  3. How can you change the node description OTA
1 Posts 1 Posters 708 Views 1 Watching
  • dougD
    dougD
    doug
    I am setting up nodes but having trouble identifying them as they all end up with the same description its because I'm a bit lazy and don't like having to change my sketch for each new node I make.
    When I load a sketch if I want a different description I have to put it into the sketch and would really like to be able to set it afterwards using some sort of C_SET message.
    Currently I set this in code as below
    present(RTCSENSOR, S_INFO, RTCSENSOR_DESCRIPTION, false);
    Does anybody have any idea where I would start. I guess i would use
    However once my node has received the data how do I use it to update the node description?
    Any suggestions or pointers on where to start would be appreciated.
