  3. My 2AA battery sensor
90 Posts 27 Posters 128.5k Views 36 Watching
    Node 105 starts to become famous here :)
    We all follow him(?) with great excitement.
    • epierreE
      epierreE
      epierre
      yes, @m26872 any news ?
      z-wave - Vera -> Domoticz
      • m26872M
        m26872M
        m26872
        The news is that my Vera Lite gave up (soft-wise) after all hacking, plug-ins and un-clean factory resets, so I gave up on her (and Z-wave too, at least for a while). We've been fighting with each other for too long, so I'd say the divorce was welcome.
        Instead, in the controller jungle I decided to try Fhem, aware of the challanges as I'm not German- (nor Perl) speaking. I'm still in the sens-but-no-control-phase and have a few test nodes running, including "the" node 105. (Very easy transition btw, just one press at reset button then a node is in production with a new controller.)
        Back home today after 2w holiday I think it's looking good. The only problem now is of course that my trending is broken. If anyone knows how to merge the old trend data with the new, you're very welcome? Or just on how to rescue the Datamine data (from NAS)? If possible? I haven't researched anything yet.
          Meister_Petz
          Just an idea... I'm not sure if someone mentioned it:
          If sending consumes so much power... what about collecting sensor data every 5 minutes and then send the data (array) once per hour? Of course there would be some time calculating before logging in the controller (fhem), but this way, I can save power... What do you think?
          m26872M 1 Reply Last reply
          • M Meister_Petz
            m26872M
            m26872M
            m26872
            @Meister_Petz Kind of what I already do in the test nodes 105/106 if you look at code above. Update frequencey and battery life time is a balance that can be adjusted just as you wish. Right now these node send update every 15 min and take sample for calculation 5 min before, which is about what I need. If you and your application is more interested in trending, history and data collection, I think your suggestion is excellent. If you need a fast response or action from your automation system it's not.
            But, what I think is most unneseccary with my test nodes 105/106 is that they check battery level every 15 min and send update if it has changed. Since the level typically is unstable right after the first transmission, it will generate a lot of useless transmissions. The only reason for me not to update code in node 105/106 is to keep it as an untouched study case. In my new nodes I usually set a fixed battery check/update frequency (1/week) which also works as a heartbeat signal for less active nodes.
            • TheoLT
              TheoLT
              TheoL
              Not sure if any one has had the same question. But the other day I stumbled on this little thing ;)
              https://www.adafruit.com/product/1572 It's a really small rechargeable battery. Now I don't no much about batteries. But I know that my LiOn powerd handdrill is very strong. The batteries of my handdril hardly lose power over time.
              So I was wondering if this could be used to power an Arduino and some sensors and how long it will take for the battery te become empty. It would make my 3.3V Sensors really small. I could almost install them in a small matchbox. Which I think is really cool!
              • TheoLT TheoL
                m26872M
                m26872M
                m26872
                @TheoL There are endless discussions about different batteries in the forum. Just search and read. I recall one issue with LiXx batteries is that max voltage is too high for the NRF24L01+ radio.
                  Meister_Petz
                  Ok, another thing: why not sending everything at once?
                  As I understand you are using FHEM which allows a lot of coding on the controller side. So you could send batteryLevel, humidity and temperature in one go.
                  Something like (this is no real code, just an idea):
                  theValues = "battlvl:hum:temp"
                  gw.send(msgAll.set(theValues, 1));
                  and in fhem you split it at ":"
                  So you have just one instead of 3 transmits.
                  • M Meister_Petz
                    m26872M
                    m26872M
                    m26872
                    @Meister_Petz I think it's a very good idea! It would be a nice option to have. Parsing with Perl should be simple even for a beginner like me, but to change the Mysensors core and fhem plugin is far beyond what I can. If you can do it, just go ahead and plz share.
                      Meister_Petz
                      ok, I did some testing and succeeded:
                      This is the important part of the Arduino code:
                      String allSens = String(sensor1) + " " + String(sensor2);
                      gw.send(msg1.set(allSens.c_str()));
                      This is the FHEM code:
                      define Sensor MYSENSORS_DEVICE 20
                      attr Sensor IODev MSGateway
                      attr Sensor mapReading_brightness1 1 brightness
                      attr Sensor mode node
                      attr Sensor version 1.5
                      attr Sensor userReadings Bat Deg
                      # split and copy to userReadings
                      define Sensor.copy at +*00:02:00 {my $a = ReadingsVal("Sensor","brightness1",1);; my @b = split(/\ /,$a);; fhem("setreading Sensor Bat $b[0]");; fhem("setreading Sensor Grad $b[1]");;}
                      P.S.: when I had this in fhem.cfg I had to use @@ instead of only one @
                      This is my complete Arduino code for a Battery Sensor with Dallas Temp:
                      #define SketchName "Sensor-send-all"
                      #define SketchVer "1.2"
                      #define NodeID 20
                      unsigned long SleepTime = 828523; // 55234 = 1 Minute --- 828523 = 15 Minuten
                      // this is the one which sends everything
                      #define SENSOR1_ID 1 // Sensor 1 - allAtOnceMessage
                        // Sensor PINS
                          #define SENSOR1_PIN  A0 // BattLevel
                          #define SENSOR2_PIN  6  // Dallas
                        // MyMessage V_TEMP, V_LIGHT_LEVEL, ... depending on Sensor Type
                           MyMessage msg1(SENSOR1_ID,V_LIGHT_LEVEL); // Sensor 5 - allAtOnceMessage
                        // Dallas Temp
                           #include <OneWire.h>
                           OneWire oneWire(SENSOR2_PIN);
                           boolean receivedConfig = false;
                           float firstRun = 1;
                           boolean metric = true;
                          analogReference(INTERNAL);
                          delay(500); // Allow time for radio if power used as reset <<<<<<<<<<<<<< Experimented with good result
                          gw.begin(NULL, NodeID, false);
                          gw.sendSketchInfo(SketchName, SketchVer);
                          // present all Sensors to Gateway - S_TEMP, S_LIGHT_LEVEL,... depending an SENSOR type
                          gw.present(SENSOR1_ID, S_LIGHT_LEVEL);
                          sensors.begin();
                             // wait some time to get all parts powered up
                             if (firstRun == 1){
                                delay(5000);
                                firstRun = 0;
                                delay(1000);
                             // Sensor1 - Battery Voltage - Part 1
                                int sensorRead10 = analogRead(SENSOR1_PIN);
                             // Sensor2 - DAL
                               gw.sleep(conversionTime);
                               float sensorRead2 = static_cast<float>(static_cast<int>((metric?sensors.getTempCByIndex(0):sensors.getTempFByIndex(0)) * 10.)) / 10.;
                             // Sensor1 - Battery Voltage - Part 2
                                int sensorRead11 = analogRead(SENSOR1_PIN);
                                //Volt der Battery
                                float sensorRead1 = (sensorRead10 + sensorRead11 + sensorRead12) / 3 * 0.0033;  // should be 0.003363075 my Batteries are different
                                float test = sensorRead10;
                             // send all to fhem
                                String allComb = String(sensorRead1) + " " + String(sensorRead2);
                                gw.send(msg1.set(allComb.c_str()));
                            gw.sleep(SleepTime);
                      • M Meister_Petz
                        #define NodeID 20
                          // Sensor PINS
                          // Dallas Temp
                             float firstRun = 1;
                            sensors.begin();
                               if (firstRun == 1){
                                  delay(5000);
                                  firstRun = 0;
                                  delay(1000);
                               // Sensor2 - DAL
                                  //Volt der Battery
                               // send all to fhem
                        m26872M
                        m26872M
                        m26872
                        @Meister_Petz Wow! Well done! I think this can be very useful.
                        In theory some power should be saved. Estimation from here is that a 250kbit/s transmission of a maximum size (32 byte) packet is >1.5ms. I think at around 20mA. Massage header is 7 byte, but a normal massage just a few bytes, i.e. just 30% of a message. Startup time for radio is fast (140us), so that shouldn't be an issue. (A side note here is that wake up atmega328p from sleep takes long (6ms?).)
                        Is there a reason that you wrote the Fhem sonsor.copy macro as an "at" and not a "notify" ? The intuitive way would be to copy upon a new reading.
                        • m26872M m26872
                          Meister_Petz
                          @m26872 there is no special reason for "at"... I think I got it from some where and it worked ;-)
                          • m26872M
                            m26872M
                            m26872
                            Soon 11 months of production including a fair amount of too frequent battery uppdates. Most exciting is wheter the initially used batteries in 106 will make it 12 months or not.
                            AnticimexA 1 Reply Last reply
                            • m26872M m26872
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @m26872 perhaps you could reduce the redundant updates by filtering. If the current sample is lower than the "next" sample ignore it. If your node does not support charging, it will never really truly read an increase in battery voltage.
                              • AnticimexA Anticimex
                                m26872M
                                m26872M
                                m26872
                                @Anticimex Yes, but in this particular case its double. Conclusion from above was that frequency and magnitude of the "low spikes" gives you information of how near the end you are. On the other hand I would never run like this if it wasn't for keeping the experiment "untouched". I think my thought for future sensors is to preserve that information, but save battery, just by reducing the number of samples.
                                I'm still not sure of the best filter/algorithm to predict battery end of life from present and historic data. It will probably differ a lot wheter there's a step-up or a nicer load.
                                • m26872M m26872
                                  @m26872 Just a suggestion: once the node dies you could take the raw data and run some filtering on it like @Anticimex suggested.
                                  It'll give you a quick way to experiment with different filter settings.
                                  Once you find an optimal filter you can implement it in the node(s).
                                  • YveauxY Yveaux
                                    m26872M
                                    m26872M
                                    m26872
                                    @Yveaux You're right. I expect a good correlation between "spike depth" and the load profile just prior to sample. By controling this it should be quite repeatable.
                                    • mntlvrM
                                      mntlvrM
                                      mntlvr
                                      • mntlvrM mntlvr
                                        [[topic:post-is-deleted]]
                                        m26872M
                                        m26872M
                                        m26872
                                        @mntlvr Interesting discussion but why in this thread?
                                        mntlvrM 1 Reply Last reply
                                        • m26872M m26872
                                          mntlvrM
                                          mntlvrM
                                          mntlvr
