  3. S_INFO NODE with OLED Display - Solved -
4 Posts 2 Posters 2.6k Views 1 Watching
  • scribere8146S
    scribere8146S
    scribere8146
    wrote on last edited by scribere8146
    Hi, this is my code for writing Text to the oled display.
    Controller is ioBroker and so far everything is working, but... I like to place multiple lines to the display using V_VAR1 - V_VAR5. How to use them?
    And do i need a ACK Command?
    Thanks for you help, sorry this is my first "self made" node.
     * Version 1.1 - Thorsten Böttcher
     * Example sketch showing how to send messages to 0,96" OLED Display
     *       OLED                 ARDUINO
     *  -----1234-----
     *  |            |  1 ->    3,3 V
     *  |            |  2 ->    GND
     *  |            |  3 -> A5 SCL
     *  |            |  4 -> A4 SDA
     *  OLED ASCII Library from https://github.com/greiman/SSD1306Ascii
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define CHILD_ID 0
    //oled display
    #include "SSD1306Ascii.h"
    #include "SSD1306AsciiAvrI2c.h"
    #define I2C_ADDRESS 0x3C
    SSD1306AsciiAvrI2c oled;
    // SketchInfo
    static const char SketchName[]    ="Info Display";
    static const char SketchVersion[] ="1.1";
    int PosX     = 0;
    int PosY     = 0;
    int ClrScr   = 0;
    int FontSize = 1;
    // loop
    MyMessage msgText (CHILD_ID, V_TEXT); // Text
    MyMessage msgVar1 (CHILD_ID, V_VAR1); // Cursor PosX
    MyMessage msgVar2 (CHILD_ID, V_VAR2); // Cursor PosY
    MyMessage msgVar3 (CHILD_ID, V_VAR3); // Clear Screen
    MyMessage msgVar4 (CHILD_ID, V_VAR4); // FontSize
    MyMessage msgVar5 (CHILD_ID, V_VAR5); // Not Used
      Serial.println("starting...");
      ShowInfo();
    void presentation()  {
      sendSketchInfo(SketchName, SketchVersion);
      present(CHILD_ID, S_INFO);
    void receive(const MyMessage &mymessage)
     if (mymessage.type==V_TEXT) {
       DisplayMessage(mymessage.getString());
     if (mymessage.type==V_VAR1) {
       PosX = atoi(mymessage.getString());
     if (mymessage.type==V_VAR2) {
        PosY = atoi(mymessage.getString());
     if (mymessage.type==V_VAR3) {
        ClrScr=atoi(mymessage.getString());
        if ( ClrScr > 0 )
          oled.clear();
     if (mymessage.type==V_VAR4) {
        oled.set1X();
        FontSize=atoi(mymessage.getString());
        if ( FontSize > 1 )
          oled.set2X();
      // Wait, but receive messages
      wait(UPDATE_INTERVAL);
    void ShowInfo()
      oled.begin(&Adafruit128x64, I2C_ADDRESS);
      oled.setFont(Arial14);
      oled.set1X();
      oled.setCursor(20,1);
      oled.write("* MySensors 2.0 *");
      oled.setCursor(30,3);
      oled.write(SketchName);
      oled.write(" ");
      oled.write(SketchVersion);
      oled.setCursor(30,5);
      oled.write("NodeID");
      oled.write(" ");
      oled.print(getNodeId());
      sleep(3000);
      oled.clear();
    void DisplayMessage(const char Message[])
      oled.setCursor(PosX,PosY);
      oled.clearToEOL ();
      oled.write(Message);
    • sundberg84S
      @awi got some examples in Domoticz: https://forum.mysensors.org/topic/1957/lcd-clock-and-text-sensor-node-with-new-v_text I dont know how this works in ioBroker with v_var though.
      • scribere8146S
        scribere8146S
        scribere8146
        Hi sundberg84, using 5 Nodes was my first idea. But i want to use V_VAR1...
        But you solved me problem indirecty. I installed MYSController and...the code (updated above) is correct.
        Looks like ioBroker is my problem.
        Thanks for your help Thorsten
        • scribere8146S
          scribere8146S
          scribere8146
          Made small update .....X,Y Pos Fontsize...
