  3. HomeGenie
  4. HomeGenie, experience?
Scheduled Pinned Locked Moved HomeGenie
21 Posts 3 Posters 12.5k Views 4 Watching
  • raptorjrR
    raptorjrR
    raptorjr
    Does anyone have any experience with HomeGenie? Hard/easy/possible/impossible to get to work with MySensors? Support for different sensors? Anything you can tell =)
      There's some buzz here.
      http://www.homegenie.it/forum/index.php?topic=1680.0
      raptorjrR 1 Reply Last reply
      • raptorjrR
        raptorjrR
        raptorjr
        Thank you. Don't know if it is abandoned by the admins. Been waiting 3 days to get access to the forums.
        It looks good, but with such poor support I'll have to continue my search for a good controller.
          mvdarend
          At the moment there is no MySensors v2.0 support in HomeGenie, but I'm working on a new Serial Gateway.
          At first there will only be limited support (Switches, Temp, Humidity and Motion) but I'm hoping to have more available within a short time.
          The first test version will be available this Friday.
          • M mvdarend
            raptorjrR
            raptorjrR
            raptorjr
            @mvdarend
            Sounds good. Looking forward to test it. Are you a developer of HomeGenie or just making a addon?
            Would be nice if there was some kind of roadmap for HomeGenie. It looks good, but need support for the right hardware too =)
              mvdarend
              No, I'm not a developer of HomeGenie, I've helped a little bit, but I'm not the greatest programmer and I think I'd hurt the project more than help :)
              It's basically a one man show, although Gene (the Developer) is very open to any help, and quite a few people have chipped in over the years.
              Not sure on the roadmap, what kind of devices are you looking at using?
                mvdarend
                wrote on last edited by mvdarend
                I've started a new thread on the HomeGenie forum with the first test version, you can find the forum here:
                MySensor v2.0 Serial Gateway for HomeGenie
                Edit: Quick summary
                Supported Devices (tested)
                S_LIGHT / S_BINARY - Actuators also tested
                S_TEMP
                S_HUM
                S_MOTION
                S_LIGHT_LEVEL
                Untested
                S_POWER
                S_DISTANCE
                S_RGB_LIGHT
                • M mvdarend
                  Edit: Quick summary
                  S_TEMP
                  S_HUM
                  S_MOTION
                  S_LIGHT_LEVEL
                  Untested
                  S_POWER
                  S_DISTANCE
                  S_RGB_LIGHT
                  raptorjrR
                  raptorjrR
                  raptorjr
                  @mvdarend
                  Nice. Will have a look at it and see how it works.
                  When it comes to hardware I'm currently most into MySensors things. Since it gives me the freedom to do things that is not that easy to buy from a commercial solution. My current project includes a outdoor fishtank and the ability to regulate the temperature in the tank by filling it up with new water. Need support for waterflow meter and water valve for example.
                  But I'm not a complete idiot =) and have some old programming skills that I maybe could use to help and add support to the gateway for devices I have. But then again HomeGenie needs support for those also. Therefore I was asking about a roadmap.
                  Domoticz have support for most of the devices, but on the other hand the developer have made them so specific to the thing he thinks they are used for, and makes it harder to use them for other things.
                  Like the water flow gadget in Domoticz is designed for incoming water to a house or something, and not very flexible when you only need to measure the flow in any other environment.
                  So if there is only full support for MySensors I would be very happy.
                  But I haven't tried HomeGenie so much yet. How is it with automation? Easy/flexible to do? I need some automated way to measure water temperature and open/close water valve accordingly.
                  M 2 Replies Last reply
                  • raptorjrR raptorjr
                    @mvdarend
                    mvdarend
                    HomeGenie is pretty good for flexible yet powerful automation rules, even if you're not great with coding. That shouldn't be a problem at all.
                      @mvdarend
                      mvdarend
                      Water valve shouldn't be a problem, it's basically on/off? Then you could just assign it as a binary switch and give it a nicer widget icon in HomeGenie.
                      For the water flow meter, could you give me an example of what you have made, and how you would like to see it work within HomeGenie. (comparison to the Domoticz solution would be a good help too)
                      • M mvdarend
                        raptorjrR
                        raptorjrR
                        raptorjr
                        @mvdarend said:
                        What would you like to see here? My sketch for the water flow meter? I can find some image and try to explain how I would like to see it work, to be flexible and usable for others too.
                        M 1 Reply Last reply
                          mvdarend
                          @raptorjr Ah yes, I wasn't very clear there. What I meant is an example of how you are using the sensor, if I have understood correctly, you are doing the following:
                          • Measure water temp, if too high (or low) then activate the water valve.
                          • Keep water valve open until the desired temperature has been reached.
                          But how the water flow sensor fits into this I'm not sure. Is it to make sure the water valve has been closed? Or to give an estimate of how long it will take? something else?
                          • M mvdarend
                            raptorjrR
                            raptorjrR
                            raptorjr
                            @mvdarend
                            Yes. The waterflow will be used to make sure that the valve is open and more important is closed when I want it to be. Otherwise notify me. Also a little interesting to see stats on how much water is added.
                              mvdarend
                              I've made a small update, S_WATER (V_FLOW, V_VOLUME) have been added. (not tested)
                              Supported Devices:
                              S_DOOR
                              S_MOTION
                              S_LIGHT / S_BINARY
                              S_TEMP
                              S_HUM
                              S_POWER *
                              S_DISTANCE *
                              S_LIGHT_LEVEL
                              S_IR *
                              S_RGB_LIGHT *
                              S_WATER *
                              S_GAS *
                              I_BATTERY_LEVEL *
                              I_ID_REQUEST
                              I_INCLUSION_MODE *
                              • Not tested
                                @mvdarend
                                mvdarend
                                Thanks to the help of @raptorjr HomeGenie will also have support for the Ethernet Gateway. :+1:
                                  raptorjrR
                                  raptorjrR
                                  raptorjr
                                  @hek
                                  It seems that there is some support for MySensors 2.0 in HomeGenie now. Would it be possible to get HomeGenie added to the list of supported controllers?
                                  Not that I'm that experienced in controllers, but I have tried a few and this one really got me excited. I think it is a good candidate on the list.
                                    Yes, absolutely.
                                    I would need some information like short background, features, logo and a few screenshots.
                                    Nice if someone fills out the Controller Matrix for HomeGenie so @AWI can add it to the main controller page.
                                    raptorjrR 2 Replies Last reply
                                      Yes, absolutely.
                                      raptorjrR
                                      raptorjrR
                                      raptorjr
                                      wrote on last edited by raptorjr
                                      @hek
                                      I just found HomeGenie a few days ago, but since I already like it I will do what I can to help. If @mvdarend has the time maybe he can take a look at the Controller Matrix. He has much more knowledge of what HomeGenie can do.
                                      EDIT: I see now that HomeGenie is already a part of the ControllerMatrix, but no link and information in the list. Will see what I can dig out.
                                        Yes, absolutely.
                                        raptorjrR
                                        raptorjrR
                                        raptorjr
                                        @hek
                                        I just got some text and images from the HomeGenie website and put it in a Word document. Maybe it is something you can use?
                                        I hope the developer of HomeGenie don't mind.
                                        0_1476565604254_HomeGenie.doc
                                          @hek
                                          mvdarend
                                          @raptorjr said:
                                          @hek
                                          AWI asked me to fill out the Controller Matrix form a few days ago, I hadn;t got around to creating a document yet. The document you made looks like I would have done it I think.
