in site , when relay is fail , when i send command , so show to me "Error sending switch command, check device/hardware !" but your sketch dont show this error. so i dont understand relay is fail or no , when we are out home. can you fix this ?
                          • korttomaK korttoma
                            Here is an example that I'm using with 4 relays and 4 monostable buttons:
                            #define SN "RelayButtonArray"
                            #define SV "1.0"
                            #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
                            #define RELAY_OFF 1
                            #define noRelays 4                     //2-4
                            const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
                            const int buttonPin[] = {6, 7, 4, 5};   //  switch around pins to your desire
                            class Relay             // relay class, store all relevant data (equivalent to struct)
                              public:
                                int buttonPin;                   // physical pin number of button
                                int relayPin;             // physical pin number of relay
                                boolean relayState;               // relay status (also stored in EEPROM)
                            Relay Relays[noRelays];
                            Bounce debouncer[noRelays];
                            MyMessage msg[noRelays];
                              void before() {
                                pinMode(pin, OUTPUT);
                              wait(100);
                              // Initialize Relays with corresponding buttons
                              for (int i = 0; i < noRelays; i++) {
                                Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                                Relays[i].relayPin = relayPin[i];
                                msg[i].sensor = i;                                   // initialize messages
                                msg[i].type = V_LIGHT;
                                pinMode(Relays[i].buttonPin, INPUT_PULLUP);
                                wait(100);
                                Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                                digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                                wait(50);
                                debouncer[i] = Bounce();                        // initialize debouncer
                                debouncer[i].attach(buttonPin[i]);
                                debouncer[i].interval(30);
                                wait(50);
                              sendSketchInfo(SN, SV);
                              wait(100);
                                present(i, S_LIGHT);                               // present sensor to gateway
                              wait(100);
                              for (byte i = 0; i < noRelays; i++) {
                                if (debouncer[i].update()) {
                                  int value = debouncer[i].read();
                                  if ( value == LOW) {
                                    // save sensor state in EEPROM (location == sensor number)
                                    saveState( i, Relays[i].relayState );
                              //wait(20);
                                if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                                  digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                  saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                              wait(20);
                            breimannB
                            breimannB
                            breimann
                            @korttoma love this sketch. Used it for a dual LED strip light controller for our loft where our kids sleep - daughter on one side and boys on the other, both with LED strips (RGB) i installed. This way we can turn them on or off remotely without having to climb up there!!
                            Worked great. Thankyou for sharing.
                              moskovskiy82
                              Anybody has a sketch where multiple buttons are put up on single wire and voltage drop is used to distinguish between them?
                              • nieatyN
                                nieatyN
                                nieaty
                                • pepsonP
                                  pepsonP
                                  pepson
                                  Hi
                                  Has anybody solution how resolved problem update status when connection with gateway is not available and then come back connection with gateway?
                                  • pepsonP
                                    pepsonP
                                    pepson
                                    Hi
                                    Boots33B 1 Reply Last reply
                                    • pepsonP pepson
                                      Hi
                                      Boots33B
                                      Boots33B
                                      Boots33
                                      @pepson have a look at this Synchronising Light switch
                                      • pepsonP
                                        pepsonP
                                        pepson
                                        I try sketch from your link but i test and the same issu.
                                        I enable relay, then disable GATEWAY MySensors on DOmoticz and then change status relay to DISABLE by button. Then enable Gateway on Domoticz and still in domoticz show that relay is ENABLED. Not update status that i manual DISABLE relay by button.
                                        • pepsonP
                                          pepsonP
                                          pepson
                                          This is my sketch with my radio and this not working... no sync status after lost connection with gateway and after come back gateway...
                                             Relay with button sketch
                                             modified to work with no uplink
                                             to gateway and try to maintain sync to controller
                                          #define MY_DEBUG                               // Enable debug prints to serial monitor
                                          #define MY_RADIO_RFM69
                                          #define MY_RFM69_FREQUENCY RF69_868MHZ
                                          #define MY_IS_RFM69HW                         // Enable and select radio type attached
                                          #define MY_TRANSPORT_WAIT_READY_MS 5000        //set how long to wait for transport ready in milliseconds
                                          // Enabled repeater feature for this node
                                          // Node id defaults to AUTO (tries to fetch id from controller)
                                          #define MY_NODE_ID 10
                                          #define RELAY_PIN  5      // Arduino Digital I/O pin number for relay
                                          #define BUTTON_PIN  3     // Arduino Digital I/O pin number for button
                                          #define CHILD_ID 1        // Id of the sensor child
                                          #define RELAY_ON 0
                                          #define RELAY_OFF 1
                                          Bounce debouncer = Bounce();
                                          int oldValue = 0;
                                          bool uplinkAvailable = true;
                                          bool state = false;
                                          bool requestState;
                                          bool firstStart = true;
                                          unsigned long uplinkCheckTime ;                // holder for uplink checks
                                          unsigned long uplinkCheckPeriod = 30*1000;     // time between checks for uplink in milliseconds
                                          unsigned long returnWait = 1500;               // how long to wait for return from controller in milliseconds
                                          MyMessage msg(CHILD_ID, V_STATUS);
                                          void setup(){
                                            pinMode(BUTTON_PIN, INPUT_PULLUP);           // Setup the button pin, Activate internal pull-up
                                            debouncer.attach(BUTTON_PIN);                // After setting up the button, setup debouncer
                                            debouncer.interval(5);
                                            pinMode(RELAY_PIN, OUTPUT);                 // set relay pin in output mode
                                            digitalWrite(RELAY_PIN, RELAY_OFF);         // Make sure relay is off when starting up
                                            sendSketchInfo("Relay & Button", "1.0");
                                            present(CHILD_ID, S_BINARY);
                                          void loop(){
                                            if (firstStart) {                            // this code is only run once at startup
                                              Serial.println("First run started");
                                              if (request( CHILD_ID, V_STATUS)) {       // request the current state of the switch on the controller and check that an ack was received
                                                Serial.println("uplink available");
                                                wait (returnWait);                      //wait needed to allow request to return from controller
                                                Serial.print("controller state --- ");
                                                Serial.println(requestState);
                                                if (requestState != state) {           // check that controller is corectly showing the current relay state
                                                  send(msg.set(state), false);         // notify controller of current state
                                              else {
                                                Serial.println("uplink not available");
                                                uplinkAvailable = false;               // no uplink established
                                                uplinkCheckTime = millis();
                                              firstStart = false;                     // set firstStart flag false to prevent code from running again
                                            debouncer.update();
                                            int value = debouncer.read();                               // Get the update value
                                            if (value != oldValue && value == 0) {                      // check for new button push
                                              state =  !state;                                          // Toggle the state
                                              digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);    // switch the relay to the new state
                                              if (!send(msg.set(state), true)) {                        //Attempt to notify controller of changed state
                                                uplinkAvailable = false;                                // no uplink available
                                           oldValue = value;
                                            if (!uplinkAvailable && (millis() - uplinkCheckTime > uplinkCheckPeriod) ) {       // test to see if function should be called
                                              uplinkCheck();        // call uplink checking function
                                          /*-------------------start of functions--------------------------*/
                                            if (message.type == V_STATUS) {                                   // check to see if incoming message is for a switch
                                              switch (message.getCommand()) {                                 // message.getCommand will give us the command type of the incomming message
                                                case C_SET:                                                   //message is a set command  from controller to update relay state
                                                  state = message.getBool();                                  // get the new state
                                                  digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);      // switch relay to new state
                                                  uplinkAvailable = true;                                     //  uplink established
                                                  /*---- Write some debug info----*/
                                                  Serial.print(message.sensor);
                                                  break;
                                                case C_REQ:                                               // message is a returning request from controller
                                                  requestState = message.getBool();                       // update requestState with returning state
                                                  break;
                                          void uplinkCheck() {
                                            if (request( CHILD_ID, V_STATUS)) {         // request the current state of the switch on the controller and check that the request was succsessful
                                              Serial.println("uplink re-established");
                                                send(msg.set(state), false);            // notify controller of current state no ack
                                            uplinkCheckTime = millis();                // reset the checktime
                                            Serial.println("uplinkchecktime reset");
