  3. ESP8266 gateway + WebServer = Awesome!
33 Posts 10 Posters 15.1k Views 16 Watching
  • JapioJ Offline
    JapioJ Offline
    Japio
    I used the indications feature of MySensors 2.0 and a webserver to have the gateway provide status information through a web page:
    This is how I did it:
    In the global section I added this:
    #include <ESP8266WiFi.h>
    #include <ESP8266WebServer.h>
    #include <WiFiClient.h>
    ESP8266WebServer WebServer(80);
    unsigned long startTime=millis();
    unsigned long gwMsgSent = 0;
    unsigned long gwMsgRec = 0;
    String WebPage = "<h1>ESP8266 MQTT client for Mysensors</h1>";
    void setupWebServer();
    void showRootPage();
    String readableTimestamp(unsigned long milliseconds);
    In the setup() Added this:
      Serial.begin(9600);
      setupWebServer();
    Defined the following functions:
      WebServer.on("/", HTTP_GET, showRootPage);
      WebServer.begin();
      Serial.println("WebServer started...");
    void indication( const indication_t ind )
      switch (ind)
        case INDICATION_GW_TX:
          gwMsgSent++;
          break;
        case INDICATION_GW_RX:
          gwMsgRec++;
          break;
        default:
        break;
    void showRootPage()
      unsigned long runningTime = millis() - startTime;
      String page = WebPage;
      page+="<br>General information</br>";
      page+= "<style> table, th, td { border: 1px solid black;}</style>";
      page+="<table style=\"width:400\">";
      page+="<tr>"; page+=  "<th>Item</th>";        page+=  "<th>Value</th>";                                            page+="</tr>";
      page+="<tr>"; page+=  "<td>Running for</td>";               page+=  "<td>"; page += readableTimestamp(runningTime) ; page+= "</td>";                 page+="</tr>";
      page+="<tr>"; page+=  "<td>Gateway messages sent</td>";     page+=  "<td>"; page += gwMsgSent; page+= "</td>";                                page+="</tr>";
      page+="</table>";
      page+="<br>MySensors gateway information</br>";
      page+="<tr>"; page+=  "<td>Gateway messages received</td>";     page+=  "<td>"; page += gwMsgRec; page+= "</td>";                                page+="</tr>";
      page+="</table>";
      Serial.println("WS: Send root webpage");
      WebServer.send(200, "text/html", page);
      int days = milliseconds / 86400000;
      milliseconds=milliseconds % 86400000;
      int hours = milliseconds / 3600000;
      milliseconds = milliseconds %3600000;
       int minutes = milliseconds / 60000;
       milliseconds = milliseconds % 60000;
       int seconds = milliseconds / 1000;
       milliseconds = milliseconds % 1000;
        String timeStamp;
        timeStamp = days; timeStamp += " days, ";
        timeStamp += hours; timeStamp += ":";
        timeStamp += minutes ; timeStamp +=  ":";
        timeStamp +=seconds; timeStamp += ".";
        timeStamp +=milliseconds;
        Serial.println(timeStamp);
        return timeStamp;
    And in loop() added the following:
      WebServer.handleClient();
    If you have any more idaes on what to add to this page (I am thinking about maintaining a list of registered nodes and sensors) just post a reply!
    Y chrilleC 2 Replies Last reply
    • mfalkviddM Offline
      Nice work, thanks for sharing!
      • JapioJ Japio
          Serial.begin(9600);
          setupWebServer();
          WebServer.begin();
          switch (ind)
              gwMsgSent++;
              break;
              gwMsgRec++;
              break;
            default:
            break;
        void showRootPage()
          page+="</table>";
          page+="</table>";
            String timeStamp;
            return timeStamp;
        Y Offline
        Y Offline
        @Japio Very nice indeed! Good to see you like the indication-feature ;-)
        Btw. I slightly reformatted your post to include code-blocks, to improve readability (use the </> markup feature for code).
        • JapioJ Offline
          JapioJ Offline
          Japio
          @Yveaux thanks for formatting the code.
          Would it be possible to get the list of registered nodes and sensors for example?
          Y 1 Reply Last reply
          • JapioJ Japio
            Y Offline
            Y Offline
            @Japio it's not exported at the api as far as I know. The routing table is stored in eeprom, which you can read from your sketch (but you have to know the internal format then).
            A better solution would be to extend the api.
            • H Offline
              H Offline
              The routing table only holds the next jump for a destination. Might be better to implement receive method and build a new data structure (as the ESP has plenty of memory). Then you would be able to pick up both from-field and even presentation messages to show which type of sensors the nodes has attached.
              • JapioJ Offline
                JapioJ Offline
                Japio
                @hek Indeed, the ESP has both plenty of processing power and memory compared to the arduino.
                This implementing a receive method, is that a method I can implement in my sketch, with a specific name and signature, and it will be called automatically (like the indication handler)? or does it require changes in de library code? Sounds promising, I can just take out the data I need and store it in a separate structure until the webpage is requested.
                Another thing I found "somewhere on the Internet" is an ESP8266 program that, when the wifi connection is not established, or the stored network SSID and password are empty, places the ESP in Access point mode. You can connect to this wifi network and configure the wifi settings. That way you don't need your SSID and password in the sketch.
                Too many things to do, and too little time I am afraid.:grinning:
                • H Offline
                  H Offline
                  Yes. Receive is standard functionality.
                  • JapioJ Japio
                    @Japio perhaps you mean https://github.com/tzapu/WiFiManager ? I'm using that. It is pretty ok, but I would prefer something that had support for the async web server.
                    pihomeP 1 Reply Last reply
                    • JapioJ Offline
                      JapioJ Offline
                      Japio
                      Hmm I implemented a receive function like this:
                        Serial.println("@@@@@@@#####@@@@@Message");
                      And when I connect my smartmeter sensor I get the following output in the serial console of my MQTT gateway:
                      0;255;3;0;9;TSP:MSG:READ 20-20-0 s=6,c=1,t=17,pt=7,l=5,sg=0:350
                      0;255;3;0;9;Sending message on topic: mygateway1-out/20/6/1/0/17
                      0;255;3;0;9;TSP:MSG:READ 20-20-0 s=7,c=1,t=17,pt=7,l=5,sg=1: 0
                      0;255;3;0;9;Sending message on topic: mygateway1-out/20/7/1/0/17
                      So I assume the receive function is not called?
                      Still, as with the indication function it is fuzzy to me how it i possible that a function is called when it is implemented, but the compiler does not complain when it is not :confused:
                      Is this some kind of inheritance relation?
                      • JapioJ Japio
                        Y Offline
                        Y Offline
                        The function is defined as weak in the library.
                        This means the user can implement its own version and then the pointer to the function will be non-null, or you can leave it unimplemented and the pointer to the function becomes null. It's up to the caller (the MySensors library in this case) to test if the pointer is null before calling the function.
                        • JapioJ Offline
                          JapioJ Offline
                          Japio
                          @Yveaux ok, thanks, I just have learned something ;-)
                          So I can assume the receive function is not called from the library then? So which function is called, on reception of data from a node?
                          • JapioJ Japio
                            Y Offline
                            Y Offline
                            @Japio Looks like you hit a bug in 2.0.0 (receive() was not called for gateways), which has been fixed in development: https://github.com/mysensors/MySensors/commit/24e3dfa36c711b4174ed615408994e8624a2b1f3#diff-9ff5690366e84c42d1e97f40dfe3b8a1R580
                            Please try with development branch (2.0.1 beta) https://github.com/mysensors/MySensors/tree/development and see if that fixes your issue.
                            • JapioJ Offline
                              JapioJ Offline
                              Japio
                              Yes, I see the difference. I'll try the bèta version tomorrow.
                              • JapioJ Japio
                                  Serial.begin(9600);
                                  setupWebServer();
                                  WebServer.begin();
                                  switch (ind)
                                      gwMsgSent++;
                                      break;
                                      gwMsgRec++;
                                      break;
                                    default:
                                    break;
                                void showRootPage()
                                  page+="</table>";
                                  page+="</table>";
                                    String timeStamp;
                                    return timeStamp;
                                chrilleC Offline
                                chrilleC Offline
                                chrille
                                @Japio Very nice idea - I just tested it on my ESP8266/RFM69 gateway. However the counters doesn't seem to increment (always shows 0) - is there anything special I need to make sure the indication() handler is called?
                                • JapioJ Offline
                                  JapioJ Offline
                                  Japio
                                  No, it worked right out of the box, something that surprised me as well.
                                  You do need Mysensors 2.0 for this.
                                  You can check if you have a myindication.h file in the source tree of the Mysensors library. That file also contains the indications sent.
                                  • JapioJ Japio
                                    chrilleC Offline
                                    chrilleC Offline
                                    chrille
                                    @Japio I am using the latest beta from github - it must be something else
                                    chrilleC 1 Reply Last reply
                                    • chrilleC chrille
                                      chrilleC Offline
                                      chrilleC Offline
                                      chrille
                                      It works on my NRF24 gateway, but not on the RFM69 gateway... Odd...
                                      I'm curious if someone else with a RFM69 based gateway could this this
                                      • Jan
                                      • JapioJ Japio
                                        chrilleC Offline
                                        chrilleC Offline
                                        chrille
                                        @Japio It's very easy to get information about available memory and wifi signal - just add
                                        page+="<tr>"; page+=  "<td>Free memory:</td>";               page+=  "<td>"; page += ESP.getFreeHeap() ; page+= " bytes</td>";                 page+="</tr>";
                                          page+="<tr>"; page+=  "<td>WIFI signal:</td>";               page+=  "<td>"; page += WiFi.RSSI(); ; page+= " dBm</td>";                 page+="</tr>";
                                        • JapioJ Offline
                                          JapioJ Offline
                                          Japio
                                          Great! This will be added.
                                          I am going to continue with the node and sensor status tomorrow.
                                          12.2k
