  3. Powering mote 24/7 using only a supercap and solar
239 Posts 10 Posters 130.5k Views 14 Watching
  • N NeverDie
    @agdemars said in Powering mote 24/7 using only a supercap and solar:
    @NeverDie Any updates on your progress? Have you received the new boards? Will you be publishing the gerber files?
    No, and for a host of reasons. The main reason is this: for most applications, it's overkill. Because this thread had become such a monolog, I continued to evolve the design offline, and along the way I've found that you can get perfectly good results with just an inexpensive mini solar panel, a capacitor, and a simple blocking diode. For the audience on this forum, that's all you really need.
    A Offline
    A Offline
    agdemars
    @NeverDie Indeed, keeping it simple is usually the best approach. I am nonetheless interested in learning about the circuit you developed if you're willing to share your observations.
    • mfalkviddM Offline
      Would it be feasible to implement mppt in software? From what I understand, the atmega328 pwm works in power-save mode (but not in power-down). Power-save mode consumes 1uA. Could the charging speed be controlled by pwm and adjusted periodically by the mcu, to keep the load on the solar cell at maximum power?
      N 1 Reply Last reply
        If I understood right NeverDie said that the supercap can be charged directly from the solar panel with just a blocking diode, then add a boost-buck dc-dc converter to have constant 3.3v
          N Offline
          N Offline
          #164
          @mfalkvidd said in Powering mote 24/7 using only a supercap and solar:
          Like you, I've also wondered what kind of MPPT might be built by leveraging an mcu and just simple components. There is a guy on youtube ( https://youtu.be/JXSRXUiUA6M ) who built his own arduino MPPT charge controller from scratch, though for a much bigger solar panel. For me, the real quesation is: why aren't there more chips that offer a proper MPPT? It seems like a rather bizarre gap in the market.
            Is that mppt really needed even if you are charging a capacitor?
              N Offline
              N Offline
              #166
              @gohan
              Let's put it this way: there's probably nothing I could achieve with MPPT that I couldn't achieve with a sufficiently bigger solar panel. So, if space isn't a concern, the economics tend to favor buying bigger mini solar panels, because mini solar panels are fairly cheap from China (cheaper than buying the BQ25504 chip). On the other hand, for large 100watt or above solar panels, it's more economic to add MPPT, because an MPPT charge controller is cheap compared to, say, doubling an already expensive solar panel.
              That said, there may be other features of the chip that you may want anyway, like charge termination or a "battery_OK" pin to power-on your atmega328p when the voltage gets to an acceptible level. So, you could create those by other means, or you could buy a package with those features and which also happens to have MPPT at some incremental cost.
              So, it's six of one, half a dozen of the other.
              • N Offline
                N Offline
                What I finally arrived at was this:
                https://www.openhardware.io/view/396/Simple-Solar-Supercap-Charger
                which is both less expensive and easier to assemble.
                  here is another circuit I found http://www.discovercircuits.com/DJ-Circuits/supcapvoltlim.htm
                  • N NeverDie
                    Anyone already doing it?
                    Seems like all that's needed is a supercap with low enough leakage current such that harvested solar energy exceeds leakage current per 24 hour cycle.
                    Yesterday I ordered a few boost converters to play around with: an AAT1217, an LTC3105, an MP3418, and an L6920DTR. Out of those four different boost converters, hopefully at least one will prove adequate. Maybe all of them will. Either way, I'm sure to learn something about what's ultimately needed.
                    I checked the unloaded voltage on an el cheapo solar cell (scavanged from a $1 garden light), and it came out around 1v under indoor ambient light conditions, near a window on a darkly overcast, rainy day with no indoor lights on. That's higher than what I was expecting. Of course, how much of that is ephemeral and how much of it is solid under load remains to be seen, and I guess that's part of what I'll be learning.
                    For illustration purposes, I put a little TH mote inside it.
                    E Offline
                    E Offline
                    Ed1500
                    @NeverDie actually I have done that, feeding an attiny85 and also an Atmega328 ("barebones" arduino) 2x1.5F capacitors. all on a 6 volt solar cel and a low drop regulator
                    The gardenlamp is quite handy as well, but better put some sealant on the edges of tha small solarcell as they do tend to leak. You will find everything has rusted inside after using it a season. Nevertheless, have been able to run an attiny on it
                    N 3 Replies Last reply
                    • E Ed1500
                      N Offline
                      N Offline
                      #170
                      Yeah, corrosion is a huge problem with the chinese ones because it seems many of their components are incredibly prone to rusting (even including their wire!). Go figure on that one. Potting epoxy will cost you much more than the garden light. I think polyurethane spray foam may be the cheapest way to weatherproof them, and it's readily available.
                      E 1 Reply Last reply
                      • E Ed1500
                        N Offline
                        N Offline
                        #171
                        @Ed1500 said in Powering mote 24/7 using only a supercap and solar:
                        Yes, for outdoors it's bright enough you don't really need a boost converter. So, your solution may be the least expensive DIY for outdoors. Interestingly, the chinese garden lights do use a boost converter. They use a special purpose IC specifically made for garden lights.
                        • N NeverDie
                          E Offline
                          E Offline
                          Ed1500
                          @NeverDie indeed, I just put a line of silicone sealant around the edge of the PV. That stopped a lot already
                          • N NeverDie
                            E Offline
                            E Offline
                            Ed1500
                            wrote on last edited by Ed1500
                            #173
                            @NeverDie It was indeed more of a concept test 'can I do this with one of those lamps'. I first tried to just use the power to the LED with the nicad in place but the NiCad just won't last long coz of the continous recharge, so I took it out and put supercaps in there. Store enough charge to get through the night. Supercaps also do better in the cold than Nicads , though I admit I brought them inside when it started freezing.
                            But those lamps are just great little boxes for a contained attiny 13/25/45/85 project
                            • E Ed1500
                              N Offline
                              N Offline
                              #174
                              Exactly so. They're cheaper than most project boxes, and then you get the solar cell "for free".
                              • E Ed1500
                                N Offline
                                N Offline
                                Exactly which supercaps are you using, and where are you sourcing them from? It would be good to compare notes.
                                • N NeverDie
                                  E Offline
                                  E Offline
                                  Ed1500
                                  #176
                                  @NeverDie I have 5.5V 1.5F Supercaps from Aliexpress. Forgot which supplier but they do well.
                                  I put them in an RC circuit to measure and though that might not be totally reliable, they were above 1 Farad
                                  Ah, found them. Although. It was a year ago, the ones I have say 1.5 F but seems they now sell 1Farad
                                  These: https://www.aliexpress.com/item/2Pcs-Ultracapacitor-1-5F-5-5V-super-capacitor-1-5Farad-farad-capacitor-5-5V1-0F/32632431698.html
                                  • E Ed1500
                                    E Offline
                                    E Offline
                                    Ed1500
                                    @Ed1500 Yep, rechecked mine. 1.5 Farad, but the 'my orders' link now points to 1 Farad caps
                                    • E Ed1500
                                      N Offline
                                      N Offline
                                      #178
                                      @Ed1500
                                      Thanks for looking that up. I keep coming back to this one:
                                      https://www.digikey.com/product-detail/en/illinois-capacitor/106DCN2R7M/1572-1287-ND/5410638
                                      if only because it seems like a good value for money, and it seems able to run any mote for quite a long time.
                                      • N NeverDie
                                        @Ed1500
                                        E Offline
                                        E Offline
                                        Ed1500
                                        @NeverDie 10F for 1.95 is definitely not bad... but not sure what the shipping would be
                                        • E Ed1500
                                          N Offline
                                          N Offline
                                          @Ed1500
                                          Good point. I use first class mail from digikey, which arrives in 2 days and which costs around $3.65 I think. If you order before 8pm, it ships the same day. So for me, since I usually order late in the day, it's almost like it arrives in a day and a half. :) I don't think I would order just a single supercap from Digikey, unless I was getting a bunch of them, but as I'm ordering a lot of parts from Digikey anyway, the incremental shipping cost is typically free.
