  3. Cant connect to w5100 ethernet gateway
3 Posts 3 Posters 1.4k Views 3 Watching
  • rkressaR
    rkressaR
    rkressa
    Wired up a w5100 and radio as shows in the ethernet gateway build page. Using a generic arduino uno with the w5100 hooked up to 5v and the radio hooked up to 3.3.
    Serial Monitor shows:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 10.0.0.25
    I cannot see the IP address on my router device page.
    Vera says: MySensors plugin : Cannot send command - communications error
    Any ideas?
    TheoLT 1 Reply Last reply
    • rkressaR rkressa
      IP: 10.0.0.25
      Any ideas?
      TheoLT
      TheoLT
      TheoL
      @rkressa What happens if you type in ping 10.0.0.25 does your ethernet respond?
      Also make sure that the 10.0.0.25 is in your network ip range and subnet mask
      • AttiqA
        AttiqA
        Attiq
        https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time
        Downgrade your AVR core to 1.6.11, it will work.
