  3. Powering mote 24/7 using only a supercap and solar
239 Posts 10 Posters 130.5k Views 14 Watching
  • N Offline
    N Offline
    I notice now that leaving the BQ25504 connected to the supercap at night when there's no light to harvest does result is a cumulative drain of about 50 millivolts to the 15F supercap (charged to 3.340 volts) versus disconnecting it during the same period.
    • N Offline
      N Offline
      I finished the LTC3501 energy harvester (https://www.openhardware.io/view/281/Solar-Energy-Harvester), but, disappointingly, its MPPC seems to be no match for the MPPT of the BQ25504 for the el cheapo solar cell.
      I think the next step will be to modify the BQ25504 breakout board to include the supercap. Going forward that should keep everything neat and tidy and avoid loose wiring.
      • N Offline
        N Offline
        I've designed the load switch and the supercap onto the PCB, and I just now sent it off to the fab. The entire board is less than 0.9 square inches in size.
          I'm looking forward to this kind of solution. Keep up the good work :-)
          • N Offline
            N Offline
            #145
            Another notion I'm toying with is a variation of the proverb "make hay while the sun is shining." In other words, squirrel away as much solar energy as possible when conditions are optimal, and not worry too much about extracting light under truly dim conditions. I think there's a happy medium to be found, and I hope that by playing around with it a bit I'll develop a better sense as to where that sweet spot is.
            • N Offline
              N Offline
              Here's the version that I most recently assembled:
              As you can see, the 15F supercap is now on the board itself. It works fine.
              I've since made a few refinements and have sent the new files off to be fabbed. The newest version of the PCB will measure roughly 22mm x 22mm.
                I'm very curious to know what kind of sensor you would be able to run with this project. Of course a lot will depends on the size of solar panel and how much light it will get.
                N 1 Reply Last reply
                  N Offline
                  N Offline
                  #148
                  @gohan
                  Early tests indicate the 15F charges to 3.6v pretty fast on even ambient light. I realize that's a somewhat vague statement, but I hope to eventually quantify it better (charge time as a function of lux level, panel size, and nominal panel voltage). Nonetheless, based on early preliminary measurements, I'm pretty confident the answer is going to be fairly simple, namely: what can you do with 15F of charge?
                  Before I began this project, I was quite worried that self discharge would strongly govern the answer, but this particular supercap (as contrasted to others I tested) seems to have a relatively low rate of self discharge. Early tests show the same also holds true for its bigger brother, the 90F supercap, in case the 15F isn't enough. The 15F supercap is rated for 100,000 charge/discharge cycles, so it won't be wearing out anytime soon if it's operated indoors under normal ambient temperature conditions. There are probably even more interesting supercaps out there, but for me this one's an existence proof and a fixed point I can gather data around.
                  If anyone knows of even better supercaps to try, I'm all ears.
                    So what can you realistically do with 15F of charge? I mean what kind of battery can you compare it to? Can you use the entire energy stored in the cap and and it keeps the voltage constant until it empty?
                    • N Offline
                      N Offline
                      Think of it like a battery whose voltage starts at 3.6v and then over time gradually drops to 1.8v. As presently configured, you would stop when the voltage gets to 1.8v, because both the atmega328p and the RFM69HW require a minimum 1.8v to operate.
                      • mfalkviddM Offline
                        #151
                        Is my math right if I calculate like this?
                        15 * 1.8 / 3600 * 1000 = 7.5 mAh
                        • N Offline
                          N Offline
                          #152
                          Not sure the answer to that. However, one thing's worth noting: these supercaps behave more like button cells than capacitors. By that I mean: they can have voltage droops and can even have voltage "recovery" after using them a bit. I really didn't expect that going into this, but it's a very significant effect.
                            What do you mean that they behave more like cells?
                              N Offline
                              N Offline
                              #154
                              @gohan said in Powering mote 24/7 using only a supercap and solar:
                              An "ideal" capacitor doesn't behave like that.
                                Sorry but I don't understand, I'm not that much into this electronic deep knowledge. By voltage drops are you referring to the small energy drain that the capacitor has?
                                  N Offline
                                  N Offline
                                  @gohan
                                  We're getting off topic. I suggest you read some of the links already provided above.
                                  • N Offline
                                    N Offline
                                    #157
                                    Good news! Last night I did some accelerated load testing on the supercap. First I charged it to 3.6v and then I hooked up an RFM69HW mote which woke up once a second to do 3 things: 1. check the voltage level, 2. turn on an LED for 1ms to simulate a sensor load, and 3. transmit a packet containing the voltage data using the RFM69HW.. Bottom line: 14,111 packets transmitted before running out of juice.
                                    Not bad for a first attempt. :)
                                    A 1 Reply Last reply
                                    • N NeverDie
                                      A Offline
                                      A Offline
                                      agdemars
                                      @NeverDie Any updates on your progress? Have you received the new boards? Will you be publishing the gerber files?
                                      • A agdemars
                                        N Offline
                                        N Offline
                                        @agdemars said in Powering mote 24/7 using only a supercap and solar:
                                        No, and for a host of reasons. The main reason is this: for most applications, it's overkill. Because this thread had become such a monolog, I continued to evolve the design offline, and along the way I've found that you can get perfectly good results with just an inexpensive mini solar panel, a capacitor, and a simple blocking diode. For the audience on this forum, that's all you really need.
                                          You are kind of pioneering in the use of supercap and sensor nodes. I'd like to be part of the discussion, but unfortunately I'm not that good at electronics so I can't contribute much. Probably you are right at using a standard cap you can get comparable results, but I believe you get smaller size with our project
