  3. Missing Bracket in DallasTemperatureSensor Sketch
5 Posts 2 Posters 1.8k Views 2 Watching
  • foad62F
    foad62F
    foad62
    I was developing my project basde on DallasTemperatureSensor sketch and I found something strange. The loop function has no closing brackets! However the code compiles without errors. And since I'm adding receive function at the end of the sketch it has made me confused about the loop functionality!
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    //#define MY_DEBUG
    #include <OneWire.h>
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    void before()
      sensors.begin();
    void presentation() {
      sendSketchInfo("Temperature Sensor", "1.1");
         present(i, S_TEMP);
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
      sleep(SLEEP_TIME);
      Not sure what you mean.. The loop-function contains a end-bracket here:
      https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/DallasTemperatureSensor/DallasTemperatureSensor.ino#L109
      foad62F 1 Reply Last reply
        foad62F
        foad62F
        foad62
        @hek
        The closing bracket you mentioned is not for "loop()" it is for the following "for":
        if you count the opening brackets starting from the loop(), there are 4 opening brackets and 3 closing brackets.
          The pre-processor (compiler) remives one of the if-statements.
            foad62F
            foad62F
            foad62
            @hek
            But when I add the missing closing bracket I get the following error:
            DallasTemperatureSensor:123: error: expected declaration before '}' token
            exit status 1
