  3. Vera
  4. Removing Gateway and Nodes from Vera
6 Posts 3 Posters 4.2k Views 1 Watching
  • C
    C
    chupacabra
    So, i ran some tests and got things working, everything is great. Now i want to break it all apart and start from scratch for some other tests. I've searched high and low on the proper way to remove the nodes and the gateway from Vera, but i have not found anything. can someone give me some pointers. My assumption is to delete them from vera and clearing the eeprom on all components and adding them in again. Any clues?
      If you remove gateway device all children should be deleted as well.
      Clearing EEPROM is good if you want to remove the nodes ids.
      • V
        V
        virgus1970
        Continuing the theme. In order to use the same node this other sensors (to make some tests, especially with mergering several sensors on one board) I had to delete sensors from Vera, without deleting the node. Is it?
        hekH 1 Reply Last reply
        • V virgus1970
          @virgus1970
          Yep, no need to remove the "Node"-device.
          • V
            V
            virgus1970
            Thanks. But as for me sometimes for some reason it doesn't work (however sometimes everything OK). Then I clear EEPROM of Arduino board (sensor) I have the same problem
              If you clear eeprom you have to remove node device also (which is tied to the id you're removing).
