  3. Strange behaviour - Check Wires and Version Mismatch
22 Posts 5 Posters 12.6k Views 3 Watching
  • marceltrapmanM
    marceltrapmanM
    marceltrapman
    I have two strange things going on.
    1. When running the serial monitor I randomly see a message "Check Wires". Really randomly but always immediately after uploading a sketch. Any idea?
    2. I can't seem to get a child id anymore. The id is sent but below is what I see (coming in) in the serial monitor. Any idea what could be going on.
    I update to the latest git version of 1.4 this morning and updated the gateway, repeater and sensors.
    send: 255-255-1-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
    sensor started, id 255
    req node id
    req node id
    req node id
    req node id
    req node id
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    Sensor status ON
    req node id
    read: 0-0-0 s=0,c=0,t=0,pt=0,l=0:
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    Sensor status ON
    req node id
    read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
    Fulltime Servoy Developer
    AnticimexA 1 Reply Last reply
    • marceltrapmanM marceltrapman
      req node id
      req node id
      req node id
      req node id
      req node id
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      Sensor status ON
      req node id
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      Sensor status ON
      req node id
      AnticimexA
      AnticimexA
      Anticimex
      @marceltrapman Is it a serial or an ethernet GW? I have received both "Check Wires" and "Version Mismatch" with W5100 Ethernet module. The problem was "war" on the SPI bus (which the W5100 abuses).
      If it is indeed an Ethernet GW, check this.
      If it is a serial GW, have a look at the supply voltages. In my experience, the onboard 3.3V regulator on an Nano (assuming you use a Nano for GW) simply does not cut it for the RF module. I have thrown in an external LE33 regulator and soldered a 4.7uF cap directly on my RF modules across GND and Vcc. This together with my patch for W5100 sorted my GW out (but it is now torn apart to be re-incarnated into something more "awesome" (forum post will cover my build) once I got things running again).
        I was a bit worried that I had broken something because I did a RF24 update (the one in util-folder) a couple of days ago to get SOFTSPI functionality for the scene controller example.
        But everything still seems to work fine here when I did a quick verification.
        What does your sensor output?
        • AnticimexA Anticimex
          marceltrapmanM
          marceltrapmanM
          marceltrapman
          @Anticimex it is the sensor reporting it (not the gateway) and the NRF24 is fed by a battery/converter combo and not the Pro Mini. I also use a cap.
          @Hek Do you mean the type of sensor? Or do you want to see what is received on the controller end?
          • marceltrapmanM
            marceltrapmanM
            marceltrapman
            @hek here is the output on the controller side. This is going on for like 2-3 minutes now :(
            MySensors Debug                 receive raw 0;0;3;0;9;read: 255-1-0 s=255,c=3,t=3,pt=0,l=0:
            MySensors Debug                 receive raw 255;255;3;0;3;
            MySensors Debug                 get device N255C255
            MySensors Debug                 command 255;255;3;0;4;4
            MySensors                       sent '255:255' ID response  4
            MySensors                       received '255:255' ID request
            MySensors Debug                 receive raw 0;0;3;0;9;send: 0-0-1-255 s=255,c=3,t=4,pt=0,l=1,st=ok:4
            MySensors Debug                 receive raw 0;0;3;0;9;read: 0-1-255 s=255,c=3,t=4,pt=0,l=1:4
            MySensors Debug                 receive raw 0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0:
            MySensors Debug                 receive raw 0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,st=fail:0
              wrote on last edited by hek
              Strange.. Looks like id sending succeeds from gateway.
                marceltrapmanM
                marceltrapmanM
                marceltrapman
                @hek I agree but the sensor does not do anything with the result.
                I will clear the memory tomorrow and see what happens.
                • marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  @hek Even stranger, the sensor did register itself with a repeater (parent id = 1) but that was it.
                  What procedure do you suggest to find out what is really going on?
                    What happens if you move the sensor close to the gateway while fetching id. When it has been received move sensor back to the final location.
                    I vaguely remember a discussion I had with @Yveaux where we concluded that the temporary id 255 would cause problems during initial id handover if a relay node was involved during this process.
                    The solution would be to choose some other id (254) during this handshake.
                    Just making a mental note from out discussion here:
                    "So a node takes on temp ID 254, broadcasts a parent-node request and selects the best incoming parent by distance (all sent to 254). Then it requests (still with ID 254) its node ID, which is forwarded to the gateway and each relay stores the route to 254 in its routing table. The gateway assigns one, and routes it back to 254, which then takes on its new node ID. Sounds good!"
                      marceltrapmanM
                      marceltrapmanM
                      marceltrapman
                      @hek Apologies for the late reply.
                      I have walked around with the sensor but without any luck.
                      The id is requested and the id is sent but that is it.
                      No further debug info either.
                      Attached is a screenshot of the arduino output (left) and the controller/gateway output (right).
                        Hmm.. where did the id-payload (4) go?
                        Type should also be 4 (I_ID_RESPONSE) but it seems to be 3...
                          marceltrapmanM
                          marceltrapmanM
                          marceltrapman
                          wrote on last edited by marceltrapman
                          Honestly I don't know what is happening here.
                          The controller seems to do its work well.
                          The gateway, as far as I can see, also.
                          The sensor is a black hole to me right now.
                          Below is the eeprom dump:
                          NODE_ID          :255
                          PARENT_NODE_ID   :2
                          DISTANCE         :2
                          ROUTES           :255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255
                          CONTROLLER_CONFIG:255255255255255255255255255255255255255255255255255255255255255255255255
                          FIRMWARE_TYPE    :255255
                          FIRMWARE_VERSION :255255
                          FIRMWARE_BLOCKS  :255255
                          FIRMWARE_CRC     :255255
                          LOCAL_CONFIG     :255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255255
                          Repeater id is indeed 2.
                          Don't know what the distance value represents.
                            what happens if you hard-code parent to 0 in begin() while fetching id?
                              marceltrapmanM
                              marceltrapmanM
                              marceltrapman
                              Even stranger. This is what I do:
                              //board.begin(msgCallback, nodeId, repeaterMode, parentNodeId, paLevel, channel, dataRate);
                              board.begin(NULL, NULL, false, 0);
                              This is now the result:
                              NODE_ID          :0
                              PARENT_NODE_ID   :2
                              DISTANCE         :2
                              Do you want me to write the node id and parent id direct into the eeprom?
                                setting the parent in constructor won't update the eeprom. It just uses the specified parent and never searches for a new one.
                                And you'll have to specify AUTO for id
                                  marceltrapmanM
                                  marceltrapmanM
                                  marceltrapman
                                  @hek So, how do I 'suddenly' have id = 0 then?
                                  I will clear the eeprom again and see what happens...
                                    marceltrapmanM
                                    marceltrapmanM
                                    marceltrapman
                                    @marceltrapman Stupid fail with that AUTO setting :blush:
                                    But the good news is that my sensor now has ID 4...
                                    So the bad news, I guess, is that the repeater seems to fail...
                                      As I mentioned earlier fetching id THROUGH a repeater need some additional love.
                                        marceltrapmanM
                                        marceltrapmanM
                                        marceltrapman
                                        Hmm, so I fail that love :(
                                        How can we get this thing going?
                                        The thing is don't want to walk down to my gateway each time I want to test something out.
                                        And, I also prefer not to use a fixed id because that would make testing the controller plugin a b****.
                                        • greglG
                                          greglG
                                          gregl
                                          Hey @marceltrapman - I just upgraded one of my sketches from 1.3 to 1.4 ( im finally moving to 1.4 in "production!!)
                                          Anyway, i had the same issue with version mismatch error and spewing out
                                          version mismatch
                                          read: 255-255-255 s=255,c=7,t=255,pt=7,l=31:NAN
                                          version mismatch
                                          version mismatch
                                          version mismatch
                                          wondering wtf was going on, i disconnected the relays board connected to VCC... the messages stopped and everything worked correctly- other than the relays actuating...
                                          figured it could be a power issue, i connected proper power source as the issue occured with just a USB 5v from my PC....and reconnecting relay all worked properly..including now the relay.
                                          So, check your powersupply!
                                          HTH..
