  3. My 2AA battery sensor
90 Posts 27 Posters 126.7k Views 36 Watching
  • SweebeeS
    SweebeeS
    Sweebee
    A tip for much better batterylife: burn a new bootloader for 1mhz. Now you can attach the arduino and nrf directly to the batteries and you can measure the battery with the Internal voltage meter of the 328p. If you use a dht you attach the step-up conv. And only attach the dht to it.
    m26872M 1 Reply Last reply
    • sundberg84S sundberg84
      Hi!
      This is also what im trying to do... have the same components/material as you and added the resistors for battery measurement. I dont get this long life (sleeps 15min, activated and sends).
      Can you post some sort of schematics or more detailed pictures so i can see your connections?
      Would be great!
      Here is my own try for a schematics:
      http://forum.mysensors.org/uploads/upload-5ed3f6ed-2d8c-4e6e-83bf-407973550c49.jpg
      m26872M
      m26872M
      m26872
      @sundberg84
      I've looked at your lovely drawing before and I don't see anything wrong with it except from that 0.1uF capacitor should be in parallell just with the 470k resistor, but it shouldn't matter regarding battery life time. What would be more interesting is to see your sketch. Or do you use the same as I do?
      A schematic and a few better pictures is on my to do list, but will probably come sooner now since you asked for it.
      • sundberg84S
        #43
        @m26872
        Pretty much the same, i have stolen majority of your code:
        Ive a array to get an average battery value each hour:
        #include <DHT.h>
        //ställ in varje gång!=========================
        #define SketchName "Sovrum Uppe"
        #define SketchVer "1.0"
        #define NodeID 2
        #define VBAT_PER_BITS 0.003363075  // Calculated volts per bit from the used battery montoring voltage divider.   Internal_ref=1.1V, res=10bit=2^10-1=1023, Eg for 3V (2AA): Vin/Vb=R1/(R1+R2)=470e3/(1e6+470e3),  Vlim=Vb/Vin*1.1=3.44V, Volts per bit = Vlim/1023= 0.003363075
        #define VMIN 1.9  // Battery monitor lower level. Vmin_radio=1.9V
        #define VMAX 3.3  //  " " " high level. Vmin<Vmax<=3.44
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        unsigned long SLEEP_TIME = 15*60000;
        //unsigned long SLEEP_TIME = 5000; //debug
        //Ställ även in gw.begin(,,,)
        float lastTemp;
        float lastHum;
        boolean metric = true;
        int batteryPcnt = 0;
        int batLoop = 0;
        int batArray[3];
        DHT dht;
          analogReference(INTERNAL);
          delay(500); // Allow time for radio if power used as reset <<<<<<<<<<<<<< Experimented with good result
          gw.begin(NULL, NodeID, false);
        //incomingMessageCallback - Callback function for incoming messages from other nodes or controller and request responses. Default is NULL.
        //nodeId - The unique id (1-254) for this sensor. Default is AUTO(255) which means sensor tries to fetch an id from controller.
        //repeaterMode - Activate repeater mode. This node will forward messages to other nodes in the radio network. Make sure to call process() regularly. Default in false
          gw.sendSketchInfo(SketchName, SketchVer);
          int sensorValue = analogRead(BATTERY_SENSE_PIN);    // Battery monitoring reading
        delay(1000);
          Serial.print("Temp: "); Serial.print(temperature); Serial.println(" C");
         if (temperature > 0) {
        delay(1000);
          Serial.print("Hum: "); Serial.print(humidity); Serial.println(" %");
           if (humidity > 0) {
        delay(1000);
           float Vbat  = sensorValue * VBAT_PER_BITS;
           int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
         Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
           batArray[batLoop] = batteryPcnt;
           if (batLoop > 2) {
             batteryPcnt = (batArray[0] + batArray[1] + batArray[2] + batArray[3]);
             batteryPcnt = batteryPcnt / 4;
            Serial.print("Battery percent (Avg (4):) "); Serial.print(batteryPcnt); Serial.println(" %");
               batLoop = 0;
             else
             batLoop = batLoop + 1;
          gw.sleep(SLEEP_TIME); //sleep a bit
        • SweebeeS Sweebee
          m26872M
          m26872M
          m26872
          @Sweebee
          It's already been discussed earlier in this thread (see EasyIoTs posts above), it's nevertheless a very good tip. I also have some test nodes running, but I consider it to be the next step from the "basic" design which was this threads concept. If I'll post something with this low-power-tweaked design it'll therefore be in a new thread. I should probably write something about this as an update in the first post...
            @m26872
            #include <DHT.h>
            #define NodeID 2
            float lastTemp;
            float lastHum;
            int batLoop = 0;
            int batArray[3];
            DHT dht;
            delay(1000);
            delay(1000);
               if (humidity > 0) {
            delay(1000);
               if (batLoop > 2) {
                   batLoop = 0;
                 else
            m26872M
            m26872M
            m26872
            @sundberg84
            I'm no code expert, and the only thing I can think of is that your "delay(1000)" will keep the power hungry radio awake. If you need delays (apart from debug) I'd prefer sleep instead. What's your battery life time look like?
            • m26872M
              m26872M
              m26872
              #46
              UPDATE
              I've updated the first post with
              • A wiring layout.
              • Added a text about the low-power option
              • A few minor details.
              • sundberg84S
                Great layout/way to show your project - really nice!
                Its exactly as I do it so im getting a bit jealus here... . One node is down after a week.
                It might be the hardware or me not so good soldering so i short something out.
                I will try some more nodes now you have comfirmed I do it the right way and that should work.
                @m26872
                Thank you!
                  @m26872
                  Thank you!
                  m26872M
                  m26872M
                  m26872
                  @sundberg84
                  Thx, good you liked it.
                  With such fast battery drain it should be easier to trace the current draw. First you'll need to measure the current. Second option is of course the good old switch-and-replace troubleshooting method.
                  I've read about hardware and quality issues, but let's hope it isn't...
                  • sundberg84S
                    #49
                    @m26872 What kind of pro-mini do you use?
                    Im using deek robot 3.3v 8mhz and it seems like there is a problem with this: (http://forum.mysensors.org/topic/230/power-conservation-with-battery-powered-sensors) i kill them when i try to remove voltage regulator so i guess i havent suceeded yet with that.
                    I dont have any good equipment to measure current... Ill have made a new sensor today - lets see how it operates.
                    • m26872M
                      m26872M
                      m26872
                      Here are some close-up pictures of my Node 105 (which I opened with maximum care not to spoil my long term testing)
                        Node 105 starts to become famous here :)
                        We all follow him(?) with great excitement.
                        • epierreE
                          epierreE
                          epierre
                          yes, @m26872 any news ?
                          z-wave - Vera -> Domoticz
                          • m26872M
                            m26872M
                            m26872
                            The news is that my Vera Lite gave up (soft-wise) after all hacking, plug-ins and un-clean factory resets, so I gave up on her (and Z-wave too, at least for a while). We've been fighting with each other for too long, so I'd say the divorce was welcome.
                            Instead, in the controller jungle I decided to try Fhem, aware of the challanges as I'm not German- (nor Perl) speaking. I'm still in the sens-but-no-control-phase and have a few test nodes running, including "the" node 105. (Very easy transition btw, just one press at reset button then a node is in production with a new controller.)
                            Back home today after 2w holiday I think it's looking good. The only problem now is of course that my trending is broken. If anyone knows how to merge the old trend data with the new, you're very welcome? Or just on how to rescue the Datamine data (from NAS)? If possible? I haven't researched anything yet.
                              Meister_Petz
                              Just an idea... I'm not sure if someone mentioned it:
                              If sending consumes so much power... what about collecting sensor data every 5 minutes and then send the data (array) once per hour? Of course there would be some time calculating before logging in the controller (fhem), but this way, I can save power... What do you think?
                              • M Meister_Petz
                                m26872M
                                m26872M
                                m26872
                                @Meister_Petz Kind of what I already do in the test nodes 105/106 if you look at code above. Update frequencey and battery life time is a balance that can be adjusted just as you wish. Right now these node send update every 15 min and take sample for calculation 5 min before, which is about what I need. If you and your application is more interested in trending, history and data collection, I think your suggestion is excellent. If you need a fast response or action from your automation system it's not.
                                But, what I think is most unneseccary with my test nodes 105/106 is that they check battery level every 15 min and send update if it has changed. Since the level typically is unstable right after the first transmission, it will generate a lot of useless transmissions. The only reason for me not to update code in node 105/106 is to keep it as an untouched study case. In my new nodes I usually set a fixed battery check/update frequency (1/week) which also works as a heartbeat signal for less active nodes.
                                • TheoLT
                                  TheoLT
                                  TheoL
                                  Not sure if any one has had the same question. But the other day I stumbled on this little thing ;)
                                  https://www.adafruit.com/product/1572 It's a really small rechargeable battery. Now I don't no much about batteries. But I know that my LiOn powerd handdrill is very strong. The batteries of my handdril hardly lose power over time.
                                  So I was wondering if this could be used to power an Arduino and some sensors and how long it will take for the battery te become empty. It would make my 3.3V Sensors really small. I could almost install them in a small matchbox. Which I think is really cool!
                                  • TheoLT TheoL
                                    m26872M
                                    m26872M
                                    m26872
                                    @TheoL There are endless discussions about different batteries in the forum. Just search and read. I recall one issue with LiXx batteries is that max voltage is too high for the NRF24L01+ radio.
                                      Meister_Petz
                                      Ok, another thing: why not sending everything at once?
                                      As I understand you are using FHEM which allows a lot of coding on the controller side. So you could send batteryLevel, humidity and temperature in one go.
                                      Something like (this is no real code, just an idea):
                                      theValues = "battlvl:hum:temp"
                                      gw.send(msgAll.set(theValues, 1));
                                      and in fhem you split it at ":"
                                      So you have just one instead of 3 transmits.
                                      • M Meister_Petz
                                        m26872M
                                        m26872M
                                        m26872
                                        @Meister_Petz I think it's a very good idea! It would be a nice option to have. Parsing with Perl should be simple even for a beginner like me, but to change the Mysensors core and fhem plugin is far beyond what I can. If you can do it, just go ahead and plz share.
                                          Meister_Petz
                                          ok, I did some testing and succeeded:
                                          This is the important part of the Arduino code:
                                          String allSens = String(sensor1) + " " + String(sensor2);
                                          gw.send(msg1.set(allSens.c_str()));
                                          This is the FHEM code:
                                          define Sensor MYSENSORS_DEVICE 20
                                          attr Sensor IODev MSGateway
                                          attr Sensor mapReading_brightness1 1 brightness
                                          attr Sensor mode node
                                          attr Sensor version 1.5
                                          attr Sensor userReadings Bat Deg
                                          # split and copy to userReadings
                                          define Sensor.copy at +*00:02:00 {my $a = ReadingsVal("Sensor","brightness1",1);; my @b = split(/\ /,$a);; fhem("setreading Sensor Bat $b[0]");; fhem("setreading Sensor Grad $b[1]");;}
                                          P.S.: when I had this in fhem.cfg I had to use @@ instead of only one @
                                          This is my complete Arduino code for a Battery Sensor with Dallas Temp:
                                          #define SketchName "Sensor-send-all"
                                          #define SketchVer "1.2"
                                          #define NodeID 20
                                          unsigned long SleepTime = 828523; // 55234 = 1 Minute --- 828523 = 15 Minuten
                                          // this is the one which sends everything
                                          #define SENSOR1_ID 1 // Sensor 1 - allAtOnceMessage
                                            // Sensor PINS
                                              #define SENSOR1_PIN  A0 // BattLevel
                                              #define SENSOR2_PIN  6  // Dallas
                                            // MyMessage V_TEMP, V_LIGHT_LEVEL, ... depending on Sensor Type
                                               MyMessage msg1(SENSOR1_ID,V_LIGHT_LEVEL); // Sensor 5 - allAtOnceMessage
                                            // Dallas Temp
                                               #include <OneWire.h>
                                               OneWire oneWire(SENSOR2_PIN);
                                               float firstRun = 1;
                                              // present all Sensors to Gateway - S_TEMP, S_LIGHT_LEVEL,... depending an SENSOR type
                                              gw.present(SENSOR1_ID, S_LIGHT_LEVEL);
                                              sensors.begin();
                                              gw.process();
                                                 // wait some time to get all parts powered up
                                                 if (firstRun == 1){
                                                    delay(5000);
                                                    firstRun = 0;
                                                 } else {
                                                    delay(1000);
                                                 // Sensor1 - Battery Voltage - Part 1
                                                    int sensorRead10 = analogRead(SENSOR1_PIN);
                                                 // Sensor2 - DAL
                                                   gw.sleep(conversionTime);
                                                   float sensorRead2 = static_cast<float>(static_cast<int>((metric?sensors.getTempCByIndex(0):sensors.getTempFByIndex(0)) * 10.)) / 10.;
                                                 // Sensor1 - Battery Voltage - Part 2
                                                    int sensorRead11 = analogRead(SENSOR1_PIN);
                                                    //Volt der Battery
                                                    float sensorRead1 = (sensorRead10 + sensorRead11 + sensorRead12) / 3 * 0.0033;  // should be 0.003363075 my Batteries are different
                                                    float test = sensorRead10;
                                                 // send all to fhem
                                                    String allComb = String(sensorRead1) + " " + String(sensorRead2);
                                                    gw.send(msg1.set(allComb.c_str()));
                                                gw.sleep(SleepTime);
