  3. ESP8266 gateway + WebServer = Awesome!
33 Posts 10 Posters 15.5k Views 16 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    wrote on last edited by Mark Swift
    #21
    Love this, subscribed. It's s such a shame I always has issues with my ESP gateway and had to revert to standard ethernet. The ESP always used to fail upon large amounts of traffic :(
    I believe this was down to blocking code, is this resolved? (off topic).
    BTW, is it possible to somehow record any failures?
    • JapioJ
      JapioJ
      Japio
      Yes, this works!
      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=15,pt=2,l=2,sg=0:0
      0;255;3;0;9;TSF:MSG:SEND,0-0-20-20,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.3
      0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/0/0/17
      @@@@@@@#####@@@@@Message
      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
      0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/3/0/6
      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=11,pt=0,l=10,sg=0:Smartmeter
      0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/3/0/11
      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=12,pt=0,l=3,sg=0:0.1
      0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/3/0/12
      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=1,c=0,t=13,pt=0,l=0,sg=0:
      0;255;3;0;9;Sending message on topic: mygateway1-out/20/1/0/0/13
      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=2,c=0,t=13,pt=0,l=0,sg=0:
      0;255;3;0;9;Sending message on topic: mygateway1-out/20/2/0/0/13
      0;255;3;0;9;TSF:SANCHK:OK
      The @@@@###@@@ Message is printed in my receive() function!
      Awesome. :smile:
      korttomaK 1 Reply Last reply
      • JapioJ Japio
        Yes, this works!
        Awesome. :smile:
        korttomaK
        korttomaK
        korttoma
        Nice work @Japio
        I'm working on a ESP8266 RFM69 Gateway myself and will definitely try this also.
        • Tomas
        chrilleC 1 Reply Last reply
        • korttomaK korttoma
          Nice work @Japio
          chrilleC
          chrilleC
          chrille
          @korttoma I'm looking forward to hear your results, as I couldn't get it to work with RFM69. However, there doesn't seem to be transport specific code for indication(), so I really don't understand why it works with NRF and not RFM
            ESP8266+RFM69 discussion forked to https://forum.mysensors.org/topic/4889/esp8266-rfm69-gateway/
            • chrilleC chrille
              @chrille said:
              I am using the latest beta from github - it must be something else
              It works on my NRF24 gateway, but not on the RFM69 gateway... Odd...
              I'm curious if someone else with a RFM69 based gateway could this this
              • Jan
              chrilleC
              chrilleC
              chrille
              I created an issue for this, but I'm still interested in hearing from other RFM69 users
              https://github.com/mysensors/MySensors/issues/584
              tekkaT 1 Reply Last reply
              • chrilleC chrille
                tekkaT
                tekkaT
                tekka
                @chrille Please see my comment on github
                • korttomaK
                  korttomaK
                  korttoma
                  Would it be possible to add information about if a controller is connected to the GW WebHMI?
                  • Tomas
                  • Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    Is this still under development?
                    • JapioJ
                      JapioJ
                      Japio
                      Yes, it actually is.
                      Current features:
                      • Stores wifi and mqtt broker configuration in flash. When no configuration is found, or the flash button of the ESP is pressed for 10 seconds, released, and then the reset button is pressed, it will restart in access point mode, allowing configuration to be done.
                      • Status page shows all nodes and sensors connected and the last sensors data and presentation time.
                      • Status indications on the box itself using a neopixel stick of 8 leds:
                        • Gateway status (operation or access point mode)
                        • Wifi strength
                        • Mqtt connection status
                        • Transmit error
                        • Receive indication.
                      I designed a board to nicely fit in a standard Aliexpress housing.
                      Main problem still is the instability of the ESP, it resets often, and I tried to work around it by maikng sure it resets quickly.
                      I am planning to make a more elaborate topic, including board designs soon.
                      R 1 Reply Last reply
                      • JapioJ Japio
                        Current features:
                          • Wifi strength
                          • Transmit error
                        R
                        R
                        r-nox
                        @japio
                        Where did this all end up?
                          @Japio perhaps you mean https://github.com/tzapu/WiFiManager ? I'm using that. It is pretty ok, but I would prefer something that had support for the async web server.
                          pihomeP
                          pihomeP
                          pihome
                          @mfalkvidd I know this is very old post but I stumble upon this while looking for esp gateway wifimanager git, can you share ur code if you don’t mind, save me time on re-inventing the wheel again...
                          PiHome - Smart Heating Control
                          • pihomeP pihome
                            @pihome I have a sketch at https://github.com/mfalkvidd/Arduino-Datormagazin-Pomodoro/blob/datormagazin/Arduino-Datormagazin-Pomodoro.ino but I think it is easier to just follow the instructions in the wifimanager readme.
